node-red-contrib-mysensors release thread
    An almost complete rewrite of the node-red-contrib-mysensors has been released.
    What have been done this time is:
    • Rewritten in typescript
    • a controller node is added, allowing node-red to hand out node id's to a mysensors network.
    The move to typescript should enable more test of the software, as I now have a compile time check, and also implemented the first unit tests of the code.
    Please note that the mysencdec node has now been removed.. If you still use it, then you should remove it before upgrading the package, or node-red might stop the flows, as it is missing nodes.
    Please use the issue tracker on github, if you find some undocumented "features" 🙂
    Btw. the only really breaking change from the 1.x series from a user perspective, is that the mysdecenc is gone.
    All other nodes should perform as the old version.
    Bugger.. I found an issue myself that sneaked past my typescript compile checks..
    So expect an update later today..
    Release 2.0.1 is out, fixing the bugs that I discovered earlier.. Thought that I had everything covered, and even did some regression testing in a dummy node-red install.. But missed some important details, that unfortunately can't be covered by the testframework at the moment (perhaps because my lack of understanding of mocha / chai)
    Released 2.1.0 today,
    Improved debug node, where I ported the parser from https://mysensors.org/build/parser.
    The controller node now also logs the last repeater a given node has used, to reach the gateway.
    Some minor details here and ther in the ui have been updated as well.
    Linting of the typescript files have been added using tslint.
    Released 2.2.0 today
    the mysdecode node now also decodes messageType and sensorType to string values, in the node message it emits.
    The emitted message now contains the following propperties:
    topicRoot: string; // Only used if it is decoding from a mqtt topic
    nodeId: number;
    childSensorId: number;
    messageType: mysensor_command;
    messageTypeStr: string;
    ack: 0|1;
    subType: mysensor_data| mysensor_internal| mysensor_sensor| mysensor_stream;
    subTypeStr: string;
    origin: MsgOrigin; // This is an indicator for where the message was received from (mqtt, serial or "undefined")
    Also did a lot of cleanup, set stricter rules in the typescript compiler etc. to avoid common mistakes.
    Released 3.0.0
    Breaking change is in the controller node, which now use a migration feature in the sqlite lilbrary that I use. It makes it easier to update database schema later on, as I can now create "patches" for the schema, that is included in the library. The database needs to be re-created from scratch, as the migration part has some extra tables to keep track of the schema version.
    Also documentation has been received an overhaul, correcting a few spelling errors, and a lot of formatting.
  • Awesome work! I was trying to create a bridge between a MQTT gateway and a Serial gateway (over TCP) so I could use firmware upload function of the MySController. However for some reason it seems to only work one way. I can send commands from the MySController to MQTTGateway but nothing is being received on the MySController side when data is sent from MQTT
    This is my flow, would be awesome if someone would spot the issue...
