Wall mounted 'mood light'
    (there is a sketch for MySensors v2 available)
    I received my 110v-230v AC to Mysensors PCB board last week en spent a few hours this weekend making 2 wall mounted mood lights.
    upload-12d13e93-9d8f-4244-b1a4-2e74d014587c
    I looks a little cheap from the backside but very luxurious on the wall ( < €20 total) and fully "MySensored".
    upload-cbbe7065-68b3-4108-b6c1-ebffc7cbdddb
    I did not use the relais on the board (and discarded some of the safety measures 😊 ). Very basic: a cut WS2812b strip, a few wires.
    Case is 12 mm MDF Board painted with Chalk paint (no primer needed, ready in half an hour ;-))
    Basic sketch with FastLED library (or Adafruit) with V_RBG.
    upload-1c215841-3f7f-4e6a-a856-f8d6f6435818
    upload-c7e90b81-b8b1-46b8-843d-b8c8007cd521 upload-1b906742-96fc-4b41-a24e-6fa302921d10
    Love your project and good use of the wall mount PCB. You showed me that I really need to order a couple of those I'm tired of all the phone charger cables 😉
    I couldn't really see it well on the photo's. But did you paint the back of light as well, the MDF part I mean? If not I would do it, because MDF has the tendency to bend when painted on one side only. That's why I use plywood or solid wood for almost all of my projects. Learned it the hard way, I made a cover for my radiator once out of MDF and painted only the outside. In just a day or two the cover started to bend. Which was really not funny after spending two weekends making it.
    If you decide to paint the back side as well I'd use a white paint, that reflects the light coming from the ledstrip better. Other colors tend to absorp the light more.
    I'm also really curious about how you mounted the MDF to the wall. It looks really great.
  • Could you please post your Arduino sketch, as I want to build something similar?
    Thank you.
    @TheoL Thank you for the tips. I painted the board on all sides. I would prefer real wood but MDF is really easy to model and I had a few sq meter left. I hate the dust though. For mounting i used a hook which fits in hole.
    upload-11a9a350-c01b-442e-b3a2-3e0c76805b15
    @gloob I will post the sketch after cleaning it up. I need to add on/off/ scene button functionality.
    I allways try to make my nodes as autonomous as possible. That way i'm not fully controller dependent and it's more safe.
  • @AWI said:
    ...and discarded some of the safety measures 😊...
    I see you've got something soldered where the fuse should be, but for the rest I can't see what you've left out. Could you tell us which components you eventually ended up using? (or not using, whatever you prefer :))
    @mvdarend I have not used the SSR, the varistors and the fuse on the low voltage side...
    I have updated the sketch to allow for independent operation and added a few light effects. The sketch can be used for any "Neopixel" (WS2812(B)) LED strip/ stick/ circle. Uses V_RBG and/ or V_STATUS and separate actuators (or the push button with long push) to switch the Pattern and Alarm. A few examples:
    "Alarm"
    Wall Light fireplace – 00:06
    — Ad Imhoff
    "Fireplace"
    Wall Light Alarm – 00:04
    — Ad Imhoff
    "Candle light" and "Rainbow" mostly non blocking code. If somebody want to add please do so.
