Which are the *best* NRF24L01+ modules?
    Here is the simple test jig that I made, using a 1 ohm resistor:
    Here it is mounted on the RFToy:
    Here is how I hooked up the oscilloscope probe:
    For comparison, here are the measurements taken on an ITEAD module:
    So, purely eyeballing it, I'd say the Itead uses about, what, 13ma? The blob module is using maybe 20ma. Perhaps that difference in transmitter current, at least in part, explains the range difference that I observed.
    For further comparison, here are the measurements taken on the red module from earlier in the thread:
    Again, just eyeballing it, that looks like, what, maybe 23ma? Acually more than the blob module, it would seem.
    @NeverDIe Very intersting measurements dude!
    I have a gut feeling for some time that accurately measuring the transmission/reception current of a chip could be used to distinguish fake from real (and of course xray/boiling acid, which is impossible to do for the average consumer).
    Both the width and level of the current spikes are different for each module.
    Could you post the sketch used for measurement somewhere, so I can repeat your measurements?
    I have some 100% genuine Nordic modules, which can be used for reference.
    Here it is:
     nRF24Sender Demo for RFToy
     This demo shows how to use RFToy to make a
     wireless temperature sensor. This is the
     sender module which transmits the current
     temperature value to a receiver module. The
     demo uses the Mirf library.
     This demo uses a 100K resistor and 100K
     thermistor to form a simple temperature
     sensor. Pin A1 is used to read the value.
     The connection is:
     VCC->100K->A1->thermistor->GND
     Written by Jonathan Goldin @ Rayshobby LLC
     Nov 2014
     For details, visit http://rayshobby.net/rftoy
    #include <Mirf.h>
    #include <nRF24L01.h>
    #include <MirfHardwareSpiDriver.h>
    #include <U8glib.h>
    U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);	// I2C / TWI
    void setup(){
       Set ce and csn pins
      Mirf.cePin = 17;
      Mirf.csnPin = 16;
      Mirf.spi = &MirfHardwareSpi;
      Mirf.init();
       * Configure reciving address.
      Mirf.setRADDR((byte *)"clie1");
       * Set the payload length to sizeof(unsigned long) the
       * return type of millis().
       * NB: payload on client and server must be the same.
      //Mirf.payload = sizeof(long);
       * Write channel and payload config then power up reciver.
       * To change channel:
       * Mirf.channel = 10;
       * NB: Make sure channel is legal in your area.
        // we use channel 90 as it is outside of WLAN bands
      // or channels used by wireless surveillance cameras
      //Mirf.channel = 90;
      Mirf.config();
      //This register value is not remembered between power cycles.
      //It defaults to 0x0F.
      //It should be initialized each time if different than 0x0F.
      Mirf.configRegister(RF_SETUP,0x07); //0x0F is 2mbps, max Tx power
                                          //0x07 is 1mbps, max Tx power
                                          //0x2F is 250kbps, max Tx power.
      Serial.println("OTA datarate set to  1Mbps.  Transmit Power set to Maximum.");
      // Read and print RF_SETUP
     byte rf_setup = 0;
     Mirf.readRegister( RF_SETUP, &rf_setup, sizeof(rf_setup) );
     Serial.print( "rf_setup = " );
     Serial.println( rf_setup, BIN );
      // OLED
      u8g.firstPage();
      do{
        uint8_t h;
        u8g.setFont(u8g_font_10x20);
        u8g.setFontRefHeightText();
        u8g.setFontPosTop();
        h = u8g.getFontAscent()-u8g.getFontDescent();
        u8g.drawStr(29,(u8g.getHeight()-h)/2,"Tx Sender");
      while(u8g.nextPage());
      Mirf.setTADDR((byte *)"serv1");
      Serial.write("Sending...\r\n");
      delay(200);
    } // End of *Setup*
    long temp;
      int temp1;
      int temp2;
      long timeTxSent;
      long timeRxReceived;
      long roundTrip;
      byte age1=52;
      byte age2=11;
      long txCounter=0;
      long matchCount=0;
      long differentCount=0;
      long lostCount=0;
      long cumulativeRoundTrip=0;
      long averageRoundTrip=0;
      boolean packetLost=false;
      float packetErrorRate=0;  //no errors yet, and maybe there never will be.
      float lostPacketRate=0;  //no packets lost yet.
      const int statusFrequency=500;  //How many iterations of main loop before printing status info.
      long minRoundTrip=9999; //value will be driven down when program runs
      long maxRoundTrip=0;  //value will be driven up when program runs
    void loop(){
      txCounter++;
      temp = txCounter;  //getTemp(resistance);
      timeTxSent=micros();
      Mirf.send((byte *)&temp);
      while(Mirf.isSending()){
      while ((micros() - timeTxSent) < 10000) {  //send at intervals of 10 milliseconds = 10,000 microseconds.
    }  //End of main loop.
    By the way, an RFToy is, from an IDE perspective, basically an 8Mhz Pro Mini.
    @NeverDie Thanks, but it has quite some dependencies: Mirf, MirfHardwareSpiDriver & u8glib... I guess I have to strip it first.
    Furthermore, which nrf24 library did you use? The one from tmrh20?
    Mirf is the nrf24 library. It's what the RFToy example used, so I started with it, because it "just worked" out of the box. It just happens to be as far as I've gotten so far. I haven't yet converted to tmrh20, which would look more familiar to you.
