  3. Version Mismatch
Version Mismatch
10 Posts 5 Posters 5.1k Views 4 Watching
  • K Offline
    K Offline
    Kurtsejr
    Hi all
    I have a strange new behave with my Ethernet GW connected to my VeraEdge (latest SW), from the GW terminal output I get a lot of these:
    0;0;3;0;9;version mismatch
    0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l
    I can see from the protocol that “3” means a request for a node ID, but I have switched off all my notes – so it seems to come from the GW itself – is this correct?
    it seems to be an outgoing message because of “0” after “3” – sub-type (9) indicates a wind sensor – this gives no meaning, my weather station is running 433 Mhz.
    My Vera and GW have been switched off for a few weeks because of Sonos problems, so I dont know when this has started.
    When I search the forum, I can’t really find similar problems
    /Kurt
    • hekH Offline
      hekH Offline
      Yes, this is a debug message from the gateway. Library checks the protocol version of the incoming messages which in your case seems to be corrupt (everything seems to be zeroes... ).
      https://github.com/mysensors/Arduino/blob/c1afc7d8e9c87d6ae2daef1b0dbcbf60d73dfab5/libraries/MySensors/MySensor.cpp#L275-L278
      • K Offline
        K Offline
        Kurtsejr
        Thanks for quick reply
        Does this mean that I have a device that send me data or is it a mismatch caused by wrong GW software?
        Kurt
        • hekH Offline
          hekH Offline
          This looks weird. Do you use the same type of radio modules on gw/nodes? Feed them enough powe?
          • K Offline
            K Offline
            Kurtsejr
            I'm now powering my UNO with a separate power supply, but with the same problem. I will try to substitute HW and are coming back when I found out why!
            /Kurt
            • K Offline
              K Offline
              Kurtsejr
              SOLVED:
              I have changed most of my hardware, it seams to be the UNO who did something strange. I also updated to lib version 1.5 and latest Arduino IDE - now all is ok again :-)
              /Kurt
              • Julien BALAXJ Offline
                Julien BALAX
                wrote on last edited by Julien BALAX
                I have quite the same problem :
                0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                0;0;3;0;9;ver mismatch
                I only have a serial gateway. No senors for now. Anyone have a clue to find a solution except change hardware parts ?
                • choffmannC Offline
                  choffmannC Offline
                  choffmann
                  i have the same problem that i get version mismatch
                  i have installe arduino version 1.6.5 an Mysensors librarie 1.5.4
                  also i habe vhanged the channel "#define RF24_CHANNEL" from 76 to 120 and to 20!
                  in Each Case i have the problem with ver mismatch.
                  There are no other devices on this channel.
                  i hope you can help me
                  • markappaM Offline
                    markappaM Offline
                    markappa
                    I have the same problem.
                    When I power on the sensor, the gateway loops forever.
                    Power up gateway:
                    When I power up the sensor, the gateway starts to loop:
                    Even switching off the sensor, the gateway continues looping forever.
                    I have exactly the same library version on serial gateway and sensor.
                    Gateway and sensor did work together in the past, then I switched to eclipse IDE and changed some code on the sensor side.
                    I am using SOFTSPI.
                    Any clue?
                    I will try rebuilding with the Arduino IDE to see if it has any influence :confused:
                    • markappaM Offline
                      markappaM Offline
                      markappa
                      Problem solved for my case. :smiley:
                      Just to give a hint to anyone who might have a similar problem, I had misconfigured the default pin assignments.
                      In particular the INCLUSION_MODE_PIN definition was colliding with one of the LED pins (maybe RADIO_RX_LED_PIN).
                      Hope this helps.
                      113.2k
