  3. Home Assistant
  4. MQTT Ethernet Gateway with Wired RS485 Network
13 Posts 6 Posters 2.3k Views 5 Watching
  • ATha1A
    ATha1A
    ATha1
    Hi everyone.
    Somehow I miss real examples, such as coding examples for wired RS485 Sensor Networks.
    Maybe the wireless option is more famous because not everyone has the opportunity to wire up with all sensors.
    However I tried now to make an example code, with btw. doesn't work so far, but maybe you can help me and use this example for a later more detailed introduction into this approach?
    OK, I use Home Assistent (hassos 3.11 on Raspberry Pi 4) as Controller and tried now to get MQTT working. So far so good, the MQTT Example including the Ethernet Shield works now and made me happy :-)
    Now I tried with the MAX485 Module to make a connection to a separate Sensor Node where I just used the MotionSensor Example for RS485 see here MotionSensorRS485
    Since I wasn't sure about how to wire up with RS485 I found with google the following example: https://maker.pro/arduino/tutorial/creating-long-distance-serial-communication-using-an-arduino-and-an-rs-485-module
    I'm using now an Arduino Uno as MQTT-Ethernet Gateway and an Arduino Nano as MotionSensor Node. Here a picture of my wiring:
    First of all, is that correct ??
    Second my code for the gateway:
    //#define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable these if your MQTT broker requires username/password
    #define MY_MQTT_USER "mqtt_user"
    #define MY_MQTT_PASSWORD "mqtt_passwd"
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 164
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 2
    // Set RS485 baud rate to use
    #define MY_RS485_BAUD_RATE 9600
    #include <Ethernet.h>
    My Configuration.yml includes the MQTT Option:
    # Example configuration.yaml entry
    mysensors:
      gateways:
        - device: mqtt
          persistence_file: 'mysensors/mysensors_mqtt.json'
          topic_in_prefix: 'mygateway1-out'
          topic_out_prefix: 'mygateway1-in'
      persistence: true
      version: '2.3.2'
    So now I don't know how to get the sensor node up and running.
    Is there something wrong in the wiring?
    I have the option for the inclusion button? What is there to do, or what else can I do?
    I tried on D3 pin to pull down to simulate the inclusion button pressed. But I didn't get any reaction.
    So maybe someone is here more experienced with that topic?
    • ATha1A ATha1
      Hi everyone.
      #define MY_SOFTSPI
      #define MY_RS485
      mysensors:
        gateways:
          - device: mqtt
        persistence: true
        version: '2.3.2'
      I don't have any experience with RS485, but the guide at https://www.mysensors.org/build/rs485 should contain everything you need about wiring.
      The MySensors build examples are not specific to wireless transports. They work regardless of transport.
      ATha1A 1 Reply Last reply
        ATha1A
        ATha1A
        ATha1
        @mfalkvidd Thank you for your reply
        Well I've read that guide. But anyway this doesn't answer my questions.
        What is necessary to do, that the 2nd sensor node shows up?
        Do you know how the MY_INCLUSION_MODE_BUTTON_PIN works?
        • BearWithBeardB
          BearWithBeardB
          BearWithBeard
          You don't need inclusion mode for Home Assistant. I don't know if it is even supported. Once you power up your sensor node while HA is running, HA should detect it automatically during the presentation(), however HA will not show any sensor data until you send at least one value. Your persistance file mysensors_mqtt.json should tell you what HA knows about your sensors.
          I may have overlooked it, but I don't know what exactly is your issue here. Does your node send no data at all? Does the gateway receive data from it, but not the gateway? Does your controller receive data but doesn't display anything? Does any of the serial outputs on the node and gateway or the HA log give you hints at what might be wrong?
          How does your sensor node sketch look like? Do you send an initial value for your PIR sensor in the loop()?
          By the way - you should change version: '2.3.2' in your HA configuration to version: '2.3' because the prior is invalid and can cause (different) problems in the future.
          • BearWithBeardB BearWithBeard
            ATha1A
            ATha1A
            ATha1
            @BearWithBeard Thanks for your reply
            Well the sensor doesn't show up.
            And I don't know if my wiring is correct, maybe you could review that, because I don't know, but I think this should be right.
            The motion sensor sketch is used as presented here: https://www.mysensors.org/build/rs485
            So the code looks like this:
            #define MY_RS485
            // Enable this if RS485 is connected to a hardware serial port
            //#define MY_RS485_HWSERIAL Serial1
            uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
            // Initialize motion message
                sendSketchInfo("Motion Sensor", "1.0");
                present(CHILD_ID, S_MOTION);
                // Read digital motion value
                bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                Serial.println(tripped);
                send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
            I will change to configuration.yml as you've suggested to version: '2.3'. But I haven't recognized any issues so far with that.
