<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NRF24L01 radio not  connecting]]></title><description><![CDATA[<p dir="auto">Hello, please help me since I'm stuck!<br />
My sensor node has problem with the radio communication. I am using an NRF24L01.<br />
Actually I do not think that the radio, nor the Arduino is faulty. I have tested both on an Easy/Newbie PCB and they are working good.<br />
I have designed my own PCB (<a href="https://www.openhardware.io/view/374/MyQTherm-replace-IQTherm-heating-thermostat" rel="nofollow ugc">https://www.openhardware.io/view/374/MyQTherm-replace-IQTherm-heating-thermostat</a>). The radio does not communicate with my gateway when I use this PCB.<br />
The strange thing is that if I touch the radio chip with a finger the signals get through! Or even if I let the chip lie on a plastic surface it works. I also tested to fix a short cable with tape onto the chip and it works. When I remove my finger, cable or move the chip from a surface, the communication is interupted.<br />
As I said above, I have tested the radio chip and the Arduino (Pro Mini 5V clone) in another setup so I know they are good.<br />
In my investigations I tried with a fresh PCB (MyQTherm) an soldered just the NRF24L01, Arduino, LE33 voltage regulator and 4.7 uF capacitor for the radio. Leaving out all other stuff. Then I connected the Arduino to a serial chip connected to USB. So the node was then powered from USB. In this test the radio was also behaving faulty as described above.<br />
I have tested 3 of my own designed PCBs with the same result.<br />
Any ideas?</p>
]]></description><link>https://forum.mysensors.org/topic/9120/nrf24l01-radio-not-connecting</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 12:32:04 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9120.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Mar 2018 07:16:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Tue, 13 Mar 2018 05:10:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bgunnarb" aria-label="Profile: bgunnarb">@<bdi>bgunnarb</bdi></a> Thanks, I did update the gateway also.</p>
]]></description><link>https://forum.mysensors.org/post/86986</link><guid isPermaLink="true">https://forum.mysensors.org/post/86986</guid><dc:creator><![CDATA[kontrollable]]></dc:creator><pubDate>Tue, 13 Mar 2018 05:10:24 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 22:37:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kontrollable" aria-label="Profile: kontrollable">@<bdi>kontrollable</bdi></a> I think you should update the GW as well. I had a lot of problems with downlink messages from GW to an RGB controller. Updating the GW solved all of this immediately.</p>
]]></description><link>https://forum.mysensors.org/post/86978</link><guid isPermaLink="true">https://forum.mysensors.org/post/86978</guid><dc:creator><![CDATA[bgunnarb]]></dc:creator><pubDate>Mon, 12 Mar 2018 22:37:47 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 18:43:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> said in <a href="/post/86972">NRF24L01 radio not connecting</a>:</p>
<blockquote>
<p dir="auto">Always stay up-to-date as many bugs get corrected</p>
</blockquote>
<p dir="auto">Oh my god! Updated the sensor (not the gateway yet) and now it seems to work! Am I surprised? Yes!<br />
Thanks so much!</p>
]]></description><link>https://forum.mysensors.org/post/86974</link><guid isPermaLink="true">https://forum.mysensors.org/post/86974</guid><dc:creator><![CDATA[kontrollable]]></dc:creator><pubDate>Mon, 12 Mar 2018 18:43:53 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 18:32:37 GMT]]></title><description><![CDATA[<p dir="auto">Always stay up-to-date as many bugs get corrected</p>
]]></description><link>https://forum.mysensors.org/post/86972</link><guid isPermaLink="true">https://forum.mysensors.org/post/86972</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Mon, 12 Mar 2018 18:32:37 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 18:31:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> said in <a href="/post/86970">NRF24L01 radio not connecting</a>:</p>
<blockquote>
<p dir="auto">Is there a reason why are you still using version 2.1.1?</p>
</blockquote>
<p dir="auto">The only reason is that I have not bothered to update. But do you really think that updating would help? Could it really be a software problem?</p>
]]></description><link>https://forum.mysensors.org/post/86971</link><guid isPermaLink="true">https://forum.mysensors.org/post/86971</guid><dc:creator><![CDATA[kontrollable]]></dc:creator><pubDate>Mon, 12 Mar 2018 18:31:56 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 18:27:39 GMT]]></title><description><![CDATA[<p dir="auto">Is there a reason why are you still using version 2.1.1?</p>
]]></description><link>https://forum.mysensors.org/post/86970</link><guid isPermaLink="true">https://forum.mysensors.org/post/86970</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Mon, 12 Mar 2018 18:27:39 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 18:06:30 GMT]]></title><description><![CDATA[<p dir="auto">I used a multimeter to measure 3.3 V on the output from my voltage regulator. 3.3 V on the radio chip and capacitor. So it seems to power the radio alright.</p>
]]></description><link>https://forum.mysensors.org/post/86969</link><guid isPermaLink="true">https://forum.mysensors.org/post/86969</guid><dc:creator><![CDATA[kontrollable]]></dc:creator><pubDate>Mon, 12 Mar 2018 18:06:30 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 18:04:14 GMT]]></title><description><![CDATA[<p dir="auto">OK, so enabled MY_DEBUG on my serial gateway. MY_DEBUG was already enabled in my sensor node.<br />
