[n00b]]Ethernet GW - without NF24
  • Helo,
    I want to build my "iHome" based only (for now) on 1 eth gw with directly connected sensors (like motion, light,smoke, temp, etc).
    How can i remove/turn off nf24 support and how can i use direct connectedd sensors on gw.
    I need only one exaple 🙂
  • gr8 but do you have any documentation or help-docs for this or anything what can help me in setting up this?
    Currently no documentation for this branch but all the examples has been updated.
    You should be able to use any one of the examples and add:
    #define MY_GATEWAY_SERIAL
    and remove
    before the MySensors.h-include.
  • Hello Hek, Hello Everyone,
    I've actually one arduino uno and an ethernet shield Wizenet W5100 and for exemple a temp sensor DS18B20 directly connected to it.
    I can send to a serial terminal the temperature value. It's working properly :-).
    I would to know how I could simplify the code of the "Ethernet GW" Sketch for send the value of a sensor directly from the GW to Domoticz. (Without using an urduino dedicated to the sensor acquisition and without an RF module).
    Could you give me an exemple of the code or the command to send to domoticz?
    Or do you have a documentation link?
    Because the link you posted before is dead https://github.com/mysensors/Arduino/tree/gateway-refactoring.
    I've made many rescearch, and i don't find the protocol documentation to discuss with domoticz!
    I appreciate if you could help me to the right way :-).
    Awayting your answer, thanks very much in advance.
    PS: Sorry for my bad english...
    The code has been merged into development-branch now:
  • Thanks for your quickly answer.
    I'm sorry but I didn't found the code or information regarde my question into the repository you noticed.
    Could you please give me the complete link?
    Thanks you again.
    We can't have all permutations of examples ready available...
    So you'll have to put it together by combining:
    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayW5100/GatewayW5100.ino
    and
    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/DallasTemperatureSensor/DallasTemperatureSensor.ino
    You'd basically only have to copy the #defines from the gateway to the DallasTemp-sketch.
  • Hi Hek,
    Sure, you can't realise every solutions or exemple for everyone :-).
    So it's a good advice for me to begin my tests.
    When i merge the both codes, i receive an error "sendSketchInfo was not declared in this scope"!
    I've checked and normally all the librairies are available for the code.
    (When i'm building the GatewayW5100 only it works) but not for the dallas.
    Do you have an idea?
    Gwen.
    Just did a quick test calling sendSketchInfo in the gateway and it compiles fine for me.
  • hum, strange.
    I continue to search a solution.
    I'll give you a feed back ;-).
  • It doesn't work.
    But i found the code of Bram81 http://forum.mysensors.org/topic/1591/how-to-add-a-sensor-to-the-serial-gateway/22
    and I can compile it well.
    And it calls the gw.sendSketchInfo("Soil_Moist_Sensor_grb", "1.15");
    Do you have another tip?
    remove "gw." from the call.
  • You are right, it blocks when i call sendSketchInfo directly (without to be an attribute of gw) !?!
  • Here is the merged code
    Thanks for the advices
    // BELOW the gateway W5100 sketch
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_RFM69 // I DONT WANT TO USE THE RADIO MODULE
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    //#if !defined(MY_W5100_SPI_EN)
    //  #define MY_SOFTSPI
    //  #define MY_SOFT_SPI_SCK_PIN 14
    //  #define MY_SOFT_SPI_MISO_PIN 16
    //  #define MY_SOFT_SPI_MOSI_PIN 15
    //#endif
    //#define MY_RF24_CE_PIN 5
    //#define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    //#define MY_IP_ADDRESS 192,168,1,100   // If this is disabled, DHCP is used to retrieve address
    //#define MY_PORT 5003
    #define IP_PORT 5003        // The port you want to open
    IPAddress myIp (192, 168, 1, 100);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
    //#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
    byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };  // DEAD BEEF FEED
    // a R/W server on the port
    EthernetServer server = EthernetServer(IP_PORT);
    // handle to open connection
    EthernetClient client = EthernetClient();
    // Flash leds on rx/tx/err
    //#define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
    #include <Ethernet.h>
    //Below the Dallas temp sketch
    #include <OneWire.h>
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
    int inputPos = 0;
    bool sentReady = false;
    void output(const char *fmt, ... ) {
       va_list args;
       va_start (args, fmt );
       va_end (args);
       Serial.print(serialBuffer);
       server.write(serialBuffer);
      // ////Prepare the ethernet connection
      Ethernet.begin(mac, myIp);
      sensors.begin();
         present(i, S_TEMP);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
      sleep(SLEEP_TIME);
    Looks like you added your own stuff..
