  • Here you go....However, I do not have EthernetGateway but a MQTTClientGateway. May be it is of help.
    What is your specific problem?
    myconfig.h (key changed)
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    #define DEBUG
    #define BAUD_RATE 115200
    #define MY_OTA_FLASH_SS 8
    // Flash jdecid
    *  Information LEDs blinking
    // disabled in the gateway.
    //#define WITH_LEDS_BLINKING
    // off when blinking
    // The RX LED default pin
    #define DEFAULT_RX_LED_PIN 6
    // The TX LED default pin
    #define DEFAULT_TX_LED_PIN 5
    // The Error LED default pin
    #define DEFAULT_ERR_LED_PIN 4
    *  Message Signing Settings
    #define MY_SIGNING_FEATURE
    #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
    #define MY_HMAC_KEY 0x10,0x23,0xBB,0x78,0x77,0x35,0xB0,0x01,0x70,0x47,0xF1,0xDE,0x21,0x94,0x54,0x67,0xEE,0x36,0x72,0x00,0x97,0x12,0xA0,0x0A,0x0F,0x09,0x03,0xE2,0x00,0x31,0xE4,0x41
    *  NRF24L01 Driver Defaults
    #define RF24_CE_PIN		   9
    #define RF24_CS_PIN		   10
    #define RF24_CHANNEL	   76
    //#define SOFTSPI
    #ifdef SOFTSPI
    *  RFM69 Driver Defaults
    /* 				MyMQTT Client Gateway 0.1b
     Created by Norbert Truchsess <norbert.truchsess@t-online.de>
     Based on MyMQTT-broker gateway created by Daniel Wiegert <daniel.wiegert@gmail.com>
     Based on MySensors Ethernet Gateway by Henrik Ekblad <henrik.ekblad@gmail.com>
     http://www.mysensors.org
     Requires MySensors lib 1.4b
     * Change below; TCP_IP, TCP_PORT, TCP_MAC
     This will listen on your selected TCP_IP:TCP_PORT below, Please change TCP_MAC your liking also.
     *1 -> NOTE: Keep first byte at x2, x6, xA or xE (replace x with any hex value) for using Local Ranges.
     *2 You can use standard pin set-up as MySensors recommends or if you own a IBOARD you may change
     the radio-pins below if you hardware mod your iBoard. see [URL BELOW] for more details.
     http://forum.mysensors.org/topic/224/iboard-cheap-single-board-ethernet-arduino-with-radio/5
     * Don't forget to look at the definitions in libraries\MySensors\MyMQTT.h!
     define TCPDUMP and connect serial interface if you have problems, please write on
     http://forum.mysensors.org/ and explain your problem, include serial output. Don't forget to
     turn on DEBUG in libraries\MySensors\MyConfig.h also.
     MQTT_FIRST_SENSORID is for 'DHCP' server in MyMQTT. You may limit the ID's with FIRST and LAST definition.
     If you want your manually configured below 20 set MQTT_FIRST_SENSORID to 20.
     To disable: set MQTT_FIRST_SENSORID to 255.
     MQTT_BROKER_PREFIX is the leading prefix for your nodes. This can be only one char if like.
     MQTT_SEND_SUBSCRIPTION is if you want the MyMQTT to send a empty payload message to your nodes.
     This can be useful if you want to send latest state back to the MQTT client. Just check if incoming
     message has any length or not.
     Example: if (msg.type==V_LIGHT && strlen(msg.getString())>0) otherwise the code might do strange things.
     * Address-layout is : [MQTT_BROKER_PREFIX]/[NodeID]/[SensorID]/V_[SensorType]
     NodeID and SensorID is uint8 (0-255) number.
     Last segment is translation of the sensor type, look inside MyMQTT.cpp for the definitions.
     User can change this to their needs. We have also left some space for custom types.
     Special: (sensor 255 reserved for special commands)
     You can receive a node sketch name with MyMQTT/20/255/V_Sketch_name (or version with _version)
     To-do:
     Special commands : clear or set EEPROM Values, Send REBOOT and Receive reboot for MyMQTT itself.
     Be able to send ACK so client returns the data being sent.
     ... Please come with ideas!
     What to do with publish messages.
     Test in more MQTT clients, So far tested in openhab and MyMQTT for Android (Not my creation)
     - http://www.openhab.org/
     - https://play.google.com/store/apps/details?id=at.tripwire.mqtt.client&hl=en
     ... Please notify me if you use this broker with other software.
     * How to set-up Openhab and MQTTGateway:
     http://forum.mysensors.org/topic/303/mqtt-broker-gateway
     Changes by Thomas Krebs <thkrebs@gmx.de>
     - Add signing support from MySensors 1.5 and update for MySensors 1.5;
     - Restructured code back to a C like implementation following the existing MQTTGateway
    #include "MyMQTTClient.h"
    #include "PubSubClient.h"
    #include <Ethernet.h>
    #include <DigitalIO.h>
    #include <MsTimer2.h>
    #include <Time.h>
    #ifdef MY_SIGNING_FEATURE
    #include <MySigningNone.h>
    //#define DSRTC
    #ifdef DSRTC
    #include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
     * To configure MQTTClientGateway.ino to use an ENC28J60 based board include
     * 'UIPEthernet.h' (SPI.h required for MySensors anyway). The UIPEthernet-library can be downloaded
    //#include <UIPEthernet.h>
     * To execute MQTTClientGateway.ino on Yun uncomment Bridge.h and YunClient.h.
     * Do not include Ethernet.h or SPI.h in this case.
     * On Yun there's no need to configure local_ip and mac in the sketch
     * as this is configured on the linux-side of Yun.
    //#include <Bridge.h>
    //#include <YunClient.h>
    // * Use this for IBOARD modded to use standard MISO/MOSI/SCK, see note *1 above!