    The start loop is just a left-over from when I was doing echo testing. I removed the OLED for this test because it was a potential source of interference, so any code related to that could be deleted. Obviously, most of the global variables aren't needed either. As far as transmitting once every 10ms, all the action happens in the main loop, which is pretty simple. It's all fairly basic, because up until I actually did it, I wasn't sure I could even get a sufficiently noiseless signal to measure. Luckily, running the RFtoy on a coincell, and because it's compact and without dangling wires, made that possible.
    So, in terms of which library to install, at the moment the easiest would be to load the RFToy library.
    Or you can wait until I convert over to tmrh20, and then you can follow along that way. I'll need to do that to do the sleep measurement, and because TMRH20 is currently the leading library to use--at least that's what ManiacBug seems to think.
    Or, if you already know tmrh20, you could code it yourself. The pseudo-code is quite simple:
    1. Note the time in microseconds.
    2. Send a packet with a 4 byte data payload (i.e. a LONG)
    3. Wait until the current time exceeds the time in step 1 by at least 10,000 microseconds.
    4. Goto Step 1
    What I don't know are the defaults for ACK's and # of retries, if any, in Mirf and in TMRH20. Aside from that possible difference, I would imagine the current draws are going to be the same in either library, wouldn't you?
    Perhaps the cleanest thing would be to skip the libraries entirely and do it all purely by register manipulations. That'd probably be a diversion from where I want to go, but maybe not a huge diversion. After all, how hard could it be? Since the guys doing the mysensors library for the attiny85 appear to be stuck, I may eventually have to do it that way if I want to use an attiny85 (which I do).
    @NeverDIe I committed a small sketch + NRF24 library which should essentially do the same as your sketch.
    Please find it at https://github.com/Yveaux/NRF24_CurrentFingerprint.
    I verified its behavior using the NRF24 sniffer:
    upload-c8184e00-67be-43e9-af4c-43242e39b830
    Maybe we could compare register settings to be absolutely sure settings are identical:
    upload-1418cfa7-5a26-40ff-9531-7221378b1875
    Maybe you can repeat one of your measurements with this sketch, just to make sure we're measuring in the same way?
    Currently I'm having a hard time measuring the actual current during transmit. I've not been able to get the individual spikes on the scope, not by using a uCurrent nor a single 1ohms resistor.
    This is a uCurrent plot, set at 1mV/uA:
    upload-2a6efb00-7e6a-462f-b3ce-f3a179b80ae6
    That boils down to 1.3mA peak during transmission... That can't be right?!
    Small update: using a 10ohms resitor, the current profile looks like:
    upload-fe4a379b-9a19-4e5d-ba78-086f1906e86b
    10mV/mA, so my module peaks at 11.7 mA. This module contains a 100% genuine Nordic nRF24L01+.
    A module containing a proven fake nRF24L01+ (marked 1242AF), reveals following current profile:
    upload-916e4d87-e4f8-4262-bef9-fd82dbfbca1d
    This one peaks at 19.8mA !!
    Register settings and on-air packets are identical.
    For completenes my measurement setup:
    • Lab supply, which powers USB isolator
    • USB isolator between PC & Arduino (otherwise ground-loops mess things up when using a USB scope on the same PC)
    • 10 ohms resistor
    upload-3ba85b97-4e4a-40af-86f6-00f38b5d545b
    That's great!
    The red module I tested (above) also used 1242AF. So, asuming the NRF chip in the Itead is genuine (which seems increasingly likely), then proportionately speaking, we're getting similar measurements.
    Aside from the Picoscope, what is your test setup? You don't seem to be experiencing the fat scope lines that I am. Where is the NRF module in your photo? Is it being levitated by the wires in the photo? I'm surprised the wires don't seem to be picking up noise.
    @NeverDie I added it to my previous post.
    Overview of whole setup:
    upload-f518c490-0a0f-4376-899d-14af8966192a
    I never had issues with the wires picking up noise; at least not enough to distort communication. They're approx. 20cm long.
    One more:
    upload-972e72b1-ed33-4440-8f4f-602ac91263bf
    Module with nRF marked 1322DQ, supposedly genuine.
    Also 11.2mA
    Tried it with another, random 1242AF, which gave 21.4mA
    Exactly which USB isolator are you using? Sounds like I should get myself a couple in case I ever need to do this again.
    @NeverDie A Chinese clone of this circuit: https://www.circuitsathome.com/measurements/usb-isolator
    The power socket is used to power the isolated USB side.
    Beware this isolator ca only handle FullSpeed (12MBit/s), so not USB 2.0 HighSpeed (480MBit/s).
    This prevents me from isolating my USB scope with it...
    Your setup roughly resembles my first attempt, where I was also using an Uno. However, I was overwhelmed with noise, which made me try the RFToy. I wasn't using isolators, though. I'm glad you got yours working, because it means that just about anyone with isolators and a scope can maybe do this test for themselves. As illustrated by you, the setup if pretty easy to follow. Good job!
    P.S. Does using ribbon cable, as you are doing, rather than individual Dupont wires (as I did when I tried using the Uno) also help with controlling noise?
    Interestingly, the USB cable that came with my Rigol has big ferrite cores on both ends of it. So, that probably helps as well.
    Actually, you could just power that arduino using a battery. Right? Having the isolator is nice, in that you can monitor what's happening, but not strictly necessary.
    So, really, I guess anyone with an o-scope can do this test, which is great!
    @NeverDie correct!
    With some simple hardware the uno could measure the current by itself and determine the maximum current used!
    This has potential!
    @Yveaux said:
    @NeverDie correct!
    This has potential!
    Which hardware would that be?
