pb compilation MEGA2560 + sketch W5100
    I'm Mysensors user newbie 😉 and I want create Ethernet Gateway
    I use:
    • Arduino 1.6.4 on Yosemit
      --> IDE in System/Applications
      --> library are in /Volumes/Data/Documents/Arduino/Arduino-master (or Arduino-development)
    • MEGA2560
    • Ethernet Shield W5100 (like this : https://www.arduino.cc/en/Guide/ArduinoEthernetShield)
    • NRF24L01+ (1436AH)
    • MySensors Arduino Library v1.5
    Pin configuration:
    CE : 10
    CSN : 11
    MISO : 50
    MOSI : 51
    SCK : 52
    I uncommented #define SOFTSPI in MyConfig.h
    But compilation doesn't work. Can you help me please?
    EthernetGateway.ino:59:90: fatal error: DigitalIO.h: No such file or directory
    compilation terminated.
    For information:
    • I tryed master and development branch and it's the same
    • I tryed without Ethernet Shield W5100, same again
    Thank you for your help,
    Fabrice.
    I use:
    • MEGA2560
    Pin configuration:
    CE : 10
    CSN : 11
    MISO : 50
    MOSI : 51
    SCK : 52
    For information:
    Fabrice.
    Where is your "mysensor" library?
    Digital.io is in the utilities directory of "mysensors".
    DigitalIO
    /Volumes/Data/Documents/Arduino/libraries/Arduino-master/DigitalIO
    MySensors
    /Volumes/Data/Documents/Arduino/libraries/Arduino-master/MySensors
    I don't have utilities directory in MySensors
    For information, if I use EthernetGatway exemple in mysensor site : http://www.mysensors.org/build/ethernet_gateway
    If I comment "#include <DigitalIO.h>" I have a same problem with other include : MySigningNone.h, MyTransportRFM69.h ...
    Only SPI.h is OK
    Thanks for your help
    Development branch should be working for you.
    Branch development is same 😞
    MyConfig.h
    #define SOFTSPI
    #ifdef SOFTSPI
    	const uint8_t SOFT_SPI_MISO_PIN = 50;
        const uint8_t SOFT_SPI_MOSI_PIN = 51;
        const uint8_t SOFT_SPI_SCK_PIN = 52;
    And I use default example EthernetGateway.ino
    Other suggestion please?
  • compilation OK !!!
    In fact I move in directory /Volumes/Data/Documents/Arduino
    • DigitalIO
    • list itemMySensors (branch development)
    • list itemPinChangeInt
    ping OK
    but I have fail msg in serial : 0;0;3;0;9;radio init fail
    One suggestion please?
  • 24
45