    [{"id":"e6a66581.c16ec8","type":"mysdecode","z":"229ed636.c3ff2a","name":"","mqtt":false,"x":450,"y":460,"wires":[["58ac0291.04974c","a3ba801.a63be8"]]},{"id":"eb5b52a1.29566","type":"tcp in","z":"229ed636.c3ff2a","name":"","server":"server","host":"","port":"5003","datamode":"stream","datatype":"utf8","newline":"\\n","topic":"","base64":false,"x":270,"y":460,"wires":[["e6a66581.c16ec8","ab0f8982.8a9588","78954899.688c28"]]},{"id":"58ac0291.04974c","type":"debug","z":"229ed636.c3ff2a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":510,"y":560,"wires":[]},{"id":"a3ba801.a63be8","type":"mysencode","z":"229ed636.c3ff2a","name":"","mqtt":true,"mqtttopic":"myGreenhouse-in","x":1040,"y":200,"wires":[["8d64662e.fbada8","595543a3.f537cc"]]},{"id":"ab0f8982.8a9588","type":"globalGetSet","z":"229ed636.c3ff2a","name":"Save Session","topic":"","context":"msg","variable":"_session","outContext":"global","outVar":"_session","x":440,"y":420,"wires":[[]]},{"id":"78954899.688c28","type":"debug","z":"229ed636.c3ff2a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":500,"y":720,"wires":[]},{"id":"cdf94190.9fb8e","type":"myscontroler","z":"229ed636.c3ff2a","database":"5fdbb924.88fb48","name":"","handleid":true,"x":770,"y":200,"wires":[["a3ba801.a63be8"]]},{"id":"8d64662e.fbada8","type":"mqtt out","z":"229ed636.c3ff2a","name":"","topic":"","qos":"","retain":"","broker":"1920bc44.5c3304","x":1270,"y":200,"wires":[]},{"id":"595543a3.f537cc","type":"debug","z":"229ed636.c3ff2a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1270,"y":260,"wires":[]},{"id":"c800320f.2a2b","type":"mysdecode","z":"229ed636.c3ff2a","name":"","mqtt":true,"x":560,"y":200,"wires":[["cdf94190.9fb8e","aa22f275.cc8ec"]]},{"id":"2222f84e.56c4e8","type":"mqtt in","z":"229ed636.c3ff2a","name":"","topic":"myGreenhouse-out/#","qos":"2","broker":"1920bc44.5c3304","x":320,"y":200,"wires":[["41588b7e.b61114","c800320f.2a2b"]]},{"id":"aa22f275.cc8ec","type":"switch","z":"229ed636.c3ff2a","name":"","property":"nodeId","propertyType":"msg","rules":[{"t":"eq","v":"203","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":570,"y":360,"wires":[[],["ea8a0d53.8140b"]]},{"id":"41588b7e.b61114","type":"debug","z":"229ed636.c3ff2a","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":530,"y":260,"wires":[]},{"id":"ea8a0d53.8140b","type":"mysencode","z":"229ed636.c3ff2a","name":"","mqtt":false,"mqtttopic":"","x":870,"y":420,"wires":[["2036eda1.dd8bf2","ad5ca8e4.1c4f68"]]},{"id":"2036eda1.dd8bf2","type":"debug","z":"229ed636.c3ff2a","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1030,"y":460,"wires":[]},{"id":"ad5ca8e4.1c4f68","type":"globalGetSet","z":"229ed636.c3ff2a","name":"Load Session","topic":"","context":"global","variable":"_session","outContext":"msg","outVar":"_session","x":1060,"y":420,"wires":[["cb6d084b.432238","f99fd97d.5f73c8"]]},{"id":"cb6d084b.432238","type":"tcp out","z":"229ed636.c3ff2a","host":"localhost","port":"5003","beserver":"reply","base64":true,"end":false,"name":"","x":1250,"y":420,"wires":[]},{"id":"f99fd97d.5f73c8","type":"debug","z":"229ed636.c3ff2a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1240,"y":480,"wires":[]},{"id":"5fdbb924.88fb48","type":"mysensorsdb","z":"","name":"Device DB","file":"sqlite"},{"id":"1920bc44.5c3304","type":"mqtt-broker","z":"","name":"LocalNew","broker":"localhost","port":"8883","tls":"","clientid":"Node-RedHome","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":""}]```
    @Thucar
    The MysController node doesn't pass any messages through it, it only emits messages if it receives a node ID request.
    Also, (depending on your version) then it is not needed to pass messages through mysdecode / mysencode before / after the myscontroller node. It understands mqtt / serial protocol directly. (this has been a feature since 2.2.0)
    / Thomas
    New release : 3.1.0
    Added features:
    Controller now supports the following messages:
    • I_TIME is replied with a unix timestamp corrected with local timezone offset
    • I_CONFIG, responds with Metric / Imperial setting
    Minor documentation updates to other nodes as well.
    Bugfix release is out: 3.1.1
    @mirodin found an issue with assigning node ID's with the controller node, which should be addressed with this release.
    Basically I tried to assign nodeid 0 to nodes, and it never went out to the nodes. At the same time, the controller never got node ID 0 marked as used, as it filtered away all packages where the nodeId was 0, null or undefined, due to a missing nullcheck.