     #define RADIO_CE_PIN        3			// radio chip enable
     #define RADIO_SPI_SS_PIN    8			// radio SPI serial select
     #define RADIO_ERROR_LED_PIN A2  		// Error led pin
     #define RADIO_RX_LED_PIN    A1  		// Receive led pin
     #define RADIO_TX_LED_PIN    A0  		// the PCB, on board LED*/
    // * Use this for default configured pro mini / nano etc :
    //#define RADIO_CE_PIN        5		// radio chip enable
    //#define RADIO_SPI_SS_PIN    6		// radio SPI serial select
    //#define RADIO_ERROR_LED_PIN 7		// Error led pin
    //#define RADIO_RX_LED_PIN    8		// Receive led pin
    //#define RADIO_TX_LED_PIN    9		// the PCB, on board LED*/
    // CE_PIN and SPI_SS_PIN for Mega
    #define RADIO_CE_PIN        48			// radio chip enable
    #define RADIO_SPI_SS_PIN    49			// radio SPI serial select
    //replace with ip of server you want to connect to, comment out if using 'remote_host'
    uint8_t remote_ip[] =  { 192, 168, 178, 74 };  // Mosquitto broker
    //replace with hostname of server you want to connect to, comment out if using 'remote_ip'
    //char* remote_ip = "server.local";
    //replace with the port that your server is listening on
    #define remote_port 1883
    //replace with arduinos ip-address. Comment out if Ethernet-startup should use dhcp. Is ignored on Yun
    uint8_t local_ip[] = {192, 168, 178, 11};
    //replace with ethernet shield mac. It's mandatory every device is assigned a unique mac. Is ignored on Yun
    uint8_t mac[] = { 0xA2, 0xAE, 0xAD, 0xA0, 0xA0, 0xA2 };
    #if defined remote_ip && defined remote_host
    #error "cannot define both remote_ip and remote_host at the same time!"
    #ifdef _YUN_CLIENT_H_
    YunClient ethClient;
    EthernetClient ethClient;
    //MyTransportRFM69 transport;
    //MySigningNone signer;
    MySigningAtsha204Soft signer;
    //MySigningAtsha204 signer;
    // Hardware profile
    MyHwATMega328 hw;
    MyMessage msg;
    char convBuf[MAX_PAYLOAD * 2 + 1];
    uint8_t buffsize;
    char buffer[MQTT_MAX_PACKET_SIZE];
    volatile uint8_t countRx;
    volatile uint8_t countTx;
    volatile uint8_t countErr;
    void processMQTTMessages(char* topic, byte* payload, unsigned int length);
    PubSubClient client(remote_ip, remote_port, processMQTTMessages, ethClient);
    // Declare and initialize MySensor instance
    // Construct MyMQTTClient (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h, if signing
    // feature not to be used, uncomment)
    MySensor gw(transport, hw
                , signer
    #ifdef WITH_LEDS_BLINKING
                , RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN
     * setup
      countRx = 0;
      countTx = 0;
      countErr = 0;
      Ethernet.begin(mac, local_ip);
      //Bridge.begin();
      delay(1000);   // Wait for Ethernet to get configured.
      begin();
     * loop
      if (!client.connected())
        client.connect("MySensor");
        client.subscribe(MQTT_TOPIC_MASK);
      client.loop();
     * processRadioMessage
     * Receives radio message, parses it and forwards it to the MQTT broker
    void processRadioMessage(const MyMessage &message)
        rxBlink(1);
        sendMQTT(message);
     * sendMQTT
     * Handles processing of radio messages and eventually publishes it to the MQTT broker
    void sendMQTT(const MyMessage &inMsg)
      MyMessage msg = inMsg;
      buffsize = 0;
        return;			//We have no connections - return
      if (msg.isAck())
    #ifdef DEBUG
        Serial.println("msg is ack!");
        if (msg.sender == 255 && mGetCommand(msg) == C_INTERNAL
            && msg.type == I_ID_REQUEST)
          // TODO: sending ACK request on id_response fucks node up. doesn't work.
          // The idea was to confirm id and save to EEPROM_LATEST_NODE_ADDRESS.
        // we have to check every message if its a newly assigned id or not.
        // Ack on I_ID_RESPONSE does not work, and checking on C_PRESENTATION isn't reliable.
        uint8_t newNodeID = gw.loadState(EEPROM_LATEST_NODE_ADDRESS) + 1;
        if (newNodeID <= MQTT_FIRST_SENSORID)
          newNodeID = MQTT_FIRST_SENSORID;
        if (msg.sender == newNodeID)
          gw.saveState(EEPROM_LATEST_NODE_ADDRESS, newNodeID);
        if (mGetCommand(msg) == C_INTERNAL)
          if (msg.type == I_CONFIG)
            txBlink(1);
            if (!gw.sendRoute(
                  build(msg, GATEWAY_ADDRESS, msg.sender, 255, C_INTERNAL,
                        I_CONFIG, 0).set("M")))
              errBlink(1);
          else if (msg.type == I_TIME)
    #ifdef DEBUG
            Serial.println("I_TIME requested!");
            txBlink(1);
            if (!gw.sendRoute(
                        I_TIME, 0).set(now())))
              errBlink(1);
          else if (msg.type == I_ID_REQUEST && msg.sender == 255)
            if (newNodeID >= MQTT_LAST_SENSORID)
              return; // Sorry no more id's left :(
            txBlink(1);
            if (!gw.sendRoute(
                        I_ID_RESPONSE, 0).set(newNodeID)))
              errBlink(1);
          else if (msg.type == I_BATTERY_LEVEL)
            strcpy_P(buffer, mqtt_prefix);
            buffsize += strlen_P(mqtt_prefix);
            buffsize += sprintf(&buffer[buffsize], "/%i/255/BATTERY_LEVEL\0", msg.sender );
            msg.getString(convBuf);
    #ifdef DEBUG
            Serial.print("publish: ");
            Serial.print((char*) buffer);
            Serial.print(" ");
            Serial.println((char*) convBuf);
            client.publish(buffer, convBuf);
          else if (msg.type == I_SKETCH_NAME)
            buffsize += sprintf(&buffer[buffsize], "/%i/255/SKETCH_NAME\0", msg.sender );
    #ifdef DEBUG
            Serial.print(" ");
          else if (msg.type == I_SKETCH_VERSION)
            buffsize += sprintf(&buffer[buffsize], "/%i/255/SKETCH_VERSION\0", msg.sender );
    #ifdef DEBUG
            Serial.print(" ");
        else if (mGetCommand(msg) != 0)
          if (mGetCommand(msg) == 3)
            msg.type = msg.type + (S_FIRSTCUSTOM - 10);	//Special message
          if (msg.type > VAR_TOTAL)
            msg.type = VAR_TOTAL;		// If type > defined types set to unknown.
