Is there a timing issue with "faster" platforms?
  • Hi All,
    Thermostat node NOW 2.3.2 - teensy 3.2
    Gateway 2.2.0 - uno clone
    Controller Domoticz, recent build
    I have posted previously with woes getting requesting data or otherwise getting data INTO a particular node, my thermostat.
    This thermostat is software Signed, and in another post I was asking about where signing is actually used, because lots of messages seemed to NOT be signed.
    post here
    I also had issues getting the teensy working with the radio.
    teensy post
    Which I eventually solved by dropping the frequency of the processor to 48Mhz.
    It occurred to me mulling this over in bed, that I had read some older posts about timings relating to a M0 processor, and that how it was resolved by introducing a delay(10) into the core code somewhere, and it was agreed that the issue was related to "timing".
    I thought I would see if I could lower the teensy speed further, so I have, and the results are startling.
    The logs are below, but long story short, running at 48Mhz (the speed at which I could get the RFM69 to work), Getting to the same point in the sketch, where I send the "Boot time" to the controller takes 85878ms
    The same sketch, BUT slowing the processor to 24Mhz takes 30046ms
    And yes I definitely have that the right way round.
    Additionally the node now mostly gets the data sent to it or requested by it.
    You can see this to an extent in the logs, where I request the time (looped 5 times in setup) At the faster speed, the time is almost never received until later in the sketch, and after certain "keys" are successfully exchanged.
    I hope that one or more of the core team will read this, and have some Ideas.
    This post is split, as I can't post over 32kbytes of text
    Kind regards
    Nigel
  • 24Mhz Log
    1304 ?TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2096 TSF:MSG:READ,0-0-10,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    2096 SGN:SKP:MSG CMD=3,TYPE=8
    2096 TSF:MSG:FPAR OK,ID=0,D=1
    2510 TSF:MSG:READ,4-4-10,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    2510 SGN:SKP:MSG CMD=3,TYPE=8
    3306 TSM:FPAR:OK
    3306 TSM:ID
    3306 TSM:ID:OK
    3306 TSM:UPL
    3306 SGN:SGN:NREQ=0
    3312 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    3640 TSF:MSG:READ,0-0-10,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    3640 SGN:SKP:MSG CMD=3,TYPE=25
    3640 TSF:MSG:PONG RECV,HP=1
    3640 TSM:UPL:OK
    3641 TSM:READY:ID=10,PAR=0,DIS=1
    3641 SGN:PRE:SGN REQ
    3641 SGN:PRE:WHI NREQ
    3641 SGN:SGN:NREQ=0
    3647 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
    3647 SGN:PRE:XMT,TO=0
    3648 SGN:PRE:WAIT GW
    4079 TSF:MSG:READ,0-0-10,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4079 SGN:SKP:MSG CMD=3,TYPE=15
    4079 SGN:SGN:NREQ=0
    4710 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
    4711 SGN:SGN:NREQ=0
    4834 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4905 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    4905 SGN:SKP:MSG CMD=3,TYPE=16
    4906 SGN:SGN:NREQ=0
