Data stored in the EEPROM
    Chatting about storing data into the EEPROM with @paqor I got a little bit curious what the mysensors library stores into that EEPROM so I wrote a little function for dumping that data. I tested it with the 1.4 version of the library:
    void DumpMySensorsEepromData()
    	Serial.println("Dumping MySensors EEPROM:");
    	Serial.println("");
    	Serial.print("Node id: ");
    	Serial.println(EEPROM.read(EEPROM_NODE_ID_ADDRESS));
    	Serial.print("Parent node id: ");
    	Serial.println(EEPROM.read(EEPROM_PARENT_NODE_ID_ADDRESS));
    	Serial.print("Distance: ");
    	Serial.println(EEPROM.read(EEPROM_DISTANCE_ADDRESS));
    	Serial.println("");
    	// child --> route
    	Serial.println("Routing information: ");
    	for (int route = EEPROM_ROUTES_ADDRESS; route < EEPROM_CONTROLLER_CONFIG_ADDRESS; route++)
    		int child = route - EEPROM_ROUTES_ADDRESS;
    		uint8_t destination = EEPROM.read(route);
    		if (destination != 0xff)
    			Serial.print(child);
    			Serial.print(" --> ");
    			Serial.print(destination);
    			Serial.println("");
    	Serial.println("");
    	// metric imperial
    	Serial.println("Controller config: ");
    	uint8_t isMetric = EEPROM.read(EEPROM_CONTROLLER_CONFIG_ADDRESS);
    	if (isMetric == 0xFF)
    		Serial.println("is metric");
    		Serial.println("is imperial");
    	Serial.println("");
    	Serial.println("Controller config raw data: ");
    	for (int config = EEPROM_CONTROLLER_CONFIG_ADDRESS; config < EEPROM_FIRMWARE_TYPE_ADDRESS; config++)
    		Serial.print(EEPROM.read(config));
    		Serial.print(", ");
    		if ((config - EEPROM_CONTROLLER_CONFIG_ADDRESS + 1) % 8 == 0)
    			Serial.println("");
    	Serial.println("");
    	Serial.print("Firmware Type: ");
    	Serial.print(EEPROM.read(EEPROM_FIRMWARE_TYPE_ADDRESS + 0));
    	Serial.print(", ");
    	Serial.println(EEPROM.read(EEPROM_FIRMWARE_TYPE_ADDRESS + 1));
    	Serial.print("Firmware Version: ");
    	Serial.print(EEPROM.read(EEPROM_FIRMWARE_BLOCKS_ADDRESS + 0));
    	Serial.print(", ");
    	Serial.println(EEPROM.read(EEPROM_FIRMWARE_BLOCKS_ADDRESS + 1));
    	Serial.print("Firmware Blocks: ");
    	Serial.print(EEPROM.read(EEPROM_FIRMWARE_VERSION_ADDRESS + 0));
    	Serial.print(", ");
    	Serial.println(EEPROM.read(EEPROM_FIRMWARE_VERSION_ADDRESS + 1));
    	Serial.print("Firmware CRC: ");
    	Serial.print(EEPROM.read(EEPROM_FIRMWARE_CRC_ADDRESS + 0));
    	Serial.print(", ");
    	Serial.println(EEPROM.read(EEPROM_FIRMWARE_CRC_ADDRESS + 1));
    	Serial.println("");
    	Serial.print("Start of local user config is at address: ");
    	Serial.println(EEPROM_LOCAL_CONFIG_ADDRESS);
    	Serial.println("");
    	Serial.println("Local user data: ");
    	for (int localConfig = EEPROM_LOCAL_CONFIG_ADDRESS; localConfig < EEPROM_LOCAL_CONFIG_ADDRESS + 255; localConfig++)
    		Serial.print(EEPROM.read(localConfig));
    		Serial.print(", ");
    		if ((localConfig - EEPROM_LOCAL_CONFIG_ADDRESS + 1) % 8 == 0)
    			Serial.println("");
    	Serial.println("");
    The output looks as follows:
    Node id: 1
    Parent node id: 0
    Distance: 1
    0 --> 0
    1 --> 1
    2 --> 100
    5 --> 101
    65 --> 101
    100 --> 100
    101 --> 101
    102 --> 102
    104 --> 100
    105 --> 105
    106 --> 106
    107 --> 107
    108 --> 108
    109 --> 109
    110 --> 110
    111 --> 111
    112 --> 112
    129 --> 101
    243 --> 243
    Controller config:
    is imperial
    1, 255, 255, 255, 255, 255, 255, 255,
    255, 255, 255, 255, 255, 255, 255, 255,
    Firmware Type: 255, 255
    Firmware Version: 255, 255
    Firmware Blocks: 255, 255
    Firmware CRC: 255, 255
    Start of local user config is at address: 291
    Local user data:
    255, 0, 0, 0, 255, 255, 255, 255,
    255, 1, 1, 1, 255, 255, 255, 255,
    The data is from a repeater. Note that the layout may change in upcoming mysensors versions.
