<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[best approach to add MySensors Node to an existing smoke detector?]]></title><description><![CDATA[<p dir="auto">I have several smoke detectors around in my house, all driven by a 9 Volt block but without a radio. I think about the best approach to add a MySensors node to it. I do not have the schematics of the smoke detector.</p>
<p dir="auto">I want to use the 9 Volt block, so the node needs a voltage regulator.<br />
The node should draw as less current as possible, so connecting the buzzer from the smoke detector via an optocoupler to the MySensors node will need far too much current. What about a zener? What about a voltage divider (resistors) to reduce buzzer voltage to Arduino pin level?<br />
Any other idea? Thanks in advance</p>
]]></description><link>https://forum.mysensors.org/topic/6752/best-approach-to-add-mysensors-node-to-an-existing-smoke-detector</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 15:36:03 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6752.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 May 2017 09:56:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to best approach to add MySensors Node to an existing smoke detector? on Sat, 02 Dec 2017 16:05:46 GMT]]></title><description><![CDATA[<p dir="auto">Hi, <a class="plugin-mentions-user plugin-mentions-a" href="/user/rvendrame" aria-label="Profile: rvendrame">@<bdi>rvendrame</bdi></a> after a while the board stopped reporting to the gateway, not sure why, while the smoke detector is  up and running. It is still in my todo list to do some troubleshooting, if I'll discover more and I'll let for sure know.<br />
Thanks</p>
]]></description><link>https://forum.mysensors.org/post/81010</link><guid isPermaLink="true">https://forum.mysensors.org/post/81010</guid><dc:creator><![CDATA[user2684]]></dc:creator><pubDate>Sat, 02 Dec 2017 16:05:46 GMT</pubDate></item><item><title><![CDATA[Reply to best approach to add MySensors Node to an existing smoke detector? on Sat, 02 Dec 2017 12:48:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/user2684" aria-label="Profile: user2684">@<bdi>user2684</bdi></a> ,  I have same smoke sensor as you (as per picture you posted).  How did you end with this?  I'm experience many false smoke alarms, no matter what resistors/diodes I use.</p>
<p dir="auto">Sorry for reopen such old thread!</p>
]]></description><link>https://forum.mysensors.org/post/80998</link><guid isPermaLink="true">https://forum.mysensors.org/post/80998</guid><dc:creator><![CDATA[rvendrame]]></dc:creator><pubDate>Sat, 02 Dec 2017 12:48:08 GMT</pubDate></item><item><title><![CDATA[Reply to best approach to add MySensors Node to an existing smoke detector? on Sat, 13 May 2017 08:45:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dirkc" aria-label="Profile: dirkc">@<bdi>dirkc</bdi></a> probably yours is different but you can try having a look at the MCU, from what I read around different vendors are likely to use just a few of those dedicated MCUs. My I/O port was also very easy to see. Alternatively you may have a look at this in case you missed it: <a href="http://harizanov.com/2014/07/diy-internet-of-things-fire-alarm/" rel="nofollow ugc">http://harizanov.com/2014/07/diy-internet-of-things-fire-alarm/</a></p>
]]></description><link>https://forum.mysensors.org/post/66608</link><guid isPermaLink="true">https://forum.mysensors.org/post/66608</guid><dc:creator><![CDATA[user2684]]></dc:creator><pubDate>Sat, 13 May 2017 08:45:24 GMT</pubDate></item><item><title><![CDATA[Reply to best approach to add MySensors Node to an existing smoke detector? on Fri, 12 May 2017 19:33:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/user2684" aria-label="Profile: user2684">@<bdi>user2684</bdi></a> good approach, I'll have to check my smoke detector, which is a German brand<br />
<a href="https://www.amazon.de/Merten-547019-ARGUS-Rauchmelder-polarwei%C3%9F/dp/B000ONMOGQ" rel="nofollow ugc">https://www.amazon.de/Merten-547019-ARGUS-Rauchmelder-polarweiß/dp/B000ONMOGQ</a><br />
Don't know if the schematic is available.</p>
]]></description><link>https://forum.mysensors.org/post/66585</link><guid isPermaLink="true">https://forum.mysensors.org/post/66585</guid><dc:creator><![CDATA[dirkc]]></dc:creator><pubDate>Fri, 12 May 2017 19:33:31 GMT</pubDate></item><item><title><![CDATA[Reply to best approach to add MySensors Node to an existing smoke detector? on Fri, 12 May 2017 16:53:36 GMT]]></title><description><![CDATA[<p dir="auto">Quick update on this one: I've used a pro mini with the voltage regulator still on board just to test, connected raw and ground to the smoke detector power supply, connected the I/O pin with a 100k/47k voltage divider to the arduino's pin 3, used the same code of a motion sensor and put the board to sleep. When I push the test button the board wakes up from the interrupt and reports back so it works to me. I now need a better LDO than the AMS1117 for the 9v-&gt;3.3v conversion. Picture below in case can be useful to somebody else.</p>
<p dir="auto"><img src="/assets/uploads/files/1494608013004-untitled.png" alt="0_1494607989801_Untitled.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/post/66578</link><guid isPermaLink="true">https://forum.mysensors.org/post/66578</guid><dc:creator><![CDATA[user2684]]></dc:creator><pubDate>Fri, 12 May 2017 16:53:36 GMT</pubDate></item><item><title><![CDATA[Reply to best approach to add MySensors Node to an existing smoke detector? on Fri, 12 May 2017 15:26:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dirkc" aria-label="Profile: dirkc">@<bdi>dirkc</bdi></a> I'm trying to do something similar here . I started from a chinese smoke detector with an unknown xc5010dw chip which revealed to be similar to the following <a href="http://www.nxp.com/assets/documents/data/en/data-sheets/MC145010.pdf" rel="nofollow ugc">http://www.nxp.com/assets/documents/data/en/data-sheets/MC145010.pdf</a>. Not sure if you have something similar but my chip has a I/O port on pin 7 which goes high when the alarm triggers which should be way easier then attaching to the buzzer. For powering on the arduino from the 9v power supply, we probably need a MCP1703 or something similar I guess (the MCP1700 that I have available do not go over 6v as input)</p>
]]></description><link>https://forum.mysensors.org/post/66574</link><guid isPermaLink="true">https://forum.mysensors.org/post/66574</guid><dc:creator><![CDATA[user2684]]></dc:creator><pubDate>Fri, 12 May 2017 15:26:51 GMT</pubDate></item><item><title><![CDATA[Reply to best approach to add MySensors Node to an existing smoke detector? on Mon, 01 May 2017 15:12:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dirkc" aria-label="Profile: dirkc">@<bdi>dirkc</bdi></a> The buzzer is most likely only powered when an alarm sounds ;-) Leakage in the optocoupler "transistor" is mostly in the nano ampere (nA) region when off.  So I would suggest you measure the voltage over the buzzer when sounding (protect your ears!). Add a series resistor (estimate 300 ohm to 1k) with the optocoupler LED.<br />
On the MySensor node side 700k to 1M as collector pull-up to the optocoupler and attach to INT0 or 1 and treat like a Motion node. Power the node with a capable LDO (mcp1700 or similar, watch the input voltage (9v)).</p>
]]></description><link>https://forum.mysensors.org/post/65693</link><guid isPermaLink="true">https://forum.mysensors.org/post/65693</guid><dc:creator><![CDATA[AWI]]></dc:creator><pubDate>Mon, 01 May 2017 15:12:58 GMT</pubDate></item></channel></rss>