    5226 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    5226 SGN:NCE:XMT,TO=10
    5608 TSF:MSG:READ,0-0-10,s=255,c=3,t=6,pt=0,l=1,sg=1:M
    5608 SGN:BND:NONCE=A0F7C4739126DCC8FFF8C2362FA2D4EEADF11ED4190AB1459AAAAAAAAAAAAAAA
    5610 SGN:BND:HMAC=9BE81338877EFE874F06BB1A04505380A33D70758C03AB43E6DAC26F0E56DDE0
    5610 SGN:VER:OK
    LivingRm Thermostat Present, 1.1.12
    5610 SGN:SGN:NREQ=0
    5683 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:LivingRm Thermostat
    5683 SGN:SGN:NREQ=0
    5819 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=12,pt=0,l=6,sg=0,ft=0,st=OK:1.1.12
    5820 SGN:SGN:NREQ=0
    5977 TSF:MSG:SEND,10-10-0-0,s=0,c=0,t=6,pt=0,l=16,sg=0,ft=0,st=OK:Room Temperature
    6077 SGN:SGN:NREQ=0
    7371 !TSF:MSG:SEND,10-10-0-0,s=5,c=0,t=33,pt=0,l=18,sg=0,ft=0,st=NACK:Thermostat RX RSSI
    7471 SGN:SGN:NREQ=0
    7479 TSF:MSG:SEND,10-10-0-0,s=2,c=0,t=3,pt=0,l=16,sg=0,ft=1,st=OK:Thermostat Relay
    7579 SGN:SGN:NREQ=0
    8739 TSF:MSG:SEND,10-10-0-0,s=3,c=0,t=3,pt=0,l=13,sg=0,ft=0,st=OK:Heat Override
    8840 SGN:SGN:NREQ=0
    10080 !TSF:MSG:SEND,10-10-0-0,s=7,c=0,t=6,pt=0,l=11,sg=0,ft=0,st=NACK:Who is Home
    10180 SGN:SGN:NREQ=0
    10254 TSF:MSG:SEND,10-10-0-0,s=1,c=0,t=14,pt=0,l=13,sg=0,ft=1,st=OK:Temp Setpoint
    10354 SGN:SGN:NREQ=0
    11578 !TSF:MSG:SEND,10-10-0-0,s=6,c=0,t=4,pt=0,l=11,sg=0,ft=0,st=NACK:Oil Tank PC
    11678 SGN:SGN:NREQ=0
    12902 !TSF:MSG:SEND,10-10-0-0,s=12,c=0,t=36,pt=0,l=12,sg=0,ft=1,st=NACK:Display Text
    13002 SGN:SGN:NREQ=0
    13010 TSF:MSG:SEND,10-10-0-0,s=8,c=0,t=3,pt=0,l=14,sg=0,ft=2,st=OK:SP Update Flag
    13110 SGN:SGN:NREQ=0
    14335 TSF:MSG:SEND,10-10-0-0,s=9,c=0,t=3,pt=0,l=13,sg=0,ft=0,st=OK:HotWater Flag
    14436 SGN:SGN:NREQ=0
    15672 !TSF:MSG:SEND,10-10-0-0,s=10,c=0,t=36,pt=0,l=21,sg=0,ft=0,st=NACK:Returned Display Text
    15772 SGN:SGN:NREQ=0
    16996 !TSF:MSG:SEND,10-10-0-0,s=11,c=0,t=36,pt=0,l=8,sg=0,ft=1,st=NACK:BootTime
    LivingRm Thermostat END Present, 1.1.12
    17096 MCO:REG:REQ
    17096 SGN:SGN:NREQ=0
    17102 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=2,st=OK:2
    17359 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    17360 SGN:SKP:MSG CMD=3,TYPE=16
    17360 SGN:SGN:NREQ=0
    17398 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    17399 SGN:NCE:XMT,TO=10
    17491 TSF:MSG:READ,0-0-10,s=255,c=3,t=27,pt=1,l=1,sg=1:1
    17492 SGN:BND:NONCE=81EDDA5E5C3E58FF581C825AFD692672D7C406E97307271B86AAAAAAAAAAAAAA
    17494 SGN:BND:HMAC=86BA35CDE1A83AEBD795C850A9B6DE4FAF4A311D8EDEC969DEBC8E7B000BFEF8
    17494 SGN:VER:OK
    17494 MCO:PIM:NODE REG=1
    17494 MCO:BGN:STP
    Loaded values
     :Relay output : 1
    17541 SGN:SGN:NREQ=0
    17548 TSF:MSG:SEND,10-10-0-0,s=7,c=1,t=45,pt=7,l=5,sg=0,ft=0,st=OK:0.0
    17549 SGN:SGN:NREQ=0
    17625 TSF:MSG:SEND,10-10-0-0,s=2,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
    uplink available
    17721 TSF:MSG:READ,0-0-10,s=2,c=3,t=16,pt=0,l=0,sg=1:
    17721 SGN:SKP:MSG CMD=3,TYPE=16
    17721 SGN:SGN:NREQ=0
    17760 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    17760 SGN:NCE:XMT,TO=10
