  3. RFM69 problems
RFM69 problems
34 Posts 5 Posters 16.1k Views 2 Watching
  • Cliff KarlssonC Offline
    Cliff Karlsson
    I managed to get my RFM69 radios working on both sensors and gateway before but the I started fiddeling around and now nothing works.
    Has there been some change to the sketches, as I recall there where a "transport" line before. Now there is none.
    I added the line "MyTransportRFM69 transport (RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, true, RF69_IRQ_NUM) ;"
    to my gateway and added #include "MyTransportRFM69.h" and MySensor(MyTransport &radio =*new MyTransportRFM69(), MyHw &hw=*new MyHwDriver() in mysensors.h
    But where and how in the sensor sketches do I specify if there is a RFM69W or RFM69HW connected?
    • C Offline
      C Offline
      carlierd
      Don't have the answer but happy to see the question as I need it !
      It seems that it's include in development branch ...
      David.
      • H Offline
        H Offline
        MyTransportRFM69 transport (RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, true, RF69_IRQ_NUM, true) ;
        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyTransportRFM69.cpp#L23
          Cliff Karlsson
          Thanks but I can't say that I understand, do I have to add a second "true" at the end?
          H 1 Reply Last reply
            Cliff Karlsson
            And should I just add "MyTransportRFM69 transport (RFM69_FREQUENCY, RFM69_NETWORKID, RF69_SPI_CS, RF69_IRQ_PIN, true, RF69_IRQ_NUM, true) ;"
            To the beginning of the sensor sketches to?
              H Offline
              H Offline
              @Cliff-Karlsson
              Sorry, missed the "true" argument you already had in your argument list.
                Cliff Karlsson
                Ok, but do I still need to add some RFM info to the sensor sketches?
                I really think that there should be some tutorial of everything that needs to be modified in the gateway and sensor sketches to be able to use the RFM69 radio
                  H Offline
                  H Offline
                  Yes, default is that NRF radio gets initialized.
                  • B Offline
                    B Offline
                    BenCranston
                    @Cliff-Karlsson
                    Here is what I did to get my RFM69HW's working (the high power variant):
                    from MyConfig.h:
                    *  RFM69 Driver Defaults
                    // Default network id. Use the same for all nodes that will talk to each other
                    #define RFM69_NETWORKID     100
                    // Default frequency to use. This must match the hardware version of the RFM69 radio (uncomment one):
                    #define RFM69_FREQUENCY     RF69_915MHZ
                    // Enable this for encryption of packets
                    #define RFM69_ENABLE_ENCRYPTION
                    #define RFM69_ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
                    I had trouble with the #isRFM69HW define not working in the sketch for whatever reason, so I just went into MyTransportRFM69.h and modified the default of "false" to "true" like so:
                    class MyTransportRFM69 : public MyTransport
                    public:
                            MyTransportRFM69(uint8_t freqBand=RFM69_FREQUENCY, uint8_t networkId=RFM69_NETWORKID, uint8_t slaveSelectPin=RF69_SPI_CS, uint8_t interruptPin=RF69_IRQ_PIN, bool isRFM69HW=true, uint8_t interruptNum=RF69_IRQ_NUM);
                    Then in my sketch, something like this:
                    #define MY_RADIO_RFM69
                      gw.sendSketchInfo(SN, SV);
                      gw.present(BUTTON1, S_LIGHT);  // Top Button
                      gw.process(); // tickle the MySensors framework
                      check_buttons();  // update logical state from button changes
                      update_mote();  //  Apply any gathered state changes to the actual hardware
                    ... and bunch of other code not shown...
                    There's likely a better way, but my brute force worked. I'd recommend that you start testing without the code signing turned on. It's easier to debug things not talking to the gateway with less features enabled as a start. Then add back in the message signing and you should be up and running. Once you've got your MyConfig.h all happy then it's really easy to use and replicate in your node sketches.
                      Cliff Karlsson
                      Thank, will try asap. Just a question, in your gateway did you only add "MyTransportRFM69 transport;" or did you also add the stuff from your sketch example like: #define MY_RADIO_RFM69 ?
