RFM69 temperature and how to check RFM69 is set to high power
    I am using RFM69HW and found how to use high power reading this post. I am now want to get the RFM69 temperature in my sketch and check if I am using high power mode.
    I found in the RFM69 library useful methods, but I don't know how to call them in my sketch ... I tried radio.readTemperature but it's not correct.
    Do you have an idea ?
    I am also interesting in getting the RSSI !
    David.
    Guess you would have to add something like this in your sketch:
    extern RFM69 _radio;
    And use use _radio.readTemperature()
    (in the development branch)
    In 1.5 the radio-object is a private member of the MySensors radio-driver class so you'd have to make it public to have access to it.
  • Thanks @hek !
    I modified the file "MyTransportRFM69.h" and moved RFM69 radio from private to public.
    I then added extern RFM69 _radio; in my sketch.
    And in the loop method, I also added _radio.readTemperature().
    But the compilation failed:
    SerialGateway.cpp.o: In function `loop':
    /Users/carlierd/SerialGateway.ino:130: undefined reference to `_radio'
    collect2: error: ld returned 1 exit status
    For the moment I prefer using the stable branch until I get something working.
    You're mixing the two solutions.
    In 1.5 you would reach the public radio object by
    radio.radio.readTemperature()
  • Sorry @hek but it's still not clear for me 😉
    I am using 1.5, so I assume that I have to:
    • put radio as public in MyTransportRFM69.h
    • add radio.radio.readTemperature() in my sketch
    Thanks !
    Yep, should work.
  • I got this error during compilation:
    SerialGateway.ino: In function 'void loop()':
    SerialGateway:128: error: 'radio' was not declared in this scope
    Any idea ?
    transport.radio.getTemperature() then? O
  • It's perfect !! Thanks !
  • 15