    It turns out my scope can do better than I thought. Here's the blob module again, but this time at 5mv/div.
    So, I may be able to use an even smaller resistor, because now I can go down to 1mv/div, whereas before it seemed it wouldn't let me go lower than 10mv/div. Hopefully that will help improve my measurement accuracy.
    @NeverDie shunt resistor & opamp. Not sure about the sampling speed of the AtMega yet. Have to dive into its data sheet first....
    @NeverDie transmission takes 233us in my measurements. What's the hdiv on your scope? 500/200us?
    Which chip? The 1242AF (presumed fake), or the one that might be genuine (the one on the Itead module)?
    @NeverDie any chip. Transmission time is identical every time.
    @Yveaux said:
    @NeverDie any chip. Transmission time if identical every time.
    Here's my best picture of the start of the transmission cycle for the blob module. I'm not sure where to call the actual start of it though, but we need to agree on that if we're going to compare numbers without pictures.
    It's labeled on the upper bar (just to the right of the red "STOP") 50us/div
    I modified the resister to be 1/2ohm, so now the vertical is 4ma/div, because it's 2mv/div vertical. Make sense?
    @NeverDie your horizontal scale is very different from what I measure.
    The initial low-level part in the last scope picture shows only part of what you identify as transmission time, while it already lasts roughy 250us. That's more than the whole transmission time I measure!
    We're definitely measuring differently.
    Quickly off my head: a single message is 14 bytes long (see the sniffer capture above). At 1mbit this will take 14*8/1mbit=112 us. Add some time for startup, preamble, shutdown etc. and I think total time will be in the order of 233us, as I measured.
    Could you try running the sketch I put on github to compare things? Probably you will only have to change cs/ss pins to run it (I stick to the default mysensors connections)
    It will also toggle a digital output on pin 3 before/after transmission which you can put on the scope together with the current measured, to have a reference when actual transmission takes place.
    Tonight (in 12 hours or so) I can do some more measurements if necessary.
    I just now noticed where you put your markers on your o-scope plot. There are two voltage increases, the second settles out higher than the first, and it looks like you're counting both. I would guess transmission doesn't really start until the higher voltage is reached, though, wouldn't you? That also is a better match to your 112us number. Perhaps the lower voltage corresponds to loading the buffer or something like that that doesn't need the higher transmit power.
    If you don't mind my asking, why the interest in the transmission length? Doesn't it have to be pretty similar from one type of chip to another, or else they won't interoperate?
    I think that's probably what's happening. I'm running on an 8Mhz Pro Mini (effectively), and you're running on a 16Mhz Uno. So, your first hump takes about half the time mine does ( is that right?), whereas both our second humps should take about the same amount of time. Ahhhhh..., except they don't. Your second hump appears to take longer than my blob module's second hump does. Mine is about 100us, and yours is about 150us? Is that what interests you?
    We would expect the data transmission per se to include a fixed prefix byte, 5 bytes of address, 9 bits of control, 4 bytes of payload, and 2 bytes of CRC (I think). 105 bits = 105uS. (I'm not sure where the 14 bytes in the calculation @Yveaux presented comes from. Either the nRF sends a 16 bit control but only documents 9 bits of it, or the nRF actually sends 9 bits but some software translates the 9th bit into a second byte for analysis purposes)
    Before that there's something like 130 uS to power up and stabilize. And there could be additional time gaps before or after the data per se.
    And of course before all that, there is the time to load the data and commands via SPI; power might potentially rise during that, I suppose.
    Only the time to load commands and data would seem to care whether the uC is running at 8 or 16 MHz. The 105 uS data time should be the same, if they are OTA compatible. The 130 uS power up and stabilizing time could vary between chip designs.
    Any way to see if the fake chip is one of those transmitting with more RF power output? (If it wastes more power doing the same job, not good. If it has the ability to run at higher power but can also be reduced to sip more carefully, that could be a win).
    I look forward to your further testing. Maybe worth checking how much supply current is saved in the other transmit power settings.
    How did you reduce the noise so much in your later scope captures?
    http://www.eevblog.com/forum/testgear/how-do-i-get-1mvdiv-on-the-1054z-i'm-only-getting-10mvdiv/
    Also,
    https://www.youtube.com/watch?v=DMXiD3dKYJc
    How's that for timely?
    Suggestion: for the clone/fake chips, could you test whether they have the SI24R01 power control?
    That is, set bit 1 of register 6 and see if they draw even more current. That should set the SI24R01 - or perhaps a derivative or clone of it - from 2-3 dBm to 7 dBm, which will probably mean using more supply current when the bit is 1 than when it's 0.
    See the (currently) last couple of links in the OP of the fakes thread.
    You might also see if the second register bank can be selected (ACTIVATE+0x53) and read. See http://sigrok.org/wiki/Protocol_decoder:Nrf24l01#Variants_and_clones_of_the_chip from the penultimate link on the fakes thread.
    If it has a second register bank then it's probably a BK24* series or a clone/derivative thereof. (Note that the contents of that second bank seem to be undocumented, at least in English). This niche is apparently popular enough that there are second level derivatives - for example advertised as being BK24* compatible which is in turn nRF24 compatible with extensions!
    I did catch a reference somewhere that implied there was a real RSSI in the second register bank in some derivative; that could be handy if true.
    There's a reference at that same link to the Nordic nRF24L01 (no plus) needing an ACTIVATE+0x73 command to enable certain features that are automatically available in the nRF24l01+.
