A little Halloween fun. I've added LED strip lights to an old Halloween plastic ghost and jack-o-lantern and automated switching them off/on using a MySensors node.
@pbw a gateway's function is to act as a gateway between the nodes and a controller. I don't think you will have all of the needed memory available to add logic to the gateway and you will make your solution very static.
You can implemented your own lightway controller, just have a look at the Serial API. But controllers like Domoticz are lightweight and the already over a browser based interface. And most of them are easy to setup creating a much more versatile and dynamic solution.
@DeepCore That is a need looking design. Did you consider using an alternative power supply other than usb? My Pi can't handle a lot of usb devices power wise, so I'm using a powered usb hub. But the wife doesn't like it, it's messy xd
Hello everyone,
Firstly, I apologize for reviving such an old thread, but I find myself in a unique situation and was hoping some of you might be able to help.
I hope everyone's doing well. I have a specific inquiry that I couldn't find a recent solution for. Does anyone here know of a tool to generate "fake" Dooya remote (DC90) RF codes for curtains? I've acquired a few motors without controllers and am trying to integrate them with Home Assistant and Bradlink RF remote. Specifically, I'm searching for a way to generate codes for the Up, Down, Stop, and the "Set" button functions to configure curtain limits.
Any insights or guidance would be immensely appreciated. Thank you so much in advance!
@Kokosnoot good solution. I remember the discussion in the early days of MySensors. I've powered the radio's for most of my sensors from the 3.3v regulator on the arduino board and for me that works perfect. But for my latest designs I decided to add a separate ams regulator for my radio's like the guys suggested in the beginning. Because you basically want the on board regulator to power the mcu only.