          buffsize += sprintf(&buffer[buffsize], "/%i/%i/V_%s\0", msg.sender,
                              msg.sensor, getType(convBuf, &VAR_Type[msg.type]));
    #ifdef DEBUG
          Serial.print(" ");
     * build
     * Constructs a radio message
    inline MyMessage& build(MyMessage &msg, uint8_t sender, uint8_t destination, uint8_t sensor,
                            uint8_t command, uint8_t type, bool enableAck)
      msg.destination = destination;
      msg.sender = sender;
      msg.sensor = sensor;
      msg.type = type;
      mSetCommand(msg, command);
      mSetRequestAck(msg, enableAck);
      mSetAck(msg, false);
      return msg;
     * getType
    char *getType(char *b, const char **index)
      char *q = b;
      char *p = (char *) pgm_read_word(index);
      while (*q++ = pgm_read_byte(p++))
      *q = 0;
      return b;
     * begin
     * wraps MySensors begin method; setup of RTC and led timers interrupt
    void begin()
    #ifdef DEBUG
      Serial.begin(BAUD_RATE);
    #ifdef DSRTC
      // Attach RTC
      setSyncProvider(RTC.get);   // the function to get the time from the RTC
      setSyncInterval(60);
      gw.begin(processRadioMessage, 0, true, 0);
      MsTimer2::set(200, ledTimersInterrupt);
      MsTimer2::start();
    #ifdef DEBUG
      Serial.print(getType(convBuf, &VAR_Type[S_FIRSTCUSTOM]));
     * processMQTTMessages
     * message handler for the PubSubClient
      processMQTTMessage(topic, payload, length);
     * processes MQTT messages, parses the topic, extracts radio address out of topic and sends them
     * to the respective radio
    void processMQTTMessage(char* topic, byte* payload,
      char *str, *p;
      uint8_t i = 0;
      buffer[0] = 0;
      buffsize = 0;
      uint8_t cmd = -1;
           str = strtok_r(NULL, "/", &p))
        switch (i)
          case 0:
              if (strcmp_P(str, mqtt_prefix) != 0)
              { //look for MQTT_PREFIX
                return;			//Message not for us or malformatted!
          case 1:
              msg.destination = atoi(str);	//NodeID
          case 2:
              msg.sensor = atoi(str);		//SensorID
          case 3:
              char match = 0;			//SensorType
              //strcpy(str,(char*)&str[2]);  //Strip VAR_
              for (uint8_t j = 0;
                   strcpy_P(convBuf, (char*) pgm_read_word(&(VAR_Type[j]))); j++)
                if (strcmp((char*) &str[2], convBuf) == 0)
                { //Strip VAR_ and compare
                  match = j;
                if (j >= VAR_TOTAL)
                { // No match found!
                  match = VAR_TOTAL;	// last item.
              msg.type = match;
           case 4:
                // support the command get and set; get will be mapped to a C_REQ and set to C_SET
                if (strcmp(str,MQTT_CMD_SET) == 0)
                  cmd = C_SET;
                else if (strcmp(str,MQTT_CMD_GET) == 0) {
                  cmd = C_REQ;
                else {
    #ifdef DEBUG
                  Serial.print("Received unsupported command - ignore: ");
                  Serial.println(str);
        i++;
      }						//Check if packge has payload
      if (cmd != -1) {
        char* ca;
        ca = (char *)payload;
        ca += length;
        *ca = '\0';
        msg.set((const char*)payload);			//Payload
        txBlink(1);
        // inject time
        if ((msg.destination == 0) && (msg.sensor == 199)) {
          unsigned long epoch = atol((char*)payload);
          if (epoch > 10000) {
    #ifdef DSRTC
            RTC.set(epoch); // this sets the RTC to the time from controller - which we do want periodically
            setTime(epoch);
    #ifdef DEBUG
          Serial.print("Time recieved ");
          Serial.println(epoch);
        if (!gw.sendRoute(
              build(msg, GATEWAY_ADDRESS, msg.destination, msg.sensor, C_SET, msg.type,
                    0)))
          errBlink(1);
    // Led handling
     * ledTimersIntterupt
    void ledTimersInterrupt() {
      if (countRx && countRx != 255) {
        // switch led on
        digitalWrite(RADIO_RX_LED_PIN, LOW);
      } else if (!countRx) {
        // switching off
        digitalWrite(RADIO_RX_LED_PIN, HIGH);
      if (countRx != 255) {
        countRx--;
      if (countTx && countTx != 255) {
        // switch led on
        digitalWrite(RADIO_TX_LED_PIN, LOW);
      } else if (!countTx) {
        // switching off
        digitalWrite(RADIO_TX_LED_PIN, HIGH);
      if (countTx != 255) {
        countTx--;
      if (countErr && countErr != 255) {
        // switch led on
        digitalWrite(RADIO_ERROR_LED_PIN, LOW);
      } else if (!countErr) {
        // switching off
        digitalWrite(RADIO_ERROR_LED_PIN, HIGH);
      if (countErr != 255) {
        countErr--;
    void rxBlink(uint8_t cnt)
      if (countRx == 255)
        countRx = cnt;
    void txBlink(uint8_t cnt)
      if (countTx == 255)
        countTx = cnt;
    void errBlink(uint8_t cnt)
      if (countErr == 255)
        countErr = cnt;
  • @tomkxy Thanks, that helped! I seemed to have two problems:
    1. I did not know where to place the necessary includes! Thanks for the examples! Helped me a lot
    2)Regarding my problems from above (error: 'DEFAULT_CE_PIN' was not declared in this scope): I removed the whole libraries/MySensors dir and copied it again from the recent devel branch - this helped, error is gone and everything is compiling fine now 🙂
    Thanks again and cheers,
    Otto
    @otto001 Great! And thanks @tomkxy for helping out. MySensors teamwork at it's best. This is what it's all about 😄
  • Hi again,
    and thanks again. signing seems to work now, unfortunately the sketch is too big for an UNO and I am right now struggling with the pinout and code adaptions to get it working with my W5100 shield and a mega...
    /edit: got it working.
