  3. MQTTClientGateway broken after upgrade - signature failure
38 Posts 4 Posters 11.3k Views 4 Watching
  • T
    tomkxy
    I just upgraded my MQTTClientGateway to the most current version of development branch.
    In parallel, I uploaded re-compiled sketches to my sensors.
    It seems that there is an issue now with respect to signature handling. I used to have ATASHA204 on all my sensors and the gateway.
    I already realized that the current version does not seem to support hardware signing so I change to soft signing including uploading the HMAC Key to EEPROM.
    I appended the log and the sketches. It seems that the gateway expects a signed message which it does not receive. However, I have signing enabled in the sensor.
    I am absolutely stuck and have no glue what the reason is. Any help is highly appreciated.
    Interesting enough and just more confusing, after I first uploaded the new sketch to the MQTT Gateway, I saw in the beginning some messages appear in the MQTT broker.
    Gateway log:
    ;255;3;0;9;Starting gateway (RNNGAS, 2.0.0-beta)
    0;255;3;0;9;Radio init successful.
    0;255;3;0;9;Init complete, id=0, parent=0, distance=0
    0;255;3;0;9;Skipping security for command 3 type 16
    0;255;3;0;9;read: 26-26-0 s=4,c=3,t=16,pt=0,l=0,sg=0:
    0;255;3;0;9;Signing backend: ATSHA204Soft
    0;255;3;0;9;SHA256: 6420A6958C538FE9A8076F1F48ACDE828A4A7886859393A20200000000000000
    0;255;3;0;9;Transmittng nonce
    0;255;3;0;9;Skipping security for command 3 type 17
    0;255;3;0;9;send: 0-0-26-26 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:6420A6958C538FE9A8076F1F48ACDE828A4A7886859393A202
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Message is not signed, but it should have been!
    0;255;3;0;9;verify fail
    0;255;3;0;9;Verification timeout
    0;255;3;0;9;read: 27-24-0 s=0,c=3,t=16,pt=0,l=0,sg=0:
    0;255;3;0;9;SHA256: D916CCAA20E05C5533CD2919E2B5286C0559C1552A7F55922CAAAAAAAAAAAAAA
    0;255;3;0;9;send: 0-0-24-27 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:D916CCAA20E05C5533CD2919E2B5286C0559C1552A7F55922C
    0;255;3;0;9;SHA256: 9394294CFBA825C26112C731879AEC90CF0AA0AA2E1338A01EAAAAAAAAAAAAAA
    0;255;3;0;9;send: 0-0-24-27 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:9394294CFBA825C26112C731879AEC90CF0AA0AA2E1338A01E
    0;255;3;0;9;read: 26-26-0 s=255,c=3,t=16,pt=0,l=0,sg=0:
    0;255;3;0;9;SHA256: 2ECD2A1584FBBB9E269C4DAF8714FA393D6BA2CBD403BF71D1AAAAAAAAAAAAAA
    0;255;3;0;9;send: 0-0-26-26 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:2ECD2A1584FBBB9E269C4DAF8714FA393D6BA2CBD403BF71D1
    0;255;3;0;9;SHA256: 49B80D12C8ED30598B0E4119D1C2F828EE38FD6B035EF520ABAAAAAAAAAAAAAA
    0;255;3;0;9;send: 0-0-26-26 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:49B80D12C8ED30598B0E4119D1C2F828EE38FD6B035EF520AB
    0;255;3;0;9;read: 27-24-0 s=2,c=3,t=16,pt=0,l=0,sg=0:
    0;255;3;0;9;SHA256: 261B252BA8FFFB20085C9B493EDA9CCC9F6293095009C5F306AAAAAAAAAAAAAA
    0;255;3;0;9;send: 0-0-24-27 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:261B252BA8FFFB20085C9B493EDA9CCC9F6293095009C5F306
    0;255;3;0;9;read: 26-26-0 s=1,c=3,t=16,pt=0,l=0,sg=0:
    0;255;3;0;9;SHA256: 74F626A70BC176FE2D2B1E0EDD64DE4110A6E210551B7E32BEAAAAAAAAAAAAAA
    0;255;3;0;9;send: 0-0-26-26 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:74F626A70BC176FE2D2B1E0EDD64DE4110A6E210551B7E32BE
    0;255;3;0;9;SHA256: D6F7E817BF30213995EDF2B5709EC24687583DEF1BA2B7DFD3AAAAAAAAAAAAAA