    Should simply be
    #define MY_IP_ADDRESS 192, 168, 1, 100 // If this is disabled, DHCP is used to retrieve address
    And what the following doing here?
    And you include <SPI.h> and <MySensor.h> twice.
  • to be honnest, i don't know ...
  • With the #define MY_IP_ADDRESS i can't compile the projet.
    With the arduino command it works now, i can ping it on 192.168.1.100.
    But still nothing in domoticz.
    Am I on the right way?
    thanks again 🙂
    // Enable to UDP
    byte ip[] = { 192, 168, 1, 100 };
    byte mac [] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
    int numSensors=0;
      Ethernet.begin(mac , ip);
      wait(1000);
      sensors.begin();
         present(i, S_TEMP);
      sleep(SLEEP_TIME);
    I don't understand.. why do you declare ip and mac like that? It most surely isn't picked up by the library. You're probably just getting an ip from your DHCP server.
    What compile error do you get when using the defines?
  • i've changed as before and it won't compile.
    The error is:
    no matching function for call to 'EthernetClass::begin(int, int, int, int, int, int, int, int, int, int)'
    No it takes the ip I put on the code before, cause the ping respond at this one.
    Thks
    // Enable to UDP
    //byte ip[] = { 192, 168, 1, 100 };
    //byte mac [] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
    int numSensors=0;
      Ethernet.begin(MY_MAC_ADDRESS , MY_IP_ADDRESS);
      wait(1000);
      sensors.begin();
         present(i, S_TEMP);
      sleep(SLEEP_TIME);
  • The final goal for me is the build ethernet sensor(s) (2 or 3 one each arduino board) connected to domoticz by lan gw.
  • Is there anyone who have done a sketch to connect sensor directly on an ethernet gateway ?
    Iam searching a working exemple or a working draft to see the process to build my own code.
    Thank everyone for your advices.
  • Hi Hek, Everyone,
    I've clean the approximative sketch I've made before to simply try to see the value of a DS18b20 sensor trough a serial gw in domoticz.
    So i've placed the merged code below to have your advices.
    In domoticz's log i can see the declaration of the gw but neither the dallas sensor!?
    Does someone could check my sketch please?
    To be sure that the arduino see the dallas, i've tested a sketch wich send the value to the serial terminal (it works properly :-).
    Thank you in advance for your help.
    Have a nice sunday all. (clouday in belgium today ;-)).
    // Enable serial gateway
    int numSensors=0;
      sensors.begin();
         present(i, S_TEMP);
      sleep(SLEEP_TIME);
    To be complete, there is the domoticz log.
    2015-10-25 10:44:40.157 MySensors: Using serial port: COM3
    2015-10-25 10:44:41.892 MySensors: Gateway Ready...
    2015-10-25 10:44:41.892 MySensors: Node: 0, Sketch Name: Temperature Sensor
    2015-10-25 10:44:41.946 MySensors: Node: 0, Sketch Version: 1.1
  • No idea?
    Sensors attached to gateway (node id=0) is a new feature.
    Might be Domoticz filtering these type of messages perhaps?
    @GizMoCuz might know if this is the case.