    MyConfig.h:
    #ifdef SOFTSPI
        //MEGA
        const uint8_t SOFT_SPI_MISO_PIN = 15;
        const uint8_t SOFT_SPI_MOSI_PIN = 14;
        const uint8_t SOFT_SPI_SCK_PIN = 16;
    EthernetGateway.ino:
    #define RADIO_CE_PIN        35 // 5  // radio chip enable
    #define RADIO_SPI_SS_PIN    34 // 6  // radio SPI serial select
    And exactly those pins I connected from radio to the mega... (just in case that anyone else is in need of this)
    Might be a little OT, but maybe someone here knows a solution for a strange problem:
    Whenever I am using an UNO or MEGA with my W5100 shield, I have to reset after every power-on to make the sketch run. Does anyone know this? Is there a solution? I am trying to adapt optiboot to wait additional 500ms when powering on, but no luck so far...
    Cheers,
    Otto
    Check here: https://www.sparkfun.com/products/11166 Their "version 2" shield has some notes about fixing the power up reset problem with regular internet shields. Not sure what it is but maybe their notes and schematic can clue you in to a help you implement a fix on your current board.
    And is the explanation of the fix that needs to be made:
    http://www.hobbyist.co.nz/?q=ethernet-shield-w5100
    http://forum.arduino.cc/index.php?topic=215798.msg1607035#msg1607035
    FYI I just ordered a Mega myself for a gateway since I figured the $7 to get one is a better expenditure of my time/money than me trying to get the MqttClientGateway + signing + RF69 radio + debug print to all fit on an Uno so I'll be doing this mod as well.
  • @Anticimex
    I think I may have found a bug in the code:
    I wanted to build a gateway that accepts both signed and unsigned messages. For this I used MySigningAtsha204Soft signer(false);.
    Now the gateway did accept unsigned messages, but also all messages sent to the gateway by another node with signing where unsigned.
    After changing this line in MySensor.cpp:
    if (signer.requestSignatures() && DO_SIGN(msg.sender))
    to
    if (signer.requestSignatures() || DO_SIGN(msg.sender))
    it worked as I wanted it. The gateway accepts unsigned messages from nodes but if a node expects signed messages, the messages to the gateway are also signed.
    This line means that the gateway requests signing from the node if he always requests signing or if the node requests signing.
    What do you think?
    @fleinze I am not sure I understand the basic problem. What do you mean by " but also all messages sent to the gateway by another node with signing where unsigned.". The signing is based on requirement. A node (or gateway) either require messages sent to it to be signed or not. You have told your gateway that it is not supposed to require signed messages so it will accept unsigned messages sent to it. It is up to the node to configure if the node require signed messages in return. The gateway configuration has nothing to do with the preferences of a node. If you tell your gateway that it does not require signing, no messages to it will be signed. The opposite also holds true. If you configure it to require signed messages, all messages have to be signed. That is "working as designed".
    @fleinze after reading the post a few times I think I understand better 🙂 you want nodes who require signed messages from the gateway to send signed messages to the gateway as well even though the gateway is configured to not require it. I don't have a problem with that change as long as it is also portable to the nodes (the same code works equally well for both gateways and nodes usecases). You are welcome to put a pull request on the code so I can have a closer look. If approved I will update the head post to reflect this changed behaviour.
  • 👍 The change only effects gateways. I will put a pull request, thx.
    @fleinze do you have some special reason for why you want this? I don't see a real benefit and it would slightly increase the traffic. I suppose it would add some symmetry to node-gw communication.
    @fleinze I am quite stressed out for the moment so I forget my own design 🙂
    What you actually should do is to configure the gateway to require signed messages. It will then do so, but only from nodes that in turn require signed messages. So you should not need to change anything, just set the GW to require signatures.
  • @Anticimex If I do so, this is the output of the Gateway:
    0;0;3;0;9;no sign
    0;0;3;0;9;no sign
    0;0;3;0;9;no sign
    0;0;3;0;9;no sign
    0;0;3;0;9;read: 2-2-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
    2;0;0;0;6;
    0;0;3;0;9;read: 2-2-0 s=1,c=0,t=30,pt=0,l=0,sg=0:
    2;1;0;0;30;
    0;0;3;0;9;no sign
    0;0;3;0;9;no sign
    0;0;3;0;9;no sign
    I tried to compile the node with deactivated signing feature and also with MySigningNone.
    The messages get rejected because in MySensor.cpp line 570 (developement branch) it is not checked if the sender requires signing:
    	if (signer.requestSignatures() && msg.destination == nc.nodeId && mGetLength(msg) && !mGetAck(msg) &&
    		(mGetCommand(msg) != C_INTERNAL ||
    		 (msg.type != I_GET_NONCE_RESPONSE && msg.type != I_GET_NONCE && msg.type != I_REQUEST_SIGNING &&
    		  msg.type != I_ID_REQUEST && msg.type != I_ID_RESPONSE &&
    		  msg.type != I_FIND_PARENT && msg.type != I_FIND_PARENT_RESPONSE)))
    My thought is that if I have a mixed network (signing and non-signing nodes) for some sensors I do not need signing (i.e. temperature-sensors). But if I have a button sensor that can actually switch something on or off (via the controller), it would be a security benefit if the messages from the sensor to the gateway are signed.
    @fleinze If you have upgraded the library version, the signing table might have shifted in EEPROM. You then need to run the clear EEPROM sketch to reset the stored state in order for the gw/nodes to re-learn the existing signing preferences of the network.
    This is the exact usecase for the gw default behavior to only require signing from nodes that require signing in return. But I also got "no sign" errors after I flashed development branch yesterday on node/gw and only after I wiped the GW EEPROM I got it back online. So please try that. If it still does not work, I have to look closer, and see why this has broken because it has been working like that when I submitted the signing behavior.
  • @Anticimex I tried to make it work:
    • took a fresh copy of the development branch
    • activated signing in MyConfig.h
    • flashed the ClearEepromConfig sketch to both the test-gateway and the test-node.
    • built the gateway with MySigningAtsha204Soft signer; (requires signing by default)
    • built the node with MySigningNone signer;
    Still got the no sign message from the gateway...
    Please have a look at this.
    @fleinze mysigningnone is a special case. It won't make signatures, so could you instead try with either hard or soft atsha?
    @fleinze also, you can mix hard and soft atsha signing in a network, but you can't mix with "none". If you mark a node that it can do signing or require signing and use the "none" backend, nodes that use atsha (hard or soft) will not accept the signatures.
  • @Anticimex
    Ok, I built the node with MySigningAtsha204Soft signer(false); so it does not require signing and the gateway with MySigningAtsha204Soft signer;
    -> no sign error.