    New release: 3.2.0
    I added the possibility to do database lookups in the decode node, which is used to add info about sensor type to the mysensors messages in node-red. The info is gathered during node presentations
    An example, from a node that report door state from the chicken coop:
    topic: "mys-in/21/5/1/0/16"
    payload: "1"
    qos: 2
    retain: false
    _msgid: "ddf9aef9.9a21a"
    topicRoot: "mys-in"
    nodeId: 21
    childSensorId: 5
    messageType: 1
    ack: 0
    subType: 16
    origin: 2
    messageTypeStr: "C_SET"
    subTypeStr: "V_TRIPPED"
    sensorTypeStr: "S_DOOR"
    As seen above, the sensorTypeStr is added.
    great work. I tried to install it, without success. First I installed node-red und npm. As operation system I use openHABian v1.4.1.
    This is the output:
    npm install node-red-contrib-mysensors
    (node:4359) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
    npm WARN package.json node-red-project@0.0.1 No repository field.
    npm WARN package.json node-red-project@0.0.1 No README data
    npm WARN package.json node-red-project@0.0.1 No license field.
    npm WARN package.json copy-descriptor@0.1.1 No README data
    npm WARN package.json log-ok@0.1.1 No README data
    npm WARN package.json log-utils@0.2.1 No README data
    npm WARN package.json object-copy@0.1.0 No README data
    npm WARN package.json static-extend@0.1.2 No README data
    npm WARN package.json ansi-wrap@0.1.0 license should be a valid SPDX license expression
    npm WARN package.json events@1.1.1 events is also the name of a node core module.
    npm WARN package.json format@0.2.2 No license field.
    npm WARN package.json jsonify@0.0.0 license should be a valid SPDX license expression
    npm WARN package.json string_decoder@1.1.1 string_decoder is also the name of a node core module.
    npm ERR! Error: Method Not Allowed
    npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
    npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
    npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
    npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
    npm ERR! If you need help, you may report this *entire* log,
    npm ERR! including the npm and node versions, at:
    npm ERR!     <http://github.com/npm/npm/issues>
    npm ERR! System Linux 4.14.52+
    npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "node-red-contrib-mysensors"
    npm ERR! cwd /home/openhabian/.node-red
    npm ERR! node -v v8.11.1
    npm ERR! npm -v 1.4.21
    npm ERR! code E405
    npm ERR!
    npm ERR! Additional logging details can be found in:
    npm ERR!     /home/openhabian/.node-red/npm-debug.log
    npm ERR! not ok code 0
    @Maschler
    Which version of node-red, nodejs and npm are you using?
    And what does /home/openhabian/.node-red/npm-debug.log tell you?
  • hey @tbowmo
    I found my mistake in /home/openhabian/.npm/_logs
    I had to use sudo ....
    But I have another Question. Do I need an Arduino in-between or can I connect the modul directly to the Raspberry pi like it is done here.
    Thank you very much for your help!! 🙂
    @Maschler
    It's not necessary to have an arduino to make the gateway. You can configure the linux variant as a MQTT gateway (which I recommend), and then have mosquitto as a broker and nodered listening for mqtt messages.
    https://www.mysensors.org/build/raspberry#configure
    New release: 3.2.1
    It's a minor update, as @pansen discovered that node IDs wasn't shown correctly in the controller view.
    Also behind the scenes a couple of module dependencies have been updated to mitigate a couple of (low-risk) security issues that has been reported against some of the npm packages that was used.
    Today I have released version 3.3.0
    New in this release is that battery level messages is now stored in the database by myscontroller, and are also shown in the table of mysensors nodes, when you open the myscontroller node.
    Version 3.3.1 is now released
    A bug with the Encapsulate node was reported, where child sensor types didn't have the correct IDs. Also updated dependencies as a few where reported to have security vulnerabilities.
  • @tbowmo I feel a little confused on how to use this node-red plugin. Is this something like "a node-red plug-in framework", but you have to invent the wheel yourself kind of solution?
    I have just opted for the Home assistant (hass.io) system as the hub for my home automation.
    Home assistant, according to documentation, is mysensors enabled, but compared to other add-ons, like zigbee2mqtt, zwave2mqtt, the mysensors implementaton is like a child's tricycle, while the others are sports cars.
    The zigbee2mqtt, you just turn on and off the IKEA light buld six times and it is added, whereas the mysensors you have to type configuration files and have limited graphical administration possibilities.
    So I thought, what if the mysensors could talk to mqtt and get into home assistant that way (my gateway is serial).
