pimatic-mysensors controller plugin
  • @Fredrik-Carlsson info you havent got one, please check my development git
    • Pulse sensor ( Watt, KWh and Ampere )
      "id": "EnergySensor,
      "name": "Energy Sensor",
      "class": "MySensorsPulseMeter",
      "nodeid": 3,
      "batterySensor": true,
      "sensorid": 1,
      "appliedVoltage" : 220
  • Yes saw it on github, very interesting. Will try as soon as I am home again
  • @Fredrik-Carlsson please try it, please notice me if you find any bugs.
    I'm in the middle of pull request to @Dheeraj
  • Hello
    haven't had the opportunity to test yet.
    will try to find time tomorrow
  • @Dheeraj said:
    newer version (0.8.15 ) of plugin release . support Acronym for devices . improves user experience.
    Hello @Dheeraj,
    Could you tell me which commit was connected with 0.8.15? I am little bit confused because your github is still contains 0.8.14 but it looks newer when 0.8.15.
    @Mad-Moo latest code 0.8.17 is pushed to github. now everything is sync.
  • @funky81
    Hello. I have had a hard time testing this. Is the future for the pulsesensor implemented in 0.8.17 official plugin?
    If not, how get the latest commit in to pimatic? Have tried to git clone the plugin and then npm install inside the folder, but then none of the sensors shows up in pimatic (the plugin is not active)
    With official 0.8.17 the arduino sketch just come in to an endless loop where it wants the latest pulsecount = no answer from pimatic
    Very nice plugin.
    Is there any chance in the future to support the ethernet gateway?
    It would be great if we could connected simultaneously to a serial and ethernet gateway from the same pimatic server.
    so we could cover remote places..!!!!
    New version of plugin available. 0.8.21.
    and a video to showcase its capability..
    MySensors & Pimatic Duo – 04:48
    — Dheeraj Khajuria
  • @Dheeraj
    Nice! One question: Could you maybe disconnect your repository from pimatic-plugin-template?
    http://stackoverflow.com/questions/16052477/delete-fork-dependency-of-a-github-repository
    With the fork connected its hard to fork. 😉
    @Oitzu sure will do it need some time..
  • Hi, I am using the mysensors-pimatic system and it works great. Now, I am using an optocoupler to simulate some buttons being pressend, and at the moment I am using the relay sketch for that. That works great, but it gives me on/off switches in pimatic. However, I only press the button momentarily. So I would need more a momentary button in pimatic. Something that does not switch but I still can press. So three questions:
    1. Is there a way to have an "ordinary" button in pimatic (not on/off)? Something I press only? This on/off switch works (everytime I switch on or off it simulates on button pressed on my optocoupler), but it is not really what I am looking for.
    2. Is there some code for a momentary button in mysensors? The relay code I am using works great. I adapted in a way that it swtiches the optocoupler on and 50ms later automatically off. Works great, but I was wondering if there was a more elegant way to do it.
    3. If there is no code for a momentary button for pimatic, where would I start looking if I'd want to contribute code?
    Cheers!
  • Hey karl261,
    1.) Yes there is a ordinary button in pimatic. The base-class is called "ButtonsDevice" if i remember correctly.
    2.) The MySensors Plugin also seems to implement this.
    See: https://github.com/DheerajKhajuria/pimatic-mysensors
    Search for: Binary Button
    3.) Depends at which point you want to contribute code.
    For the mysensors plugin: https://github.com/DheerajKhajuria/pimatic-mysensors
    For the Pimatic framework: https://github.com/pimatic/pimatic
    Make also sure to read the howto @ www.pimatic.org and visit the forum forum.pimatic.org.
    @karl261 using ButtonsDevice as mentioned by Oitzu, you can achieve the point no. 1 . non off/on switch..
    upload-9622ca50-7f41-488d-b9db-64391bbf0479
          "id": "mode",
          "name": "TV Mode",
          "class": "ButtonsDevice",
          "buttons": [
              "id": "PVR",
             "text": "PVR"
              "id": "HTPC",
              "text": "HTPC"
              "id": "Chromecast",
              "text": "Chromecast"
              "id": "testing",
              "text": "RainBowCycle"
    for point no. 2 you can use pimatic IFTTT rules to control (*hidden * relay switch button) moreover you can switch off optocoupler after 50 ms using rules.
    1. if you have some special requirement you are welcome to contribute..
  • Hi guys. Thanks for the replies. This seems to work. I created a button and made a rule "if button XY pressed then toggle AB". So I suppose I leave the relay device as is, just remove it from my pimatic page (out of sight) and move in the button instead. IS that right?