    0;255;3;0;9;send: 0-0-24-27 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:D6F7E817BF30213995EDF2B5709EC24687583DEF1BA2B7DFD3
    MQTTClientGateway sketch (using ethernet shield W5100)
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #define MY_DEBUG_VERBOSE_SIGNING //!< Enable signing related debug prints to serial monitor
    // Hardware signing not yet supported
    #define MY_SIGNING_FEATURE
    #define MY_SIGNING_SOFT
    //#define MY_SIGNING_ATSHA204
    //#define MY_SIGNING_ATSHA204_PIN A3
    // Set this nodes subscripe and publish topic prefix
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "GW1_out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "GW1_in"
    // Set MQTT client id
    #define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    //#define MY_RF24_CE_PIN 5
    //#define MY_RF24_CS_PIN 6
    // CE_PIN and SPI_SS_PIN for Mega
    #define MY_RF24_CE_PIN    48			// radio chip enable
    #define MY_RF24_CS_PIN    49			// radio SPI serial select
    #define MY_MQTT_USER "gw"
    #define MY_MQTT_PASSWORD "wL6g401gUIUa3xwQ"
    #define MY_IP_ADDRESS 192,168,178,11
    #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 74
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    void presentation() {
      // Send locally attech sensors data here
    Sensor Sketch:
    Multisensor Sketch
    Author: Thomas Krebs, thkrebs@gmx.de
    This sketch reads temperature, humidity, light and presence.
    It is based on the various examples sketches from SparkFun and MySensors
    It uses the following sensors:
    Light           - TSL2561
    Temp&Humidity   - HTU21D
    Presence
    HTU21D and TLS2561 need to connect the I2C pins (SCL and SDA) to your Arduino.
    The pins are different on different Arduinos:
                        SDA    SCL
    Any Arduino         "SDA"  "SCL"
    Uno, Redboard, Pro  A4     A5
    Mega2560, Due       20     21
    Leonardo            2      3
    #define MY_NODE_ID              26
    #define MY_SIGNING_ATSHA204_PIN 17
    #define BATT_SENSOR
    #include <TSL2561.h>
    #include <SparkFunHTU21D.h>
    #include <Wire.h>
    #include <avr/power.h>
    #define VERSION           "1.3"
    #define SKETCH_NAME       "Multisensor Sketch Type A - Battery Powered Temp/Humid/Light/Presence"
    #define TEMP_CHILD_ID   1
    #define HUM_CHILD_ID    2
    #define LIGHT_CHILD_ID  3
    #define MOTION_CHILD_ID 4
    // Uncomment the line below, to transmit battery voltage as a normal sensor value
    #define BATT_SENSOR    199
    #define MAX_VOLTAGE    1316
    #define MIN_VOLTAGE    890     // it seems that about 0.89 V the sensor stops working
    // How many milli seconds between each measurement
    #define MEASURE_INTERVAL 120000
    unsigned long SLEEP_TIME = 30000;  // Sleep time between reads (in milliseconds)
    // FORCE_TRANSMIT_INTERVAL, this number of times of wakeup, the sensor is forced to report all values to the controller
    #define FORCE_TRANSMIT_INTERVAL 30
    // When MEASURE_INTERVAL is 60000 and FORCE_TRANSMIT_INTERVAL is 30, we force a transmission every 30 minutes.
    // Between the forced transmissions a tranmission will only occur if the measured value differs from the previous measurement
    // HUMI_TRANSMIT_THRESHOLD tells how much the humidity should have changed since last time it was transmitted. Likewise with
    // TEMP_TRANSMIT_THRESHOLD for temperature threshold.