    This is not something I am aware of. I wonder if some features like ESB can be enabled on the non-plus version? Anyway, if so, this might also be a test which helps sort out clones - if they look like a non-plus derivative, do they respond to ACTIVATE+0x73? (the linked source does not suggest that 250 Kbps mode is one of the features which could be activated)
    @Zeph: I'll may attempt those things tonight, though I'll be giving priority to moving over to TBRH20 first, as it will be better for comparisons if we minimize platform differences, as well as run the same library.
    I agree that using the same library is good for cross comparison among multiple experimenters.
    However, if it turns out that the power profile differs between libraries, on the same hardware sending the same packet, that would be worth some investigation as well to understand why (and perhaps learn how to optimize power). Yeah, that's a different question than detecting variants and understanding their advantages/disadvantages, but the same measurement hardware can be used.
    I was wondering if a small cap across your sense resistor might smooth the traces a bit, and still tell us what we want to know - which is about average power, on a multi-microsecond timescale.
  • Using a non-scientific method; looking at the angle of battery discharge graphs over a week, I've noticed that the modules I got from ITEAD are draining batteries at about half the rate compared to an unknown (but probably fake) pretty good module.
    ITEAD module; slightly under 1% per day
    "other modules"; about 2% per day
    This is when measuring and transmitting DHT21 data every minute.
    Sounds plausible. What cap value would you suggest? I pretty much skipped over learning analog electronics and haven't yet found the time to backfill that gap in my knowledge.
    I've been collecting on eevblog and elsewhere some seemingly good on-point advice about how to improve my scope captures in this situation. I'll probably learn one technique at a time, as time permits, and phase it in gradually.
    I don't really know what a good value would be. Since it's across a 1 ohm resistor (in one case), and you probably want an RC time in the vicinity of microseconds, I'd start with around 1 uF and move up or down from there based on the scope trace. You may be able to just clamp the (short) leads of a cap to your probes to get a look, before soldering.
    And I'll be interested in what other tips you collect that are useful.
    Good information. Hopefully, the scope will help sort out whether that faster drain is mostly during transmit/receive activity, or mostly during the idle time, or both.
    Sounds good. We'll solve for the cap value using empiricism. 😄
    Also, I want to start measuring sleep current soon, because it may prove decisive as to whether a module must be rejected from further consideration because of its potential impact on battery life. Stric's data suggests there are significant differences to be found there. I suspect saving power is one of the harder engineering challenges--or, if not, at least an area where clones may get sloppy--and it might serve as a good separator.
    Agreed. If the module takes more power during transmit because it's putting out more RF, we might be able to back it off by using less than the maximum power settings, or use it in applications where it more rarely transmits.
    But if it uses too much sleep current, it's a bad option for battery power.
    Exactly! You said it better than I did.
    @NeverDie It should be possible to get some better (noiseless) measurements on the rigol scope.... at least if I look at what HARI is measuring on the ESP8266 current...
    I hooked up the uCurrent inline with the Itead NRF24L01+ module, measured using a Fluke 87V multimeter, and I got these measurements:
    Powered Down (Sleep): 0.6uA
    Standby: 22.6uA
    I'm satisfied that these are within error tolerances for the expected results.
    Prior to that, I tested the blob module and seemed to get bizarre results. I'm going to go back and re-test now that I'm reasonably confident the test setup and measurements are working right.
    I'm using an Arduino Uno. This was the test code I used:
    /* Adapted by NeverDie on 8/11/2015 to facilitate uCurrent measurements.
     Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
     TMRh20 2014 - Updates to the library allow sleeping both in TX and RX modes:
          TX Mode: The radio can be powered down (.9uA current) and the Arduino slept using the watchdog timer
          RX Mode: The radio can be left in standby mode (22uA current) and the Arduino slept using an interrupt pin
     * Example RF Radio Ping Pair which Sleeps between Sends
     * This is an example of how to use the RF24 class to create a battery-
     * efficient system.  It is just like the GettingStarted_CallResponse example, but the
     * ping node powers down the radio and sleeps the MCU after every
     * ping/pong cycle, and the receiver sleeps between payloads.
     * Write this sketch to two different nodes,
     * connect the role_pin to ground on one.  The ping node sends the current
     * time to the pong node, which responds by sending the value back.  The ping
     * node can then see how long the whole cycle took.
    #include <avr/sleep.h>
    #include <avr/power.h>
    #include "nRF24L01.h"
    #include "RF24.h"
    #include "printf.h"
    // Set up nRF24L01 radio on SPI bus plus pins 7 & 8
    RF24 radio(7,8);
    // sets the role of this unit in hardware.  Connect to GND to be the 'pong' receiver
    // Leave open to be the 'ping' transmitter
    const int role_pin = 5;
    const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };   // Radio pipe addresses for the 2 nodes to communicate.
    // Role management
    // Set up role.  This sketch uses the same software for all the nodes
    // in this system.  Doing so greatly simplifies testing.  The hardware itself specifies
    // which node it is.
    // The various roles supported by this sketch
    typedef enum { role_ping_out = 1, role_pong_back } role_e;
    // The debug-friendly names of those roles
    const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
    // The role of the current running sketch
    role_e role;
    void setup(){
      // set up the role pin
      pinMode(role_pin, INPUT);
      digitalWrite(role_pin,HIGH);
      delay(20); // Just to get a solid reading on the role pin
      // read the address pin, establish our role
      if ( digitalRead(role_pin) )
        role = role_ping_out;
        role = role_pong_back;
      Serial.begin(57600);
      printf_begin();
      printf("\n\rRF24/examples/pingpair_sleepy/\n\r");
      printf("ROLE: %s\n\r",role_friendly_name[role]);
      radio.begin();
      // Open pipes to other nodes for communication
      // This simple sketch opens two pipes for these two nodes to communicate
      // back and forth.
