Battery percentage incorrectly send to gateway.
  • I ordered a custom pcb with a ATMega328P and a dallas tempsensor , powered by 2AA batteries. Simular like http://forum.mysensors.org/topic/1107/sensors-in-boxes/7.
    I use allso the sketch as shown in that topic, however the battery status allways read 102%. I'm sure the batteries are not full.
    Can you point me in the right direction why my battery percentage is not send correctly?
    // Example sketch showing how to send in OneWire temperature readings
    #include <OneWire.h>
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    MyMessage msgvolt(1,V_VOLTAGE);
    int BATTERY_SENSE_PIN = A0;
    int oldBatteryPcnt = 0;
    analogReference(INTERNAL);
    // Startup OneWire
    sensors.begin();
    // Startup and initialize MySensors library. Set callback for incoming messages.
    gw.begin();
    gw.sendSketchInfo("Temperature Sensor", "1.0");
    gw.present(i, S_TEMP);
    // Process incoming messages (like config from server)
    // Battery Monitoring
    float batteryV = sensorValue * 0.003363075;
    Serial.print(batteryV);
    Serial.println(" V");
    Serial.print(batteryPcnt);
    Serial.println(" %");
    gw.send(msgvolt.set(batteryPcnt,1));
    oldBatteryPcnt = batteryPcnt;
    float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
    if (lastTemperature[i] != temperature && temperature != -127.00) {
      gw.send(msg.setSensor(i).set(temperature,1));
    gw.sleep(SLEEP_TIME);
  • I believe the sketch you linked was built for 2-AAA batteries, not 2-AA.
  • I tried just with 2 AAA batteries (used from a remotecontrol), again it shows 102%. 😞
    Did you wire the voltage divider like this? http://www.mysensors.org/build/battery or how does your wiring look like=?
  • @sundberg84
    This is a screenshot of the schema. ( left out the top layer which is only used for the radio)
    I tried the basic battery sensor sketch. I see that the sensor value is devided 10.
    Should this be default or can I calculate how the devider should be programmed?
    end: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=o x00x00send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
    send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=1, parent=0, distance=1
    send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,st=ok:Battery Meter
    1023
    Battery Voltage: 3.44 V
    Battery percent: 102 %
    send: 1-1-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:102
  • Ok... resistors are switched place , problem solved 😉 make a big difference offcource.
    934
    Battery Voltage: 3.14 V
    Battery percent: 93 %
    send: 1-1-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:93