    The sketch, heavily commented. Can always be improved
     PROJECT: MySensors / RGB light NEOPIXEL
     PROGRAMMER: AWI
     DATE: october 10, 2015/ last update: october 14, 2015
     FILE: AWI_RGB.ino
     LICENSE: Public domain
     Hardware: Nano and MySensors 1.5, Wall light 16 WS2812B leds (neopixel)
     Special:
    	uses Fastled library with NeoPixel (great & fast RBG/HSV universal library) 			https://github.com/FastLED/FastLED
     SUMMARY:
    	Different patterns and brightness settings
    	Button switches on/off and cycles through all Color patterns on long press
     Remarks:
    	Fixed node-id
    #include <FastLED.h>										// https://github.com/FastLED/FastLED
    #include <Button.h>											// https://github.com/JChristensen/Button
    const int stripPin = 5 ;									// pin where 2812 LED strip is connected
    const int buttonPin = 4 ;									// push button
    const int numPixel = 16 ;									// set to number of pixels (x top / y bottom)
    const int NODE_ID = 62 ;									// fixed MySensors node id
    const int RGB_LightChild = 0 ;								// Child Id's, standard light child on/off/ dim
    const int RGB_RGBChild = 1 ;								// RGB light child (on/off/dim/color, if controller supports V_RBG))
    const int RGB_SolidColorChild = 2 ;							// when set, node reads Color text from ColorTextChild
    const int RGB_TextColorChild = 3 ;							// Holds Text value for color (custom colors from controller)
    const int RGB_AlarmPatternChild = 4 ;						// Switches to alarm status
    const int RGB_NextPatternChild = 5 ;						// Move to next pattern when set
    CRGB leds[numPixel];
    // Kelving colors: Light & daylight (in Fastled reference only)
    /// 1900 Kelvin Candle=0xFF9329 /* 1900 K, 255, 147, 41 */,
    /// 2600 Kelvin Tungsten40W=0xFFC58F /* 2600 K, 255, 197, 143 */,
    /// 2850 Kelvin Tungsten100W=0xFFD6AA /* 2850 K, 255, 214, 170 */,
    /// 3200 Kelvin	Halogen=0xFFF1E0 /* 3200 K, 255, 241, 224 */,
    /// 5200 Kelvin CarbonArc=0xFFFAF4 /* 5200 K, 255, 250, 244 */,
    /// 5400 Kelvin HighNoonSun=0xFFFFFB /* 5400 K, 255, 255, 251 */,
    /// 6000 Kelvin DirectSunlight=0xFFFFFF /* 6000 K, 255, 255, 255 */,
    /// 7000 Kelvin OvercastSky=0xC9E2FF /* 7000 K, 201, 226, 255 */,
    /// 20000 Kelvin ClearBlueSky=0x409CFF /* 20000 K, 64, 156, 255 */
    char controllerRGBvalue[] = "FFDEAD";		 				// Controller sent RGB value, default
    uint16_t curBrightness, actualBrightness, controllerRGBbrightness = 0x7F ;	// Brightness globals
    unsigned long updateBrightnessDelay, lastBrightnessUpdate ; // Brightness timers
    int RGBonoff ;												// OnOff flag
    enum { pSolid, pOff, pAlarm, pFire, pFire2, pCandle, pRainbow}  ;	// Pattern globals (stored in int for convenience)
    const int lastPatternIdx = pRainbow + 1 ;					// use last pattern for patterncount
    int curPattern ;											// current pattern
    unsigned long updatePatternDelay, lastPatternUpdate ;		// Pattern timers
    unsigned long idleTimer = millis() ;						// return to idle timer
    int idleTime = 10000 ;										// return to idle after 10 secs
    // initialize MySensors (MySensors 1.5 style)
    MyTransportNRF24 transport(9, 10); 							// Ceech board, 3.3v (7,8)  (pin default 9,10)
    MySensor gw(transport);
    MyMessage lightRGBMsg(RGB_LightChild,  V_RGB);				// standard messages, light
    MyMessage lightdimmerMsG(RGB_LightChild ,V_DIMMER);
    MyMessage lightOnOffMessage(RGB_LightChild, V_STATUS);
    Button myBtn(buttonPin, true, true, 20);					//Declare the button (pin, pull_up, invert, debounce_ms)
    // Simple state machine for button state
    enum {sIdle, sBrightness, sPattern} ;						 // simple state machine for button press
    int State ;
    	FastLED.addLeds<NEOPIXEL, stripPin >(leds, numPixel) ;	// initialize led strip .setCorrection(TypicalLEDStrip);
    	gw.begin(incomingMessage, NODE_ID, false);				// initialize MySensors
    	gw.sendSketchInfo("AWI RGB Wall 0", "1.0");
    	gw.present(RGB_RGBChild, S_RGB_LIGHT, "RGB Wall RGB 0");// present to controller
