Binary Control Modules , Switches, or Outlets on a Vera Edge
  • Hello my name is Bob and I have been with this forum for several months , I was having much trouble with getting started with My Sensors for various reason but with some help from members and patience I finally got it working. I built 2 LUX sensors first then I wanted to control some lights and fans remotely so I searched this forum ,found several interesting projects that used relays and "door/Window" switches so I modified the reed switches that were used to "mini" toggle switches and then modified the code so I am using 6 switches to control 3 different "Zwave" modules and 3 different "Zwave" Wall switches. I used a Arduino Nano for the 1st unit and placed it in a small enclosure and powered it with a 5 vdc wall wart. I will built 3 more of these units and place them in different rooms to control the same modules and wall switches and in one room one of the unit I build will control 3 different modules and or wall switches. Now I believe in Home Automation and most of my home the lights either turn on by motion or some by time , Wall outlets are turned on by time and off by time. My alarm system is also turned on/off by time except when I am away from the home they you must activate a virtual switch on your phone or tablet using the Vera Mobile interface. Now you will see in the sketch that my msg for each switch is for my use and you may have to change the msg to your needs. Also the Sleep time has not been tested , I was just thinking ahead a bit to see if I could conserve power and make this project able to be powered by batteries. The current draw when this is in operation as is , about 33 ma a bit more when transmission is used but since it mostly listens the 32-33 ma is about right for a Nano, Now you can also use a Pro-Mini and naturally You can use 3.3 v version of Pro-Mini. Below are the pictures of the build placed in a temporary case. So if anyone is interested in the Vera coding or the sketch coding let me know, and I will try to help you. Thanks for reading, Have a great day.
    /* This Sensor has multi Binary Inputs
    /* It can control vera modules by either using PLEG properties,trigger and conditions and actions
    /* or you can use "combination switch" app along with scenes to do the toggling
    /* of the action for a given binary condition
    /* you use digital pins as inputs and connect a spst switch between digital input and Gnd
    /* normally open switches are easiest to use
    /* This is built on a Nano or a pro-mini */
    //unsigned long SLEEP_TIME = 30000; // 30000 Sleep time between reads (in milliseconds)
    #define BUTTON_PIN_1 3 // Arduino Digital I/O pin for button/switch
    #define BUTTON_PIN_2 4 // Arduino Digital I/O pin for button/switch
    #define BUTTON_PIN_3 5 // Arduino Digital I/O pin for button/switch
    #define BUTTON_PIN_4 6 // Arduino Digital I/O pin for button/switch
    #define BUTTON_PIN_5 7 // Arduino Digital I/O pin for button/switch
    #define BUTTON_PIN_6 8 // Arduino Digital I/O pin for button/switch
    #define CHILD_ID_BUTTON_PIN_1 3
    #define CHILD_ID_BUTTON_PIN_2 4
    #define CHILD_ID_BUTTON_PIN_3 5
    #define CHILD_ID_BUTTON_PIN_4 6
    #define CHILD_ID_BUTTON_PIN_5 7
    #define CHILD_ID_BUTTON_PIN_6 8
    Bounce debouncer_1 = Bounce();
    Bounce debouncer_2 = Bounce();
    Bounce debouncer_3 = Bounce();
    Bounce debouncer_4 = Bounce();
    Bounce debouncer_5 = Bounce();
    Bounce debouncer_6 = Bounce();
    int oldValue_1 = -1;
    int oldValue_2 = -1;
    int oldValue_3 = -1;
    int oldValue_4 = -1;
    int oldValue_5 = -1;
    int oldValue_6 = -1;
    MyMessage msgMBR(BUTTON_PIN_1, V_TRIPPED);
    MyMessage msgGBR(BUTTON_PIN_2, V_TRIPPED);
    MyMessage msgLR1(BUTTON_PIN_3, V_TRIPPED);