    Very cool indeed!
  • Hi there, I have problem that appears recently. I hope somebody can point me in the right direction.
    I had my setup running for the past two weeks without any problems. No changes in hardware. Now the following happened:
    Suddenly out of nowhere pimatic stop transmitting/receiving. Just like this. No error message. Pimatic frontend working finde. But no data going out to or coming in from the serial gateway.
    I checked all logs: Nothing. I re-started pimatic: No success. All logs normal. I restarted the pi2: Nothing. All logs normal. I unplugged/replugged the arduino nano: Nothing. No success.
    Then I shutdown the pi2, I pulled the power cable, I put it back in and voila: Everything worked normally. Still nothing in any logs. Unfortunately, now about 24h later, the same issue.
    What is happening there? How can I debug that? I also tried resetting the usb:
    echo 0 > /sys/bus/usb/devices/1-1.5/authorized
    echo 1 > /sys/bus/usb/devices/1-1.5/authorized
    Nothing.
    What can I do? Why was it running perfectly for two weeks?
    I changed back to a super simple pimatic config with just one device, but still the same issues.
    What to do? Please advice!
    Hi there! Spontaneously i have no idea what could be going wrong, only chance is to narrow down the problem.
    Based on your writing i assume you are using the serial gateway to interface with the mysensors network?
    Did you try to enable the debug output in pimatic?
    You could try to stop pimatic, detach usb, attach usb and look directly with screen on the serial device what the gateway is doing.
    screen <device>
  • This is the only thing I see in the screen
    Then nothing else. No signal recieved, even if I now my sensors are sending, but also, when I am sending something via pimatic, no send message.
  • @karl261 maybe a defect nrf24 module? The serial connection to the nano seems to work and should normaly show received messages.
    Do you have any spare modules laying arround?
  • @Oitzu that is possible. And also weird. It was working for three weeks without problem. Is there no way to get an error message from the nrf24? Why does it work after unplugging the pi? Why does it not help to reset the sub bus, which should power cycle the nano and the radio module?
    I have some nrf24 around, but the installation is in a remote place which I can only access from time to time. That's why I installed mysensors and piratical in the first place. To remote control some things. So three weeks before I can try another radio. I hoped I could reset the system somehow to be able to use my system in the meantime...
    Well i can only guess whats the problem or whats the reason to it.
    A faulty device can fail at the first day or just after 3 weeks.
    The mysensors libs will check at start time the communication with the nrf24 module. If the communication don't work it will give out a "check wires" instead of the "Gateway startup complete.".
    Maybe the difference between the full power cycle and the nano power cycle is the duration of the power cycle?
    I can guess that the full power cycle left the nrf24 module for a longer time without power?
    A longer power down of the nano would result in more time for the caps to discharge?
  • @Oitzu thanks a lot for your help. I appreciate it.
    Some more observations:
    • If I reboot the pi, I get
    in the screen session.
    • However, if I do
    echo '1-1.5' > /sys/bus/usb/drivers/usb/unbind
    echo '1-1.5' > /sys/bus/usb/drivers/usb/bind
    which should power cycle the usb device I do not see anything in the screen session. Which means that the arduino nano was not power cycled.
    However I do see that something happened in the log file:
    Nov 12 17:31:40 raspberrypi kernel: [  300.831131] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
    Nov 12 17:31:40 raspberrypi kernel: [  300.839881] ftdi_sio 1-1.5:1.0: device disconnected
    Nov 12 17:31:46 raspberrypi kernel: [  306.271337] ftdi_sio 1-1.5:1.0: FTDI USB Serial Device converter detected
    Nov 12 17:31:46 raspberrypi kernel: [  306.278553] usb 1-1.5: Detected FT232RL
    Nov 12 17:31:46 raspberrypi kernel: [  306.283631] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB0
    So, what does it mean? I don't understand. Maybe there is something wrong with the pi's USB hub? Which is only reset when I pull the plug? But then the wifi should also not work, because it is sitting on the same USB hub.
    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
        |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
            |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
            |__ Port 4: Dev 4, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
            |__ Port 5: Dev 5, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
    I really don't like that there is no error message nowhere...
    Is there any other place I could ask for help?
  • Ok, so I found a way to reset the usb bus using hub-ctrl.c. There is interesting information here:
    https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=93463
    https://github.com/codazoda/hub-ctrl.c
    https://www.raspberrypi.org/forums/viewtopic.php?t=71044&p=513908
    http://raspberrypi.stackexchange.com/questions/27903/usb-power-cycling-problem
    So, in my case I can issue the command
    ./hub-ctrl -h 0 -P 5 -p 0 ; sleep 3; ./hub-ctrl  -h 0 -P 5 -p 1
    and it does indeed reset the right port, because if I open now the screen sessoin I get the usual
    BUT: Still the thing is not sending receiving anything. WHY?
