Node doesn't receive data from RPI MQTT Gateway
  • I am trying to send data from an MQTT Gateway to a node. I expect the receive() method in my node sketch to be activated when I send an MQTT message to my MQTT gateway.
    The mysgw receives this message, as shown in the logs.
    My sketch in the node (id=156) has a sensor with id 7 of type V_DIMMER.
    I assume the mysgw should forward this message to my node, but no sign of any activity on my node 156.
    Do I have to call wait(time, command, datatype)? In the example sketch for the dimmer, there is no wait() call at all.
    I have implemented the receive() method, but that doesn't seem to get called if I send an MQTT message to my gateway.
    BTW: this gateway is working perfectly with a few other nodes and sensors I have in my MySensors network.
    What am I doing wrong?
    My sketch:
    #define MY_BAUD_RATE 38400
    //#define MY_RADIO_RF24
    #define MY_RADIO_RFM69
    // If using mysensors version<2.3.0 and want to use NEW DRIVER (OH SO BAD NAMING):
    #define MY_RFM69_NEW_DRIVER
    // if you use MySensors 2.0 use this style
    //#define MY_RFM69_FREQUENCY   RF69_433MHZ
    //#define MY_RFM69_FREQUENCY   RF69_868MHZ
    //#define MY_RFM69_FREQUENCY   RF69_915MHZ
    // Do not use default 100 to avoid conflicts with neighbors that won't change this id
    #define MY_RFM69_NETWORKID 197
    //#define MY_RFM69_FREQUENCY   RFM69_433MHZ
    #define MY_RFM69_FREQUENCY   RFM69_868MHZ
    //#define DEFAULT_RFM69_CS_PIN     (PB2)                      //!< DEFAULT_RFM69_CS_PIN
    // default #define MY_RF69_IRQ_PIN PD2
    //#define MY_RADIO_NRF24
    // Comment it out for Auto Node ID #, original was 0x90=144
    #define MY_NODE_ID 156
    #include <OneWire.h>
    #define ONE_WIRE_BUS 8 // Pin where dallas sensor is connected
    #define MAX_ATTACHED_DS18B20 1
    #define LED_PIN LED_BUILTIN
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    unsigned long SLEEP_TIME = 3000; // Sleep time between reads (in milliseconds)
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    static int16_t currentLevel = 0;  // Current dim level...
    MyMessage dimmerMsg(0, V_DIMMER);
    MyMessage lightMsg(0, V_LIGHT);
    void before()
      wdt_disable();
      pinMode(LED_PIN,OUTPUT);
      Serial.println("before(): between wdt_disable and sensors.begin");
      sensors.begin();
      Serial.println("before(): after sensors.begin");
      // Pull the gateway's current dim level - restore light level upon node power-up
      request( 0, V_DIMMER );
      //sensors.setWaitForConversion(false);
      Serial.print("End setup for node number ");Serial.println(MY_NODE_ID);
      //Serial.print("Start presentation for node number ");Serial.print(MY_NODE_ID);
      sendSketchInfo("FanAttic_156", "1.1");
      numSensors=1; // !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      // !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!numSensors = sensors.getDeviceCount();
      present(7,S_DIMMER);
         present(i+1, S_TEMP);
      //wdt_reset();
      Serial.println("Start loop");
      float temperature=37.9;
      send (msg.setSensor(0).set(temperature,1));
      Serial.println("msg sent");
      //sleep(SLEEP_TIME);
      wait(conversionTime);
      wait(SLEEP_TIME,C_SET,V_PERCENTAGE);
      Serial.println("End loop");
      analogWrite(LED_PIN,(int)128);
        Serial.print( "Message received" );
      if (message.getType() == V_LIGHT || message.getType() == V_DIMMER || message.getType() == V_PERCENTAGE) {
        requestedLevel *= ( message.getType() == V_LIGHT ? 100 : 1 );
        Serial.print( "Changing level to " );
        Serial.print( ", from " );
        Serial.println( currentLevel );
        fadeToLevel( requestedLevel );
        send(lightMsg.set(currentLevel > 0));
        // hek comment: Is this really nessesary?