    How do I correctly build a node that does not sign in a mixed network (signing and non-signing nodes mixed)?
    @fleinze
    In a network where you have "mixed" nodes, I would suggest something like this:
    The gateway has signing enabled and is set to require signatures and uses either hard or soft ATSHA (since you earlier wrote that you wanted the GW to sign messages to nodes that signed messages in return).
    For all nodes that need to be secure, enable signing and pick either hard or soft ATSHA (depending on the node hardware) and set them to require signatures.
    For all nodes that do not need to be secure, just disable signing alltogether, or pick any signing backend and set it to NOT require signatures.
    The result should be like this:
    A "insecure" node sends and receives unsigned messages to/from GW.
    A "secure" node sends and receives signed messages to/from GW.
    The GW will send signed messages to all nodes that has reported to the GW that they require signatures.
    The GW will send unsigned messages to all nodes that has reported to the GW that they do NOT require signatures.
  • @Anticimex In your original post you said:
    However, the difference is that the gateway will only require signed messages from nodes it knows in turn require signed messages.
    I made pull request 208 to match this behavior in the code:
    https://github.com/mysensors/Arduino/pull/208
    • If node is not a gateway, everything is as always. (1 || x)
    • if node is gateway and the sender requires signed messages, check signature (0 || 1)
    • if node is gateway and the sender does not requires signed messages, do not check signature (0 || 0)
      please consider adding this.
    @fleinze Ok, lets discuss this in the PR and conclude it in this thread later.
    Ok, the problem is identified and @fleinze has provided a fix that resolves the issue which is now merged to the development branch.
    Thanks for finding the issue and fixing it!
    There is no change in the signing behavior as it is documented. Now gateway does as it is supposed to.
    Great work @fleinze and @Anticimex !
    Reading this thread (yes, all of it) has made me ready to start configuring my nodes to use signing. Better start now, while my sensor network is still small 🙂
    Compiling with the latest dev branch SecureActuator example
    I get following error:
    In file included from /Users/mm/Documents/Arduino165/libraries/MySensors/MySensor.h:157:0,
                     from SecureActuator.ino:58:
    /Users/mm/Documents/Arduino165/libraries/MySensors/core/MyTransport.cpp: In function 'void transportProcess()':
    /Users/mm/Documents/Arduino165/libraries/MySensors/core/MyTransport.cpp:92:10: error: 'MY_IS_GATEWAY' was not declared in this scope
        if ((!MY_IS_GATEWAY || DO_SIGN(sender)) &&
    /Users/mm/Documents/Arduino165/libraries/MySensors/core/MyTransport.cpp:93:20: error: 'nc' was not declared in this scope
    Fehler beim Kompilieren.```
    Is this a problem of the code or of my setup?
    @FotoFieber @hek something related to the recent refactoring? I have not had the opportunity to evaluate the effects on signing myself.
    Let's see how Jenkins feels about this
    https://github.com/mysensors/Arduino/pull/231
  • @Anticimex Hello, I found this thread now. I'll ask a few more questions, sorry. This all seems really-really great.
    1. If someone wishes to use TMRh20's RF24Mesh instead of MySensors how would one sign the messages sent with that library? Is is even possible? What should be done to use that functionality?
    2. Also, as I understand it is possible to emulate the ATSHA204A, on what hardware is is possible (on Uno's ATMega too?)?
    3. Is it also possible to use whitelisting with RF24Mesh somehow?
    Again, sorry for any dumb questions and my poor English.
    @Avamander
    1. Signing as described in this post is specific to users of the MySensors library. I suppose you could use any rf backend you like but you will need to use the MySensors library to get the nonce exchange and such. Or manually port the signing specifics out from the MySensors library and integrate them into another library. It's all open source.
    2. The software emulated atsha signing backend (for MySensors) is compatible with any Arduino product.
    3. See 1.
    Lastly, there are no dumb questions, only dumb answers 🙂
    firstly, I must say that you're doing a great job and this section about security is very interesting.
    Sorry, but I want to ask a question: as regards the whitelisting system, how can I add more nodes to the list of the trusted nodes of the gateway?
    The part of code is this:
    #ifdef MY_SECURE_NODE_WHITELISTING
    whitelist_entry_t node_whitelist[] = {
      { //I want to add nodes HERE:
        .nodeId = 55, // Just some value, this need to be changed  to the NodeId of the trusted node
        .serial = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09} } // This need to change to the serial of the trusted node
    MySigningAtsha204 signer(true, 1, node_whitelist);  // Select ATSHA204A software signing backend with one entry in the whitelist
    but the gateway continue to fail the verification of the trusted nodes that I inserted.
    To sum up, how can I add more nodeIDs and serials in addition to the number "55" presented in the example of the code?
    Thank you very much in advance,
    Silver978
    @Silver978 Thanks!
    Try something like this:
        .serial = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09} // This need to change to the serial of the trusted node
        .nodeId = 56, // Just some value, this need to be changed  to the NodeId of the trusted node
        .nodeId = 57, // Just some value, this need to be changed  to the NodeId of the trusted node
    MySigningAtsha204 signer(true, 3, node_whitelist);  // Select ATSHA204A software signing backend with three entries in the whitelist
    Note the changed argument in the constructor (3 and not 1)
  • @Anticimex I tried also this syntax but I haven't changed the argument of the signer, so that number indicates how many nodes the gateway must trust?
    Thank you!
    @Silver978 The number gives the number of entries in the whitelist the backend is expected to iterate over. Having a number for this allows the use of a potenitally very large whitelist but where "uninteresting" entries to this particular node can be ignored by having them last in the list and make sure the number does not cover those entries when searching the list.
  • @Anticimex Perfect, understood! Very good explanation and super-fast support, fantastic 🙂
    Thank you very much again!
  • I would like to add security to my sensor network as well so I am very glad I found your thread. Your explanation are very detailed but I´m a guy who needs more practical examples. For example I would like to know, where exactly I have to activate this. I am using an arduino as an MQTT to Ethernet gateway and Mosquitto running on a raspberry pi. So all I have to do is activate the soft version in Myconfig.h, if not already activated, set a serial, re-upload to my arduino gateway and that´s it? I guess the Nodes have to get flashed again to get the serials as well, right?