    I understand the node-red implementation enables you to decode the messages as you like, but do I really need to invent how it should decode it and send it to mqtt?
    Are there any ready to use implementations of the plug.in?
    Could it support "auto discovery"? So you just have to turn the device on, and voila, it appears in home assistant (if mqtt auto discovery is turned on)?
    @magpern this module is more if you want to only use nodered for your home automation, without Hass.io or the likes.
    Most of the standard controllers (domoticz, openhab, home assistant etc) are all able to handle the mysensors network directly (more or less), and handle the device registration for you.
    My module for nodered is implementing a crude controller, that only handles out node id's to the mysensors network, when asked for, and then leaves everything else up to your imagination, for how to wire things together behind the scenes.
    That being said, if you only need to convert your serial mysensors gateway into mqtt, I do have a small python script that I use for that particular case, as my nodered instance can't access the serial Ports from my docker swarm setup. So this script is running besides everything else. I can post it tomorrow if interested, as my pc is closed for the night now.
    / Thomas
  • @tbowmo said in node-red-contrib-mysensors release thread:
    / Thomas
    I'd love to try the script! /Magnus
    @magpern
    It's more or less the script below, I removed some stuff from my utility meter, that I also handles in my script (but isn't needed for just mysensors).
    #!/usr/bin/python3
    import serial
    import paho.mqtt.client as mqtt
    import time
    mysensors = serial.serial_for_url('/dev/ttyNRF24', 115200, rtscts=0, timeout=1000)
    mysensors.isOpen()
    mqtt_connect = False
    def mqtt_reception(client, userdata, msg):
        payload = msg.payload.decode("ascii")
        topic = msg.topic.split('/')
        topic.remove('mys-out')
        mymsg = ';'.join(topic) + ';' + payload + '\n'
        print("out <- ", mymsg)
        mysensors.write(str.encode(mymsg))
    def mqtt_connect(client, userdata, flags, rc):
        print('Connected')
        mqtt_connect = True
        client.subscribe('mys-out/#')
    def mqtt_disconnect(client, userdata, rc):
        print(rc)
    client = mqtt.Client('mys')
    client.on_connect = mqtt_connect
    client.on_message = mqtt_reception
    client.on_disconnect = mqtt_disconnect
    client.connect('192.168.1.64')
    def handle_data(data):
        print("in -> ", data)
        s = data.split(';')
        payload = s[-1]
        s.remove(payload)
        topic = 'mys-in/' + '/'.join(s)
        if mqtt_connect:
            client.publish(topic, payload.rstrip())
    if __name__ == "__main__":
        client.loop_start()
        mys_data_str = '';
        util_data_str = '';
        while (True):
            if (mysensors.inWaiting()>0):
                char = mysensors.read(1).decode('ascii')
                mys_data_str += char
                if (char == '\n'):
                    handle_data(mys_data_str)
                    mys_data_str = ''
            time.sleep(0.01)
  • Hi there all,
    I just try to install the node in my Node-Red (Home Assistant)
    and I got error:
    2021-04-30T07:18:09.293Z Install : node-red-contrib-mysensors 3.3.1
    2021-04-30T07:18:07.624Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-mysensors@3.3.1
    2021-04-30T07:18:11.638Z [err] npm WARN deprecated @types/moment-timezone@0.5.30: This is a stub types definition. moment-timezone provides its own type definitions, so you do not need this installed.
    2021-04-30T07:18:14.813Z [err] npm WARN
    2021-04-30T07:18:14.813Z [err]  deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
    2021-04-30T07:18:19.176Z [out]
    2021-04-30T07:18:19.176Z [out] > sqlite3@4.2.0 install /config/node-red/node_modules/sqlite3
    2021-04-30T07:18:19.176Z [out] > node-pre-gyp install --fallback-to-build
    2021-04-30T07:18:19.551Z [err] node-pre-gyp
    2021-04-30T07:18:19.552Z [err]  WARN Using request for node-pre-gyp https download
    2021-04-30T07:18:20.511Z [err] node-pre-gyp
    2021-04-30T07:18:20.512Z [err]  WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.2.0/node-v83-linux-x64.tar.gz
    2021-04-30T07:18:20.512Z [err] node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.2.0 and node@14.16.1 (node-v83 ABI, musl) (falling back to source compile with node-gyp)
    2021-04-30T07:18:21.714Z [err] gyp
    2021-04-30T07:18:21.715Z [err]
    2021-04-30T07:18:21.715Z [err] ERR!