I found that the gateway did not receive any signals from the node at all.<br />
The node reports that it does not find any parent.<br />
So my conclusion is that the radio on the node sends a weak signal.</p>
<p dir="auto">Here is the log from the gateway:<br />
0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1<br />
0;255;3;0;9;TSM:INIT<br />
0;255;3;0;9;TSF:WUR:MS=0<br />
0;255;3;0;9;TSM:INIT:TSP OK<br />
0;255;3;0;9;TSM:INIT:GW MODE<br />
0;255;3;0;9;TSM:READY:ID=0,PAR=0,DIS=0<br />
0;255;3;0;9;MCO:REG:NOT NEEDED<br />
0;255;3;0;14;Gateway startup complete.<br />
0;255;0;0;18;2.1.1<br />
0;255;3;0;9;MCO:BGN:STP<br />
0;255;3;0;9;MCO:BGN:INIT OK,TSP=1</p>
<p dir="auto">Here is the log from the node:<br />
0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1<br />
3 MCO:BGN:BFR<br />
19 TSM:INIT<br />
20 TSF:WUR:MS=0<br />
27 TSM:INIT:TSP OK<br />
28 TSF:SID:OK,ID=6<br />
30 TSM:FPAR<br />
50 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:<br />
2057 !TSM:FPAR:NO REPLY<br />
2059 TSM:FPAR<br />
2077 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:<br />
4085 !TSM:FPAR:NO REPLY<br />
4087 TSM:FPAR<br />
4106 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:<br />
6114 !TSM:FPAR:NO REPLY<br />
6116 TSM:FPAR<br />
6134 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:<br />
8142 !TSM:FPAR:FAIL<br />
8143 TSM:FAIL:CNT=1<br />
8145 TSM:FAIL:PDT<br />
18148 TSM:FAIL:RE-INIT<br />
18150 TSM:INIT<br />
18157 TSM:INIT:TSP OK<br />
18159 TSF:SID:OK,ID=6<br />
18161 TSM:FPAR<br />
18181 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:<br />
20188 !TSM:FPAR:NO REPLY<br />
20190 TSM:FPAR<br />
20209 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:<br />
22216 !TSM:FPAR:NO REPLY<br />
22218 TSM:FPAR<br />
22238 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:<br />
24245 !TSM:FPAR:NO REPLY<br />
24247 TSM:FPAR<br />
24266 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:<br />
26273 !TSM:FPAR:FAIL<br />
26274 TSM:FAIL:CNT=2<br />
26276 TSM:FAIL:PDT</p>
]]></description><link>https://forum.mysensors.org/post/86968</link><guid isPermaLink="true">https://forum.mysensors.org/post/86968</guid><dc:creator><![CDATA[kontrollable]]></dc:creator><pubDate>Mon, 12 Mar 2018 18:04:14 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 09:28:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a> Awesome! I will check the debug logs from my node and gateway this evening.</p>
]]></description><link>https://forum.mysensors.org/post/86955</link><guid isPermaLink="true">https://forum.mysensors.org/post/86955</guid><dc:creator><![CDATA[kontrollable]]></dc:creator><pubDate>Mon, 12 Mar 2018 09:28:38 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 09:04:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kontrollable" aria-label="Profile: kontrollable">@<bdi>kontrollable</bdi></a> ok. Good. Then it is probably something else. Have you looked at the troubleshooting diagram at <a href="https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/">https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/</a> ?</p>
<p dir="auto">Debug logs from the node and the gateway will probably be very useful when troubleshooting.</p>
]]></description><link>https://forum.mysensors.org/post/86954</link><guid isPermaLink="true">https://forum.mysensors.org/post/86954</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Mon, 12 Mar 2018 09:04:14 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 08:40:10 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!<br />
The NFR chip is oriented in such a way that the antenna is way outside the PCB. So I'm not sure that this is he problem.</p>
]]></description><link>https://forum.mysensors.org/post/86953</link><guid isPermaLink="true">https://forum.mysensors.org/post/86953</guid><dc:creator><![CDATA[kontrollable]]></dc:creator><pubDate>Mon, 12 Mar 2018 08:40:10 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 08:36:28 GMT]]></title><description><![CDATA[<p dir="auto">See <a href="https://forum.mysensors.org/topic/8869/troubleshooting-communication-solved">https://forum.mysensors.org/topic/8869/troubleshooting-communication-solved</a> for more details on a similar case. You have found the same solution as I did: find something to extend the antenna</p>
]]></description><link>https://forum.mysensors.org/post/86952</link><guid isPermaLink="true">https://forum.mysensors.org/post/86952</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Mon, 12 Mar 2018 08:36:28 GMT</pubDate></item><item><title><![CDATA[Reply to NRF24L01 radio not  connecting on Mon, 12 Mar 2018 08:14:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kontrollable" aria-label="Profile: kontrollable">@<bdi>kontrollable</bdi></a> if I'm understanding the PCB design correctly, the nrf24l01 module will be placed so the nrf's antenna is in the middle of the PCB. Is that correct? If so, I'm pretty sure we have an answer: there is a lot of metal close to the antenna, which will interfere with the radio signal.</p>
]]></description><link>https://forum.mysensors.org/post/86951</link><guid isPermaLink="true">https://forum.mysensors.org/post/86951</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Mon, 12 Mar 2018 08:14:13 GMT</pubDate></item></channel></rss>