  • Tried to extend the sleep between power down and up?
  • Yes, I also tried with 30 seconds. Longer?
  • Well.. i think you can't lose anything. 😄
    Will be hard to debug after that without access to the actual hardware.
  • So, I made some modifications to the Serial Gateway sketch so it includes
    radio.printDetails();
    I see that it is looping though the loop function, but I actually see NO ouput from this function. What does this mean? That there is actually no radio connected? Wouldn't it say something like "no radio" or so?
  • Good point. I had not, now I have. But still, there is absolutely 0 output from this. The only message I see is the "Gateway startup complete" stuff.
  • I use Pimatic for more than a year now and I am using the Mysensors plugin 0.8.21 for more than 4 weeks now.
    I use a serial gateway based on a arduino nano and a NRF24 radio.
    I have already several sensors running without troubles and it appear to be stable.
    What I see from your information is that the serial gateway is communicating, but seems to recieve nothing from your sensors.
    If you can see on the PI that your gateway is started up, then the PI is able to recieve the information.
    I debugged my serial gateway using the
    serial monitor in the Arduino ide. This is also the way to test your sensors. In the serial monitor you can see if they are connecting to the gateway and sending information.
    After using OpenHAB for quite some time, I've made the transition to Pimatic.
    I've got a pro mini 3V running on 2 AA batteries with a DS18B20-temp-sensor.
    I would like to be able to display the battery level but am having some trouble.
    I combined the temp and battery sensor into 1, but the battery status isn't being analyzed properly.
    When I restart the node it transmits a value of 12 and shortly after that a value of 0.
    Any ideas how to solve this?
    Is this related to pimatic and the format in which it receives battery data or is it simply a fault in my code?
    Thanks in advance!
    This is my code:
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    #include <OneWire.h>
    int numSensors=0;
    int node_id = 12;
    int oldBatteryPcnt = 0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
      sensors.begin();
       analogReference(INTERNAL1V1);
       analogReference(INTERNAL);
     // Startup and initialize MySensors library. Set callback for incoming messages.
      gw.begin(NULL, node_id);
      gw.sendSketchInfo("Temperature Sensor met battery", "1.0");
         gw.present(i, S_TEMP);
       // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;}
      // Process incoming messages (like config from server)
      gw.sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
          gw.send(msg.setSensor(i).set(temperature,1));
      gw.sleep(SLEEP_TIME);
    @BastienVH . check few things first.
    1. hardware wiring is correct and as per mysensor guide.
    2. what debug value "sensorValue" you are seeing on serial console if you debug your sensor node.
    3. check the debug log in pimatic
  • @Dheeraj
    I feel so stupid now... I built this circuit on a breadboard and after fiddling around with it yesterday, I forgot to place the resistor for the battery in the right pin. It was now on a different row.
    Saw it and fixed it. Now I get a battery percentage in Pimatic!
    Thanks for your help!
  • @karl261 Do you have any news ?
    Which raspberry pi are you using ? PI 2 ?
    I experienced the same issue with domoticz on raspberry pi2 + serial gateway with RFM69 radio.
    I really don't think that the issue is the controller. It seems that the radio is stuck cause when I debug my node after reset, all outgoing messages are marked with st=fail meaning that radios can't reach each other.
    I don't know if it's my chinese arduino nano or raspberry pi 2 usb power or my radio module.
    Investigation in progress. Something a reboot is not enough, I have to disconnect usb cable in order to make it work again.
  • @fets Yes, indeed, I made some progress during the last weeks. Today I finally found a way to display these debug messages. Took me months. See this thread: http://forum.mysensors.org/topic/2392/how-to-properly-debug-serial-gateway-nrf24l01
    I think my serial gateway was somehow badly connected. During the past weeks I verified everything, re-soldered, tested various power supplies and radio modules, etc. Now it seems to work usually stable. But not always. Now I am playing around with increasing the sending power of the radio modules.
    I am using a pi 2.
    Interesting, your problem sounds very similar. Unfortunately I do not really have any advice. Maybe try to build a duplicate and see if this works better?
  • @karl261 My issue seems solve using capacitors on my rfm69 radios.
  • Hi everyone,
    I installed Pimatic and it looks work just fine.
    In the Config menu I added the codes below.
    Saved and restarted the Pimatic.
