No communication between Sensor and Gateway
  • So I am a real newbe on this, so please be gentle with me...!
    Situation:
    Gateway;
    Arduino Uno with NRF24L01+ module
    Uploaded the Serial Gateway on this one
    Sensor;
    Arduino mini pro with NRF24L01+ module
    Uploaded the binairy switch sensor on this one
    Connected a push button on GND and D3
    Problem
    There seems to be no communication between the sensor and the gateway.
    Steps I have taken to troubleshoot
    Looked up the serial output on gateway;
    6-12-2015 12:48:40 RX 0;0;3;0;9;gateway started, id=0, parent=0, distance=0
    6-12-2015 12:48:40 RX 0;0;3;0;14;Gateway startup complete.
    Looked up the serial output on the sensor;
    6-12-2015 12:49:34 INFO Unknown message, Msg=find parent, dc=1
    6-12-2015 12:49:34 RX find parent
    6-12-2015 12:49:34 INFO Unknown message, Msg=send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:, dc=1
    6-12-2015 12:49:34 RX send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    When I push my button on the sensor it outputs upper 4 lines again.
    In MYSController I only 'see' my gateway, no sensors.
    Measured the 3.3 output voltage on the PCB of the 2.4Ghz board.
    Please help to take the next troubleshooting step!
  • Hi
    Like you, i'have got a lot a problem to connect nano pro mini with a serial gateway on a raspeberry
    Everything is fine on with a Arduino Uno.i think there are problems with the 3,3 V pover on tte nano pro mini
    I keep on investigating..
    TRy to connect with UNO with gateway sketch and one UNO with sensor sketch.. and everyting wikk be ok..
    As you i'm newbee
    Which version do you run?
    Like sundberg84, I would advise that you both provide us with the sketch that you are using and let us know what version of the MySensors API you've got the sketch from.
  • When I started with MySensors recently, I got non-communication because I didn't assign the gateway and the sensor node an ID so they can identify themselves during communication. Seeing node ID's 0 and 255 on your logs, my first question would be: did you assign node ID's (from controller)?
  • I use version 1.5
    @sundberg84
    @samuel235
    On the gateway I loaded the sketch SerialGateway.ino from the examples folder.
    On the Sensor I loaded the sketch BinarySwitchSensor.ino from the examples folder.
    @jantup
    No, I did not change anything on the example sketches, how do I assign an ID to the gateway and sensor? (I thought this was an automated proces?)
    Thanks for your replies!
    If you have some sort of controller they assign the id (gateway is 0 by default). what does your serial logs lock like?
  • @sundberg84
    My serials logs are on the OP
    @Martien-Wijnands By the look of the logs i would say that your Gateway has a ID of 0 (Which is default). Now, the node needs to be assigned an ID. Some controllers do support auto assignment however, for troubleshooting at least i would force an ID on the node manually. To do so you need to edit "gw.begin()" on the sensor node sketch to read:
    gw.begin(NULL, [NODE_ID], true)
    Just add a number between 1-254 (Any number that isn't already taken by another node on the network) in the above code. Remember to remove the square brackets too.
    Sorry I didnt explain @Martien-Wijnands I was interested i how the node serial looks during startup, in OP it its only when you press the button? As samuel235 explains that can help setting a node ID but if you dont see the node in MYSController i dont think the node radio traffic reaches the gw...
    Do you see anything about ST:Fail or ST:OK (or this was removed in 1.5? maybe, I never used 1.5).
    Sketches needs not to be changed. Node IDs are not encoded in software, they are data from MySensors perspective. Nodes doesn't manage IDs themselves, but any node need an ID in order to communicate. Assigning node IDs must be done from outside MySensors network and totally depends on the controller you use.
    I use OpenHab as a controller, you can automate (code) ID assigning there.
    Honestly, I myself am too lazy and still assign node IDs manually by sending appropriate string to controller's USB port the gateway is attached to from command line as a response to gateway when a node asks for ID on the nodes radio network. You can do the same without even having a controller, just attach the gateway node to a computer through USB, monitor what's incoming and send the right string back to the USB port when you see a node asking for the ID.
    I was very surprised when I found out that MySensors nodes network is not self-sufficient in this sense. You can see how I figured it out here, but as I said, it really depends on the controller you use.
  • I use MYScontroller as the controller, when this works I plan for using domoticz.
    @samuel235
    The logs on the gateway;
    The logs on the node (after setting the node ID to 5)
    find parent
    send: 5-5-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    find parent
    find parent
    repeater started, id=5, parent=255, distance=255
    find parent
    find parent
    No ST:Fail or ST:OK in both outputs. I really think my radio's are not sending/receiving data!
    did you solve the issue?
    I have the same behavior between my Gateway (Arduino Nano 5V ) and just one sensor (Arduino Pro Mini 3.3V connected to PC USB port via Arduino UNO board). The Serial Monitor get just the same entries as yours.
    Thank you.
    @mortommy - And are you running the same version of mysensors?
  • Hi @samuel235 , Yes, v1.5.
    I also connected the caps between the radio Vcc and GND connectors to exclude power issues, but I wanted to recycle some pieces I already had, so I used 3.3 uF, could be the problem?
    Thank you.
    It could possibly be, its all depending on your environment. I would like a hardware contributer to confirm or correct me on this one but i would change that cap to something higher, check the 'connecting the radio' page, don't quote me on this but i think the recommended is something like a 4.7uF to start with. I actually have 100uF on mine, i went over the top and was just being safe. However on my custom board thats in design stages i will be trying a 47uF.
    It could quite possibly not be this thats the issue, but it would be step 1 of trial and error troubleshooting that i would take.
    I solved the issue. After reading many posts I went to check if my radio module was a real NRF24L01+ plus version, and I realized that one of the 5 modules I bought as one pack, the one connected to the serial gateway, is different. So I connected a real plus version and now is working!
    Thank you.
    I solved the issue!
    My radio's were fake/defect.
    I ordered some new radio's and they work like a charm!
    Thanks for all your help and tips/tricks.
  • Hi Martien, It seems that I have the same problem. I bought my NRF24L01+ through the aliexpress link on this site. The initiate like they should but do not communicate at all. Where did you order your new ones ?
  • I had quite similar issue with sensor and gateway not communicating.
    Solved today