        send( dimmerMsg.set(currentLevel) );
     *  This method provides a graceful fade up/down effect
    void fadeToLevel( int toLevel )
      int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
      while ( currentLevel != toLevel ) {
        currentLevel += delta;
        analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
        delay( FADE_DELAY );
    My mqtt call:
    # // Topic structure: MY_MQTT_PUBLISH_TOPIC_PREFIX/NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
    # carl/mysensors/156/0/????/?????/?????
    # try to set dim level (test script/sketch)
    # V_PERCENTAGE 3 command type
    mqtt pub --host rpi3.home --mqttVersion 3 --topic 'carl/mysensors/156/7/1/0/3' --message 35
    The output of mysgw (I also show some other messages, my problem is only about the sensor-id=7 messages):
    Aug  4 23:25:51 rpi3 mysgw: TSF:MSG:READ,156-156-0,s=0,c=1,t=0,pt=7,l=5,sg=0:37.9
    Aug  4 23:25:51 rpi3 mysgw: GWT:TPS:TOPIC=mysensors/all/156/0/1/0/0,MSG SENT
    Aug  4 23:25:53 rpi3 mysgw: GWT:IMQ:TOPIC=carl/mysensors/156/7/1/0/3, MSG RECEIVED
    Aug  4 23:25:53 rpi3 mysgw: GWT:TPS:TOPIC=mysensors/all/0/156/7/1/0,MSG SENT
    Aug  4 23:25:54 rpi3 mysgw: TSF:MSG:READ,156-156-0,s=0,c=1,t=0,pt=7,l=5,sg=0:37.9
    Aug  4 23:25:54 rpi3 mysgw: GWT:TPS:TOPIC=mysensors/all/156/0/1/0/0,MSG SENT
    Aug  4 23:25:58 rpi3 mysgw: TSF:MSG:READ,156-156-0,s=0,c=1,t=0,pt=7,l=5,sg=0:37.9
    Aug  4 23:25:58 rpi3 mysgw: GWT:TPS:TOPIC=mysensors/all/156/0/1/0/0,MSG SENT
    Aug  4 23:25:58 rpi3 mysgw: TSF:MSG:READ,153-153-0,s=4,c=1,t=23,pt=0,l=4,sg=0:2.92
    Aug  4 23:25:58 rpi3 mysgw: GWT:TPS:TOPIC=mysensors/all/153/4/1/0/23,MSG SENT
    The debug output of the sketch (nothing to see about sensor-id=7):
    Start loop
    2039105 TSF:MSG:SEND,156-156-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:37.9
    msg sent
    End loop
    Start loop
    2042230 TSF:MSG:SEND,156-156-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:37.9
    msg sent
    End loop
    Start loop
    2045356 TSF:MSG:SEND,156-156-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:37.9
    msg sent
    End loop
    Start loop
    2048538 TSF:MSG:SEND,156-156-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:37.9
    msg sent
    End loop
    Start loop
    2051663 TSF:MSG:SEND,156-156-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:37.9
    msg sent
    My gateway has been compiled on a rpi3 with:
    ./configure --my-transport=rfm69 --my-rfm69-frequency=868 \
    --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 \
    --my-mqtt-publish-topic-prefix=mysensors/all \
    --my-mqtt-subscribe-topic-prefix=+/mysensors \
    --my-mqtt-client-id=mygateway1 \
    --my-mqtt-user=mysensors \
    --my-mqtt-password=<PASS>
  • @cvdenzen In case of troubleshooting, try to comment out the maximum of code, only the bare minimum of code should remain active.
    Go back to the original code of the dimmer : https://www.mysensors.org/build/dimmer and test first if this sketch receives the messages.
  • No, the bare sketch (with only the necessary modifications, like NEW_DRIVER, NODE_ID etc.) does not receive the message.
    I tried the bare sketch on two different pieces of hardware (an arduino mini pro and an easypirmultisensors2, which also is an 8 MHz avr).
    The sketch:
     * Copyright (C) 2013-2019 Sensnology AB
     * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
     * Version 1.0 - February 15, 2014 - Bruce Lacey
     * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
     * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
     * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
     * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
     * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
     * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
     * to the LED negative terminal and the MOSFET Source pin is connected to ground.
     * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
     * http://www.mysensors.org/build/dimmer
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_RFM69_NETWORKID 197// Comment it out for Auto Node ID #, original was 0x90=144
    #define MY_NODE_ID 157
    #define SN "DimmableLED"
    #define SV "1.1"
    #define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
     * Dimmable LED initialization method
    	// Register the LED Dimmable Light with the gateway
    	present( 0, S_DIMMER );
    	sendSketchInfo(SN, SV);
     *  Dimmable LED main processing loop
       Serial.print( "Received a message! (node 157)" );
    	if (message.getType() == V_LIGHT || message.getType() == V_DIMMER) {
    The mqtt invocation:
    mqtt pub --host rpi3.home --mqttVersion 3 --topic 'carl/mysensors/157/0/1/0/3' --message 35
    The mysgw logging:
    Aug  9 22:20:04 rpi3 mysgw: GWT:IMQ:TOPIC=carl/mysensors/157/0/1/0/3, MSG RECEIVED
    Aug  9 22:20:04 rpi3 mysgw: GWT:TPS:TOPIC=mysensors/all/0/157/0/1/0,MSG SENT
    The logging from the easypirmultisensorsbox2 (nothing shows up when an MQTT message is sent to the MQTT broker):
     __  __       ____
            |___/                      2.3.2
    51 MCO:BGN:INIT NODE,CP=RPNNA---,FQ=8,REL=255,VER=2.3.2
    83 TSM:INIT
    86 TSF:WUR:MS=0
    92 TSM:INIT:TSP OK
    96 TSM:INIT:STATID=157
    102 TSF:SID:OK,ID=157
    108 TSM:FPAR
    116 ?TSF:MSG:SEND,157-157-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    425 TSF:MSG:READ,0-0-157,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    440 TSF:MSG:FPAR OK,ID=0,D=1
    2138 TSM:FPAR:OK
    2142 TSM:ID
    2146 TSM:ID:OK
    2150 TSM:UPL
    2187 TSF:MSG:SEND,157-157-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2392 TSF:MSG:READ,0-0-157,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2406 TSF:MSG:PONG RECV,HP=1
    2414 TSM:UPL:OK
    2418 TSM:READY:ID=157,PAR=0,DIS=1
    2449 TSF:MSG:SEND,157-157-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2656 TSF:MSG:READ,0-0-157,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2689 TSF:MSG:SEND,157-157-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
    2723 TSF:MSG:SEND,157-157-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4761 TSF:MSG:SEND,157-157-0-0,s=0,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
    4796 TSF:MSG:SEND,157-157-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:DimmableLED
    4835 TSF:MSG:SEND,157-157-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    4855 MCO:REG:REQ
    4870 TSF:MSG:SEND,157-157-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    5076 TSF:MSG:READ,0-0-157,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    5093 MCO:PIM:NODE REG=1
    5099 MCO:BGN:STP
    5122 TSF:MSG:SEND,157-157-0-0,s=0,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    5140 MCO:BGN:INIT OK,TSP=1
  • Is the mysgw output looking good? The sent message doesn”t include the message type (3). Has anybody tested this with a topic that contains a slash?
  • @cvdenzen I don't have experience with a Raspberry Pi as MQTT gateway, but your last remark about the slash is maybe a path to debug...
    From the docs for a Arduino MQTT gateway:
    The topic is build like this: MY_MQTT_PUBLISH_TOPIC_PREFIX/FROM-NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
    Read more about the serial protocol here. An example topic for data received from your gateway could look like this:
    mygateway1-out/2/1/1/0/49
    If you want to send data to your sensors use MY_MQTT_SUBSCRIBE_TOPIC_PREFIX defined in your sketch. Should be looking like this (using default sketch):
    mygateway1-in/2/1/1/0/49
    Can you try to change your mqtt topic build?
  • @evb It took some time (have also another home renovation project), but now I have set up a test gateway.
    The mqtt topic with a slash in its name seems to be the problem. I changed the mqtt topic to mysensorsa and now the sketch receives the message. The mqtt gateway outputs:
    Aug 15 22:50:33 DEBUG GWT:IMQ:TOPIC=mysensorsa/157/0/1/0/3, MSG RECEIVED
    Aug 15 22:50:33 DEBUG TSF:MSG:SEND,0-0-157-157,s=0,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:35
    Aug 15 22:50:34 DEBUG TSF:MSG:READ,157-157-0,s=0,c=1,t=2,pt=1,l=1,sg=0:1
    Aug 15 22:50:34 DEBUG GWT:TPS:TOPIC=mysensors/all/157/0/1/0/2,MSG SENT
    Aug 15 22:50:34 DEBUG TSF:MSG:READ,157-157-0,s=0,c=1,t=3,pt=2,l=2,sg=0:35
    Aug 15 22:50:34 DEBUG GWT:TPS:TOPIC=mysensors/all/157/0/1/0/3,MSG SENT
    I will have a look at the MySensors code and if I cannot find the problem, maybe I will change my mqtt subscription topic.