    I see "Light Unknown%" on the frontpage.
    How can I fix that? Thanks....
      "plugin": "mysensors",
      "driver": "serialport",
      "protocols": "1.5.1",
      "startingNodeId": 1,
      "driverOptions": {
        "//": "'/dev/ttyUSB0' if using serial Gateway",
        "serialDevice": "/dev/ttyMySensorsGateway",
        "baudrate": 115200
    "devices": [
    "id": "Light",
    "name": "Light",
    "class": "MySensorsLight",
    "nodeid": 15,
    "batterySensor": false,
    "sensorid": 2
  • @fahrettine How does your sketch look? Does pimatic receive anything in de log?
    Thanks for the answer.
    1-I installed Pimatic.
    2-I installed Serial Gateway on the Arduino Nano.
    3-I installed the Light sketch from MySensors on the Nano.
    Pimatic logs look like below. It seems it doesnt receive any signal.
    I think there is someting wrong with the USB port...
    Are my USB port settings coreect?
    You can see MySensors plugin settings above.
    2016-04-05 19:23:46info [pimatic]: Listening for HTTP-request on port 80...
    19:23:46info [pimatic-mobile-frontend]: rendering html finished
    19:23:20info [pimatic-mobile-frontend]: rendering html
    19:23:20info [pimatic-mobile-frontend]: packing static assets finished
    19:23:18info [pimatic-mobile-frontend]: packing static assets
    19:23:18info [pimatic]: New device "Light"...
    19:23:08info [pimatic-cron]: the time is: Tue Apr 05 2016 14:23:08 GMT-0200 (GMT+2)
    19:23:08info [pimatic]: Loading plugin: "pimatic-mysensors" (0.8.25)
    19:23:02info [pimatic]: Loading plugin: "pimatic-mobile-frontend" (0.8.82)
    19:22:59
       "driverOptions": {
         "baudrate": 115200
    You may want to double check that config.
    It should be more like:
       "driverOptions": {
         "serialDevice": "/dev/ttyUSB0",
         "baudrate": 115200
    if, ttyUSB0 is your connected arduino nano.
  • I plugged the controller and light sensor on my pc.
    The controller receives and the sensor transmits signals.
    So, the hardware is OK.
    I changed the USB setting as "serialDevice": "/dev/ttyUSB0"
    But still no signal.
    Because I am new on RPi I cant set the USB corectly.
    My USB settings (lsusb -t) are like below:
    What is my USB port? USB0 or USB1 or other else?
    pi@raspberrypi:~ $ lsusb -t
    |__ Port 2: Dev 4, If 0, Class=Wireless, Driver=btusb, 12M
    |__ Port 2: Dev 4, If 1, Class=Wireless, Driver=btusb, 12M
    |__ Port 3: Dev 5, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
    |__ Port 5: Dev 7, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
    dmesg | grep tty
    Will give you an output like:
    ch341-uart converter now attached to ttyUSBXX
  • Oitzu thank you very much.
    I solved the problem.
    It was the nodeID. I set the nodeID to on the sketch to 15 and the problem solved.
    Thanks for your help...
  • Hi everyone,
    I installed Pimatic. It works fine...
    I installed light sensor code from MySensor: http://www.mysensors.org/build/light
    Light sensor works fine...
    After that I intalled the Relay code: http://www.mysensors.org/build/relay
    The relay doesnt work!!! Any idea for the problem???
    When I turn the buton On/Off I can see the sending messages on debug.
    Thanks!!!
    Below are my Pimatic Config codes and debug messages:
      "id": "Switch",
      "name": "Switch",
      "class": "MySensorsSwitch",
      "nodeid": 10,
      "sensorid": 1
    debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;1
    21:21:09debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;0
    21:21:01debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;1
    21:20:56debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;0
    21:20:26info [pimatic]: Listening for HTTP-request on port 80...
    21:20:26info [pimatic-mobile-frontend]: rendering html finished
    @fahrettine said:
    check whether you received any message ( serialport output ) on relay sensor node.
  • I've seen the "protocol" line. Is it suitable for 2.0.0beta sketches ?
  • @rollercontainer the plug-in works fine with 2.0. You dont have to change the protocol value in the plug-in.
  • Is there any development of this plugin?
  • @Dheeraj,
    Do you plan to continue to develop this plugin? I will very pleased to see a mysensors button. Thank you!
  • @ricardot said in pimatic-mysensors controller plugin:
    @Dheeraj,
    I second this. And also see if we can lose the dependency on serialport 2.0.6 so that we can use Node.js > 4.9.1
