Need a little help to alter my sketch
  • Hey everyone,
    I have a few on the Mini Rboards working very well for control of a few light switches, using Vera 3 as my controller. What is driving me and the family a little crazy is how the manual light switches have to work so that they operate the Mini Rboard.
    Here is my sketch:
    // Example sketch fΓΆr a "light switch" where you can control light or something
    // else from both vera and a local physical button (connected between digital
    // pin 14 and GND).
    // This node also works as a repeader for other nodes
    #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  14  // Arduino Digital I/O pin number for button -A0 which is D14
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
      gw.sendSketchInfo("Relay & Button", "1.0");
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      state = gw.loadState(CHILD_ID);
    *  Example on how to asynchronously check for new messages from gw
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          gw.send(msg.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID, state);
    So to use mu current light switches, I have to turn them on and then off, for the light to operate. If I only turn the switch on, the light will operate, but to operate it again I have to turn the switch off and then on again.
    I have looked into a momentary switch, but to get the ones to fit are quite expensive...
    Is there a way to alter the sketch to make it work better? IE can I have the sketch open the relay when the binary switch is connected, and then close the relay when it is disconnected?
    thanks for your help πŸ™‚
    @Dean, try to change this line:
    by removing the '&& value==0'
         if (value != oldValue)
  • @rvendrame thanks for that mate! I will give that a go.
    So that I am clear on the understanding, I have it so that it is waiting for a change, and it needs to equal zero. So by removing the zero bit, it should just be waiting for a change. I suppose the reason for it to be waiting for both is to reduce the chance of it missing a change in value, which I could see happening, but it may not be a big deal, so I'll change the code and try it.
    Thanks again for your help πŸ™‚
    The original code is written for a Momentary switch. Press it and it closes the circuit driving a change of state, release it and again it changes back to an open circuit and the pin state changes again.
    You have a toggle switch which when 'flipped' remains in its new state.
  • 24
  • 15
