  3. How to properly debug Serial Gateway nRF24L01+ ?
4 Posts 2 Posters 4.9k Views 1 Watching
  • K Offline
    K Offline
    karl261
    I have a problem with my serial gateway described in more detail here:
    http://forum.mysensors.org/topic/797/pimatic-mysensors-controller-plugin/57
    I am using the 1.5 mysensors library. And an arduino nano with a nRF24L01+ which has worked for 3 weeks before it started to do weird stuff.
    My question is now, how can I get some debug messages? I never get any output, apart from the
    So, I tried to add
    rf24.printDetails();
    in the MyTransportNRF24.cpp but it did not show anything. I also discovered
    #define FAILURE_HANDLING
     #define SERIAL_DEBUG
    //  #define MINIMAL
    in the RF24_config.h and that it has something to do with what debug output is shown. But whatever combination of these I do, I never see any debug output.
    What am I overlooking?
    Thanks!
    • K Offline
      K Offline
      karl261
      wrote on last edited by karl261
      No one? Really? I can't get the output of
      RF24 printDetails();
      in my sketch.
      Can anybody tell me how I can use the printDetails(); function in the SerialGateway.ino to show the radio details on the serial console? I can't get it to work... I am using the 1.5 library.
      • hekH Offline
        hekH Offline
        You might get some help from here:
        http://forum.mysensors.org/topic/2461/rfm69-temperature-and-how-to-check-rfm69-is-set-to-high-power
        • K Offline
          K Offline
          karl261
          @hek Thanks a lot! That really helped. Finally had time to look into it. So for other people I will try to write down what I did. I tested this for one of my sensors.
          I am using Mysensors 1.5 master branch.
          1. MyTransportNRF24: I commented out the "private:" to make the rf24 function public.
          2. RF24_config.h: I commented out the "#define MINIMAL" to make some more functions available in RF24.cpp.
          3. then I added to my sketch:
          • "#include <printf.h>" in the beginning, I found the file somewhere on the net.
          • in the void setup() function I added "printf_begin();" I do not fully understand this, but it seems to define stdio. Because I read in RF24.h
            printf.h
             * Print a giant block of debugging information to stdout
             * @warning Does nothing if stdout is not defined.  See fdevopen in stdio.h
            void printDetails(void);
          • in the void loop(); I added "radio.rf24.printDetails();"
          ... and after several months of research it is finally printing some debug output. For example: PA Power = PA_HIGH
          I wonder why this is so difficult to use and there is so little info about debugging.
          Hope it helps someone!