    2021-04-30T07:18:21.716Z [err] build error
    2021-04-30T07:18:21.716Z [err] gyp
    2021-04-30T07:18:21.717Z [err]
    2021-04-30T07:18:21.717Z [err] ERR!
    2021-04-30T07:18:21.717Z [err] stack
    2021-04-30T07:18:21.717Z [err]  Error: not found: make
    2021-04-30T07:18:21.717Z [err] gyp
    2021-04-30T07:18:21.717Z [err]      at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
    2021-04-30T07:18:21.718Z [err] gyp
    2021-04-30T07:18:21.718Z [err] ERR!
    2021-04-30T07:18:21.718Z [err] stack
    2021-04-30T07:18:21.718Z [err]      at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
    2021-04-30T07:18:21.719Z [err]      at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
    2021-04-30T07:18:21.719Z [err] gyp
    2021-04-30T07:18:21.719Z [err] ERR!
    2021-04-30T07:18:21.719Z [err] stack
    2021-04-30T07:18:21.719Z [err]      at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
    2021-04-30T07:18:21.720Z [err]
    2021-04-30T07:18:21.720Z [err] stack
    2021-04-30T07:18:21.720Z [err]      at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
    2021-04-30T07:18:21.720Z [err] gyp
    2021-04-30T07:18:21.720Z [err] ERR!
    2021-04-30T07:18:21.720Z [err]      at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
    2021-04-30T07:18:21.721Z [err] ERR!
    2021-04-30T07:18:21.721Z [err] stack
    2021-04-30T07:18:21.721Z [err]      at FSReqCallback.oncomplete (fs.js:183:21)
    2021-04-30T07:18:21.721Z [err] gyp
    2021-04-30T07:18:21.721Z [err] System
    2021-04-30T07:18:21.722Z [err]  Linux 5.0.0-27-generic
    2021-04-30T07:18:21.722Z [err] gyp
    2021-04-30T07:18:21.722Z [err] ERR!
    2021-04-30T07:18:21.722Z [err] command
    2021-04-30T07:18:21.722Z [err]  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
    2021-04-30T07:18:21.723Z [err]
    2021-04-30T07:18:21.723Z [err] cwd
    2021-04-30T07:18:21.723Z [err]  /config/node-red/node_modules/sqlite3
    2021-04-30T07:18:21.723Z [err] gyp
    2021-04-30T07:18:21.723Z [err] ERR!
    2021-04-30T07:18:21.723Z [err] node -v
    2021-04-30T07:18:21.724Z [err]  v14.16.1
    2021-04-30T07:18:21.724Z [err] gyp
    2021-04-30T07:18:21.724Z [err] ERR!
    2021-04-30T07:18:21.724Z [err] node-gyp -v
    2021-04-30T07:18:21.725Z [err]  v5.1.0
    2021-04-30T07:18:21.725Z [err] gyp
    2021-04-30T07:18:21.725Z [err] ERR!
    2021-04-30T07:18:21.725Z [err] not ok
    2021-04-30T07:18:21.730Z [err] node-pre-gyp
    2021-04-30T07:18:21.730Z [err]  ERR! build error
    2021-04-30T07:18:21.731Z [err] node-pre-gyp ERR!
    2021-04-30T07:18:21.731Z [err] stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
    2021-04-30T07:18:21.731Z [err] node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/config/node-red/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    2021-04-30T07:18:21.731Z [err] ERR! stack     at ChildProcess.emit (events.js:315:20)
    2021-04-30T07:18:21.731Z [err] stack     at maybeClose (internal/child_process.js:1048:16)
    2021-04-30T07:18:21.731Z [err] node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
    2021-04-30T07:18:21.731Z [err] System Linux 5.0.0-27-generic
    2021-04-30T07:18:21.731Z [err]  ERR! command "/usr/bin/node" "/config/node-red/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    2021-04-30T07:18:21.731Z [err]  ERR! cwd /config/node-red/node_modules/sqlite3
    2021-04-30T07:18:21.731Z [err]  ERR! node -v v14.16.1
    2021-04-30T07:18:21.732Z [err] node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    2021-04-30T07:18:21.732Z [err] node-pre-gyp ERR! not ok
    2021-04-30T07:18:21.732Z [out] Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
    2021-04-30T07:18:22.158Z [err] npm ERR!