    #define HUMI_TRANSMIT_THRESHOLD   0.5
    #define TEMP_TRANSMIT_THRESHOLD   0.5
    #define LIGHT_TRANSMIT_THRESHOLD  0.3    // relative change
    // Pin definitions
    #define LED_PIN            13            // TODO: need to check that
    #define BATTERY_SENSE_PIN  A0            // select the input pin for the battery sense point
    #define MOTION_SENSOR      3             // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define INTERRUPT          1             // Usually the interrupt = pin -2 (on uno/nano anyway)
    // Global settings
    int tempMeasureCount = 0;
    int lightMeasureCount = 0;
    int sendBattery = 0;
    boolean isMetric = true;
    boolean highfreq = true;
    boolean motionDetected = false;
    int repeats = 3;
    // Storage of old measurements
    float lastTemperature = -100;
    float lastHumidity = -100;
    long  lastBattery = -100;
    long  lastLight = -5000;
    int   lastTripped = -1;
    HTU21D myHumidity;
    TSL2561 myLight(TSL2561_ADDR_FLOAT);
    // Sensor messages
    MyMessage msgTemp(TEMP_CHILD_ID,V_TEMP);
    MyMessage msgHum(HUM_CHILD_ID,V_HUM);
    MyMessage msgLight(LIGHT_CHILD_ID,V_LEVEL);
    MyMessage msg(MOTION_CHILD_ID, V_TRIPPED);
    #ifdef BATT_SENSOR
    MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
     * Setup code
      pinMode(LED_PIN, OUTPUT);
      Serial.print(F(SKETCH_NAME));
      Serial.println(VERSION);
      Serial.flush();
    #ifdef MY_SIGNING_ATSHA204_PIN
      // Make sure that ATSHA204 is not floating
      pinMode(MY_SIGNING_ATSHA204_PIN, INPUT);
      digitalWrite(MY_SIGNING_ATSHA204_PIN, HIGH);
      analogReference(INTERNAL);
      // setup sensors
      setup_htu21d();
      delay(100);
      setup_tls2561();
      delay(500);
      // setup motion sensor
      pinMode(MOTION_SENSOR, INPUT);
      Serial.flush();
      Serial.println(F(" - Online!"));
      sendSketchInfo(SKETCH_NAME, VERSION);
      present(TEMP_CHILD_ID, S_TEMP);
      present(HUM_CHILD_ID, S_HUM);
      present(LIGHT_CHILD_ID,S_LIGHT_LEVEL);
      present(MOTION_CHILD_ID, S_MOTION);
    #ifdef BATT_SENSOR
      present(BATT_SENSOR, S_POWER);
      isMetric = getConfig().isMetric;
    #ifdef MY_DEBUG
      Serial.print(F("isMetric: ")); Serial.println(isMetric);
      sendTempHumidityMeasurement(false);
      sendLightLevelMeasurement(false);
      sendBattLevel(false);
    /* Setup HTU21d
    void setup_htu21d() {
      myHumidity.begin();
    #ifdef MY_DEBUG
      Serial.println("Setup temp/humid sensor completed");
    /* Setup TLS2561
    void setup_tls2561() {
      if (myLight.begin()) {
        Serial.println(F("Found light sensor"));
      } else {
        Serial.println(F("Light Sensor not found - cont. anyway"));
      myLight.setGain(TSL2561_GAIN_0X);          // set 16x gain (for dim situations)
      // Changing the integration time gives you a longer time over which to sense light
      // longer timelines are slower, but are good in very low light situtations!
