  3. Eeprom usage
Eeprom usage
7 Posts 5 Posters 7.3k Views 6 Watching
  • P
    P
    pawel
    Hi.
    How mySensors usage eeprom memory?
    How many bytes and with addresses?
    I would like use eeprom memory to own application but I don't know with address will be free.
    Thx.
    Pawel
      You'll find the addresses used here:
      https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L44
      If you only need 256 bytes you can use the library functions saveState()/loadState() which makes sure you won't mess up anything.
        marcusvdt
        @hek I have a quick question regarding the gw.saveState and consequently the gw.loadState instructions
        As per the link and code you have mentioned, reproduced below:
        // EEPROM start address for mysensors library data
        #define EEPROM_START 0
        // EEPROM location of node id
        #define EEPROM_NODE_ID_ADDRESS EEPROM_START
        // EEPROM location of parent id
        #define EEPROM_PARENT_NODE_ID_ADDRESS (EEPROM_START+1)
        // EEPROM location of distance to gateway
        #define EEPROM_DISTANCE_ADDRESS (EEPROM_PARENT_NODE_ID_ADDRESS+1)
        #define EEPROM_ROUTES_ADDRESS (EEPROM_DISTANCE_ADDRESS+1) // Where to start storing routing information in EEPROM. Will allocate 256 bytes.
        #define EEPROM_CONTROLLER_CONFIG_ADDRESS (EEPROM_ROUTES_ADDRESS+256) // Location of controller sent configuration (we allow one payload of config data from controller)
        #define EEPROM_FIRMWARE_TYPE_ADDRESS (EEPROM_CONTROLLER_CONFIG_ADDRESS+24)
        #define EEPROM_FIRMWARE_VERSION_ADDRESS (EEPROM_FIRMWARE_TYPE_ADDRESS+2)
        #define EEPROM_FIRMWARE_BLOCKS_ADDRESS (EEPROM_FIRMWARE_VERSION_ADDRESS+2)
        #define EEPROM_FIRMWARE_CRC_ADDRESS (EEPROM_FIRMWARE_BLOCKS_ADDRESS+2)
        #define EEPROM_LOCAL_CONFIG_ADDRESS (EEPROM_FIRMWARE_CRC_ADDRESS+2) // First free address for sketch static configuration
        I understand it translates to:
        ADDRESS	SIZE		ALIAS
        0X000	1 BYTE		EEPROM_START, EEPROM_NODE_ID_ADDRESS
        0X001	1 BYTE		EEPROM_PARENT_NODE_ID_ADDRESS
        0X002	1 BYTE		EEPROM_DISTANCE_ADDRESS
        0X003	256 BYTES		EEPROM_ROUTES_ADDRESS
        0X103	24 BYTES	EEPROM_CONTROLLER_CONFIG_ADDRESS
        0X11B	2 BYTES		EEPROM_FIRMWARE_TYPE_ADDRESS
        0X11D	2 BYTES		EEPROM_FIRMWARE_VERSION_ADDRESS
        0X11F	2 BYTES		EEPROM_FIRMWARE_BLOCKS_ADDRESS
        0X121	2 BYTES		EEPROM_FIRMWARE_CRC_ADDRESS
        0X123	???			EEPROM_LOCAL_CONFIG_ADDRESS
        So it means when I perform these instructions:
        lightStatus = state;
        gw.saveState(0,state);
        In what specific address am I saving the data? The instruction itself says position zero, so am I saving to the first address 0x123 in this case???
        Thanks in advance.
          0x123
          Yes, that sounds about right.
          • bisschopsrB
            bisschopsrB
            bisschopsr
            Sound good! How can I write/read values over 255 to the EEPROM. This takes more then one byte.
            If I write 255, I get: 255 0 (place 0 place 1)
            256 will give: 0 255
            257 will give: 1 255
            etc.
            Reading only reads the byte indicated with the function loadState()
            Thanks in advance
            Ralph
            Domoticz, P1 meter interface, MySensors and more to come!
            fetsF 1 Reply Last reply
            • bisschopsrB bisschopsr
              etc.
              Thanks in advance
              Ralph
              fetsF
              fetsF
              fets
              @bisschopsr I think you can use hw_writeConfigBlock/hw_readConfigBlock with the "right" address
              • bisschopsrB
                bisschopsrB
                bisschopsr
                wrote on last edited by bisschopsr
                Hi All,
                Resolved this with a simple funtion splitting the value in byte long parts. Bit shifting and OR are a perfect fit for this :-).
                The code:
                void storeEeprom(int pos, int value) {
                	// function for saving the values to the internal EEPROM
                	// value = the value to be stored (as int)
                	// pos = the first byte position to store the value in
                	// only two bytes can be stored with this function (max 32.767)
                	gw.saveState(pos, ((unsigned int)value >> 8 ));
                	pos++;
                	gw.saveState(pos, (value & 0xff));
                int readEeprom(int pos) {
                	// function for reading the values from the internal EEPROM
                	// pos = the first byte position to read the value from
                	int hiByte;
                	int loByte;
                	hiByte = gw.loadState(pos) << 8;
                	pos++;
                	loByte = gw.loadState(pos);
                	return (hiByte | loByte);