    I have created ethernet gateway 🙂 with 2 sensors 🙂 (DHT11, and door/windows sensor) all data are send to domoticz without problem.But when i adds "przekaznik" - one channel relay - i can't send/receive data about this relay. Can anyone check why ?
    sorry for mess in code
    #define MY_SOFTSPI
    // Enable to UDP
    #define MY_IP_ADDRESS 192,168,0,250   // If this is disabled, DHCP is used to retrieve address
    //Przekaznik
    #define MY_REPEATER_FEATURE
    #define RELAY_1  22  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #include <DHT.h>   //dodany czujnik
    //czujnik temp i wilgotnosci
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define DOOR_ID1 4
    #define DOOR_ID1_PIN A0
    unsigned long SLEEP_TIME = 300; // Sleep time between reads (in milliseconds)
    DHT dht;
    float lastTemp;
    float lastHum;
    MyMessage msgDOOR_ID1(DOOR_ID1, V_TRIPPED);
    int old_DOOR_ID1_STATE = -1;
      //temp + hum
      //  kontaktron DOOR_ID1
      pinMode(DOOR_ID1_PIN, INPUT);
      //  //przekaznik
      //    // Then set relay pins in output mode
          pinMode(pin, OUTPUT);
      //    // Set relay to last known state (using eeprom storage)
      //temp + hum
      sendSketchInfo("Humidity", "1.0");
      present(CHILD_ID_HUM, S_HUM);
      present(DOOR_ID1, S_DOOR);
      //przekaznik
      sendSketchInfo("Relay", "1.0");
      for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
        present(sensor, S_LIGHT);
        Serial.print("Petla presentation");
      //temp + hum
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
        lastHum = humidity;
        Serial.print("H: ");
        Serial.println(humidity);
      int DOOR_ID1_STATE = analogRead(DOOR_ID1_PIN);
      Serial.print("Analog= ");
      Serial.println(DOOR_ID1_STATE);
      Serial.println(old_DOOR_ID1_STATE);
      if (DOOR_ID1_STATE == 0) {
        DOOR_ID1_STATE = 0;
        send(msgDOOR_ID1.set(DOOR_ID1_STATE));
        old_DOOR_ID1_STATE = DOOR_ID1_STATE;
        Serial.print("drzwi_1=");
        DOOR_ID1_STATE = 1;
        Serial.print("drzwi_2=");
        // Change relay state
        digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
        // Store state in eeprom
    Just did some verification of message receiving in gateway on the ESP8266 sent from my shell (using netcat). Messages is showing up in receive() just fine here.
    Are you sending to node 0 from Domoticz? What does the log say in the gateway?
  • Nothing special
    0;0;3;0;9;Starting...
    IP: 192.168.0.250
    Domoticz log
     2015-11-09 23:09:50.588 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:09:53.599 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:09:56.614 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:09:56.620 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:10:00.632 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:10:00.680 (GW) Lighting 2 (Security Sensor)
    2015-11-09 23:10:03.706 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:10:07.718 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:10:12.730 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:10:17.745 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:10:21.762 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:10:22.770 (GW) Lighting 2 (Security Sensor)
    2015-11-09 23:10:27.791 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:10:31.805 (GW) Temp + Humidity (TempHum)
    2015-11-09 23:10:32.812 (GW) Temp + Humidity (TempHum)
    I'm receiving only this kind of information.
    How can i send "0" from domoticz to GW ?
    Your have messed up the presentation of your S_LIGHT devices in the loop. They start with id 1 in the loop. But that id has already been used by CHILD_ID_TEMP.
  • Even if i change CHILD_ID_RELAY (to 5 or 6 ) sill the same.
  • I had the same problem as you and I have found a possible solution. The arduino has default auto reset on serial connection. So when you connect gateway to controller trough USB, the gateway is rebooting immediately and processing presentation(). In case of wireless gateway (esp8266) this does not happen. The presentation() runs only on startup of the gateway. I made little change in MyGatewayTransportEthernet.cpp and now the gateway processes presentation() when the controller is connecting to it.
    You can find here my solution:
    https://github.com/zaphodus/Arduino/commit/ce93db73513f1da45637b186787c9b2501e5d882
  • 44
18
