Starting my PC with a 3.3v arduino pro mini?
    I'd like to start my PC using an Arduino Pro Mini (3.3v) but I am not sure how to hook it up.
    There are a lot of tutorials (if you include esp8266 devices) but I am not sure which parts I exactly need. In essence I need to pull the power pin high that is connected to the power button (if I understood correctly).
    So on my mainboard (Gigabyte Aorus B450M) that means I connect RES+ to a pin on my arduino and RES- to GND, right?
    There is a 3.3v pin on the mainboard (schematic), can I connect the arduino to that pin to power it?
    And the most important question: Do I need any other parts? Is the voltage higher on RES+? Does that mean it can fry my arduino?
    And in case the question comes up: I can't use wol because I disconnect the PC from power when off. That is apparently against the wol specs and only works in a few cases (of which my mainboard apparently isn't one).
    Thanks for any help!
  • Thank you. It seems I have some groundwork to do and learn how to read the schematics 😄 That hasn't been necessary until now. I'll do that and come back here when I understand enough
  • So I think I understand the main part of your drawing: The optocoupler keeps the Arduino circuit separate from the mainboard circuit to prevent a short. The resistor is for the diode inside the optocoupler.
    There are a few things about your drawing that I don't understand:
    1. Why is there a 5V powerline with a diode?
    2. What does the MB stand for? Mainboard
    3. Why are there two connection points from the Mainboard? Is one reset?
    I tried my first Fritzing to make sense of this and to show how I would design the connections (doesn't mean it's right).
    PW+ and PW- are the pins from the schematic in the first post. , 3,3V and GND are available on another set of pins on the mainboard. Would this work?
  • @kiesel Great work! 🙂
    1. 5V connected through diode to protect of polarity revers
    2. MB = Motherboard, you right
    3. First need to connect power button from front panel, second to connect to "Power Switch" on motherboard. This allows power on both from power button and Arduino.
    You disign is absolutely working!
  • @cabat
    Cool, thank you for your help!
    Should I use a diode between 3.3v and GND too? And do I need a resistor in the mainboard-side of the schematic? Some people used them to protect the optocoupler from high current but I guess there isn't a high current when the power button is pressed?
  • @kiesel I don't undestand - why you want to use diode between 3.3V and GND?
    About resistor on the mainboard side - i don't use it and all works fine 🙂
  • @cabat
    To protect from polarity reversing, like you did in your sketch. Sorry if that's a stupid question!
  • @cabat
    Ah, ok, I get it now. The diode protects me from wiring this up with POWER and GND switched. So I would use it like this
    But I guess I can't because of the voltage drop. I think that's out of specs for the PC817. And anyway there is a very low chance that I will wiring this side of the schematic up wrong.
    I guess I was just confused by the lower part of your drawing.
    Thank you VERY much for your patience! I'll supply pictures when I have this hooked up in the hopes they will help others.
    Have a nice weekend!
  • @kiesel Sorry friend, I guess I confused you a little ..
    The diode is needed so that, when powered from the contacts on the motherboard with 5V, it does not damage my arduino, that's all 🙂
    Have a nice weekend to!
  • @cabat
    If I wanted this protection where would I put it in my schematic? 🙂
    Between ground an 3.3v?
    /edit: no between the arduino and 3.3v from the Mainboard, right?
  • @kiesel Yes, you rigth - between 3.3V on mainboard and VCC of arduino!
    @kiesel said in Starting my PC with a 3.3v arduino pro mini?:
    It wouldn't be logic to put it between the opto coupler and the Arduino pin. Because it's purpose is to separate the 2 circuits. Hence protecting both circuits. At least that's how I understand how Opto Couplers work. The opto coupler connects 2 circuits trough light no physical contact.
  • So, I finally got this done and it works just like I want it to. I used my initial schematics (plus radio, of course) and this code:
     * Version 1.0: Yveaux
     * sensor using a Si7021 sensor.
     * http://www.mysensors.org/build/humiditySi7021
    // Enable debug prints
    #define MY_OWN_DEBUG
    #ifndef MY_OWN_DEBUG //disable serial in production compile, potentially saves few uA in sleep mode
         #define MY_DISABLED_SERIAL
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define MY_RFM69_NEW_DRIVER
    #define MY_NODE_ID 5
    #define CHILD_ID_TXT 0
    #define OUTPIN 8
    #define SKETCH_NAME "media_pc_switch"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    static bool metric = true;
    MyMessage msgTxt(CHILD_ID_TXT, V_TEXT);
      present(CHILD_ID_TXT, S_INFO);
       pinMode(OUTPIN, OUTPUT);    //
       digitalWrite(OUTPIN, LOW);
       #ifdef MY_OWN_DEBUG
          Serial.print("Starting: ");
      send(msgTxt.set("Ready"));
    void receive(const MyMessage &msg)
      uint16_t ms;
      Serial.print("Received a message: ");
      Serial.println(msg.getString());
      send(msgTxt.set(msg.getString()));
      ms = msg.getUInt();
      if (ms > 10000 || ms < 1){return;}
      send(msgTxt.set("Received"));
      Serial.println("Pulling pin high");
      digitalWrite(OUTPIN, HIGH);
      Serial.print("Waiting for "); Serial.println(ms);
      delay(ms);
      Serial.println("Switching off");
      Serial.println("Delaying a few seconds to ignore message resends.");
      send(msgTxt.set("Sleeping"));
      delay(10000);
    Now I can use this sequence in HA to start my PC even when the power was cut:
    wzimmer_ms_start_htpc:
      alias: Use mysensors node 5 to start the mediapc in the living room
      sequence:
        repeat:
          sequence:
            #don't run if htpc already running
              - condition: not
                conditions:
                - condition: state
                  entity_id: binary_sensor.htpc
                  state: 'on'
            #send start signal to mysensors
              - service: notify.mysensors
                data:
                  target: "media_pc_switch 5 0"
                  message: 1000
            #wait for timeout seconds whether a message has been received
              - wait_for_trigger:
                - platform: state
                  entity_id: sensor.media_pc_switch_5_0
                  to: "Received"
                timeout: '00:00:04'
          until:
              # Did it work?
              - condition: state
                state: Received
    Thank you, @cabat for your help and your patience!!! 🙂