    17854 TSF:MSG:READ,0-0-10,s=2,c=2,t=2,pt=0,l=1,sg=1:0
    17855 SGN:BND:NONCE=FAB0FAFA566EB33918E67D902BE5D7B7ABEFACEEBDD07D897FAAAAAAAAAAAAAA
    17857 SGN:BND:HMAC=DDDD34C0FB7050D86BE29336AF71BCBFC08DDE8DAB01133D70FB17F12358BE24
    17857 SGN:VER:OK
    REQ_Msg :2 MsgCmd:2 childID:2 Data:S/0 Data:I/ 0 Data:B/ 0
    19125 SGN:SGN:NREQ=0
    20343 !TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=NACK:0
    20343 SGN:SGN:NREQ=0
    20444 TSF:MSG:SEND,10-10-0-0,s=12,c=1,t=47,pt=0,l=8,sg=0,ft=1,st=OK:Boot ...
    REQ DISPLAYTXT
    20445 SGN:SGN:NREQ=0
    21810 !TSF:MSG:SEND,10-10-0-0,s=12,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=NACK:
    Rx Error 1
    22010 SGN:SGN:NREQ=0
    22015 TSF:MSG:SEND,10-10-0-0,s=12,c=2,t=47,pt=0,l=0,sg=0,ft=1,st=OK:
     Request OK ACK Received
    22078 TSF:MSG:READ,0-0-10,s=12,c=3,t=16,pt=0,l=0,sg=1:
    22079 SGN:SKP:MSG CMD=3,TYPE=16
    22079 SGN:SGN:NREQ=0
    22239 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    22239 SGN:NCE:XMT,TO=10
    Req PC
    22239 SGN:SGN:NREQ=0
    23583 !TSF:MSG:SEND,10-10-0-0,s=6,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=NACK:
    Rx Error 1
    23783 SGN:SGN:NREQ=0
    23788 TSF:MSG:SEND,10-10-0-0,s=6,c=2,t=3,pt=0,l=0,sg=0,ft=1,st=OK:
    23842 TSF:MSG:READ,0-0-10,s=6,c=3,t=16,pt=0,l=0,sg=1:
    23842 SGN:SKP:MSG CMD=3,TYPE=16
    23843 SGN:SGN:NREQ=0
    23858 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    23858 SGN:NCE:XMT,TO=10
    23986 TSF:MSG:READ,0-0-10,s=6,c=2,t=3,pt=0,l=2,sg=1:65
    23986 SGN:BND:NONCE=66FA19948675FCDD4A73D33EC0C4B5F6F7D57A8A112CE93A1DAAAAAAAAAAAAAA
    23988 SGN:BND:HMAC=E34A8061453CB4DC770DFD3AC83567E58DCA3D42FA7CDB743CDBF40EE9327DD7
    23988 SGN:VER:OK
    REQ_Msg :3 MsgCmd:2 childID:6 Data:S/65 Data:I/ 65 Data:B/ 1
    Req SP
    23989 SGN:SGN:NREQ=0
    24033 TSF:MSG:SEND,10-10-0-0,s=1,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    display init
    WD Enabled
    24084 SGN:SGN:NREQ=0
    24090 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    24095 SGN:SGN:NREQ=0
    24101 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    24196 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    24196 SGN:SKP:MSG CMD=3,TYPE=16
    24197 SGN:SGN:NREQ=0
    25447 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=NACK:<NONCE>
    25447 !SGN:NCE:XMT,TO=10 FAIL
    Time REQ 1
    26101 SGN:SGN:NREQ=0
    26918 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=1,st=OK:
    26963 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=0:
    26963 SGN:SKP:MSG CMD=3,TYPE=16
    26964 SGN:SGN:NREQ=0
    27232 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    27233 SGN:NCE:XMT,TO=10
    27326 TSF:MSG:READ,0-0-10,s=255,c=3,t=1,pt=0,l=10,sg=1:1629281252
    27326 SGN:BND:NONCE=96DC361C795A3C064B82B2F1C201D95BF3C78786A2187E36CFAAAAAAAAAAAAAA
    27328 SGN:BND:HMAC=F65B83755837BAF5093BE2D62C9EE70C5B115B1330F9886B6481D8884A9E8E32
    27328 SGN:VER:OK
    Time value received: Time value valid: 1629281252
    10 7 32 18 8 2021
    Boot = 2021:8:18:10:7:32
    27329 SGN:SGN:NREQ=0
    28621 TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=17,sg=0,ft=0,st=OK:2021:8:18:10:7:32
    28621 !MCO:WAI:RC=1
    28622 !MCO:PRO:RC=1
    28622 !MCO:PRO:RC=1
    28622 !MCO:PRO:RC=1
    28622 !MCO:PRO:RC=1
    28622 !MCO:PRO:RC=1
    28622 !MCO:PRO:RC=1
    28622 !MCO:PRO:RC=1
    28622 !MCO:PRO:RC=1
    28622 !MCO:PRO:RC=1
    28622 !MCO:PRO:RC=1
    28622 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28623 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28624 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28625 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28626 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28627 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28628 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28629 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28630 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28631 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28632 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28633 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28634 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28635 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28636 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28637 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28638 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28639 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28640 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28641 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28642 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28643 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28644 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28645 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28646 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28647 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28648 