    	gw.present(RGB_LightChild, S_LIGHT, "RGB Wall Light 0");
        gw.present(RGB_SolidColorChild, S_LIGHT, "RGB Set Solid color (text) 0");
    	gw.present(RGB_TextColorChild, S_INFO, "RGB Wall textcolor 0");
    	gw.present(RGB_AlarmPatternChild, S_BINARY, "RGB Wall Alarm 0");
    	gw.present(RGB_NextPatternChild, S_BINARY, "RGB Wall Pattern 0");
    	// initialize strip with color and show (strip expects long, so convert from String)
    	for(int i = 0 ; i < 6 ; i++) {							// get color value from EEPROM (6 char)
    		controllerRGBvalue[i] = gw.loadState(i) ;
    	setLightPattern(pSolid, NULL) ;							// default controller Solid
    	FastLED.show();
    	State = sIdle ;											// Initial state
    	//randomSeed(analogRead(0));
    // read button and act accordingly
    // short press: on/off
    // longer press: set patterns with following short press
    // long press: set brightness increase
    	gw.process();											// wait for incoming messages
    	myBtn.read();               							//Read the button (only read)
    	unsigned long now = millis(); 							// loop timer reference
    	switch (State) {
    		case sIdle:											// default state, browse through patterns
    			if (myBtn.wasReleased()){						// light on/ off in idle
    				RGBonoff = !RGBonoff ;						// invert light state
    				setLightPattern((RGBonoff == 1)?pOff:pSolid, 100);
    				gw.send(lightOnOffMessage.set(RGBonoff));	// and update controller
    			} else if (myBtn.pressedFor(500)){				// move to Pattern update state with long press
    				idleTimer = now ;							// return to idle after ...
    				State = sPattern ;
    			break ;
    		case sPattern:										// entered after long press
    			if (myBtn.pressedFor(2000)){					// when press even longer move to Brightness update
    				State = sBrightness ;
    			} else if (myBtn.wasPressed()){
    				setLightPattern((curPattern + 1) % lastPatternIdx, 500 ); // increase pattern and wrap
    				idleTimer = now ;
    			} else if ( now > idleTime + idleTimer  ){		// return to idle after ...
    				State = sIdle ;
    			break ;
    		case sBrightness:									// entered after looong press
    			if (myBtn.wasPressed()){							// if pressed again increase brightness
    				setLightBrightness((curBrightness+1) % 0xFF, 0) ; // increase brightness and wrap (0..0xFF)
    				idleTimer = now ;
    				State = sIdle ;
    			break ;
    		default :
    			State = sIdle ;
    			break ;
    	updateLightBrightness();								// update Brightness if time
    	updateLightPattern();									// update Pattern if time
    // Sets the light brightness, takes value and time (ms) as input
    void setLightBrightness(int newBrightness, unsigned long updateTime){
    	// global: curBrightness, actualBrightness, updateBrightnessDelay
    	updateBrightnessDelay = updateTime / 0xFF ;				// delay = time / max steps
    	actualBrightness = curBrightness ;						// assume curBrightness is actual
    	curBrightness = newBrightness ;							// set curBrightness to new value, rest is done in update
    // Update the light brightness if time
    void updateLightBrightness(){
    	// global: curBrightness, actualBrightness, updateBrightnessDelay, lastBrightnessUpdate ;
    	unsigned long now = millis() ;
    	if (now > lastBrightnessUpdate + updateBrightnessDelay){// check if time for update
    		if ( actualBrightness > curBrightness) {
    			FastLED.setBrightness( actualBrightness-- );
    			FastLED.show();
    		} else if ( actualBrightness < curBrightness){
    			FastLED.setBrightness( actualBrightness++ );
    			FastLED.show();
    		lastBrightnessUpdate = now ;
    // **** Pattern routines *****
    // Sets and initializes the light pattern if nescessary
    void setLightPattern( int newPattern, unsigned long updateDelay){
    	// global: curPattern, updatePatternDelay
    	curPattern = newPattern ;
    	updatePatternDelay = updateDelay ;						// delay for next pattern update, can be changed in pattern
    	switch(curPattern){
    		case pSolid:										//  solid is controller value in all pixels