      // Open 'our' pipe for writing
      // Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
      if ( role == role_ping_out ) {
        radio.openWritingPipe(pipes[0]);
        radio.openReadingPipe(1,pipes[1]);
        radio.openWritingPipe(pipes[1]);
        radio.openReadingPipe(1,pipes[0]);
      // Dump the configuration of the rf unit for debugging
      radio.printDetails();
    void loop(){
      radio.powerDown();              // NOTE: The radio MUST be powered back up again manually
      delay(5000);
      radio.powerUp();                // Power up the radio after sleeping
      delay(5000);
    Yup, same as before. The measurements on the blob module are:
    -43.3ua and -42.8ua.
    I'm not sure which is standby current and which is sleep current. I definitely was not expecting a negative current. There's not much difference in magnitude between the two currents.
    So, I tried it on a different blob module:
    -43.5ua and -42.9ua.
    Essentially the same results.
    Truly bizarre. What's going on? I'm powering the Uno through a roughly 9V battery pack of Eneloop batteries via its barrel jack, as with the earlier measurement of the Itead module, whose measurements not only met expected value, but they were positive currents, not negative ones.
    Here's the red module:
    Powered Down (Sleep): 1.6uA
    Standby: 13.9uA
    Here's an Addicore module from Amazon:
    Powered Down (Sleep): 1.8uA
    Standyby: 16.3uA
    It's a very simple test. I'd say anyone can do these measurements, provided they have a good way to measure microamps.
    So the blob module is so good that it is charging your batteries 😉
    I'm measuring the current between the Uno 3.3 Female header pin and the Vcc pin on the RF module.
    Now talking seriously, maybe the some current is leaking through the other pins (MISO, CE, CS, etc), from arduino to radio? That would could an negative VCC flow I think...
    It must be that. I wonder how it would measure if I were to use 3.3v on the datapins rather than the 5v the Uno uses.
    In theory it would require a logic level converter
    But for sure the atmega is tolerant between 3.3V and 5V. And probably the converter would introduce an error in the u-measurement, I guess.
    I plugged a blob module into the RFToy, which is effectively an 8Mhz Mini Pro running at 3.3v, and used a jig similar to the one before (just no resistor) to route the module Vcc current into the uCurrent.
    This time it is powered through the USB port, and the voltage is downshifted from there.
    New measurements for the blob module:
    Powered Down (Sleep): 3.3uA
    Standby: 67.2uA
    For comparison, I plugged the Itead module (Nordic tracecode 1301CL) into the same apparatus, and this time I got
    Standby: 22.8uA
    which, within measurement error, I would call the same as when it was hooked up to the Uno.
    @Zeph: For the NRF24L01+ modules, I now have good enough current measurements that I wanted to get, so I'll be holding off on doing further measurements, at least for now. I want to try the RFM69HW for comparison, but that is outside the scope of this thread.
    BTW, using just my Fluke 87V multimeter set on the uA setting, the measurements I get are:
    Fluke 87V Itead Module Measurements:
    Powered Down(Sleep): 0.5uA
    Standby: 22.5uA
    and
    Fluke 87V Blob Module Meaasurements:
    Powwred Down(Sleep): 3.0uA
    Standby: 56uA
    and
    Fluke 87V Addicore module from Amazon Measurements:
    Powered Down: 1.2uA
    Standby: 18.2uA
    So, although a bit different than the uCurrent measurements, they seem good enough for separating out the fakes that I have from the genuine article (which at this point the evidence suggests is what the chip in the Itead module is).
    So, good news! Maybe all you need is a DMM with decent uA measurements. If I'd had this information at the very beginning of this thread, it would have saved me a lot of frustration and doubt. Now everyone can be empowered. 😄 The next time you buy modules, you can now easily test them right away and send them back if they're fake! 😄 😄 😄
    I told you in the fifth post 👊 😉
    @hek said:
    Where exactly did you read it anyway?
    Just a lucky guess.
    @hek said:
    Just a lucky guess.
    What??? You were BS'ing me about reading it? 👊 😲
    @hek said:
    You should also compare the power consumption. From what I have read the genuine Nordic module has much better characteristics.
    @NeverDie said:
    You were BS'ing me then?
    Hmm.. no.. but I cannot for my mind recollect where I could have read it. So it might just have been a creation of my (weird) mind. 🙂
    All's well that ends well. 😄
    BTW, I just now measured this surface mount module using the uCurrent, and it measures out at
    Powered Down (Sleep): 0.7uA
    Standyby: 22.7uA
    Therefore, I deem it genuine. I got it at ICStation two or three months ago:
    http://www.icstation.com/nrf24l01-rfid-wireless-transmission-module-2dbm-p-4620.html
    It would help a lot if others here, when you measure your module, would post your measurements and where you got it from, and when. That way we can all benefit from the network effect and make better purchases and possibly avoid bad purchases also.
    Er, check the second sentence of the first (real) paragraph of the OP of the earlier fake nRF24L01+ thread.. Maybe that's where @hek got that impression.
    And now I am the one who doesn't recall exactly where I read that - but it's undoubtedly from one of the sources I linked to in that post, raised as one of the reasons to be concerned about fakes.
    Those with a low idle/sleep power usage are either Nordic or a quality clone.
    Even the blob modules would be workable in non-battery nodes, if they indeed have excellent range and low packet loss.