  • @cvdenzen
    I have added a GATEWAY_DEBUG line in core/MyProtocol.cpp at line 122:
    	for (str = strtok_r(topic + strlen(MY_MQTT_SUBSCRIBE_TOPIC_PREFIX) + 1, "/", &p);
    	        str && index < 5;
    	        str = strtok_r(NULL, "/", &p), index++
    	    GATEWAY_DEBUG(PSTR("GWT:TPS:Index=%d, mqttstr=%s\n"), str);
    My conclusion is that the length of the mqtt subscription topic is the problem. The first call shows that it thinks "rs" is part of the topic beyond the PREFIX. And "rs" gets translated to "0" in the outgoing mqtt message, shifting the real items one position further and dropping the last item.
    Later on I will have a look at the cause of this limitation (or maybe someone else is quicker than I am).
    The output of mysgw, first try is with topic carl/mysensors, second try (that succeeds) is with mqtt topic c/mysensors:
    Aug 15 23:53:19 DEBUG GWT:TPS:TOPIC=mysensors/all/157/255/3/0/21,MSG SENT
    Aug 15 23:53:24 DEBUG GWT:IMQ:TOPIC=carl/mysensors/157/0/1/0/3, MSG RECEIVED
    Aug 15 23:53:24 DEBUG GWT:TPS:Index=0, mqttstr=rs
    Aug 15 23:53:24 DEBUG GWT:TPS:Index=1, mqttstr=157
    Aug 15 23:53:24 DEBUG GWT:TPS:Index=2, mqttstr=0
    Aug 15 23:53:24 DEBUG GWT:TPS:Index=3, mqttstr=1
    Aug 15 23:53:24 DEBUG GWT:TPS:Index=4, mqttstr=0
    Aug 15 23:53:24 DEBUG GWT:TPS:TOPIC=mysensors/all/0/157/0/1/0,MSG SENT
    Aug 15 23:54:42 DEBUG GWT:IMQ:TOPIC=c/mysensors/157/0/1/0/3, MSG RECEIVED
    Aug 15 23:54:42 DEBUG GWT:TPS:Index=0, mqttstr=157
    Aug 15 23:54:42 DEBUG GWT:TPS:Index=1, mqttstr=0
    Aug 15 23:54:42 DEBUG GWT:TPS:Index=2, mqttstr=1
    Aug 15 23:54:42 DEBUG GWT:TPS:Index=3, mqttstr=0
    Aug 15 23:54:42 DEBUG GWT:TPS:Index=4, mqttstr=3
    Aug 15 23:54:42 DEBUG TSF:MSG:SEND,0-0-157-157,s=0,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:35
    Aug 15 23:54:42 DEBUG TSF:MSG:READ,157-157-0,s=0,c=1,t=2,pt=1,l=1,sg=0:1
    Aug 15 23:54:42 DEBUG GWT:TPS:TOPIC=mysensors/all/157/0/1/0/2,MSG SENT
  • The problem is clear: the subscription topic that I use contains a wildcard: “+/mysensors”.
    I send my message with prefix “carl/mysensors”.
    The MySensors code assumes the length of the prefix I send is the same as the length of the subscription prefix. But it isn’t because of the wildcard character.
    Is there anybody who likes to change the code to make it work? Or should I try it myself?
    I see two possible solutions:
    1. Parse the message from end to begin and not from begin to end.
    2. Try to match the wildcard character(s) with the sent string.
  • I have made some modifications to the code, tested it and it seems to work.
    There is a pull request https://github.com/mysensors/MySensors/pull/1497 but I don't know how this will be handled by the MySensors developers.
    Can anybody give me a link or some information about the development process? A review of my code will be necessary, I am not a C programmer.
    Contribution guidelines are available at https://www.mysensors.org/download/contributing
  • @mfalkvidd Thank you for the link. I followed the instructions, had to download/compile some packages.
    It will take some time for me, I have to solve this error:
     git commit -m "Accept wildcards in mqtt subscription prefix"
    cppcheck: Failed to load library configuration file 'std.cfg'. File not found
    cppcheck: Failed to load library configuration file 'avr'. File not found
    nofile:0:0: information: Failed to load the library avr [failedToLoadCfg]
    Few minutes later, resolved, had to add CFGDIR to make cppcheck:
    sudo make install FILESDIR=/usr/share/cppcheck CFGDIR=/usr/share/cppcheck
  • It seems like building MySensors with my edit failed but I don’t understand the error messages.
    The first error: https://ci.mysensors.org/job/MySensors/job/MySensors/job/PR-1497/2/warnings2Result/new/file.702256833/source.9006459693321295180/#1
    @cvdenzen I don't understand the build system, but I have permission to restart builds. Sometimes that helps. I've restarted the build for your PR. Hopefully we'll get a better result this time.
  • @mfalkvidd Thank you!