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28649 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28650 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28651 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28652 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28653 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28654 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28655 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28656 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28657 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28658 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28659 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28660 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28661 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28662 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28663 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28664 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28665 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28666 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28667 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28668 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28669 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28670 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28671 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28672 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28673 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28674 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28675 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28676 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28677 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28678 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28679 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28680 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28681 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28682 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28683 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28684 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28685 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28686 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28687 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28688 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28689 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28690 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28691 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28692 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28693 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28694 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28695 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28696 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28697 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28698 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28699 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28700 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28701 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28702 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28703 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28704 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28705 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28706 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28707 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28708 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28709 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28710 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28711 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28712 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28713 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28714 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28715 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28716 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28717 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28718 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28719 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28720 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28721 !MCO:PRO:RC=1
    28722 SGN:SGN:NREQ=0
    30046 !TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=17,sg=0,ft=0,st=NACK:2021:8:18:10:7:32
    Resent Dateboot
    Time REQ 2
    Time Received in Setup
    Boot = 2021:8:18:10:7:34
    30046 SGN:SGN:NREQ=0
    31277 !TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=17,sg=0,ft=1,st=NACK:2021:8:18:10:7:34
    31377 SGN:SGN:NREQ=0
    31385 TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=17,sg=0,ft=2,st=OK:2021:8:18:10:7:34
    Resent Dateboot
    31386 MCO:BGN:INIT OK,TSP=1
    TEMP1 SP sent :14.00
    32177 TSF:MSG:READ,0-0-10,s=11,c=1,t=47,pt=0,l=17,sg=0:2021:8:18:10:7:34
