  3. Sonoff Wifi Switch, GPIO14 and interrupts
2 Posts 2 Posters 2.9k Views 2 Watching
    mgaman
    The Sonoff has a 'spare' GPIO number 14.
    I hooked this up to a Hall Effect Water Meter and tried to count the pulses.
    The Arduino sketch I wrote works fine on the NODEMCU but doesn't record interrupts on the Sonoff.
    For the NODEMCU the board was set as NodeMCU 0.9, for the Sonoff I set it as Generic ESP8266
    I'm open to ideas as to why I'm not getting interrupts.
    Awaiting your valuable insight
    • pansenP
      pansenP
      pansen
      wrote on last edited by pansen
      can you post some code? interrupts work fine with my sonoff:
      attachInterrupt(PIN_PIR_SENSOR, ISR_PIRPinHasChanged, CHANGE);
      void ISR_PIRPinHasChanged(){
        int currentPinStatus = digitalRead(PIN_PIR_SENSOR);
        if(currentPinStatus == LOW){
          Serial.println("ISR fired, pin LOW");
        else{
          Serial.println("ISR fired, pin HIGH");
          ToggleRelay();
      ISR fired, pin LOW
      ISR fired, pin HIGH
      toggling relay to OFF
      switching off
      sending status to controller
      ISR fired, pin LOW
      ISR fired, pin HIGH
      toggling relay to ON
      switching on
      ISR fired, pin LOW
      ISR fired, pin HIGH
      switching off
      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
