  3. OpenHAB
  4. OpenHAB binding is crashing
openhab2crash
4 Posts 2 Posters 2.3k Views 2 Watching
  • A
    A
    Avamander
    wrote on last edited by Avamander
    So after switching from Home Assistant to MyController to OpenHAB it seems that OpenHAB doesn't like the way my sensors are reporting their values. I'm seeing this stacktrace in the log all the time (something is wrong with it's output, Konsole isn't letting me copy it properly, image of it: image of stacktrace) :
    01:47:24.343 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 3 found in gateway
    01:47:24.350 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 4 found in node 3
    01:47:24.357 [ERROR] [internal.event.MySensorsEventRegister] - Event broadcasting throw an exception
    java.lang.NumberFormatException: null
    24) ~[?:?]
    a:122) ~[?:?]
    a:79) [211:org.openhab.binding.mysensors:2.3.0.201803141156]
    nection.java:358) [211:org.openhab.binding.mysensors:2.3.0.201803141156]
    01:47:24.462 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;2225831 TSF:MSG:READ,3-3-0,s=4,c=1,t=37,pt=3,l=2,sg=0:0
    01:47:24.469 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;2225838 TSF:MSG:ACK REQ
    01:47:24.475 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;2225842 TSF:MSG:SEND,0-0-3-3,s=4,c=1,t=37,pt=3,l=2,sg=0,ft=0,st=OK:0
    01:47:24.483 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 3;4;1;0;37;0
    Sensor 3 sending code:
    void presentation() {
      sendSketchInfo("Gassensor", "0.0");
      Serial.begin(115200);
      for (uint8_t sensor_id = 0; sensor_id < 11; sensor_id++) {
        pinMode(sensor_pins[sensor_id], INPUT);
        present(sensor_id, V_UNIT_PREFIX);  // Custom unit message.
      for (uint8_t sensor_id = 0; sensor_id < 10; sensor_id++) {
        uint16_t reading = analogRead(sensor_pins[sensor_id]);
        Serial.print(F("Sensor: "));
        Serial.print(sensor_id);
        Serial.print(F(", reading: "));
        Serial.println(reading);
        send(msgPrefix.setSensor(sensor_id).set("ppm"), true);
        send(msg.setSensor(sensor_id).set(reading), true);
        sleep(100);
      send(msgPrefix.setSensor(10).set("ppm"), true);
      send(msg.setSensor(10).set(analogRead(DUST)), true);
      sleep(SLEEP_TIME);
    • F
      F
      freynder
      Not sure if this has anything to do with it, but you should not use V_UNIT_PREFIX as a parameter in the present function call. The function expects a sensor-type and not a value-type. I suppose you could use S_CUSTOM instead.
      A 1 Reply Last reply
      • F freynder
        A
        A
        Avamander
        @freynder I'll comment that out, it was only needed for Home Assistant, I added it to get the right type of chart. But still, the crash itself happens after presentation?
        • A
          A
          Avamander
          It turns out that V_UNIT_PREFIX is not supported by OpenHAB's MySensors binding.
