OTA:FWP:UPDATE SKIPPED :(
  • Hi All,
    i had some spare time and thought to play with OTA, i have burned bootloader with right channel and then upload blank sketch with, i have swapped the arduino just in case.
    MySensors version 2.3.1
    ESP8266 Gateway.
    hex file size is 43KB
    can any one see what i m doing wrong?
    Blank sketch:
    //Set MY_SPLASH_SCREEN_DISABLED to disable MySensors splash screen. (This saves 120 bytes of flash)
    //Define Sketch Name
    #define SKETCH_NAME "Blank Over The Air Node"
    //Define Sketch Version
    #define SKETCH_VERSION "0.001"
    #define MY_RADIO_RF24
    //Define this to use the IRQ pin of the RF24 module (optional).
    #define MY_RF24_IRQ_PIN 2
    #define MY_RX_MESSAGE_BUFFER_FEATURE
    #define MY_RX_MESSAGE_BUFFER_SIZE 5
    #define MY_RF24_PA_LEVEL RF24_PA_MIN
    //Default RF channel Default is 76
    #define MY_RF24_CHANNEL	91
    //PiHome Zone Controller Node ID
    #define MY_NODE_ID 1
    //If Following LED Blink does not work then modify C:\Program Files (x86)\Arduino\libraries\MySensors_2_1_1\MyConfig.h
    #define MY_DEFAULT_ERR_LED_PIN 16 //A0 previous version 8
    #define MY_DEFAULT_TX_LED_PIN 14
    #define MY_DEFAULT_RX_LED_PIN 15
    #define MY_DEFAULT_LED_BLINK_PERIOD 400
    #define MY_OTA_FIRMWARE_FEATURE
    	//Send the sensor node sketch version information to the gateway
    Here is my boards.txt file just incase if i m missing something
    MYS.name=OTA nRF Ch91 8MHz RF24_PA_MIN BOD-1.8v
    MYS.upload.tool=avrdude
    MYS.upload.protocol=arduino
    MYS.upload.maximum_size=30720
    MYS.upload.speed=57600
    MYS.bootloader.tool=avrdude
    MYS.bootloader.low_fuses=0xFF
    MYS.bootloader.high_fuses=0xDA
    # all the possible values:
    #MYS.extended_fuses=0x04 -> BOD at 4.3V
    #MYS.extended_fuses=0x05 -> BOD at 2.7V
    #MYS.extended_fuses=0x06 -> BOD at 1.8V
    #MYS.extended_fuses=0x07 -> BOD disabled
    MYS.bootloader.extended_fuses=0x06
    MYS.bootloader.path=MYSBootloader
    MYS.bootloader.file=MYSBootloader.ch91.8000000L.RF24_PA_MIN.hex
    MYS.bootloader.unlock_bits=0x3F
    MYS.bootloader.lock_bits=0x0F
    MYS.build.mcu=atmega328p
    MYS.build.f_cpu=8000000L
    MYS.build.core=arduino
    MYS.build.variant=standard
    serial console logs for node.
    ⸮Q)6 TSF:WUR:MS=0
    12 TSM:INIT⸮2064 !TSM:FPAR:NO REPLY
    2066 TSM:FPAR
    2103 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    K,ID=0,D=1
    4110`⸮⸮⸮255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    4225 TSF:MSG:PONG RECV,HP=1
    4229 TSM:UPL:⸮⸮⸮⸮⸮b⸮⸮⸮0,ft=0,st=OK:FFFFFFFFB803CFD40300
    4247 TSF:MSG:S4442 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4460 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4706 TSF:MSG:READ,0-0-1,s=2⸮<sg=0,ft=0,st=OK:Blank Over The Air Node
    4726 TSF:MSG:SE⸮SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    5001 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    5007 MCO:PIM:NODE⸮60993 TSF:MS⸮609826 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,p⸮702⸮702980 TSF:MSG:SEND,1-1-0-0,s=255,c=4⸮SG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    703197 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
    ⸮P&⸮703457 OTA:FWP:UPDATE SKIPPED
    703578 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    ⸮END,1-1-0-0,s=255,c=3,t=11,pt=0,l=23,sg=0,ft=0,st=OK:Blank Over The Air ⸮⸮⸮i⸮710047 OTA:FWP:UPDATE SKIPPED
    screenshot of MYSController
  • just tired with different fuse settings bootloader.low_fuses=0xE2 but no success
    2088 TSM:FPAR:OK
    2088 TSM:ID
    2091 TSM:ID:OK
    2093 TSM:UPL
    2097 2193 TSF:MSG:READ,0-0-1⸮2209 TSF:MSG:SEND,1-1-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft.Wz-⸮0100
    2410 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:012428 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    >TSF:MSG:READ,0-0-1,s=0,c=4,t=1,pt=6,l=8,sg=0:20000100D00374A3
    2674 OTA:FWP:UPDATE
    26⸮2791 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,⸮⸮⸮Blank Over The Air Node
    2811 TSF:MSG:SEND,1-1-0-0,s=255⸮MMi⸮3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    3088 MCO:BGN:STP
    3090 MCO:BGN:INIT OK,TSP=1
    24172 TSF:MSG:READ,0-0-1,s=0,c=4,t=1,pt=6,l=8,sg=0:20000100D00374A3
    24178 OTA:FWP:UPDATE
  • 24
  • 15