    2021-04-30T07:18:22.158Z [err]  code ELIFECYCLE
    2021-04-30T07:18:22.158Z [err] npm ERR! errno 1
    2021-04-30T07:18:22.164Z [err] npm ERR!
    2021-04-30T07:18:22.164Z [err]  sqlite3@4.2.0 install: `node-pre-gyp install --fallback-to-build`
    2021-04-30T07:18:22.164Z [err] npm ERR! Exit status 1
    2021-04-30T07:18:22.164Z [err] ERR! Failed at the sqlite3@4.2.0 install script.
    2021-04-30T07:18:22.164Z [err] npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    2021-04-30T07:18:22.178Z [err]
    2021-04-30T07:18:22.178Z [err] npm ERR! A complete log of this run can be found in:
    2021-04-30T07:18:22.178Z [err] npm ERR!     /root/.npm/_logs/2021-04-30T07_18_22_169Z-debug.log
    2021-04-30T07:18:22.201Z rc=1
    Is there still possibility to install it please ?
    Thanks a lot
    Denis
    NPM is trying to build sqlite, because it cannot find a suitable pre-built one for your architecture, it fails because you do not have the needed tools installed for this on your machine.
    Might help if you install build-essentials (sudo apt-get install build-essentials, assuming you are on a debian like install)
    I currently use it on node-red 1.1.2, without problems. But I'm using plain node-red in a docker container..
    Thanks for the answer.
    I have now Node-Red 1.3.3 under Home Assistant installed.
    But I must search on net how can I install the build-essentials from the docker console.
    Do you know if is there some other node that I can install from the palette that maybe incluse the build-essentials please ?
    Thanks again
    Denis
    What I did way back when I got it up and running in docker, was to jump into the container shell, and install the package manually (So you are using the same node.js version that node-red is using).
    You could also (in that docker shell) do a apt install (given that it builds upon a debian based image).
    something in the line of:
    $ docker exec -it <id of container running node-red> /bin/bash
    # now you are in docker..
    $ apt install build-essentials
    $ cd <to your node-red data directory>
    $ npm install node-red-contrib-mysensors
    $ exit
    Above is taken purely from what I think is the right commands, as I have not tried working with home-assistant for a while.
    I think I have not the apt inside of Node_red docker.
    Can I install it from outside in this case.
    Sorry but I'm very beginner so I need some basic info in this case.
    Thanks a lot again
    Denis
  • In Home Assistant you have the Node Red configuration (under supervisor). There you can add packages to be installed under system_packages: []
  • @electrik said in node-red-contrib-mysensors release thread:
    system_packages
    I have try to insert in the system_packages like this:
    But it give me errore when start:
    I think I'll make some translate node by my self
    Thanks a lot again
    Denis
  • Shouldn't it be
    build-essentials
    build-essentials
    I try it but it give me same errore.
    I think that that package must be here in this link like the error log tell
    Do you have Home Assistant installed ? if yes... do you have this "essentials" installed also ?
    Thanks again
    Denis
  • Yes I have home assistant but don't have the build essentials. I did some more reading and it seems like a package of build tools. Perhaps @tbowmo knows which specific one is needed?
  • No problem @electrik I have already set the Node-Red to translate my node sensor in human leggibile data 🙂
    And now I can see it like this:
    All ok and thanks a lot for the help
    Denis
    @electrik
    When I said that you needed the package "build-essentials" I assumed that you where running on a barebone ubuntu distribution, and not in docker. This complicates things, but it seems that others do have the same issue with node-red and sqlite on home-assistant forum.
    One solution is given here: https://community.home-assistant.io/t/how-to-get-access-to-sqlite-on-hassio/241439/3
    As said earlier I do not know anything about the internals in home-assistant and their specific docker / node-red setup.
    Thanks a lot @tbowmo
    Denis
  • 6
34