    MyMessage msgMBF(BUTTON_PIN_4, V_TRIPPED);
    MyMessage msgGBF(BUTTON_PIN_5, V_TRIPPED);
    MyMessage msgDRF(BUTTON_PIN_6, V_TRIPPED);
    gw.begin();
    gw.sendSketchInfo("RemoteControl", "1.05");
    // Setup the Switch sensor
    pinMode(BUTTON_PIN_1, INPUT_PULLUP);
    pinMode(BUTTON_PIN_2, INPUT_PULLUP);
    pinMode(BUTTON_PIN_3, INPUT_PULLUP);
    pinMode(BUTTON_PIN_4, INPUT_PULLUP);
    pinMode(BUTTON_PIN_5, INPUT_PULLUP);
    pinMode(BUTTON_PIN_6, INPUT_PULLUP);
    debouncer_1.attach(BUTTON_PIN_1);
    debouncer_1.interval(5);
    debouncer_2.attach(BUTTON_PIN_2);
    debouncer_2.interval(5);
    debouncer_3.attach(BUTTON_PIN_3);
    debouncer_3.interval(5);
    debouncer_4.attach(BUTTON_PIN_4);
    debouncer_4.interval(5);
    debouncer_5.attach(BUTTON_PIN_5);
    debouncer_5.interval(5);
    debouncer_6.attach(BUTTON_PIN_6);
    debouncer_6.interval(5);
    /* Register binary input sensor to gw (they will be created as child devices) */
    gw.present(BUTTON_PIN_1, S_DOOR);
    gw.present(BUTTON_PIN_2, S_DOOR);
    gw.present(BUTTON_PIN_3, S_DOOR);
    gw.present(BUTTON_PIN_4, S_DOOR);
    gw.present(BUTTON_PIN_5, S_DOOR);
    gw.present(BUTTON_PIN_6, S_DOOR);
    // Check if digital input has changed and send in new value
    // Get the update value
    debouncer_1.update();
    int value_1 = debouncer_1.read();
    if (value_1 != oldValue_1) {
    // Send in the new value
    gw.send(msgMBR.set(value_1 == HIGH ? "1" : "0"));
    oldValue_1 = value_1;
    debouncer_2.update();
    int value_2 = debouncer_2.read();
    if (value_2 != oldValue_2) {
    gw.send(msgGBR.set(value_2 == HIGH ? "1" : "0"));
    oldValue_2 = value_2;
    debouncer_3.update();
    int value_3 = debouncer_3.read();
    if (value_3 != oldValue_3) {
    gw.send(msgLR1.set(value_3 == HIGH ? "1" : "0"));
    oldValue_3 = value_3;
    debouncer_4.update();
    int value_4 = debouncer_4.read();
    if (value_4 != oldValue_4) {
    gw.send(msgMBF.set(value_4 == HIGH ? "1" : "0"));
    oldValue_4 = value_4;
    debouncer_5.update();
    int value_5 = debouncer_5.read();
    if (value_5 != oldValue_5) {
    gw.send(msgGBF.set(value_5 == HIGH ? "1" : "0"));
    oldValue_5 = value_5;
    debouncer_6.update();
    int value_6 = debouncer_6.read();
    if (value_6 != oldValue_6) {
    gw.send(msgDRF.set(value_6 == HIGH ? "1" : "0"));
    oldValue_6 = value_6;
    // gw.sleep(SLEEP_TIME);
    }20150804_134621.jpg 20150804_134514.jpg 20150804_134605.jpg 20150804_134614.jpg
    Great to see that you have your rig working just the way you like!
    You can simplify that code a lot with the use of arrays, for example (compiles but not tested):
    #define NUMBER_OF_PINS 6
    int buttonPin[NUMBER_OF_PINS] = {3,4,5,6,7,8};
    Bounce debouncer[NUMBER_OF_PINS] = Bounce();
    int oldValue[NUMBER_OF_PINS];
    MyMessage msg[NUMBER_OF_PINS];  /* or you can fashion the constructor like this:*/  //= {MyMessage(0,V_TRIPPED),MyMessage(1,V_TRIPPED),MyMessage(2,V_TRIPPED),MyMessage(3,V_TRIPPED),MyMessage(4,V_TRIPPED),MyMessage(5,V_TRIPPED)};
      gw.begin();
      for (int i = 0; i < NUMBER_OF_PINS; i++)
        msg[i] = MyMessage(i, V_TRIPPED); // instead of this
        gw.present(i, S_DOOR);
        pinMode(buttonPin[i], INPUT_PULLUP);
        debouncer[buttonPin[i]].attach(buttonPin[i]);
        debouncer[buttonPin[i]].interval(5);
        debouncer[i].update();
        if (value != oldValue[i])
          gw.send(msg[i].set(value));
          oldValue[i] = value;
      gw.begin();
    Thanks will try out code and let you know if that works.
  • @BulldogLowell I tried your sketch, had to put in the digitalwrite(i,HIGH), but even then it would only find 5 of the 7 nodes it needed, Switch 3-8 and the Arduino Node. I will see later what is going on because it should have worked .
