Motion Sensor not presenting to RS485 Gateway / TSM:FPAR:NO REPLY
  • Hardware: Arduino nano boards+ RS485 devices with separate 5 volt power supply
    I am trying to set up my 1st Rs485 gateway motion sensor on Home Assistant, per the following tutorial:
    https://www.mysensors.org/build/rs485
    The motion sensor is not presenting itself to the gateway, so I did some digging and found this thread on the subject:
    https://forum.mysensors.org/topic/11048/mqtt-ethernet-gateway-with-wired-rs485-network.
    I have things wired up as per this pic provided in the tutorial
    Although I am not using mqtt, everything seemed to be pertinent but I was still unable to get communication between the sensor and gateway.
    Ha logs show the gateway seems to be happy:
    [mysensors] Connected to Serial<id=0x7f2fd0c2f518, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False)
    2020-10-05 13:17:05 INFO (MainThread) [mysensors] Connected to <_SelectorSocketTransport fd=25 read=idle write=<idle, bufsize=0>>
    p:Gateway startup complete.
    However serial monitor for the motion sensor shows the following:
    |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
    | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
    |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
            |___/                      2.3.2
    16 MCO:BGN:INIT NODE,CP=RSNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    29 TSM:INIT:TSP OK
    31 TSM:FPAR
    33 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2041 !TSM:FPAR:NO REPLY
    2043 TSM:FPAR
    2045 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4054 !TSM:FPAR:NO REPLY
    4056 TSM:FPAR
    4058 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6066 !TSM:FPAR:NO REPLY
    6068 TSM:FPAR
    6070 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8078 !TSM:FPAR:FAIL
    8079 TSM:FAIL:CNT=1
    8081 TSM:FAIL:DIS
    8083 TSF:TDI:TSL
    18085 TSM:FAIL:RE-INIT
    18087 TSM:INIT
    18088 TSM:INIT:TSP OK
    Gateway sketch:
    * Copyright (C) 2013-2019 Sensnology AB
    * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
    * The RS485 Gateway prints data received from sensors on the serial link.
    * The gateway accepts input on seral which will be sent out on
    * the RS485 link.
    * LEDs (OPTIONAL):
    * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
    * - ERR (red) - fast blink on error during transmission error or receive crc error
    * If your Arduino board has additional serial ports
    * you can use to connect the RS485 module.
    * Otherwise, the gateway uses AltSoftSerial to handle two serial
    * links on one Arduino. Use the following pins for RS485 link
    *  Board          Transmit  Receive   PWM Unusable
    * Teensy 3.0 & 3.1  21        20         22
    * Teensy 2.0         9        10       (none)
    * Teensy++ 2.0      25         4       26, 27
    * Arduino Uno        9         8         10
    * Arduino Leonardo   5        13       (none)
    * Arduino Mega      46        48       44, 45
    * Wiring-S           5         6          4
    * Sanguino          13        14         12
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 2
    // Set RS485 baud rate to use
    #define MY_RS485_BAUD_RATE 115200
    // Enable this if RS485 is connected to a hardware serial port
    #define MY_RS485_HWSERIAL Serial
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
    Motion detector Sketch:
     * Version 1.0 - Henrik Ekblad
     * This is an example of sensors using RS485 as transport layer
     * Otherwise, the transport uses AltSoftSerial to handle two serial
     * Wiring-S           5         6          4
     * Sanguino          13        14         12 *
    #define MY_RS485
    //#define MY_RS485_HWSERIAL Serial
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    #define DIGITAL_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define MY_NODE_ID 123
    #define CHILD_ID 1   // Id of the sensor child
    // Initialize motion message
      pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
      present(CHILD_ID, S_MOTION);
      // Read digital motion value
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
      send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
    To rule out hardware failure, I followed this tutorial, and all works as expected:
    https://naylampmechatronics.com/blog/37_Comunicación-RS485-con-Arduino.html
    Transmitter sketch:
    const int ledPin =  13;  // Built-in LED
    const int EnTxPin =  2;  // HIGH:Transmitter, LOW:Receiver
      Serial.begin(9600);
      Serial.setTimeout(100);
      pinMode(ledPin, OUTPUT);
      pinMode(EnTxPin, OUTPUT);
      digitalWrite(ledPin, LOW);
      digitalWrite(EnTxPin, HIGH);
      int rdata = analogRead(0); //data from potentiometer
      int angle= map(rdata, 0, 1023, 0, 180);
      //transmitter data packet
      Serial.print("I"); //initiate data packet
      Serial.print("S"); //code for servo
      Serial.print(angle); //servo angle data
      Serial.print("F"); //finish data packet
      delay(50);
      //receiver data packet
      Serial.print("L"); //code for sensor
      Serial.flush();
      digitalWrite(EnTxPin, LOW); //RS485 as receiver
      if(Serial.find("i"))
          int data=Serial.parseInt();
          if(Serial.read()=='f') //finish reading
             onLED(data);
      digitalWrite(EnTxPin, HIGH); //RS485 as transmitter
    void onLED(int data)
      if(data>500)
         digitalWrite(ledPin, HIGH);
    Reciever sketch:
    #include <Servo.h>
    Servo myservo;
    void setup () {
      Serial.begin (9600);
      myservo.attach (9);
      pinMode(EnTxPin, OUTPUT );
      digitalWrite (EnTxPin, LOW );
    void loop (){
      if ( Serial.available ()){
        if ( Serial.read () == 'I' ){
          char function = Serial.read ();
          if (function == 'S' ){
            int angle = Serial.parseInt ();
            if ( Serial.read () == 'F' ){
              if (angle <= 180) {
                myservo.write (angle);
          else if (function == 'L' ){
              int val = analogRead (0);
              digitalWrite (EnTxPin, HIGH ); //enable to transmit
              Serial.print ( "i" );
              Serial.print (val);
              Serial.println ( "f" );
              Serial.flush ();
              digitalWrite (EnTxPin, LOW ); //enable to receive
      delay (10);
    Any ideas about what might be causing the issue?