      //tsl.setTiming(TSL2561_INTEGRATIONTIME_13MS);  // shortest integration time (bright light)
      myLight.setTiming(TSL2561_INTEGRATIONTIME_101MS);  // medium integration time (medium light)
      //tsl.setTiming(TSL2561_INTEGRATIONTIME_402MS);  // longest integration time (dim light)
     *  Main loop function
      tempMeasureCount++;
      lightMeasureCount++;
      sendBattery++;
      bool forceTransmit = false;
      if (motionDetected) {
        sendMotion(false);  // do not force transmission unless it motion status has changed
      else {
        // I do the battery check at the beginning
        if (sendBattery > 60) {
           sendBattLevel(forceTransmit); // Not needed to send battery info that often
           sendBattery = 0;
        if ((lightMeasureCount > FORCE_TRANSMIT_INTERVAL) || (tempMeasureCount > FORCE_TRANSMIT_INTERVAL) ) { // force a transmission
          forceTransmit = true;
        // Get & send sensor data
        sendTempHumidityMeasurement(forceTransmit);
        sendLightLevelMeasurement(forceTransmit);
        sendMotion(forceTransmit);
      wait(100);  // I don't know whether that is really required; however I have the impression that shutting down the radio leads to
                     // problems in the communication when using signatures
      if (sleep(INTERRUPT,RISING, MEASURE_INTERVAL)) {
        motionDetected = true;
     * Sends state of motion sensor
     * Parameters
     * - force : Forces transmission of a value (even if it's the same as previous measurement)
    void sendMotion(bool force) {
      bool tx = force;
      // Read digital motion value
      bool tripped = digitalRead(MOTION_SENSOR) == HIGH;
      Serial.print(F("Tripped: ")); Serial.println(tripped);
      if (lastTripped != tripped) tx = true;
      if (tx) {
        resend(msg.set(tripped?"1":"0"),repeats);  // Send tripped value to gw
        lastTripped = tripped;
     * Sends temperature and humidity from HTU21D sensor
     * Parameters
    void sendTempHumidityMeasurement(bool force)
        bool tx = force;
        float hum = myHumidity.readHumidity();
        float temp = myHumidity.readTemperature();
        Serial.print(F("lastTemperature: ")); Serial.println(lastTemperature);
        Serial.print(F("lastHumidity: ")); Serial.println(lastHumidity);
        float diffTemp = abs(lastTemperature - temp);
        float diffHum = abs(lastHumidity - hum);
    #ifdef MY_DEBUG
        Serial.print(F("TempDiff :"));Serial.println(diffTemp);
        Serial.print(F("HumDiff  :"));Serial.println(diffHum);
        if (isnan(diffHum)) tx = true;
        if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
        if (diffHum >= HUMI_TRANSMIT_THRESHOLD) tx = true;
        if (tx) {
          resend(msgTemp.setSensor(TEMP_CHILD_ID).set(temp,1),repeats);
          resend(msgHum.setSensor(HUM_CHILD_ID).set(hum,1),repeats);
          lastTemperature = temp;
          lastHumidity = hum;
     * Sends light level from TLS6512 sensor
     * Parameters
    void sendLightLevelMeasurement(bool force) {
      bool tx = force;
      uint32_t lum = myLight.getFullLuminosity();
      uint16_t ir, full;
      ir = lum >> 16;
      full = lum & 0xFFFF;
      Serial.print(F("IR: ")); Serial.print(ir);   Serial.print(F("\t\t"));
      Serial.print(F("Full: ")); Serial.print(full);   Serial.print(F("\t"));
      Serial.print(F("Visible: ")); Serial.print(full - ir);   Serial.print(F("\t"));
      double lux = myLight.calculateLux(full, ir);
      Serial.print(F("Lux: ")); Serial.println(lux);
      float diffLux = abs(lastLight - lux);
    #ifdef MY_DEBUG
        Serial.print(F("Lux difference since last measurement: ")); Serial.println((float)diffLux/abs(lastLight));
        if (isnan(diffLux)) tx = true;
        if (diffLux/abs(lastLight)  >= LIGHT_TRANSMIT_THRESHOLD) tx = true;
        if (tx) {
          resend(msgLight.setSensor(LIGHT_CHILD_ID).set(lux,1),repeats);
          lastLight = lux;
     * Prints error on I2C comm bus
    void printError(byte error)
      // If there's an I2C error, this function will
      // print out an explanation.