    @siod correct. You have to activate signing in both ends. The serial numbers you only need of you want to use whitelisting which is a bit more complex to set up. At the very least, for software signing, you need to enable it, have an unconnected analog pin on your boards, and set a hmac key.
    EDIT: Topic post updates with a documentation link for those using the development branch.
  • Great topic as usual. I have a question please.
    You mentioned "Because it is pure-software however, it does not provide as good nonces (it uses the Arduino pseudo-random generator) and the HMAC key is stored in SW and is therefore readable if the memory is dumped. "
    Isn't this case also dangerous if the node which contains ATSHA chip was stolen ? The attacker will use the chip to be on the network ?
    @ahmedadelhosni thanks!
    Correct. That is why I also implemented whitelisting and node revocation. It's all described in the topic (and for development branch in doxygen, linked in the topic).
  • @Anticimex Thanks.
    So this gets me to my next question 🙂
    What I understood is that if I use whitelisting, I need to know the node ID of my sensor door to define it in the GW, correct ?
    I guess the below code is in the GW.
      { .nodeId = 55, // Just some value, this need to be changed  to the NodeId of the trusted node
    another question, If I want to remove this node, do I have to reflash the GW and remove it ?
    Yes.
  • @Anticimex mmmm
    Can't it be implemented in a way so that whitelist is to be defined by the controller ?
    For example, an internal message to be used to set the data.
    My concern is that auto assignation of nodes is flexible but at the same time you may need to choose which sensor node to be added to your whitelist. Thus if a Controller can show you all your nodes, like vera or domoticz, I guess this option can be added to the plugin to send an internal message to the GW to choose which sensor node to be added.
    Am I saying something logic ? 🙂
    Possibly. But that would mean that security features is dictaded by the controller plugins and I do not like that at all.
    For months I have been trying to convince the Domoticz people that their ACK timeout is way to short and needs to be configurable for signing to work with Domoticz, but they do not even reply to me.
    And I do not trust controllers at all and want to have full control over all configuration aspects of the signing solution. So I do not think it is good to move that logic off the nodes (whitelisting can also be used by a node, communicating with another node).
    It is not only a GW that can have a whitelist. So although it might have been flexible to have it configurable, I think it compromises security (who knows, your controller could be hacked to inject a whitelist that permits a rogue node in your network).
    Of course, security is at some level compromised anyway if the controller is hacked. But it is not the signing solution that is compromised in this case.
    And ultimately, that feature would mean that the level of signing security and signing features for MySensors, becomes controller specific. And that I do not think is a good idea. If I want to change or improve the feature, the controller plugins all also have to be updated. It just becomes a too big turnaround for something as important as this in my opinion.
  • Yeah I got your point of view and convinced me. The only solution to implement this is that other communities works together to improve flexibility and security. This is not that easy of course as you have said.
    Thanks a lot for your time.
    Thanks for understanding 🙂
  • Also in all cases I see that if your controller is being hacked there will be no use to play with the whitelist 🙂 The attacker has full control already to blow my house if he wants to 🙂
    Anyway maybe I need to reflash using signing to understand things more.
    Keep it up 🙂
  • Hi again.
    I managed to set run the softsign and everything seems fine till now. I just want to understand the system much more if you please.
    Now my Gateway sends this data when I turn on Light.
    ( I am using GatewayW5100 with Domoticz ) Development branch
    0;0;3;0;9;Eth: 0;0;3;0;18;PING
    0;0;3;0;9;Eth: 2;7;1;0;2;1
    0;0;3;0;9;send: 0-0-2-2 s=7,c=3,t=16,pt=0,l=0,sg=0,st=ok:
    0;0;3;0;9;read: 2-2-0 s=255,c=3,t=17,pt=6,l=25,sg=0:01F470C061A0B9FF3DE248835736E2B85E31C8D6D1844AACAC
    0;0;3;0;9;Signing backend: ATSHA204Soft
    0;0;3;0;9;Message to process: 00020E01020731
    0;0;3;0;9;Current nonce: 01F470C061A0B9FF3DE248835736E2B85E31C8D6D1844AACACAAAAAAAAAAAAAA
    0;0;3;0;9;HMAC: 135DBD85528E869ECC86C9C53679795D7FDA7B789DB7A0A74053C94FE8D668F0
    0;0;3;0;9;Signature in message: 015DBD85528E869ECC86C9C53679795D7FDA7B789DB7A0A7
    0;0;3;0;9;send: 0-0-2-2 s=7,c=1,t=2,pt=0,l=1,sg=1,st=ok:1
    I want to know how was the following data calculated please:
    • sg=0:01F470C061A0B9FF3DE248835736E2B85E31C8D6D1844AACAC
    • Message to process: 00020E01020731
    • Current nonce: 01F470C061A0B9FF3DE248835736E2B85E31C8D6D1844AACACAAAAAAAAAAAAAA
    • HMAC: 135DBD85528E869ECC86C9C53679795D7FDA7B789DB7A0A74053C94FE8D668F0
    • Signature in message: 015DBD85528E869ECC86C9C53679795D7FDA7B789DB7A0A7
    So how was sg= calculated ?
    What is message to process ?
    The nonce is depending on analogue signal + what ? to get this value ?
    I have already defined a random HMAC, but this one is different. It is a combination of what ?
    Finally what is signature in message ?
    On the other side I am trying to sniff the data by a serialgateway which is trying to hack the network. It only read the following data:
    2;255;3;0;17;01F470C061A0B9FF3DE248835736E2B85E31C8D6D1844AACAC
    It is the sg only which it succeeded to read. Also I do understood form the topic that the attacker can read values sent between nodes unencrypted, but here I can't figure out where is the unencrypted data which can be sniffed by the attacker but we don't bother ourselves with cas we protect our network by using signing.
    Lots of questions but I am trying to understand the logic and architecture in details to understand what I am doing 🙂
    Thanks a lot.
    I suggest you read the doxygen documentation for signing carefully as it answers the questions you have. Signing does not in any way prevent anyone from reading your messages. As I have described in the documentation, it provides authenticity. That is, you can trust the sender of a signed message to be yours and not someone else's.
  • @Anticimex Yeah I understand it doesn't prevent anyone from reading my messages, and that's what I am trying to do now. To hack the system depending on the data available. But when I read the post I understood that encryption is not a priority as signing is enough now to prevent an attacker from sending data, but it can read text. I thought I will find clear text describing that I am sending to node X value Y but I found this 2;255;3;0;17;01F470C061A0B9FF3DE248835736E2B85E31C8D6D1844AACAC
    so I wanted to ask.