    32177 SGN:SKP:ECHO CMD=1,TYPE=47
    32177 TSF:MSG:ECHO
    +Ack/Echo FMGW
    *InMsgty :47 MsgComd:1 childID:11 Data:S/2021:8:18:10:7:34 Data:I/ 2021 Data:B/ 1
  • 48Mhz Log
    1317 TSF:MSG:READ,0-0-10,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    1318 SGN:SKP:MSG CMD=3,TYPE=8
    1318 TSF:MSG:FPAR OK,ID=0,D=1
    2305 TSM:FPAR:OK
    2305 TSM:ID
    2305 TSM:ID:OK
    2305 TSM:UPL
    2305 SGN:SGN:NREQ=0
    5661 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    6869 TSF:MSG:READ,0-0-10,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    6869 SGN:SKP:MSG CMD=3,TYPE=25
    6869 TSF:MSG:PONG RECV,HP=1
    6869 TSM:UPL:OK
    6869 TSM:READY:ID=10,PAR=0,DIS=1
    6869 SGN:PRE:SGN REQ
    6869 SGN:PRE:WHI NREQ
    6869 SGN:SGN:NREQ=0
    6875 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
    6876 SGN:PRE:XMT,TO=0
    6876 SGN:PRE:WAIT GW
    8084 TSF:MSG:READ,0-0-10,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    8085 SGN:SKP:MSG CMD=3,TYPE=15
    8085 SGN:SGN:NREQ=0
    9091 TSF:MSG:SEND,10-10-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
    9091 SGN:SGN:NREQ=0
    9670 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    10477 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    10477 SGN:SKP:MSG CMD=3,TYPE=16
    10478 SGN:SGN:NREQ=0
    14347 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    14348 SGN:NCE:XMT,TO=10
    14348 SGN:SGN:NREQ=0
    16669 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:LivingRm Thermostat
    16669 SGN:SGN:NREQ=0
    17675 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=12,pt=0,l=6,sg=0,ft=0,st=OK:1.1.12
    17676 SGN:SGN:NREQ=0
    18684 TSF:MSG:SEND,10-10-0-0,s=0,c=0,t=6,pt=0,l=16,sg=0,ft=0,st=OK:Room Temperature
    18784 SGN:SGN:NREQ=0
    19997 TSF:MSG:SEND,10-10-0-0,s=5,c=0,t=33,pt=0,l=18,sg=0,ft=0,st=OK:Thermostat RX RSSI
    20098 SGN:SGN:NREQ=0
    21311 TSF:MSG:SEND,10-10-0-0,s=2,c=0,t=3,pt=0,l=16,sg=0,ft=0,st=OK:Thermostat Relay
    21411 SGN:SGN:NREQ=0
    22951 !TSF:MSG:SEND,10-10-0-0,s=3,c=0,t=3,pt=0,l=13,sg=0,ft=0,st=NACK:Heat Override
    23051 SGN:SGN:NREQ=0
    24058 TSF:MSG:SEND,10-10-0-0,s=7,c=0,t=6,pt=0,l=11,sg=0,ft=1,st=OK:Who is Home
    24158 SGN:SGN:NREQ=0
    26371 TSF:MSG:SEND,10-10-0-0,s=1,c=0,t=14,pt=0,l=13,sg=0,ft=0,st=OK:Temp Setpoint
    26471 SGN:SGN:NREQ=0
    27993 TSF:MSG:SEND,10-10-0-0,s=6,c=0,t=4,pt=0,l=11,sg=0,ft=0,st=OK:Oil Tank PC
    28093 SGN:SGN:NREQ=0
    30157 TSF:MSG:SEND,10-10-0-0,s=12,c=0,t=36,pt=0,l=12,sg=0,ft=0,st=OK:Display Text
    30258 SGN:SGN:NREQ=0
    32593 !TSF:MSG:SEND,10-10-0-0,s=8,c=0,t=3,pt=0,l=14,sg=0,ft=0,st=NACK:SP Update Flag
    32678 !SGN:BND:TMR
    32881 TSF:MSG:READ,0-0-10,s=8,c=0,t=3,pt=0,l=14,sg=0:SP Update Flag
    32881 SGN:SKP:ECHO CMD=0,TYPE=3
    32881 TSF:MSG:ECHO
    +Ack/Echo FMGW
    32882 SGN:SGN:NREQ=0
    35095 TSF:MSG:SEND,10-10-0-0,s=9,c=0,t=3,pt=0,l=13,sg=0,ft=1,st=OK:HotWater Flag
    35195 SGN:SGN:NREQ=0
    37410 TSF:MSG:SEND,10-10-0-0,s=10,c=0,t=36,pt=0,l=21,sg=0,ft=0,st=OK:Returned Display Text
    37510 SGN:SGN:NREQ=0
    39721 TSF:MSG:SEND,10-10-0-0,s=11,c=0,t=36,pt=0,l=8,sg=0,ft=0,st=OK:BootTime
    39821 MCO:REG:REQ
    39821 SGN:SGN:NREQ=0
    39827 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    41042 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    41042 SGN:SKP:MSG CMD=3,TYPE=16
    41042 SGN:SGN:NREQ=0
    42840 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    42841 SGN:NCE:XMT,TO=10
    42841 SGN:SGN:NREQ=0
    43847 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    45062 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    45062 SGN:SKP:MSG CMD=3,TYPE=16
    45062 SGN:SGN:NREQ=0
    47526 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    47527 SGN:NCE:XMT,TO=10
    47527 SGN:SGN:NREQ=0
    48533 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    49747 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    49747 SGN:SKP:MSG CMD=3,TYPE=16
    49747 SGN:SGN:NREQ=0
    49898 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    49898 SGN:NCE:XMT,TO=10
    50986 TSF:MSG:READ,0-0-10,s=255,c=3,t=27,pt=1,l=1,sg=1:1
    50987 SGN:BND:NONCE=C13859714FA31337A133BAB1F5CD132246438213AC9B278A5AAAAAAAAAAAAAAA
    50988 SGN:BND:HMAC=F01FDEF38DB44960D2D22E4E38A141D08432DB6DE34268815F1E29133D451B6D
    50988 SGN:VER:OK
    50988 MCO:PIM:NODE REG=1
    50988 MCO:BGN:STP
    Loaded values
     :Relay output : 1
    51035 SGN:SGN:NREQ=0
    51041 TSF:MSG:SEND,10-10-0-0,s=7,c=1,t=45,pt=7,l=5,sg=0,ft=0,st=OK:0.0
    51042 SGN:SGN:NREQ=0
    51445 TSF:MSG:SEND,10-10-0-0,s=2,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
    uplink available
    52092 TSF:MSG:READ,0-0-10,s=2,c=3,t=16,pt=0,l=0,sg=1:
    52092 SGN:SKP:MSG CMD=3,TYPE=16
    52092 SGN:SGN:NREQ=0
    53101 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    53102 SGN:NCE:XMT,TO=10
    53102 SGN:SGN:NREQ=0
    54108 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    54108 SGN:SGN:NREQ=0
