Compiling Problems
  • Hey
    I get this problem when i'm compiling. No matter what i do. I have tried to delete det libery and indset the new libery.
    Can any one help me?
    Arduino: 1.6.6 (Mac OS X), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
    Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:150:9: error: prototype for 'uint8_t SPIFlash::readByte(uint32_t)' does not match any in class 'SPIFlash'
    uint8_t SPIFlash::readByte(uint32_t addr) {
    In file included from /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:35:0:
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:79:11: error: candidate is: uint8_t SPIFlash::readByte(long int)
    uint8_t readByte(long addr);
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:161:6: error: prototype for 'void SPIFlash::readBytes(uint32_t, void*, uint16_t)' does not match any in class 'SPIFlash'
    void SPIFlash::readBytes(uint32_t addr, void* buf, uint16_t len) {
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:80:8: error: candidate is: void SPIFlash::readBytes(long int, void*, word)
    void readBytes(long addr, void* buf, word len);
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:220:6: error: prototype for 'void SPIFlash::writeByte(uint32_t, uint8_t)' does not match any in class 'SPIFlash'
    void SPIFlash::writeByte(uint32_t addr, uint8_t byt) {
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:81:8: error: candidate is: void SPIFlash::writeByte(long int, uint8_t)
    void writeByte(long addr, uint8_t byt);
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:234:6: error: prototype for 'void SPIFlash::writeBytes(uint32_t, const void*, uint16_t)' does not match any in class 'SPIFlash'
    void SPIFlash::writeBytes(uint32_t addr, const void* buf, uint16_t len) {
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:82:8: error: candidate is: void SPIFlash::writeBytes(long int, const void*, uint16_t)
    void writeBytes(long addr, const void* buf, uint16_t len);
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:269:6: error: prototype for 'void SPIFlash::blockErase4K(uint32_t)' does not match any in class 'SPIFlash'
    void SPIFlash::blockErase4K(uint32_t addr) {
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:85:8: error: candidate is: void SPIFlash::blockErase4K(long int)
    void blockErase4K(long address);
    /Users/nikolajmadsen/Documents/Arduino/libraries/MySensors/utility/SPIFlash.cpp:278:6: error: prototype for 'void SPIFlash::blockErase32K(uint32_t)' does not match any in class 'SPIFlash'
    void SPIFlash::blockErase32K(uint32_t addr) {
    /Users/nikolajmadsen/Documents/Arduino/libraries/SPIFlash/SPIFlash.h:86:8: error: candidate is: void SPIFlash::blockErase32K(long int)
    void blockErase32K(long address);
    exit status 1
    Fejl i kompilering.
  • I am also having a very similar problem trying to compile the code or the serial gateway onto a nano. I am running Arduino IDE 1.6.6.on Ubuntu 15.04. Error log as follows:
    Arduino: 1.6.6 (Linux), Board: "Arduino Nano, ATmega328"
    /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:150:9: error: prototype for 'uint8_t SPIFlash::readByte(uint32_t)' does not match any in class 'SPIFlash'
    In file included from /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:35:0:
    /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:79:11: error: candidate is: uint8_t SPIFlash::readByte(long int)
    /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:161:6: error: prototype for 'void SPIFlash::readBytes(uint32_t, void*, uint16_t)' does not match any in class 'SPIFlash'
    /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:80:8: error: candidate is: void SPIFlash::readBytes(long int, void*, word)
    /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:220:6: error: prototype for 'void SPIFlash::writeByte(uint32_t, uint8_t)' does not match any in class 'SPIFlash'
    /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:81:8: error: candidate is: void SPIFlash::writeByte(long int, uint8_t)
    /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:234:6: error: prototype for 'void SPIFlash::writeBytes(uint32_t, const void*, uint16_t)' does not match any in class 'SPIFlash'
    /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:82:8: error: candidate is: void SPIFlash::writeBytes(long int, const void*, uint16_t)
    /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:269:6: error: prototype for 'void SPIFlash::blockErase4K(uint32_t)' does not match any in class 'SPIFlash'
    /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:85:8: error: candidate is: void SPIFlash::blockErase4K(long int)
    /home/glenn/Arduino/libraries/MySensors/utility/SPIFlash.cpp:278:6: error: prototype for 'void SPIFlash::blockErase32K(uint32_t)' does not match any in class 'SPIFlash'
    /home/glenn/Arduino/libraries/SPIFlash/SPIFlash.h:86:8: error: candidate is: void SPIFlash::blockErase32K(long int)
    exit status 1
    Error compiling.