    Anyway I'll re read the documents more carefully and return to you back please. Thanks.
    Encryption is available for both rf24 and rf69 radios. But encryption and signing are two different things, and I work with signing. And signing is more efficient against hackers than encryption. Encryption is more if you care about privacy.
  • @Anticimex @hek is it possible to encrypt the data sent over nrf modules using this https://github.com/DavyLandman/AESLib ???
    @noelgeorgi AES encryption is already supported for both NRF24 and RFM69 radios. See MyConfig.h on the development branch for the flag to use. Doyxgen documentation I link to in this thread on the topic post also contain the personalization instructions for encryption on the development branch.
    Thanks for the info.
    I'm getting the following errors when compiling securitypersonalizer:
    Arduino: 1.6.7 (Linux), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
    /home/technoman/Arduino/libraries/MySensors/examples/SecurityPersonalizer/SecurityPersonalizer.ino:83:28: fatal error: sha204_library.h: No such file or directory
     #include <sha204_library.h>
    compilation terminated.
    exit status 1
    Error compiling.
    doesnt the ATSHA204 library has ATSHA204.h
    @noelgeorgi master or development branch?
  • @Anticimex development branch
    @noelgeorgi have you made changes to the sketch? Jenkins builds it without problems.
  • @Anticimex no, I'm using the sketch from the examples.....😕
    am i missing some libraries????
    @noelgeorgi if you have cloned the arduino git you have everything you need. I can build that sketch myself and have used it many times. I suspect you have a problem with your environment if you get compilation errors in it. We continously test the repository and build all examples nightly to make sure it all works as it is supposed to. You can see this at ci.mysensors.org
  • @Anticimex sorry for the interruption, i was using rsync to get eveything synced and i might have messed something uop, sha204 library was missing from my libraries folder, now everything works, thanks for the prompt and fast support.
    @Anticimex - thanks for this. I finally got around to enabling signing on everything while I was testing out my new board design. I followed your schematic from your board design when I built mine and I just went through the instructions to configure the crypto chip and everything went smoothly. Thanks for the work and the good instructions!
    @TD22057 that's really nice to hear! Are you using a stable release or the development/beta channel?
    @Anticimex
    I used the signing sketch on the dev branch - I'm in the process of shifting my stuff over to the dev branch from 1.5 now.
    Ok, cool. As you might have noticed, personalization has changed a bit on development. Also, whitelisting works slightly differently/better.
  • Isn't blacklisting cool too to use ?
    Like, if we know the "name" of the sensor lost, we push it to the black list and voila ? This way, we don't have to put a long list a agreed sensors if we have only two nodes outside the house.
    ... I think.
    @Pierre-P because if a node is lost, you no longer control that node. So anyone could reprogram it to have it identify itself in any way possible. We have to assume an attacker has full source code access, so they can rewrite the signing algorithm to use a fake serial as salt for the signature to trick the GW to believe it is a new node. A whitelist mean the attacker has to know the ID/serial of one of the nodes you trust. Which they won't know unless they can get access to that node.
  • Thanks for the complet answer !
    @Pierre-P you are welcome. Security is best when it is totally open and the implementation is aware of this. That makes it quite difficult to circumvent, and it also allows to be challenged. That way, with many eyes examining it, it gets stronger and stronger 🙂 I welcome all attempts to crack it. White or black hat style.
    Hello all! What would require less flash memory? Signing by ATSHA204A Chip or by software?
    Signing by ATSHA204A require less flash memory, but takes longer to execute (at least on 8MHz AtMega328).
    @Anticimex assumed that, but this post on the forum got me confused: http://forum.mysensors.org/topic/2005/software-aes-encryption-for-nrf24/19
    According to that post, he uses software on the SenseBender with Encryption because, according to him "...encryption and ATSHA204A is to big for the SenseBender... ".
    I would like to add Signing and encryption to my nodes, but I don't know if it will fit on my Atmega328 flash!
    Well, how much space you have depend on your sketch and on the features you enable in the library, so it is impossible to predict how your code will fit. I suggest you just try to enable what you want and compile, and you'll know 🙂
    The easiest way to find out is to look at the output in Arduino IDE when you click "Verify".
    There are some factors that affect size:
    • Size of bootloader
    • MySensors version (different versions of the library have different size requirements)
    • MySensors features used (software signing, encryption, debug on or off, etc)
    • Size of other libraries you use in your sketch
    • Size of your sketch
    ouch, @Anticimex was a bit faster 🙂
    oh, and the problem in the thread you quoted @Soloam is encryption. At least at that time, encryption used too much space so there wasn't space to include either hardware or software signing.
    And on development branch, @tekka has an open PR where he has cut down significantly on the size of the NRF24 driver as well.
    And you might also have read mine and @mfalkvidd's stand on encryption, so don't be discouraged if you find that you can't fit both. Just skip the encryption in that case. It adds far less in security than signing does.
    Yes, if I have to discard one it would be encryption! Thank you for the help @Anticimex and @mfalkvidd
    I currently testing various bootloader to measure impact on CPU speed on the power consumption.
    I got a lot of nonce error when using 1 MHz configuration.
    Is signing feature possible at 1 MHz ?
    David.
    @carlierd could you specify a bit clearer what you mean by "nonce error"? Signing should work, but the atsha driver is not tested @ 1MHz and might get bad timing. Also, for soft (and hard) signing, if 1MHz is used, performance could degrade to the point that the nonce timeout needs to be increased.
  • @Anticimex
    Hello.
    I am using soft signing.
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    sensor started, id=255, parent=255, distance=255
    find parent
    read: 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    parent=0, d=1
    req id
    read: 0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0:9
    send: 9-9-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:1
    read and drop: 9-9-0 s=255,c=3,t=15,pt=2,l=2,sg=0:1
    read: 0-0-9 s=255,c=3,t=15,pt=2,l=2,sg=0:1
    send: 9-9-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=fail:
    nonce tr err
    nonce tr err
    read and drop: 9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
    read: 0-0-9 s=255,c=3,t=17,pt=6,l=25,sg=0:0129D04B64916F5E805EFDF704C34F56B47E547FDDE93805BE
    id=9
    send: 9-9-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0,st=ok:
    send: 9-9-0-0 s=1,c=0,t=30,pt=0,l=0,sg=0,st=fail:
    [Setup duration: 9928 ms]
    send: 9-9-0-0 s=0,c=3,t=16,pt=0,l=0,sg=0,st=fail:
    nonce tr err
    send: 9-9-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=fail:
    nonce tr err
    nonce tr err
    Value is 1   Cycle is 1   3.39 v   [753 ms]
    David.