                      B 2 Replies Last reply
                        B Offline
                        B Offline
                        BenCranston
                        @Cliff-Karlsson The only things I really had to edit, was in MyConfig.h for the network ID, Frequency and encryption settings. In the sketch you just add the first line "#define MY_RADIO_RFM69" and the rest gets sorted out by the libraries. If you don't add the #define MY_RADIO_RFM69 it will default as @hek indicated to the NRF radio.
                        • H Offline
                          H Offline
                          @Cliff-Karlsson
                          Note that @BenCranston is using the development branch.
                            B Offline
                            B Offline
                            BenCranston
                            @Cliff-Karlsson I just posted to Git my Serial gateway and a node. The code is still in flux, but it might help your endeavors. Find it here: https://github.com/TheCranston/MY-Sensors.git Caveat emptor... :) (first time posting anything via Github, so please excuse any conventions that I might have ignored - I'm learning)
                            @hek, good point. I just checked my Version.h and it says "1.5" which i thought was the latest master... humm... gotta check it over closely now.
                            • H Offline
                              H Offline
                              I will do a couple of adjustments of the RF69 stuff tonight here on dev-branch.
                              Add a mis-wired check like we do for the RF24 driver. I also currently you have to do a
                              #define MY_IS_RFM69HW true
                              to activate the HW-version... this will be changed to
                                Cliff Karlsson
                                Ok, one more stupid question. If I want to try the developer branch do I just install the regular 1.5 zip amd then just overwrite them with the files from the developer branch on git?
                                  Cliff Karlsson
                                  Ok, I think I have figured it out. But I am trying this sketch:
                                   * The ArduinoGateway prints data received from sensors on the serial link.
                                   * The gateway accepts input on seral which will be sent out on radio network.
                                   * The GW code is designed for Arduino Nano 328p / 16MHz
                                   * Wire connections (OPTIONAL):
                                   * - Inclusion button should be connected between digital pin 3 and GND
                                   * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
                                   * LEDs (OPTIONAL):
                                   * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
                                  //#define MY_RADIO_NRF24
                                  // Enable serial gateway
                                  #define MY_GATEWAY_SERIAL
                                  // Flash leds on rx/tx/err
                                  #define MY_LEDS_BLINKING_FEATURE
                                  // Set blinking period
                                  // Enable inclusion mode
                                  #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
                                  #define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
                                  #define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
                                  void presentation() {
                                  But I am getting this error when trying to complie:
                                  Arduino: 1.6.6 (Windows 7), Board: "Arduino Nano, ATmega328"
                                  Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                                  Warning: platform.txt from core 'Mysensors SAMD (32-bits ARM Cortex-M0+) Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                                  Library can't use both 'src' and 'utility' folders.
                                  Error compiling.
                                    enabled in File > Preferences.
                                  • H Offline
                                    H Offline
                                    wrote on last edited by hek
                                    Do like it says, turn on verbose output.
                                    (you have to replace the old MySensors-folder under libraries with the new)
                                      Cliff Karlsson
                                      Ok, I turned on the verbose output and this is what I got:
                                      C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Cliff\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10606 -build-path "C:\Users\Cliff\AppData\Local\Temp\build8a702dc9de8b52c506f71d8c8aabed09.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Cliff\AppData\Local\Temp\arduino_8a702dc9de8b52c506f71d8c8aabed09\GatewaySerial.ino"
                                      Error compiling.
                                      I have removed arduino IDE and all mysensor libraries, I reinstalled the arduino IDE added/replaced the librarys with the Arduino-master, then replaced again with Arduino-development.
                                      • H Offline
                                        H Offline
                                        You must have done something wrong setting it up (I'm also running 1.6.6).
                                        You should get the following error using the sketch you posted above:
                                        Users/hek/Documents/ArduinoGithub/libraries/MySensors/MySensor.h:195:3: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                                          Cliff Karlsson
                                          Ok, after trying again I extracted Arduino-development to a separate folder in my sketchbook location witout replacing anything. I then got an error saying it could not find Mysensors.h so I copied it to the Gatewayserial folder and now it complies but gives me the error you specified hek. So how do I solve this? is not the gatewayserial sketch ready to complie as is?
                                          12.1k
