Error when restarting Homeassistant (mysensors-error)
    i need help again.
    when i want to restart or quickly reboot my homeassistant i get the error.
    configuration could not be started
    "error calling the service homeassistant/reload_all. 'mysensors'"
    so i can only do a complete restart.
    has something changed in homeassistant in version Core 6.1 regarding MySensors?
    best regards
  • Hi @Branther
    Could you please post the error log for this error? You'll find it under "Einstellungen" -> "System" -> "Protokolle"
  • Hi, thank you for your feedback.
    here are the 2 protocols that concern mysensors:
    First:
    Logger: homeassistant.components.websocket_api.http.connection
    Source: helpers/check_config.py:184
    Integration: Home Assistant WebSocket API (documentation, issues)
    First occurred: 11:20:17 (1 occurrences)
    Last logged: 11:20:17
    [547863234576] 'mysensors'
    File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 205, in handle_call_service
    await hass.services.async_call(
    File "/usr/src/homeassistant/homeassistant/core.py", line 1910, in async_call
    task.result()
    File "/usr/src/homeassistant/homeassistant/core.py", line 1950, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
    File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 887, in admin_handler
    await result
    File "/usr/src/homeassistant/homeassistant/components/homeassistant/init.py", line 311, in async_handle_reload_all
    if errors := await conf_util.async_check_ha_config_file(hass):
    File "/usr/src/homeassistant/homeassistant/config.py", line 982, in async_check_ha_config_file
    res = await check_config.async_check_ha_config_file(hass)
    File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 184, in async_check_ha_config_file
    result[domain] = config[domain]
    KeyError: 'mysensors'
    and the second:
    Logger: homeassistant.components.mysensors
    Source: helpers/config_validation.py:867
    Integration: MySensors (documentation, issues)
    First occurred: 11. Juni 2023 um 18:35:52 (2 occurrences)
    The 'mysensors' option near /config/configuration.yaml:2 has been removed, please remove it from your configuration
    The 'mysensors' option has been removed, please remove it from your configuration
    unfortunately my knowledge is not sufficient to understand that😕
    thanx
    branther
  • ...or did you mean the full protocol?
    i have downloaded it. i hope it will be of help.
    sorry, i can't send upload as file or as graphic. the board always gives error.
    it always expects a graphic file.
  • Hi there,
    Well, MySensors configuration has moved from configuration.yaml to the UI config (which I also don't like, because at the moment, it's impossible to change something like the IP of a gateway). So you have to remove all MySensors related Stuff from the yaml file and (if not already there) add the gateway(s) over the UI again. Do a backup before. Not sure if the entities match after that operation.
    Can you post the relevant section from your configuration.yaml?
    Btw: to post large text files, you can use something like pastebin.
    Thanks a lot, it works.
    If I remove mysensors from the yaml I can actually call a reboot again without problems.
    i had only the serial usb-gateway in the configuration.yaml
    MySensors now works without the entry in the yaml. After a reboot all entities are listed and work. but how can i change the parameters, e.g. the serial port of the gateway?
    here the section which concerns mysensors.
    mysensors:
    gateways:
    • device: '/dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0'
      optimistic: true
      persistence: true
      version: 'V2.0'
    logger:
    default: info
    logs:
    homeassistant.components.mysensors: debug
    mysensors: debug
  • Hey @Branther
    Cool it works again. Regarding your question:
    Short answer:
    You can't. Thats what I ment when I said I didn't like the change to the UI config in my last post.
    Experimental answer:
    • Create a backup
    • Delete the gateway device
    • Create a new gateway device, enter the name of the old persistence file
    If you are lucky enough, all your devices will continue to work.
    Risky answer:
    YOU ARE NOT SUPPOSED TO EDIT THESE FILES, BUT IT WORKED FOR ME
    • Create a backup
    • in your config directory, you'll find a hidden folder .storage
    • in this folder, you'll find the json file core.config_entries
    • search for "domain": "mysensors", in this section you can change the settings
    With this method, I successfully changed the IP address and the API version of a gateway.
    A kind request Could you do us a favor and include things like the config excerpt in your last post into code tags (```... your code here ...```)? This makes things easier to read.
    A hint It's a good idea to use the serial devices by the symlinks in /dev/serial like you do. It's even a better idea to use a symlink to this device like ln -s /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0 /mydev/mysensors. Then, you can change the device and recreate the symlink without changing the configuration.
    Regards, Edi
  • thanks again Edi.
    I will first make a full backup and put it on a new ssd.
    after that i will test your solutions as far as i can.
    sorry, i must have overlooked the code snippets function.
    best regards
  • 24
  • 15