            • BearWithBeardB
              BearWithBeardB
              BearWithBeard
              I haven't worked with RS485 neither but your wiring looks good as far as I can tell.
              I asked you to look at the serial output. If your gateway receives data (presentation and triggering of the PIR sensor), your network is wired properly and the issue is somewhere else.
              In this case, an excerpt of your HA log would be helpful. Maybe you don't have write permissions for your persistance file. Does it even exist? Could it be that the node and sensor ID is already present from earlier projects, but the sensor type is different from the current one?
              This is because the MySensors integration converts this version string you specify in the configuration into a float value. A string which contains more than one dot fails this conversion, which causes the pymysensors module to fall back to the 1.4 version of the serial protocol, which doesn't support some of the newer sensor types and features of later MySensors versions.
                ATha1A
                ATha1A
                ATha1
                wrote on last edited by ATha1
                @BearWithBeard alright, I've changed the config version to 2.3 now and restarted HASS
                I also change the gateway code and removed the following lines:
                I deployt the gateway node and this is the output of the Serial Monitor there:
                ⸮⸮Q8V⸮⸮⸮⸮0 MCO:BGN:INIT GW,CP=RSNGA---,FQ=16,REL=255,VER=2.3.2
                19:58:49.479 -> 4 TSM:INIT
                19:58:49.479 -> 5 TSF:WUR:MS=0
                19:58:49.479 -> 7 TSM:INIT:TSP OK
                19:58:49.479 -> 8 TSM:INIT:GW MODE
                19:58:49.479 -> 10 TSM:READY:ID=0,PAR=0,DIS=0
                19:58:49.516 -> 12 MCO:REG:NOT NEEDED
                10183 GWT:TPC:IP=192.168.0.220
                11186 MCO:BGN:STP
                19:59:00.662 -> 11188 MCO:BGN:INIT OK,TSP=1
                15335 GWT:TPC:IP=192.168.0.220
                16338 GWT:RMQ:CONNECTING...
                16996 GWT:RMQ:OK
                19:59:06.476 -> 16998 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
                19:59:06.476 -> 17004 TSM:READY:NWD REQ
                19:59:06.512 -> 17024 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                btw. yes my mysensors_mqtt.json (persistent file) exists but only looks like this:
                And had no other sensors in this wired network with that id or child_id as far as I know.
                Now I've redeployt the sensor node and output on Serial Monitor is:
                ⸮⸮⸮z⸮⸮⸮⸮⸮Y⸮⸮⸮A⸮h⸮l⸮,ht⸮⸮⸮⸮⸮Q
                20:14:41.610 ->  __  __       ____
                20:14:41.610 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
                20:14:41.610 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
                20:14:41.610 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
                20:14:41.610 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
                20:14:41.610 ->         |___/                      2.3.2
                20:14:41.610 ->
                20:14:41.610 -> 16 MCO:BGN:INIT NODE,CP=RSNNA---,FQ=16,REL=255,VER=2.3.2
                20:14:41.645 -> 26 TSM:INIT
                20:14:41.645 -> 28 TSF:WUR:MS=0
                20:14:41.645 -> 29 TSM:INIT:TSP OK
                20:14:41.645 -> 31 TSM:FPAR
                20:14:41.645 -> 49 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2057 !TSM:FPAR:NO REPLY
                20:14:43.660 -> 2059 TSM:FPAR
                20:14:43.696 -> 2076 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                4084 !TSM:FPAR:NO REPLY
                20:14:45.674 -> 4086 TSM:FPAR
                20:14:45.710 -> 4104 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                6112 !TSM:FPAR:NO REPLY
                20:14:47.714 -> 6114 TSM:FPAR
                20:14:47.749 -> 6131 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                8139 !TSM:FPAR:FAIL
                20:14:49.763 -> 8140 TSM:FAIL:CNT=1
                20:14:49.763 -> 8142 TSM:FAIL:DIS
                20:14:49.763 -> 8144 TSF:TDI:TSL
                18146 TSM:FAIL:RE-INIT
                20:14:59.754 -> 18148 TSM:INIT
                20:14:59.754 -> 18149 TSM:INIT:TSP OK
                20:14:59.754 -> 18151 TSM:FPAR
                20:14:59.790 -> 18169 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                20178 !TSM:FPAR:NO REPLY
                20:15:01.773 -> 20180 TSM:FPAR
                20:15:01.809 -> 20199 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                22206 !TSM:FPAR:NO REPLY
                20:15:03.800 -> 22208 TSM:FPAR
                20:15:03.837 -> 22226 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                24235 !TSM:FPAR:NO REPLY
                20:15:05.829 -> 24237 TSM:FPAR
                20:15:05.867 -> 24255 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                26262 !TSM:FPAR:FAIL
                20:15:07.855 -> 26263 TSM:FAIL:CNT=2
                20:15:07.855 -> 26265 TSM:FAIL:DIS
                20:15:07.855 -> 26267 TSF:TDI:TSL