    @mntlvr,
    so this single line of code:
    pinMode(myPin, INPUT_PULLUP);
    is identical to these two lines of code:
    pinMode(myPin, INPUT);
    digitalWrite(myPin, HIGH);
    try adding some hold time to make sure your radio has enough power to transmit:
      gw.begin();
        gw.wait(75); //<<<<<<<<<<<<<<<<<<<<<< here
  • @BulldogLowell , You are so correct the two lines of code mean exactly the same, thank you for pointing that out, so wo I will try this code again and I will try my modified code and see what happens. Now both should work but your code is more Nano or Pro-Mini friendly when it comes to memory.
  • @BulldogLowell
    I tried the code again but it still only finds 0-4 delay made no difference. Also I don't follow your code for changing the msg so it shows 1,2,3,4,5,6 tripped could use a little visual help on this also. I am trying to trap the condition that is preventing it from running 0-5 instead of 0-4.
    @mntlvr
    use some serial debug messages like this to see what's what:
    MyMessage msg[NUMBER_OF_PINS]; //= {MyMessage(0,V_TRIPPED),MyMessage(1,V_TRIPPED),MyMessage(2,V_TRIPPED),MyMessage(3,V_TRIPPED),MyMessage(4,V_TRIPPED),MyMessage(5,V_TRIPPED)};
      gw.begin();
        Serial.print(F("Setting up Pin"));
        Serial.println(i);
        gw.wait(100);
      Serial.println(F("Sensor presentation complete"));
          Serial.print(F("Pin "));
          Serial.print(i);
          Serial.print(F(" changed state...  New State: "));
          Serial.println(value? F("Tripped") : F("Not Tripped"));
  • @BulldogLowell
    Bulldog I ran your debug code and here is the 6th irratition of the Serial Monitor on IDE ver 1.6.4
    • sensor started, id 32
      send: 32-32-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
      send: 32-32-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
      send: 32-32-0-0 s=255,c=3,t=11,pt=0,l=13,st=fail:RemoteControl
      send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=fail:1.05
      Setting up Pin0
      send: 32-32-0-0 s=0,c=0,t=0,pt=0,l=0,st=fail:
      Setting up Pin1
      send: 32-32-0-0 s=1,c=0,t=0,pt=0,l=0,st=fail:
      Setting up Pin2
      send: 32-32-0-0 s=2,c=0,t=0,pt=0,l=0,st=fail:
      send: 32-32-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
      Setting up Pin3
      send: 32-32-0-0 s=3,c=0,t=0,pt=0,l=0,st=fail:
      read: 32-32-0 s=3,c=0,t=0,pt=0,l=0:
      Setting up Pin4
      send: 32-32-0-0 s=4,c=0,t=0,pt=0,l=0,st=ok:
      read: 32-32-0 s=4,c=0,t=0,pt=0,l=0:
      Setting up Pin5
      send: 0-0-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
      read: 48-201-0 s=0,c=5,t=0,pt=0,l=0:
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      send: 0-0-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:1
      Pin 3 changed state... New State: Tripped
      send: 0-0-0-0 s=4,c=1,t=16,pt=2,l=2,st=ok:1
      Pin 4 changed state... New State: Tripped
      send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:1
      Pin 5 changed state... New State: Tripped
      send: 0-0-0-0 s=0,c=1,t=16,pt=2,l=2,st=ok:1
      Pin 0 changed state... New State: Tripped
      send: 0-0-0-0 s=1,c=1,t=16,pt=2,l=2,st=ok:1
      Pin 1 changed state... New State: Tripped
      send: 0-0-0-0 s=2,c=1,t=16,pt=2,l=2,st=ok:1
      Pin 2 changed state... New State: Tripped
  • @BulldogLowell
    Connected pin 5 to ground and reset Serial Monitor windows and this is the results
      send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=fail:1.08
      Setting up Pin0
      Setting up Pin1
      Setting up Pin2
      Setting up Pin3
      Setting up Pin4
      Setting up Pin5
      read: 50-219-0 s=0,c=5,t=0,pt=0,l=0:
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
    This is as far as the code went..
    you would need to flip the switches to see anything else 🙂 so try that.
    this is a problem:
    Setting up Pin0
    Setting up Pin1
    Setting up Pin2
    Setting up Pin3
    let's slow down the startup... it looks like your initial radio messages are not making it to the gateway.