    So I just looked up the Fluke 87V, and the price is a bit high for my budget. So alas, the current state of our fake detection (pun acknowledged) is not a universal solution.
    Perhaps a variant with a coulomb counter will arise. Or perhaps using the 200x amplified differential ADC input of the Leonardo or Mega2560 with averaging.
    And I think it would be very apropos to distill the knowledge from these many posts into a wiki page. As with many threads here, there's some great info but sometimes it's embedded in hours of reading to find it again.
    @NeverDie - now that you have the measurement down, how about measuring receive current, and perhaps carrier-only transmit current? Both of those can be steady state.
    I'd still like to know how the various models rate in those areas too, while you have the setup handy.
    @Zeph said:
    ...carrier-only transmit current?
    What is "carrier only transmit current", and how would I measure that?
    Register 6 (RF_SETUP) bit 7 (CONT_WAVE) on p 55 of the rev 1 datasheet.
    Set it up to transmit constantly (carrier only, no data) and measure the Vcc current usage. (For a short time obviously!) Probably close to the current it would take while sending data.
    Likewise, measure current while waiting to receive with no actual data coming in (unless that's what your standby is).
    I haven't tried the constant-wave transmit mode, I just remembered that it was mentioned in the datasheet.
    For the IcStation module I profiled directly above, the receive current (using the microcurrent) measures out at 8.4mA using this sketch to put the module into receive mode:
    /* Adapted by NeverDie on 8/11/2015 for uCurrent measurements.
     *  Sketch for measuring receive current.
    #include "RF24.h"
    #include "printf.h"
    RF24 radio(7,8);
    // Role management
    role_e role;
    void setup(){
      while (!Serial) {
        ; // wait for serial port to connect. Needed for Leonardo only
      printf_begin();
      radio.begin();
      // back and forth.
    void loop(){
      radio.startListening();
    I can't promise to do the other measurements, as I'm facing some deadlines I need to attend to. If anyone else would like to pick up the baton and carry it forward, please feel free.
    I understand about other deadlines - I appreciate the efforts you have made so far.
    Sounds like all that's needed in the final version of your testing is a bent-pin 2x8 connector test shim such as you have described and photographed, and a $400 DVM 🙂
    Yes, a 2x4 connector, or I actually used (2) 1x6 female headers (I didn't have 1x4 female headers readily at hand)
    and a $400 DVM 🙂
    I imagine some of the cheaper DVM's would get the job done too. That's another topic entirely though.
    I'm not sure where you draw the line on how much testing is enough. I think it probably already is enough. 80/20 rule. ☺
    Have you decided to toss the blob modules (or put them in the back of the drawers), in favor of genuine Nordic only?
    No, at present I still prefer the blob modules. It may yet turn out that there's a better PCB or antenna or something for the genuine chips that will make a huge difference in their effective performance, but so far I'm underwhelmed by the modules with genuine chips. Also, modules with the genuine chips seem to cost around ~$3/each, and so for about only an extra dollar I could have an RFM69HW. Yesterday I ordered a couple Moteino's with the RFM69HW, and so after they arrive I'll see how that goes rather than re-invent the wheel. They were kinda pricey, which is my main reservation about them.
    If others are happy with their genuine chip NRF24L01+ modules, then good for them. Unfortunately I can't count myself among them, and so I'm restless to find something and settle on it. My guess is it may be the blob module, or it may be the RFM69.
    Ah, OK.
    I saw the testing as serving two purposes:
    • Learning a "power signature" to distinguish variations on the chips
    • Finding out how bad (or good) the variants are in regard to power usage
    Seems like the first is nailed. The latter has begun to be characterized (thanks to you). The idle and sleep power is substantially greater on the blobs (for example). If the 8.4 ma for Receive is for the blobs, that doesn't sound bad, don't know about transmit.
    And if powered by the mains, it doesn't much matter.
    @Zeph said:
    ....don't know about transmit.
    Blob module transmit current was about 20ma, (my interpretation of the oscilliscope pictures I posted). I was surprised that the "listening" current was just 8.4ma, because that's lower than the spec sheet for "receiving" current. I don't know, but perhaps "receiving" consumes more current than just "listening."
    On a relative scale compared to the other modules, the blob modules obviously consume more current. However, on an absolute scale, they seem like they may be good enough..
    @Zeph Looks as though you could use the LTC2440 to measure the sleep and standby currents and read the results with your arduino: http://dangerousprototypes.com/forum/viewtopic.php?f=2&t=4247#p45583
    or maybe use one of these breakout boards to similar effect:
    http://www.ebay.com/itm/LTC2400-24bit-analog-to-digital-converter-ADC-module-temp-sensor-SPI-AVR-arduino-/111005456125?pt=LH_DefaultDomain_0&hash=item19d870d6fd
    I'm seeing similar results with my radios. I bought these from aliexpress and then after reading the various threads about fakes and the problems people were having, I bought a bunch of authentic modules from ITEAD just to avoid those headaches. The real modules have much cleaner PCB's and better looking solder joints. The two types seem to be able to talk to each other OK but if set two modules at opposite ends of the house (with 2 exterior walls in between as well), the cheap modules still connect and the genuine ones don't. I'm assuming this is similar to what you're seeing with the real modules having a lower transmit power. I'm now regretting spending the extra money on the genuine modules (if anyone in the CONUS wants some genuine modules, PM me and I'll sell you some at my cost).
    Thank you! Finally some confirmation of what I've been saying.