                36270 TSM:FAIL:RE-INIT
                20:15:17.879 -> 36272 TSM:INIT
                20:15:17.879 -> 36273 TSM:INIT:TSP OK
                20:15:17.879 -> 36275 TSM:FPAR
                20:15:17.913 -> 36293 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                38301 !TSM:FPAR:NO REPLY
                20:15:19.905 -> 38303 TSM:FPAR
                20:15:19.943 -> 38322 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                40329 !TSM:FPAR:NO REPLY
                20:15:21.944 -> 40331 TSM:FPAR
                20:15:21.944 -> 40349 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                42356 !TSM:FPAR:NO REPLY
                20:15:23.961 -> 42358 TSM:FPAR
                20:15:23.997 -> 42377 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                44384 !TSM:FPAR:FAIL
                20:15:25.987 -> 44385 TSM:FAIL:CNT=3
                20:15:25.987 -> 44387 TSM:FAIL:DIS
                20:15:25.987 -> 44389 TSF:TDI:TSL
                54392 TSM:FAIL:RE-INIT
                20:15:35.987 -> 54394 TSM:INIT
                20:15:35.987 -> 54395 TSM:INIT:TSP OK
                20:15:35.987 -> 54397 TSM:FPAR
                20:15:36.023 -> 54416 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                56424 !TSM:FPAR:NO REPLY
                20:15:38.017 -> 56426 TSM:FPAR
                20:15:38.055 -> 56444 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                58452 !TSM:FPAR:NO REPLY
                20:15:40.051 -> 58455 TSM:FPAR
                20:15:40.088 -> 58473 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                60480 !TSM:FPAR:NO REPLY
                20:15:42.099 -> 60482 TSM:FPAR
                20:15:42.099 -> 60500 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                62508 !TSM:FPAR:FAIL
                20:15:44.117 -> 62509 TSM:FAIL:CNT=4
                20:15:44.117 -> 62511 TSM:FAIL:DIS
                20:15:44.117 -> 62513 TSF:TDI:TSL
                72516 TSM:FAIL:RE-INIT
                20:15:54.121 -> 72518 TSM:INIT
                20:15:54.121 -> 72519 TSM:INIT:TSP OK
                20:15:54.121 -> 72521 TSM:FPAR
                20:15:54.157 -> 72540 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                74548 !TSM:FPAR:NO REPLY
                20:15:56.174 -> 74550 TSM:FPAR
                20:15:56.174 -> 74568 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                76575 !TSM:FPAR:NO REPLY
                20:15:58.190 -> 76577 TSM:FPAR
                20:15:58.190 -> 76596 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                78603 !TSM:FPAR:NO REPLY
                20:16:00.193 -> 78605 TSM:FPAR
                20:16:00.226 -> 78623 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                80630 !TSM:FPAR:FAIL
                20:16:02.238 -> 80631 TSM:FAIL:CNT=5
                20:16:02.238 -> 80633 TSM:FAIL:DIS
                20:16:02.238 -> 80635 TSF:TDI:TSL
                90638 TSM:FAIL:RE-INIT
                20:16:12.234 -> 90640 TSM:INIT
                20:16:12.234 -> 90641 TSM:INIT:TSP OK
                20:16:12.234 -> 90643 TSM:FPAR
                20:16:12.270 -> 90661 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                92670 !TSM:FPAR:NO REPLY
                20:16:14.274 -> 92673 TSM:FPAR
                20:16:14.312 -> 92691 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                94698 !TSM:FPAR:NO REPLY
                20:16:16.302 -> 94700 TSM:FPAR
                20:16:16.340 -> 94718 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                96726 !TSM:FPAR:NO REPLY
                20:16:18.335 -> 96728 TSM:FPAR
                20:16:18.371 -> 96746 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                98753 !TSM:FPAR:FAIL
                20:16:20.373 -> 98754 TSM:FAIL:CNT=6
                20:16:20.373 -> 98756 TSM:FAIL:DIS
                20:16:20.373 -> 98758 TSF:TDI:TSL
                108761 TSM:FAIL:RE-INIT
                20:16:30.382 -> 108763 TSM:INIT
                20:16:30.382 -> 108764 TSM:INIT:TSP OK
                20:16:30.382 -> 108766 TSM:FPAR
                20:16:30.382 -> 108784 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                110792 !TSM:FPAR:NO REPLY
                20:16:32.394 -> 110794 TSM:FPAR
                20:16:32.431 -> 110813 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                112821 !TSM:FPAR:NO REPLY
                20:16:34.425 -> 112823 TSM:FPAR
                20:16:34.463 -> 112841 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                114849 !TSM:FPAR:NO REPLY
                20:16:36.443 -> 114851 TSM:FPAR
                20:16:36.477 -> 114870 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                116878 !TSM:FPAR:FAIL
                20:16:38.485 -> 116880 TSM:FAIL:CNT=7
                20:16:38.485 -> 116882 TSM:FAIL:DIS
                116884 TSF:TDI:TSL
                176886 TSM:FAIL:RE-INIT
                20:17:38.493 -> 176888 TSM:INIT
                20:17:38.493 -> 176889 TSM:INIT:TSP OK
                20:17:38.493 -> 176891 TSM:FPAR