    			for(int i = 0 ; i < numPixel ; i++) leds[i] = strtol( controllerRGBvalue, NULL, 16);
    			FastLED.show();
    			break ;
    		case pOff:											//  off state all pixels off
    			for(int i = 0 ; i < numPixel ; i++) leds[i] = 0 ;
    			FastLED.show();
    			break ;
    		default :
    			break ;
    // Update the light pattern when time for it
    void updateLightPattern(){
    	// global: curPattern, updatePatternDelay, lastPatternUpdate
    	if (now > lastPatternUpdate + updatePatternDelay){		// check if time for update
    		switch (curPattern) {
    			case pAlarm:									// flash light
    				patternAlarm();
    				break ;
    			case pFire:										// wild fire
    				patternFire();
    				break ;
    			case pFire2:									// cosy fire
    				patternFire2();
    				break ;
    			case pCandle:									// flame
    				patternCandle();
    				break ;
    			case pRainbow:									// rotating rainbow
    				patternRainbow();
    				break ;
    			case pSolid:									// do nothing fall through
    			case pOff:
    			default	:										// def
    				break ;
    		lastPatternUpdate = now ;
    // Define the different patterns
    // Alarm - intermittent white and red color, full intensity, intermittent top & bottom half
    void patternAlarm() {
        static boolean topBot ;							// indicates direction for next entry
    	const CRGB colorTop = CRGB(0xFF, 0, 0 );				// red color
    	const CRGB colorBottom = CRGB(0xFF, 0xFF, 0xFF );		// white color
    	FastLED.setBrightness(0xFF);							// set the strip brightness
    	for(int i=0; i <= (numPixel / 2 - 1) ; i++) {					// for half of strip size
    		leds[i] = topBot?colorTop:colorBottom ;
    		leds[i+ (numPixel/2)] = topBot?colorBottom:colorTop ;
    	topBot = !topBot ;										// switch direction
    	FastLED.show();
    // Simulate fire with red color, varying number of leds intensity & tempo
    void patternFire() {
        byte numberLeds = random(0,numPixel);					// start number and end of led's for flickering
        byte lum = random(100,255);								// set brightness
        CRGB color = CRGB(200, 50+random(1,180),0 );			// get red color with varying green
        for(int i=0; i <= numberLeds; i++) {
          leds[i] = color ;
          FastLED.setBrightness(lum);							// set the strip brightness
          FastLED.show();
          gw.wait(random(0,10));
        updatePatternDelay = 100 ;
    // Simulate fire with red color and varying intensity & tempo
    void patternFire2() {
        CRGB color = CRGB(200, random(100,150),0);				// get red color with varying green
        for (byte p=0; p < numPixel; p++) {
          leds[p] = color;
        FastLED.setBrightness(random(50,255));
        FastLED.show();
        updatePatternDelay = random(20,300);					// variable delay
    // Simulate candle based on fire with red color, varying number of leds intensity & tempo
    void patternCandle() {
        byte lum = random(60, 80);								// set brightness
        CRGB color = CRGB(200, 50+random(40,100),0 );			// get red color with varying green
          leds[i] = color ;
          FastLED.show();
          gw.wait(random(5,10));
    void patternRainbow() {
    	static uint16_t hue ;								// starting color
    	FastLED.clear();
    	// for(hue=10; hue<255*3; hue++) {
    	hue = (hue+1) % 0xFF ;									// incerease hue and wrap
    	fill_rainbow( leds, numPixel , hue /*static hue value */, 5);// set a rainbow from hue to last in stepsize 5
    	FastLED.show();
    // Incoming messages from MySensors
    	int ID = message.sensor;
    	Serial.print("Sensor: ");
    	Serial.println(ID);
    	switch (ID){
    		case RGB_LightChild:								// same behaviour as RGB child/ fall through
    		case RGB_RGBChild:									// if controller can handle V_RGB
    			if (message.type == V_RGB) {					// check for RGB type
    				strcpy(controllerRGBvalue, message.getString());// get the payload
    				setLightPattern(pSolid, NULL);				// and set solid pattern
    			} else if (message.type == V_DIMMER) {			// if DIMMER type, adjust brightness