  • Update: I should have mentioned in previous post that I have also attempted to remove and reinstall recipes. Also removed and reinstalled the arduino IDE. I also install IDE 1.0.6 which does result in different errors:
    Arduino: 1.0.6 (Linux), Board: "Arduino Nano w/ ATmega328"
    In file included from SerialGateway.ino:53:
    GatewayUtil.h:40: error: ‘MyParserSerial’ does not name a type
    GatewayUtil.h:44: error: ‘MAX_PAYLOAD’ was not declared in this scope
    GatewayUtil.h:67: error: expected ‘,’ or ‘...’ before ‘&’ token
    GatewayUtil.h:67: error: ISO C++ forbids declaration of ‘MyMessage’ with no type
    GatewayUtil.h: In function ‘void incomingMessage(int)’:
    GatewayUtil.h:74: error: ‘message’ was not declared in this scope
    GatewayUtil.h:74: error: ‘mGetCommand’ was not declared in this scope
    GatewayUtil.h:74: error: ‘mGetAck’ was not declared in this scope
    GatewayUtil.h:74: error: ‘convBuf’ was not declared in this scope
    GatewayUtil.h: At global scope:
    GatewayUtil.h:98: error: variable or field ‘parseAndSend’ declared void
    GatewayUtil.h:98: error: ‘MySensor’ was not declared in this scope
    GatewayUtil.h:98: error: ‘gw’ was not declared in this scope
    GatewayUtil.h:98: error: expected primary-expression before ‘char’
  • I'm having the same problem.
    Started with MySensors yesterday and tried to install the esp8266 WiFi Gateway.
    Did a clean install of the Arduino IDE 1.6.6 and followed all steps described here
    The result is the same as the topicstarter.
    The problems are related to arduino 1.6.6, and currently only dev is able to compile on it (as far as I know).
  • I can confirm that. Just removed 1.6.6 and revert to 1.6.5 and now it is working instantly.
    Thank you for the hint.
    Maybe it's an option to edit the esp8266_gateway page and remove the + from Arduino 1.6.5+ and add a remark that it's not (yet) working on 1.6.6
  • Thanks!! That solved it!!
  • That worked. Thank you.
    FYI: Updated master branch (1.5.1) to compile on Arduino IDE 1.6.6 a couple of days ago.
  • Is there a link to the 1.5.1 ? And is it considered a stable release? Also might be worth making it the default download for stable so new people don't get scared away.
    The "Download Libraries" button on this page -> http://www.mysensors.org/about/arduino will give you the 1.5.1 version.
  • I need help! Does not work WiFi Gateway using ESP8266.
    WARNING: Category '' in library OneWire is not valid. Setting to 'Uncategorized'
    upload-87fb2d34-a887-4c42-bdcc-1ede9c6b8f51
    That's just warnings the new IDE is spitting out. Nothing to worry about.
  • Thank you! Ok.
    But after flashing WiFi Gateway ESP8266 not pinged .. When I unplug the USB cord from your computer and connect an external source of 5V, then it worked ...
  • This thread helped me as well when I installed Arduino IDE 1.6.7. I still had an old version of the MySensors library kicking around in my Sketch Book (if it isn't broke, don't fix it). I just want to keep this thread alive for awhile. 🙂
  • 15