                20:17:38.529 -> 176910 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                178918 !TSM:FPAR:NO REPLY
                20:17:40.521 -> 178920 TSM:FPAR
                20:17:40.558 -> 178938 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                180947 !TSM:FPAR:NO REPLY
                20:17:42.544 -> 180950 TSM:FPAR
                20:17:42.579 -> 180968 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                182976 !TSM:FPAR:NO REPLY
                20:17:44.599 -> 182978 TSM:FPAR
                20:17:44.599 -> 182996 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                185005 !TSM:FPAR:FAIL
                20:17:46.606 -> 185007 TSM:FAIL:CNT=7
                20:17:46.606 -> 185009 TSM:FAIL:DIS
                185011 TSF:TDI:TSL
                I don't see something in the HA logs which has to do with mqtt gateway.
                BearWithBeardB 1 Reply Last reply
                • ATha1A ATha1
                  11186 MCO:BGN:STP
                  16996 GWT:RMQ:OK
                  20:14:41.610 ->
                  8139 !TSM:FPAR:FAIL
                  116884 TSF:TDI:TSL
                  185011 TSF:TDI:TSL
                  BearWithBeardB
                  BearWithBeardB
                  BearWithBeard
                  @ATha1 Okay, thank you for the logs. There were people with similar issues recently, who weren't able to get their sensor values to show up on HA. At least one of them "fixed" it by switching from an ethernet to a serial gateway, so I quickly setup a new MySensors network with an EthernetMQTT gateway (Arduino Uno + W5500), but using NRF24 radios instead to see if there is a fundamental issue regarding ethernet gateways in combination with HA.
                  With only the gateway connected, my newly created persistance file contains an object of my gateway right away:
                      "0": {
                          "sensor_id": 0,
                          "children": {},
                          "type": 18,
                          "sketch_name": null,
                          "sketch_version": null,
                          "battery_level": 0,
                          "protocol_version": "2.3.2",
                          "heartbeat": 0
                  If yours is empty, I suspect that the link between gateway and controller is incorrect. This might be a stupid question, but did you confirm that your gateway is publishing successfully to the topic HA is subscribed to? If you manually subscribe to mygateway1-out/0/255/0/0/18, you should see a 2.3.2 payload after powering up the gateway, according to its serial output. And is MQTT setup correctly in configurations.yml?
                  After I confirmed that my gateway does connect to the controller, I added a sensor node to the network, which found its parent right away, received a dynamically assigned ID from HA, got added to the persistance file and started reporting messages as expected. Atleast we now know there is no fundamental issue with the ethernet gateway and HA.
                  If your MQTT setup is working fine, I don't know what causes your problem. You could try using static routing between your sensor node and gateway, see if a serial gateway works, double-check your wiring or if replacing RS485 with any other transport method gets you further. I'm out of ideas at this point, sorry.
                  • MichalM
                    MichalM
                    Michal
                    @ATha1 What tool do you use to draw a diagram ?
                    • MichalM Michal
                      ATha1A
                      ATha1A
                      ATha1
                      @Michal
                      I’ve downloaded an older version of fritzing.
                      I think this is a beta version btw.
                      I’ve just googled fritzing download.
                      • P
                        P
                        pjr
                        Back then when I built my RS485 network with normal ethernet GW and domoticz I had to define static node id's for all the nodes(except GW) to get RS485 network working. Not sure if thats the case anymore.
                        #define MY_NODE_ID 123
                        • P pjr
                          ATha1A
                          ATha1A
                          ATha1
                          @pjr said in MQTT Ethernet Gateway with Wired RS485 Network:
                          wow awesome!
                          I've just tried and it seems to recognize the other wired node ☺️
                          Now I did some soldering, so that the wiring is easier and moved to a serial gateway.
                          Later I will try again to use the MQTT with Ethernet Gateway
                          • Giovanni ChivaG
                            Giovanni ChivaG
                            Giovanni Chiva
                            Hey @ATha1, I'm sorry for reviving this old topic but I'm currently struggling with getting RS485 and RF24 to work together. I can't find any other threads mentioning this so I'm really wondering if you did manage to make them work together and how.