    @carlierd you have a lot of st=fail, so your problem is radio related, not signing related. I also see non nonce related messages fail so you need to stabilize your rf connection before signing can work. And since signing uses the maximum payload size, it has the least probability to succeed to be sent, so you could find that unsigned messages work while nonces and signed messages fail, but this is normal of the rf link is not fully working. If you get st=fail, it is a radio problem. See this discussion for details: http://forum.mysensors.org/topic/3386/mqttclientgateway-broken-after-upgrade-signature-failure
  • @Anticimex Hello. Everything is working at 16 or 8MHz so I am pretty sure it's not an issue with the material.
    I will burn the bootloader again and create a new post if it's still not correct. I will also disable signing feature to be sure there is no impact.
    David.
    @carlierd well, st=fail indicate transmission failure so it is pretty clear that you have a issue with rf, at least on that frequency. st=fail is not signing related. But, like previously discussed, enabling signing can trigger more st=fail because the payload gets bigger and is more sensitive to noise.
  • @calierd You can have a look here at the discussion I had with a similar problem which I was able to resolve finally. See the last reply in the aforementioned thread where I summarized how I resolved it, eventually.
  • @Anticimex @tomkxy
    Perhaps the arduino and RFM69 can't run at 1MHz. I have capacitors and I tried with two different power sources. Without signing it's better but still a lot of st=fail. No matter, it was just for testing purpose 🙂
  • @calierd I cannot comment on RFM69 since I have non in operation. Sorry, try to place the nodes further apart and look whether it changes.
  • @Anticimex Thank you for the effort you have put into signing, this is great!
    Would it make sense to explore the I2C version of ATSHA204A ? The reason I'm asking is speed.
    Thanks @duovis,
    Yes, I welcome anyone who has the HW to provide a IO routine for I2C-variants of ATSHA204A. I don't have the hw myself though.
  • @Anticimex Ok, I'll try to play with it and see if I can come up with something that works on I2C.
    @duovis Great. I'll happily review any code. You should only need to worry about the low level stuff.
    Hello all!
    Two fast question! Can I have nodes working with ATSHA204A chip and others with software?
    And, can I have nodes with signing on and others off? Or if I add signing to my network, all nodes must have it?
    Thank you all!
    @Soloam
    You can mix nodes with soft signing and ATSHA signing as you like.
    You can mix nodes with signing on and off as well. The GW will only sign messages to nodes that require it, and it will also only check signatures from nodes that require signatures. So you can have one node which support/require signing and another which don't. The GW will be able to exchange messages with both nodes.
    Great work indeed!
    Thank you @Anticimex
    @Soloam thanks 🙂
  • Slightly silly question, but did anyone manage to get signing working (MySigningAtsha204Soft signer;) on Arduino Uno on MS 1.5.4 on the Ethernet gateway please? I am going out of memory and really hate to upgrade it to Mega
    @alexsh1 if you feel adventurous try 2.0.0-beta2, or if you are patient, go to 2.0.0 in a few months and redesigns will have made space available for you.
  • @Anticimex Thanks - I am currently trying an Ethernet GW and a node (Sensebender Micro) with dev branch. I am stuck at personalisation. I cannot lock data. Any idea what I am doing wrong?
    This is Sensebender (with ATSHA204):
    Device revision: 00020009
    Device serial:   {0x01,0x23,0x53,0x3F,0x52,0x6A,0x1A,0x06,0xEE}
    0123533F526A1A06EE
    Skipping configuration write and lock (configuration already locked).
    Chip configuration:
    EEPROM DATA:
    ATSHA204A DATA:
               SN[0:1]           |         SN[2:3]           | 01   23 | 53   3F
                              Revnum                         | 00   09   04   00
                              SN[4:7]                        | 52   6A   1A   06
        SN[8]    |  Reserved13   | I2CEnable | Reserved15    | EE | 13 | 00 | 00
      I2CAddress |  TempOffset   |  OTPmode  | SelectorMode  | C8 | 00 | 55 | 00
             SlotConfig00        |       SlotConfig01        | 8F   80 | 80   A1
             SlotConfig02        |       SlotConfig03        | 82   E0 | A3   60
             SlotConfig04        |       SlotConfig05        | 94   40 | A0   85
             SlotConfig06        |       SlotConfig07        | 86   40 | 87   07
             SlotConfig08        |       SlotConfig09        | 0F   00 | 89   F2
             SlotConfig0A        |       SlotConfig0B        | 8A   7A | 0B   8B
             SlotConfig0C        |       SlotConfig0D        | 0C   4C | DD   4D
             SlotConfig0E        |       SlotConfig0F        | C2   42 | AF   8F
      UseFlag00  | UpdateCount00 | UseFlag01 | UpdateCount01 | FF | 00 | FF | 00
      UseFlag02  | UpdateCount02 | UseFlag03 | UpdateCount03 | FF | 00 | FF | 00
      UseFlag04  | UpdateCount04 | UseFlag05 | UpdateCount05 | FF | 00 | FF | 00
      UseFlag06  | UpdateCount06 | UseFlag07 | UpdateCount07 | FF | 00 | FF | 00
                          LastKeyUse[0:3]                    | FF   FF   FF   FF
                          LastKeyUse[4:7]                    | FF   FF   FF   FF
                          LastKeyUse[8:B]                    | FF   FF   FF   FF
                          LastKeyUse[C:F]                    | FF   FF   FF   FF
      UserExtra  |    Selector   | LockValue |  LockConfig   | 00 | 00 | 55 | 00
    Take note of this key, it will never be the shown again:
    #define MY_HMAC_KEY [deleted]
    Writing key to slot 0...
    Send SPACE character to lock data...
    Data lock failed. Response: D3
    Halting!
    @alexsh1 actually, I have never actually locked data. Could be a bug there. But I also highly recommend that you don't. If you do, you will never be able to change hmac key in that device.