    Your local data is for example stored at offset 291, so be careful when using the native EEPROM functions where you have to provide an offset!
    Works good! I made a few minor mods just for my taste, and dumped what I think is from an old gateway v1.4
    #include <EEPROM.h>
      DumpMySensorsEepromData();
    void loop() {}
    void printByte(uint8_t b) {
      if (b<100) Serial.print(" ");
      if (b<10) Serial.print(" ");
      Serial.print(b);
      Serial.print(", ");
        Serial.println("");
        Serial.print("Node id (");Serial.print(EEPROM_NODE_ID_ADDRESS);Serial.print(") : ");
        Serial.print("Parent node id (");Serial.print(EEPROM_PARENT_NODE_ID_ADDRESS);Serial.print(") : ");;
        Serial.print("Distance (");Serial.print(EEPROM_DISTANCE_ADDRESS);Serial.print(") : ");
        Serial.println("");
        // child --> route
        Serial.print("Routing information (adr ");
        Serial.print(EEPROM_ROUTES_ADDRESS);
        Serial.print(" - ");
        Serial.print(EEPROM_CONTROLLER_CONFIG_ADDRESS-1);
        Serial.println(") :");
                Serial.println("");
        Serial.println("");
        // Raw routing data
        Serial.print("Raw routing information (adr ");
            for (int i = EEPROM_ROUTES_ADDRESS; i < EEPROM_CONTROLLER_CONFIG_ADDRESS; i++)
            printByte(EEPROM.read(i));
            //Serial.print(", ");
            if ((i - EEPROM_ROUTES_ADDRESS + 1) % 10 == 0)
                Serial.println("");
        Serial.println("");
        Serial.println("");
        // metric imperial
        Serial.print("Controller config (");Serial.print(EEPROM_CONTROLLER_CONFIG_ADDRESS);Serial.println(") : ");
        Serial.println("");
        Serial.print("Controller config raw data (adr ");
        Serial.print(EEPROM_FIRMWARE_TYPE_ADDRESS-1);
            printByte(EEPROM.read(config));
            if ((config - EEPROM_CONTROLLER_CONFIG_ADDRESS + 1) % 10 == 0)
                Serial.println("");
        Serial.println("");
        Serial.println("");
        Serial.print("Firmware Type (adr ");
        Serial.print(EEPROM_FIRMWARE_TYPE_ADDRESS);
        Serial.print(EEPROM_FIRMWARE_TYPE_ADDRESS+1);
        Serial.print(", ");
        Serial.print("Firmware Blocks (adr ");
        Serial.print(EEPROM_FIRMWARE_VERSION_ADDRESS);
        Serial.print(EEPROM_FIRMWARE_VERSION_ADDRESS+1);
        Serial.print(", ");
        Serial.print("Firmware Version (adr ");
        Serial.print(EEPROM_FIRMWARE_BLOCKS_ADDRESS);
        Serial.print(EEPROM_FIRMWARE_BLOCKS_ADDRESS+1);
        Serial.print(", ");
        Serial.print("Firmware CRC (adr ");
        Serial.print(EEPROM_FIRMWARE_CRC_ADDRESS);
        Serial.print(EEPROM_FIRMWARE_CRC_ADDRESS+1);
        Serial.print(", ");
        Serial.println("");
        Serial.println("");
        Serial.print("Local user data (adr ");
        Serial.print(EEPROM_LOCAL_CONFIG_ADDRESS);
        Serial.print(EEPROM_LOCAL_CONFIG_ADDRESS+255);
            printByte(EEPROM.read(localConfig));
            if ((localConfig - EEPROM_LOCAL_CONFIG_ADDRESS + 1) % 10 == 0)
                Serial.println("");
        Serial.println("");
    Output example:
    Node id (0) : 255
    Parent node id (1) : 255
    Distance (2) : 255
    Routing information (adr 3 - 258) :
    16 --> 16
    17 --> 50
    101 --> 50
    102 --> 50
    104 --> 50
    105 --> 105
    106 --> 106
    110 --> 110
    Raw routing information (adr 3 - 258) :
    255, 255, 255, 255, 255, 255, 255, 255, 255, 255,
    255, 255, 255, 255, 255, 255,  16,  50, 255, 255,
    255,  50,  50, 255,  50, 105, 106, 255, 255, 255,
    110, 255, 255, 255, 255, 255, 255, 255, 255, 255,
    Controller config (259) :
    is metric
    Controller config raw data (adr 259 - 282) :
    255, 255, 255, 255,
    Firmware Type (adr 283 - 284) :
    255, 255
    Firmware Blocks (adr 285 - 286) :
    255, 255
    Firmware Version (adr 287 - 288) :
    255, 255
    Firmware CRC (adr 289 - 290) :
    255, 255
    Start of local user config is at address: 323
    Local user data (adr 323 - 578) :
    Thanks, looks good.
  • 198
20