    #define RADIO_ID 32
      delay(1000);
      Serial.print(F("Sending device info..."));
      gw.begin(NULL, RADIO_ID, false);
      gw.wait(250);
        Serial.println(i);
        gw.wait(250);
          Serial.print(i);
    How are you powering the node? Is there any capacitor between radio VCC / GND? If you have an spare radio/power supply try replacing them. Make sure radio gets stable, 1.9-3.6V supply.
    And check this thread. Many of us are experiencing random results from fake radios...
  • @BulldogLowell Ok Bulldog ran new code still getting Version Mismatch?and at the beginning fails.
    My transceiver is about 4 feet away from the gateway.
    • .sensor started, id 32
      Setting up Pin0
      Setting up Pin1
      Setting up Pin2
      Setting up Pin3
      Setting up Pin4
      0;0;3;0;9;send: 32-32-0-0 s=4,c=0,t=0,pt=0,l=0,st=ok:
      Setting up Pin5
      0;0;3;0;9;send: 0-0-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
      read: 52-63-0 s=0,c=5,t=0,pt=0,l=0:
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      0;0;3;0;9;send: 0-0-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:1
      0;0;3;0;9;send: 0-0-0-0 s=4,c=1,t=16,pt=2,l=2,st=ok:1
      0;0;3;0;9;send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:1
      0;0;3;0;9;send: 0-0-0-0 s=0,c=1,t=16,pt=2,l=2,st=ok:1
      0;0;3;0;9;send: 0-0-0-0 s=1,c=1,t=16,pt=2,l=2,st=ok:1
      0;0;3;0;9;send: 0-0-0-0 s=2,c=1,t=16,pt=2,l=2,st=ok:1
    Setting up Pin5
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    yeah, this isn't what I would expect, but maybe hardware related... look here.
    Power is my first instinct.
    @hek any ideas here?
    also, you didn't try flipping the switches!
    Message seems corrupt... command-type=5!!
    Underpowered or some strange mix of different radio-modules.
  • @BulldogLowell Bulldog
    The power is coming from 2 LIPO 1500mAH batteries in series, so the boards input voltage is 8.4 volts which the on board regulator is handling on the 24l01 so the nRF24l01 is getting 3.3 volts one 22ufd caps on input right on nrf24l01 board. I am running the exact setup my first board is using when I built it on a Nano. On the Nano build when I would ground anyone of the input pin the Vera would show the state of change right away and so would the Serial Monitor on IDE. I will keep on it until I resolve it.
  • @hek All the radio modules are nRF24l01+ and I have 3 other sensors all working just fine with this gateway all using the same transceiver from the same company.
  • @hek this is the Serial Monitor output from the same board powered the same way except running my original code and no failures.
    You can see when I gnd the input the output responds.
    send: 32-32-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
    send: 32-32-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    send: 32-32-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:RemoteControl
    send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:1.05
    send: 32-32-0-0 s=3,c=0,t=0,pt=0,l=0,st=ok:
    send: 32-32-0-0 s=5,c=0,t=0,pt=0,l=0,st=ok:
    send: 32-32-0-0 s=6,c=0,t=0,pt=0,l=0,st=ok:
    send: 32-32-0-0 s=7,c=0,t=0,pt=0,l=0,st=ok:
    send: 32-32-0-0 s=8,c=0,t=0,pt=0,l=0,st=ok:
    send: 32-32-0-0 s=3,c=1,t=16,pt=0,l=1,st=ok:1
    send: 32-32-0-0 s=4,c=1,t=16,pt=0,l=1,st=ok:1
    send: 32-32-0-0 s=5,c=1,t=16,pt=0,l=1,st=ok:1
    send: 32-32-0-0 s=6,c=1,t=16,pt=0,l=1,st=ok:1
    send: 32-32-0-0 s=7,c=1,t=16,pt=0,l=1,st=ok:1
    send: 32-32-0-0 s=8,c=1,t=16,pt=0,l=1,st=ok:1
    send: 32-32-0-0 s=5,c=1,t=16,pt=0,l=1,st=ok:0
    I suspect the message array is doing some buffer overwrite.
    Just define one msg and reuse it with
    msg.setSensor(x)
    msg.setSensor(x)
    agree...
    look here:
    not winding its way through the array like you wold expect.
    @mtnlvr
    like this perhaps:
    #define RADIO_ID 32
    MyMessage msg(0,V_TRIPPED);
      delay(1000);
      gw.wait(250);
        Serial.println(i);
        gw.wait(250);
          msg.setSensor(i);
          gw.send(msg.set(value));
          Serial.print(i);
  • @BulldogLowell
    This seems to work much better but what is the "version mismatch"?