      Serial.print(F("I2C error: "));
      Serial.print(error,DEC);
      Serial.print(F(", "));
      switch(error)
        case 0:
          Serial.println(F("success"));
          break;
        case 1:
          Serial.println(F("data too long for transmit buffer"));
          break;
        case 2:
          Serial.println(F("received NACK on address (disconnected?)"));
          break;
        case 3:
          Serial.println(F("received NACK on data"));
          break;
        case 4:
          Serial.println(F("other error"));
          break;
        default:
          Serial.println(F("unknown error"));
     * Sends battery information (battery percentage)
     * Parameters
    void sendBattLevel(bool force)
      if (force) lastBattery = -1;
      long batteryV =  analogRead(BATTERY_SENSE_PIN);
      for (int i = 1; i<5; i++) {
        long newSample = analogRead(BATTERY_SENSE_PIN); //readVcc();
        batteryV -= batteryV / (i+1);
        batteryV += newSample / (i+1);
       // 10M, 2,86M divider across battery and using internal ADC ref of 1.1V
       // ((10+4,7)/4,7)*1.1 = 3.4404255
       // 3.4404255/1023 = Volts per bit = 0.003630748
      long vcc  = batteryV * 3.3630748;
      if (vcc != lastBattery) {
        lastBattery = vcc;
    #ifdef BATT_SENSOR
        resend(msgBatt.set(vcc),repeats);
        // Calculate on the fully charged cell. Since I have a step-up in place I go as low as possible no offset for minimum
       sendBatteryLevel(  ((vcc-MIN_VOLTAGE)*10.0)/((MAX_VOLTAGE-MIN_VOLTAGE)*10.0) *100.0);
     * Send message, resend on error
     * Parameters
     * - msg : message to send
     * - repeats: number of repetitions
    void resend(MyMessage &msg, int repeats)
      int repeat = 1;
      int repeatdelay = 0;
      boolean sendOK = false;
      while ((sendOK == false) and (repeat < repeats)) {
        if (send(msg)) {
          sendOK = true;
        } else {
          sendOK = false;
          Serial.print(F("Send ERROR "));
          Serial.println(repeat);
          repeatdelay += random(50,200);
        repeat++;
        delay(repeatdelay);
     * Internal battery ADC measuring
    long readVcc() {
      #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
        ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
      #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
        ADMUX = _BV(MUX5) | _BV(MUX0);
      #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
        ADcdMUX = _BV(MUX3) | _BV(MUX2);
      #else
      long result = (high<<8) | low;
    • T
      tomkxy
      I have just collected the log from the sensor node. I also removed a repeater node which I had out of the communication chain.
      From the log it seems that the node requests a nonce but does not receive it, although the gateway seems to send one...
      Increasing MY_VERIFICATION_TIMEOUT_MS to 15000 did change anything.
      Starting sensor (RNNNAA, 2.0.0-beta)
      Multisensor Sketch Type A - Battery Powered Temp/Humid/Light/Presence1.3
      Found light sensor
       - Online!
      send: 26-26-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok:
      Nonce requested from 0. Waiting...
      Timeout waiting for nonce!
      sign fail
      send: 26-26-0-0 s=255,c=3,t=11,pt=0,l=25,sg=0,st=ok:Multisensor Sketch Type A
      sign fail
      send: 26-26-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.3
      send: 26-26-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=ok:
      sign fail
      send: 26-26-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
      send: 26-26-0-0 s=2,c=3,t=16,pt=0,l=0,sg=0,st=ok:
      sign fail
      send: 26-26-0-0 s=2,c=0,t=7,pt=0,l=0,sg=0,st=ok:
      send: 26-26-0-0 s=3,c=3,t=16,pt=0,l=0,sg=0,st=ok:
      Message to send could not be signed!
      sign fail
      send: 26-26-0-0 s=3,c=0,t=16,pt=0,l=0,sg=0,st=ok:
      send: 26-26-0-0 s=4,c=3,t=16,pt=0,l=0,sg=0,st=ok:
      sign fail
      send: 26-26-0-0 s=4,c=0,t=1,pt=0,l=0,sg=0,st=ok:
      send: 26-26-0-0 s=199,c=3,t=16,pt=0,l=0,sg=0,st=ok:
      sign fail
      send: 26-26-0-0 s=199,c=0,t=13,pt=0,l=0,sg=0,st=ok:
      isMetric: 1
      lastTemperature: -100.00
      lastHumidity: -100.00
      TempDiff :127.42
      HumDiff  :120.93
      sign fail
      send: 26-26-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:27.4
      sign fail
      send: 26-26-0-0 s=2,c=1,t=1,pt=7,l=5,sg=0,st=ok:20.9
      IR: 1		Full: 2	Visible: 1	Lux: 1.00
      Lux difference since last measurement: 1.00
      read: 0-0-26 s=255,c=3,t=17,pt=6,l=25,sg=0:5333F4601AD619250DDA35ADEBB1E46F78EB96A1D769F33114
      Nonce received from 0. Proceeding with signing...
