Can't receive parent answer
    Trying to integrate a basic node but it seems it isn't "hearing" the GW.
    It boots up nicely, starts the signing backend and radio encryption. Then, it tries to find a parent, the gateway answers but it seems it isn't "heard" by the node.
    The node is 2m away from the gateway, I've tried different RFM69HW modules and different PCBs (slim node PCB).
    The node is a slimnode with internal 8MHz clock. Other nodes are working fine with the GW.
    Any idea what can be wrong?
     __  __       ____
            |___/                      2.3.2
    16 MCO:BGN:INIT NODE,CP=RPNNAS-X,FQ=8,REL=255,VER=2.3.2
    40 SGN:PER:OK
    75 SGN:INI:BND OK
    77 TSM:INIT
    79 TSF:WUR:MS=0
    81 TSM:INIT:TSP OK
    83 TSM:INIT:STATID=34
    86 TSF:SID:OK,ID=34
    88 TSM:FPAR
    90 SGN:SGN:NREQ=255
    2095 ?TSF:MSG:SEND,34-34-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4102 !TSM:FPAR:NO REPLY
    4104 TSM:FPAR
    4106 SGN:SGN:NREQ=255
    6109 ?TSF:MSG:SEND,34-34-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8116 !TSM:FPAR:NO REPLY
    8118 TSM:FPAR
    8120 SGN:SGN:NREQ=255
    10123 ?TSF:MSG:SEND,34-34-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    12130 !TSM:FPAR:NO REPLY
    12132 TSM:FPAR
    12134 SGN:SGN:NREQ=255
    14139 ?TSF:MSG:SEND,34-34-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    16146 !TSM:FPAR:FAIL
    16148 TSM:FAIL:CNT=1
    16150 TSM:FAIL:DIS
    16152 TSF:TDI:TSL
    26155 TSM:FAIL:RE-INIT
    26157 TSM:INIT
    26159 TSM:INIT:TSP OK
    26161 TSM:INIT:STATID=34
    26165 TSF:SID:OK,ID=34
    26167 TSM:FPAR
    26169 SGN:SGN:NREQ=255
    28174 ?TSF:MSG:SEND,34-34-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    30181 !TSM:FPAR:NO REPLY
    30183 TSM:FPAR
    30185 SGN:SGN:NREQ=255
    32190 ?TSF:MSG:SEND,34-34-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    34197 !TSM:FPAR:NO REPLY
    34199 TSM:FPAR
    34201 SGN:SGN:NREQ=255
    36206 ?TSF:MSG:SEND,34-34-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    38213 !TSM:FPAR:NO REPLY
    Dec 06 19:28:25 DEBUG TSF:MSG:READ,34-34-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Dec 06 19:28:25 DEBUG TSF:MSG:BC
    Dec 06 19:28:25 DEBUG TSF:MSG:FPAR REQ,ID=34
    Dec 06 19:28:25 DEBUG TSF:CKU:OK,FCTRL
    Dec 06 19:28:25 DEBUG TSF:MSG:GWL OK
    Dec 06 19:28:26 DEBUG SGN:SGN:NREQ=34
    Dec 06 19:28:30 DEBUG !TSF:MSG:SEND,0-0-34-34,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Dec 06 19:28:33 DEBUG TSF:MSG:READ,34-34-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Dec 06 19:28:33 DEBUG TSF:MSG:BC
    Dec 06 19:28:33 DEBUG TSF:MSG:FPAR REQ,ID=34
    Dec 06 19:28:33 DEBUG TSF:CKU:OK,FCTRL
    Dec 06 19:28:33 DEBUG TSF:MSG:GWL OK
    Dec 06 19:28:34 DEBUG SGN:SGN:NREQ=34
    Dec 06 19:28:38 DEBUG !TSF:MSG:SEND,0-0-34-34,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    #define MY_DEBUG //!< Enable debug prints to serial monitor
    // RADIO STUFF
    #define MY_RADIO_RFM69 //!< RFM69 radio driver
    #define MY_RFM69_NEW_DRIVER
    #define MY_RFM69_FREQUENCY RFM69_433MHZ
    #define MY_IS_RFM69HW
    #define MY_RFM69_ENABLE_ENCRYPTION
    // SIGNING STUFF
    // Select soft/hardware signing method
    #define MY_SIGNING_SOFT //!< Software signing
    //#define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
    // Enable node whitelisting
    //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId =
    #define MY_SIGNING_REQUEST_SIGNATURES //!< destination node signs all messages sent to this node
    //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 //!< Unconnected analog pin for random seed
    // SETTINGS FOR MY_SIGNING_ATSHA204
    #define MY_SIGNING_ATSHA204_PIN 17 //!< A3 - pin where ATSHA204 is attached
    #define MY_DEBUG_VERBOSE_SIGNING //!< Enable signing related debug prints to serial monitor
    #define MY_NODE_ID 34
    #define LOCK_1  3     //!< Arduino Digital I/O pin number for first lock (second on pin+1 etc)
    #define NOF_LOCKS 2   //!< Total number of attached locks
    #define LOCK_LOCK 1   //!< GPIO value to write to lock attached lock
    #define LOCK_UNLOCK 0 //!< GPIO value to write to unlock attached lock
    	for (int lock=1, pin=LOCK_1; lock<=NOF_LOCKS; lock++, pin++) {
    		// Set lock pins in output mode
    		pinMode(pin, OUTPUT);
    		// Set lock to last known state (using eeprom storage)
    		digitalWrite(pin, loadState(lock)?LOCK_LOCK:LOCK_UNLOCK);
    	sendSketchInfo("Secure Lock", "1.0");
    	// Fetch lock status
    		// Register all locks to gw (they will be created as child devices)
    		present(lock, S_LOCK, "SecureActuator", false);
    /** @brief Sketch execution code */
     * @brief Incoming message handler
     * @param message The message to handle.
    	// And echoed messages are not accepted as control messages
    	if (message.getType()==V_LOCK_STATUS && message.getSensor()<=NOF_LOCKS && !message.isEcho()) {
    		// Change relay state
    		digitalWrite(message.getSensor()-1+LOCK_1, message.getBool()?LOCK_LOCK:LOCK_UNLOCK);
    		// Store state in eeprom
    		saveState(message.getSensor(), message.getBool());
    		Serial.print("****\n\nIncoming change for lock:");
    		Serial.print(message.getSensor());
        Serial.print("\n\n****\n");
  • @joaoabs I might not have been clear in the other thread (https://forum.mysensors.org/topic/11465).
    Slim Node does not route RFM69-signal DIO0 (interrupt) to Arduino-pin D2 (INT0) (at least PCB version 1.4).
    Have you added a trace for this signal?
  • @frits I think you are right!
    I admit initially I didn't thought it could be that because I have a slim node working 100%, but after your comment, I checked it and there is in fact a shunt between INT0 and DIO0 (I must have done it last year or so and didn't remember). The other nodes I've been trying don't have it, so that's likely the case.
    Maybe the slim node page could have some reference to this?
    I'll solder some shunts and will re-try this evening, but I'm sure that was the problem.
    My slim nodes PCB's are red, but were ordered in 2018. Not sure what PCB release they are, though.
    Thank you very much!
  • @joaoabs said in Can't receive parent answer:
    I totally agree, the IRQ line should be routed, also for nrf24 modules. Could you propose this in the slimnode maker's thread?