    You can see the change of pin 5 now immediately now when I connect it to gnd or leave it open.
    Sending device info...sensor started, id 32
    read: 0-0-32 s=255,c=3,t=6,pt=0,l=1:I
    send: 32-32-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:1.15
    Setting up Pin0
    send: 32-32-0-0 s=0,c=0,t=0,pt=0,l=0,st=ok:
    Setting up Pin1
    send: 32-32-0-0 s=1,c=0,t=0,pt=0,l=0,st=ok:
    Setting up Pin2
    send: 32-32-0-0 s=2,c=0,t=0,pt=0,l=0,st=ok:
    Setting up Pin3
    Setting up Pin4
    Setting up Pin5
    read: 39-155-0 s=0,c=5,t=0,pt=0,l=0:
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    version mismatch
    send: 0-0-0-0 s=5,c=1,t=16,pt=2,l=2,st=ok:0
    Pin 5 changed state... New State: Not Tripped
    You seem to have radio disturbance (or the nodes radio get wacky when gateway sends its ack...).
    I think I have similar things when underpowering my gateway and sending with full power on a amplified nrf-module.
  • @hek I just re-ran my Serial Monitor and now pin 5 only shows "version mismatch" I don't know how else to power any of these units because I have a 9 vdc 1 amp power pack on the Gateway and my sensors all have 1 amp, 9 vdc power packs
    @mntlvr
    I really never use toggle switches like you are using here but it dawned on me that you are drawing current on all six pins simultaneously using the internal pull-ups. Perhaps you are overdrawing the power of the arduino a bit, causing the spurious results. We don't see the error until we power up that #5 pin.... but you are getting some crazy radio activity prior to that after we power up pin 3. That's where it occurred to me that we may be asking too much of your arduino, sinking all of the 6 pins to ground at once.
    Can you try:
    a: opening all of the switches before initialization and see if you still get the funky version mismatch error? Or,
    b: just let the pins float by changing the initialization of the pin to:
    pinMode(buttonPin[i], INPUT);
    and see if it at least initializes correctly (your switches won't work correctly, that's fine to test this theory).
    just spitballing here... but if that helps, there are solutions (at least one of which may require you to remove some of that lovely potting ;).
    @mntlvr
    Can you try:
    Oh no Bulldog that is the one unit that is working just fine, all the version mismatches comes from your code I am trying out and we are making progress. For some reason when you are using arrays and for next loop this is where some of the issues are . If you look up a few replys when I replied to @hek I was using my code and there were no version mismatches.
    @mntlvr
    yes, I meant with my code!
  • @BulldogLowell
    O.k I will try your change when I can get some free time and see if I can prove out your theory.
    @mntlvr
    Can you try:
    Now when I sent my last set of results and most of the other including my code I leave all but 1 pin open and most of the time all pins open. And if all six switches are set to gnd the total current would only be 1.5 ma (5volts /20k)x6=.0015 amps I believe. the internal pullup resistors are 20k-50k according to arduino spec.
    yeah, I know, but if you are underpowered already (the radio....) the extra draw may create an issue... who the heck knows.
    I'll try on one of mine when I get the chance... your code works, and that's a treat, but now I need to understand why the simpler execution of the same code doesn't seem to cooperate with your rig.
    weird...
    weird...
    Bulldog same power pack is running nRF24l01+ in the fully working unit as in this test sensor I am using with your code I don't believe power is the issue my code probably runs much slower than yours and that might be the issue I will play with slowing down your code even further and see if it makes any difference. We shall overcome...
    weird...
    My code and changed to High powered nRF24l01+ Transceiver only running off of USB cable nothing else..
    This is a UNO and it is very repeatable output no version mismatch and no long hesitation on pin 4 or 5 or 6.
      Sending device info...send: 32-32-0-0 s=3,c=0,t=0,pt=0,l=0,st=ok:
      Pin 3
      Pin 4
      Pin 5
      Pin 6
      Pin 7
      Pin 8
    weird...
    you code with pinMode(buttonPin[i], INPUT);
    exactly same board and USB power supply and same transceiver, here are the results
    • Sending device info...sensor started, id 32
      Setting up Pin0
      Setting up Pin1
      Setting up Pin2
      Setting up Pin3
      Setting up Pin4
      Setting up Pin5
      read: 36-81-0 s=0,c=5,t=0,pt=0,l=0:
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      version mismatch
      send: 0-0-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:0
      Pin 3 changed state... New State: Not Tripped
  • 11
  • 7
  • 53
  • 6