    55115 TSF:MSG:SEND,10-10-0-0,s=12,c=1,t=47,pt=0,l=8,sg=0,ft=0,st=OK:Boot ...
    REQ DISPLAYTXT
    55115 SGN:SGN:NREQ=0
    57323 TSF:MSG:SEND,10-10-0-0,s=12,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    Req PC
    57324 SGN:SGN:NREQ=0
    59532 TSF:MSG:SEND,10-10-0-0,s=6,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    Req SP
    59533 SGN:SGN:NREQ=0
    60945 TSF:MSG:SEND,10-10-0-0,s=1,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    display init
    WD Enabled
    60996 SGN:SGN:NREQ=0
    63407 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    63413 SGN:SGN:NREQ=0
    63419 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    63453 !SGN:BND:TMR
    64020 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    64021 SGN:SKP:MSG CMD=3,TYPE=16
    64021 SGN:SGN:NREQ=0
    66060 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    66061 SGN:NCE:XMT,TO=10
    Time REQ 1
    66061 SGN:SGN:NREQ=0
    67066 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    68098 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    68099 SGN:SKP:MSG CMD=3,TYPE=16
    68099 SGN:SGN:NREQ=0
    69956 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    69957 SGN:NCE:XMT,TO=10
    Time REQ 2
    69957 SGN:SGN:NREQ=0
    73296 !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
    Time REQ 3
    75296 SGN:SGN:NREQ=0
    76853 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=1,st=OK:
    76870 !SGN:BND:TMR
    77871 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    77872 SGN:SKP:MSG CMD=3,TYPE=16
    77872 SGN:SGN:NREQ=0
    80120 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    80121 SGN:NCE:XMT,TO=10
    Time REQ 4
    80121 SGN:SGN:NREQ=0
    81810 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    82828 TSF:MSG:READ,0-0-10,s=255,c=3,t=16,pt=0,l=0,sg=1:
    82828 SGN:SKP:MSG CMD=3,TYPE=16
    82828 SGN:SGN:NREQ=0
    83837 TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
    83838 SGN:NCE:XMT,TO=10
    Time REQ 5
    Timedout
    83838 MCO:BGN:INIT OK,TSP=1
    84628 TSF:MSG:READ,0-0-10,s=255,c=3,t=1,pt=0,l=10,sg=1:1629281049
    84629 SGN:BND:NONCE=15658CB551D0856E0D3D26A68781A1AAA1D936FC5D7D7FF61DAAAAAAAAAAAAAA
    84630 SGN:BND:HMAC=B47AA377E18CFCB9727224D78769289C4CAADC0D13EBEF44E8C5A371F9303002
    84630 SGN:VER:OK
    Time value received: Time value valid: 1629281049
    10 4 9 18 8 2021
    Boot = 2021:8:18:10:4:9
    84630 SGN:SGN:NREQ=0
    84639 TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=16,sg=0,ft=0,st=OK:2021:8:18:10:4:9
    84639 !MCO:WAI:RC=1
  • more of the 48Mhz log
    84639 !MCO:PRO:RC=1
    84639 !MCO:PRO:RC=1
    84639 !MCO:PRO:RC=1
    84639 !MCO:PRO:RC=1
    84639 !MCO:PRO:RC=1
    84639 !MCO:PRO:RC=1
    84639 !MCO:PRO:RC=1
    84639 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84640 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84641 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84642 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84643 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84644 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84645 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84646 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84647 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84648 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84649 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84650 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84651 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84652 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84653 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84654 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84655 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84656 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84657 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84658 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84659 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84660 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84661 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84662 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84663 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84664 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84665 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84666 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84667 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84668 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84669 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84670 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84671 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84672 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84673 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84674 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84675 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84676 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84677 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84678 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84679 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84680 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84681 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84682 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84683 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84684 