    				controllerRGBbrightness = map(message.getLong(), 0, 100, 0, 255);
    				setLightBrightness(controllerRGBbrightness, 2000) ;
    			} else if (message.type == V_STATUS) {			// if on/off type, toggle brightness
    				RGBonoff = message.getInt();
    				setLightBrightness((RGBonoff == 1)?controllerRGBbrightness:0, 2000);
    			break ;
    		case RGB_SolidColorChild:							// request color from controller
    			if (message.type == V_STATUS) {					// if get color from text child
    				gw.request(RGB_TextColorChild, V_TEXT);
    				setLightPattern(pSolid, NULL);					// and set solid pattern (if not alre)
    			break ;
    		case RGB_TextColorChild:							// Text color from controller
    			if (message.type == V_TEXT) {					// if get color from text child
    				for(int i = 0 ; i < 6 ; i++) {				// save color value to EEPROM (6 char)
    					gw.saveState(i, controllerRGBvalue[i]) ;}// Save to EEPROM
    			break ;
    		case RGB_AlarmPatternChild:							// set Alarm pattern
    				if (message.getInt() == 1){
    					setLightPattern(pAlarm, 500);			// set slow alarm pattern
    					FastLED.setBrightness(curBrightness);
    			break ;
    		case RGB_NextPatternChild:							// next pattern
    				if (message.getInt() == 1 ) {
    			break ;
        FastLED.show();
    	dispRGBstat();
    // debug
    // display the status of all RGB: controller, requested, real
    void dispRGBstat(void){
        Serial.print(" Color: "); Serial.print(controllerRGBvalue);
        Serial.print(" Brightness: "); Serial.println(controllerRGBbrightness);
  • hello,
    i've problem with the sketch :+1 :
    sketch_dec08a.ino: In function 'void setup()':
    sketch_dec08a:89: error: 'S_INFO' was not declared in this scope
    sketch_dec08a.ino: In function 'void incomingMessage(const MyMessage&)':
    sketch_dec08a:308: error: 'V_TEXT' was not declared in this scope
    sketch_dec08a:313: error: 'V_TEXT' was not declared in this scope
    exit status 1
    S_INFO inly exist in the dev branch.
    That also means you have to convert the 1.5 sketch. Convert instructions here:
    https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#
  • @mickaelr30 , did you ever get this working with 1.5?
    i've got the upgrade instructions, but struggling to reverse it so it works with my current setup. Don't think i'm quite ready to upgrade all my nodes to dev quite yet.
    @Adam-McCartney add these lines in the header and you will have it working with the production version...
    // V_TEXT & V_INFO when not using the DEVELOPMENT version
    const byte V_TEXT = 47 ;					// values taken from development edition MyMessage.h
    const byte S_INFO = 36 ;
    awesome, thanks!
    I'm more of a butcher than a surgeon. I can quite happily take things apart, but fixing things usually goes right over my head!!
  • I really love this project.
    May I can include it in all of my sensors (doorbell, thermostat, alarm,...).
    Really sounds great, thanks
  • Is there a way to get your wiring schema ?
    @Mehdi-HAMIDA There is nothing to it. A standard MySensors node (5v) with the strip connected to D5 and a button between ground and D4.
  • @AWI OK, just ordered the PCB
    thx
    @AWI: Won't this part of your sketch create sort of an endless loop?
    @mfalkvidd Good observation. Probably the the result of an 'efficient' copy/paste 😳
    The line
    I there with no reason, can be deleted...
  • Im building the same light, but i use 12v LED strips controlled with mosfets. Is it possible to use the same scetch?
    @Tore-André-Rosander If you use standard 12v strips it won't work as such. The ws2812/11 chips in the strip used make it possible to address the individual led's.
  • @AWI Is this code for version 1.5?
    Im trying to compile it for the dev (v2) but i get a lot of errors.
    Mostly alot of code that "was not declared in this scope".
    EDIT: Just found your link to the "Conversion guide", will have look at it!
    A version for MySensors 2 is available at https://forum.mysensors.org/topic/4934/wall-mounted-mood-light-v2
  • 90
  • 29
