Gateway - I2C Advanced button and led
  • I have a gate based on esp2866, wemos mini board. There are few gpio outputs on it. To implement additional features, such as an inclusive button and status LEDs, I had to connect a gpio expansion board via I2C. I took a PCF8574 based board. For the operation of the button and indication through it, the sources had to be slightly changed, the patch for version 2.4.0 is attached in gist.
    Example sketch code:
    #define MY_DEFAULT_LED_EXT 1
    #define MY_INCLUSION_MODE_DURATION 10
    #include <core/MyInclusionMode.h>
    #include <PCF8574.h>
    const uint8_t scl_PIN = D1;
    const uint8_t sda_PIN = D2;
    const uint8_t led_device[4] { 2U, 3U, 6U, 4U };
    const uint8_t btn_device[4] { 0U, 1U, 5U, 7U };
    PCF8574 expander(0x22, sda_PIN, scl_PIN);
      Wire.begin(sda_PIN, scl_PIN);
      while (!Serial) delay(50);
      for (uint8_t i = 0; i < 4U; i++) {
        expander.pinMode(led_device[i], OUTPUT);
        expander.digitalWrite(led_device[i], HIGH);
        Serial.printf("Init LED expander: %u/%u\n", (uint16_t)i, (uint16_t)led_device[i]);
        expander.pinMode(btn_device[i], INPUT);
        expander.digitalWrite(btn_device[i], HIGH);
        Serial.printf("Init BTN expander: %u/%u\n", (uint16_t)i, (uint16_t)btn_device[i]);
      expander.begin();
      ledsSetCb(
        [=](uint8_t & state) { expander.digitalWrite(led_device[1], state); },
        [=](uint8_t & state) { expander.digitalWrite(led_device[2], state); },
        [=](uint8_t & state) { expander.digitalWrite(led_device[3], state); }
      inclusionSetCb(
        [=]() { return (expander.digitalRead(btn_device[0], true) == LOW); },
        [=](uint8_t & state) { expander.digitalWrite(led_device[0], state); }
    void loop() {}
    I2C extender
  • small fix of the patch, removed "contact bounce" in the inclusive button.
  • 29