    @mrhutchinsonmn I haven’t used rs485 myself, but I think it will work better if you use the same speed for MY_RS485_BAUD_RATE on gateway and nodes.
  • @mrhutchinsonmn said in Motion Sensor not presenting to RS485 Gateway / TSM:FPAR:NO REPLY:
    9600
    Good catch.. That was an old version... both are set to 115200 after 9600 did not work
  • @mrhutchinsonmn Might have confused the issue with my reply.. Neither 115200 nor 9600 baud rates resolve the communication issue.
    The sketch uses MY_RS485_HWSERIAL but you say you have wired according to https://forum.mysensors.org/topic/11048/mqtt-ethernet-gateway-with-wired-rs485-network which uses pins 8 and 9?
    Pins 8 and 9 are not the hardware serial pins.
  • @mfalkvidd Ugh!!! Too many versions of the sketch :)... Had to switch between my laptop and pc because of sketch upload issues.... Must have grabbed an old sketch.. I HAD commented hwserial out earlier... Getting communication now but not a valid message, not enough values to unpack errors. I will dig into that tomorrow. Thank you!!!
    @mrhutchinsonmn I would try 9600 again. 115200 leaves very little room for interference and oscillator differences.
  • Thank you for the advice!
    I started over, just to be sure I didn't have anymore mix ups, but still have not been able to get the RS485 motion sensor and RS485 gateway to talk.
    Hardware: Arduino Nanos+ RS485 modules.
    Wiring:
    RO = Pin 8 of Arduino
    DI = Pin 9 of Arduino
    A = A on other Nano
    B = B on other Nano
    DI= Pin 9 of Nano
    RO = Pin 8 of Nano
    DE & RE = Pin 2 of Nano
    VCC = External power source
    GND = External power source
    Current Gateway Sketch:
    * the RS485 link.
    * LEDs (OPTIONAL):
    * Wiring-S           5         6          4
    * Sanguino          13        14         12
    #define MY_RS485
    //Digital pin used for inclusion mode button
    Current Motion Detector Sketch:
     * Wiring-S           5         6          4
    #define MY_RS485
    //#define MY_RS485_HWSERIAL Serial1
    Commented the following out on the gateway, as per other forum users recommendations ( but made no difference)
    Serial Monitor info:
    21257 TSM:FAIL:CNT=7
    321259 TSM:FAIL:DIS
    321261 TSF:TDI:TSL
    381263 TSM:FAIL:RE-INIT
    381265 TSM:INIT
    381266 TSM:INIT:TSP OK
    381268 TSM:FPAR
    381287 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    383295 !TSM:FPAR:NO REPLY
    383297 TSM:FPAR
    383315 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    385324 !TSM:FPAR:NO REPLY
    385326 TSM:FPAR
    385344 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    387352 !TSM:FPAR:NO REPLY
    387354 TSM:FPAR
    387373 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    389381 !TSM:FPAR:FAIL
    Ideas?
  • @mrhutchinsonmn At RS485, it's obligatory to assign NodeIDs within your sketch.
  • You should move the define for the node ID before you include mysensors.h
  • @rejoe2 In research, some stated it needed to be there if the sensor did not present itself. Followed @electrik advice and it now works. Thank you for your feedback!
  • @electrik Yes... that worked!!! Moved node and child id above mysensors.h
    Thank you!!!!
  • 17