    I received some "genuine" modules from AliExpress today: http://www.aliexpress.com/item/Free-shipping-Original-Genuine-NRF24L01-Wireless-Module-2-4G-wireless-communication-module-2-54mm-Interface-2/1781618813.html
    Power Down (Sleep): 0.5uA
    Standby: 23.5uA
    Listening: 8.6ma
    The transmit waveform looks exactly the same as the the module from Itead.
    Therefore, I deem them genuine.
    I was able to sharpen my o-scope pictures by turning on Hi-Res mode. With this better detail, a lot more is apparently different between the genuine modules and the blob modules.
    Here are some transmit shots of the new genuine modules:
    and here are some shots of the blob module, also now taken at Hi-Res on the o-scope:
    As you can see now that I'm using Hi-Res mode, even the shapes of the waveforms are completely different looking.
    Reminder: because I'm now using a 1/2 ohm sense resister, each verticle devision now represents 4ma.
    So, eyeballing it, the genuine chips are using about 12ma for their transmit current, whereas the blob module chips are closer to about 18ma.
    Also, the second peak after the first peak is higher on the genuine chips, whereas it is lower on the blob chips. I don't know what those peaks represent.
    So, for completeness, here's the Hi-Res o-scope pictures of the red module, whose tracecode suggests it may be fake, as previously noted:
    In this case, one thing that jumps out as different than the other two is that the height of the second tall peak is much lower than the first tall peak. In the genuine chip, the second tall peak is actually higher than the first tall peak, so it's quite a distinctive difference.
    I have a hypothesis for what's going on. According to the NRF24L01+ datasheet,
    • 11.3mA TX at 0dBm output power
    • 13.5mA RX at 2Mbps air data rate
    Therefore, I think Mirf probably does a TX, waits for an ACK, and if it isn't found, it tries 3 more times. Therefore, on the genuine chip, you see one tall peak for TX, followed by a second taller peak for RX. It does it again3 times, because, for measurement repeatability, I deliberately removed anything that might receive or ACK its transmissions. So, all the ACKs fail and it transmits 3 more times after the first transmission. That's the hypothesis.
    Anyhow, now that I've switched over to the TBRH20 library, this could be checked more easily.
    Although already shown above, here it is again for easy reference:
    If the hypothesis is true, then the TX and RX currents measure out to exactly what one would expect based on the above specs in the datasheet.
    Also, it would explain why it is that before and after the transmission burst, the measured current is the same as the second peak current. That's because the chip is in RX mode between transmissions.
    So, from the looks of things, if it doesn't receive an ACK within 250uSeconds (as measured above) after transmission ends, it tries again (up to 3 times). In fact, according to the datasheet, the default for ARD (automatic retransmission delay) is 250 uSeconds. It appears to match up exactly!
    So, indeed, that's what's happening.
    I just switched to TBRH20 and wrote a simple loop to send a packet every 100ms, and to not be listening inbetween. Apparently the default behavior for TBRH20 is to try 16 times to send the packet before giving up!
    As before, this is just one shot on the oscilliscope. I'm zooming in on each successive screen by adjusting the time base. I did the measurement on one of the modules with a "genuine" Nordic chip.
    I would guess that in this case TBRH20 is managing the retries in software on the Arduino rather than utilizing the radio chip, because the time between retries is much larger: about 1.5ms.
    BTW, I switched to a Mega2560 to do the testing, and, although I haven't yet investigated it, I think the new type of noise that's now evident is probably from the 5v and/or 3v voltage regulator. It doesn't obscure the view, so for now I'm not really concerned.
    Nailed it. If I explicitly turn ACKing off, then:
    What's shown is just a single transmit pulse at 100ms intervals, and with no RX current afterward, as would be required if an ACK was being listened for.
    Bottom line: now that the anatomy of the Tx current is known, it should help spot and identify clone chips by comparing their Tx current waveform against that of chips known to be genuine.
    You've nailed it indeed.
    I'm guessing that the first peak on the blob chips is higher because it has higher RF output as well.
    If you set bit 0 of register 6 to a 1 on the Blob (unused on the nRF24L01+), and if this chip is a Si24R01 or derivative, it will switch from +2~3dBm to +7dBm RF output, and probably draw even more power.
    @TD22057 said:
    I'm seeing similar results with my radios. ... The two types seem to be able to talk to each other OK but if set two modules at opposite ends of the house (with 2 exterior walls in between as well), the cheap modules still connect and the genuine ones don't. I'm assuming this is similar to what you're seeing with the real modules having a lower transmit power.
    My hypothesis: The blob units have more transmit power (perhaps being Si24R01 or related) and thus a higher first peak, but perhaps no better receive sensitivity.
    If so a blob to genuine would have at least as good a range as blob to blob, and a genuine to blob would have similar range as a genuine to genuine.
    Of course testing that may involve a one way transmission, where we check for lost packets on the receive side (without expecting a round trip).
    If however the blobs have managed to beat the genuine receive sensitivity, then they are really hot stuff!
    @Zeph I'm pretty sure the blob modules are using the RFM75 die because the above mA and uA measurements appear to be a good match for the electrical specification on page 22 of http://www.hoperf.com/upload/rf/RFM75 Datasheet v1.0.pdf
    Makes me wonder if it would perform the same or differently if it were installed on the manufacturer recommended PCB along with all the recommended passive components, because you can buy proper RFM75 modules cheaper than "genuine" NRF24L01+ modules.