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84685 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84686 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84687 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84688 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84689 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84690 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84691 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84692 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84693 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84694 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84695 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84696 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84697 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84698 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84699 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84700 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84701 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84702 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84703 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84704 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84705 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84706 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84707 !MCO:PRO:RC=1
    84708 !MCO:PRO:RC=1
    84708 !MCO:PRO:RC=1
    84708 !MCO:PRO:RC=1
    84708 !MCO:PRO:RC=1
    84708 !MCO:PRO:RC=1
    84708 !MCO:PRO:RC=1
    84708 !MCO:PRO:RC=1
    84709 !MCO:PRO:RC=1
    84709 !MCO:PRO:RC=1
    84709 !MCO:PRO:RC=1
    84709 !MCO:PRO:RC=1
    84709 !MCO:PRO:RC=1
    84709 !MCO:PRO:RC=1
    84709 !MCO:PRO:RC=1
    84709 !MCO:PRO:RC=1
    84709 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84710 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84711 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84712 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84713 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84714 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84715 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84716 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84717 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84718 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84719 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84720 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84721 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84722 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84723 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84724 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84725 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84726 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84727 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84728 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84729 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84730 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84731 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84732 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84733 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84734 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84735 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84736 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84737 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84738 !MCO:PRO:RC=1
    84739 SGN:SGN:NREQ=0
    85878 TSF:MSG:SEND,10-10-0-0,s=11,c=1,t=47,pt=0,l=16,sg=0,ft=0,st=OK:2021:8:18:10:4:9
    Resent Dateboot
    SendInterval Timed :TEMPERATURE :1.91
    85883 SGN:SGN:NREQ=0
    88149 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:1.91
    88160 SGN:SGN:NREQ=0
    89572 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
    89572 SGN:SGN:NREQ=0
    93622 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:0
    Setpoint requested :
    93632 SGN:SGN:NREQ=0
    95044 TSF:MSG:SEND,10-10-0-0,s=1,c=2,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
     Request OK ACK Received
    95049 SGN:SGN:NREQ=0
    95055 TSF:MSG:SEND,10-10-0-0,s=6,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    95055 SGN:SGN:NREQ=0
    96504 TSF:MSG:SEND,10-10-0-0,s=8,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    SendInterval Timed :TEMPERATURE :19.31
    156806 SGN:SGN:NREQ=0
    157102 TSF:MSG:SEND,10-10-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.31
    157112 SGN:SGN:NREQ=0
    159321 TSF:MSG:SEND,10-10-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
    159321 SGN:SGN:NREQ=0
    160733 TSF:MSG:SEND,10-10-0-0,s=5,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:0
    161562 TSF:MSG:READ,0-0-10,s=5,c=1,t=37,pt=2,l=2,sg=0:0
    161562 SGN:SKP:ECHO CMD=1,TYPE=37
    161562 TSF:MSG:ECHO
    +Ack/Echo FMGW
    *InMsgty :37 MsgComd:1 childID:5 Data:S/ Data:I/ 0 Data:B/ 0
  • No one have any ideas?
    It can't just be me surely?
    regards Nigel
    @Njwyborn judging from the logs, i would suspect that you're at least suffering from this issue https://github.com/mysensors/MySensors/issues/1458, which unfortunately is still open.
  • @Yveaux
    Thank you, at least I'm not going mad.
    Would this issue likely be the root cause of the curious inverse clock speed / performance results / performance?
    regards Nigel
    @Njwyborn sorry, I don't know. If the stack is called recursively, something is seriously wrong and behavior is undefined I guess.