  • Look at this RFM75 module. It's got the blob. It sounds like a bad horror movie.
    http://m.ebay.com/itm/171874462905
    I've since learned that "COB Module" would be a more proper term, but I didn't know that when I started this thread. COB = "Chip on Board" The bare semiconductor die is wire bonded directly to the board. I don't know why, but apparently that's cheaper by what, a penny or two? Once that work is done, the epoxy goes on to protect it.
    Based on the mA and uA measurements above, it's likely that the Addicore modules and the red modules are based on the Si24R01, because they are a reasonably good match for the electrical specifications on page 22 of the Si24R01 datasheet: https://www.dropbox.com/sh/kdenpdg60v5hzbd/AACG1jxQR71fkzX-U4a7CIh0a/SI24R1 (cn).pdf?dl=0
    That's all the modules that I have. I'm pretty confident everything has been properly ID'd. 😄
    Could you see if they work on channels above 84? The RFM75 lists fewer channels than the nRF24L01+, which is probably for regulatory rather than technical reasons (the frequency band does extend further in another part of the spec). I would be curious to know if channel 125 works, for example.
    I previously tested the COB modules as working on channel 112, both with each other and interoperating with "genuine" NRF24L01+ modules.
    This is one of the areas where there's a disconnect between what the HopeRF website says and what the electrical specs on the datasheet I referenced above say regarding the RFM75. The website says it only goes up to 2.450Ghz or something, and the datasheet specs say it goes all the way to 2.5Ghz. I'm assuming the datasheet is right, not the website.
    The modules are cheap enough that I may order a couple, just to see if they perform a whole lot better when soldered to proper PCBs and the correct passives are used. It may be moot though if I decide to use RFM69x's instead.
  • Is it possible to use NRF24LE1 (L01+MCU) as simple NRF24L01+? Are there any of these LE1 modules fake too?
    Question inspired by this topic: http://forum.mysensors.org/topic/1774/introducing-mysensors-on-nrf24le1
  • Would it be possible that someone would create a sketch that would detect fake modules and warn about discrepancies? I would hate to spend more money on fake modules.
    Yes, but currently the 'scene' is not aware of a decent way to distinguish fake from real.
    As soon as we know how to determine this a sketch can be written.
  • Speed is one thing that can be tested, fakes are slower. Packet loss too. ACK with dynamic payloads too. Registers that exist only on fakes (the datasheet error one for example).
    I suppose you mean the maximum bitrate possible?
    Most fakes will handle all nRF bitrates flawlessly.
    Packet loss too
    I have not seen any proof of differences in reception between reals & fakes.
    The construction & orientation of the module on which the nRF is mounten will IMHO mostly determine the transmission quality.
    I'd like to see an algorithm which reliably determines fakes from real using packet loss.
    This is claimed to be a difference and it might be true for some modules, but all my fakes behave identical on-air compared with real nRF's (verified by sniffer)
    Again, the web is full of contradictory reports...
    Most of these fakes are very good copies and I doubt if anyone can find a software-only solution to determine real from fakes reliably.
    Our best bet would be to create an accurate power fingerprint of a genuine module and compare the fakes to it -- that's the only more or less consistent difference I've seen so far.
    Remember that even Nordic will perform an X-Ray on a suspicious nRF to be absolutely sure if its genuine or not.
    That said -- be my guest and try to create a sketch. The scene will thank you for it if you succeed 😉
    The power fingerprint seems to work very well. I suggest you use that. The work is already done (see above).
  • Lots of useful info here, thanks everyone for the hard work!
    Based on the findings, are the NRF24L01+ modules linked on the shop page still the best recommendation? Is it worth adding the cap as a required part of the setup to increase reliability?
    Just received 20 units from the vendor linked through aliexpress and am working through issues which appear to be related to the radios (not using cap's currently)
    Starting...
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    find parent
    find parent
    find parent
    find parent
    sensor started, id=255, parent=255, distance=255
    @nftrix I'm using nRF24L01+'s for all of my applications at the moment still with no issues at all. They are running perfectly smooth, without interference off of anything. I personally just soldered my caps straight onto my radios when they arrived, before even testing them. If you're not restricted by space, just solder/attach them straight to the module as they arrive through your door.
    As with your issue that you have shown, i would say give the cap a try before jumping to conclusions as it appears that its sending out a message asking the gateway to reply back with a connection package but its not finding it (I may be wrong, but that is what i see there). Give it a try and report back with your findings 🙂
    @nftrix Another way to deal with the fact that some nrf24l01+ modules can not find the gateway, is by reducing the transmit powerlevel. Some of these modules "scream" so loud, that the receiver on the gateway gets a distorted signal and fails to recognise a proper packet.
    In my house I have had to reduce the transmit levels of most of my modules, and as a result they now all connect to the gateway without any caps.
    The NRF24 on the gateway does have a potent powersupply and caps on the board it is mounted on, but my sensornodes do not need it.
  • @samuel235 @GertSanders thanks for the feedback. I'm picking up some caps from the store today and will try them out. As for the power settings, I've been adjusting the data rate settings between 250kbs, 1 and 2Mbps but am seeing the same results. If the caps don't fix the issue, i'll start another thread to work through the problem, don't want to hijack this thread.
    Just wanted to confirm that the findings here did not make the NRF's on the store "not recommended" or anything.
    Most definitely not. They're more than recommended from most of us i think, from a quick look at the forum topics anyway.
    The speeds settings (250k, 1M, 2M) are not the same as the power settings (Low, Med, High, Max).
  • @NeverDie
    I just compiled and uploaded your code to two uno's and all I am getting is
    rf_setup = 111
    Sending...
    how long does it take to get any output on the serial monitor?
  • 87
  • 7