      Message to process: 1A002EE125030000803F01
      Current nonce: 5333F4601AD619250DDA35ADEBB1E46F78EB96A1D769F33114AAAAAAAAAAAAAA
      HMAC: 51A6B54EB9C0BAF3A4F982216BC4764F2DD2810D74392BC952DDAA976C78A051
      Signature in message: 01A6B54EB9C0BAF3A4F982216BC4764F2DD2810D
      Message signed
      Message to send has been signed
      send: 26-26-0-0 s=3,c=1,t=37,pt=7,l=5,sg=1,st=ok:1.0
      sign fail
      send: 26-26-0-0 s=199,c=1,t=38,pt=4,l=4,sg=0,st=ok:1274
      sign fail
      send: 26-26-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:90
      Signing required
      Skipping security for command 3 type 15
      send: 26-26-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
      Waiting for GW to send signing preferences...
      read: 0-0-26 s=255,c=3,t=15,pt=0,l=2,sg=0:
      Mark node 0 as one that require signed messages
      Mark node 0 as one that do not require whitelisting
      sign fail
      send: 26-26-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
      read: 0-0-26 s=255,c=3,t=17,pt=6,l=25,sg=0:BDFF3B5B9BC735ADF4C3375DE3B98A0BD45BCB30469DC8D4F3
      Message to process: 1A000E2306FF00
      Current nonce: BDFF3B5B9BC735ADF4C3375DE3B98A0BD45BCB30469DC8D4F3AAAAAAAAAAAAAA
      HMAC: 6B2DE4B7DCB4F5D4691AD3979CEA4D6DD80D8E1D0D8A659906D9F0B0B9497C66
      Signature in message: 012DE4B7DCB4F5D4691AD3979CEA4D6DD80D8E1D0D8A6599
      Message signed
      send: 26-26-0-0 s=255,c=3,t=6,pt=1,l=1,sg=1,st=ok:0
      Init complete, id=26, parent=0, distance=1
      lastTemperature: 27.42
      lastHumidity: 20.93
      TempDiff :0.04
      HumDiff  :0.43
      Lux difference since last measurement: 0.00
      Tripped: 1
      sign fail
      send: 26-26-0-0 s=4,c=1,t=16,pt=0,l=1,sg=0,st=ok:1
      • AnticimexA
        AnticimexA
        Anticimex
        Try increasing the timeout for the nonce. I don't know if MQTT logic results in a longer turnaround time for message processing.
        • T
          tomkxy
          @Anticimex I increased MY_VERIFICATION_TIMEOUT_MS to 15s. Isn't that the nonce timeout?
          AnticimexA 1 Reply Last reply
          • T tomkxy
            AnticimexA
            AnticimexA
            Anticimex
            @tomkxy yes
            • AnticimexA Anticimex
              @tomkxy yes
              AnticimexA
              AnticimexA
              Anticimex
              @Anticimex nonce requested from node 0 looks suspicious. Is that the correct node id?
              • T
                tomkxy
                @Anticimex Isn't node 0 the gateway node id? If not that might be something to follow up on.
                • AnticimexA
                  AnticimexA
                  Anticimex
                  Ah, it's the GW. But I see from gw log that you get st=fail on the nonce so the GW does try to send it but your node does not receive it. So you have communication problems. Bear in mind that with signing, the full payload size is used, which puts maximum strain on the rf link so you have to have a solid coverage.
                  • T
                    tomkxy
                    @Anticimex Both node were lying side by side. And I had my small network working perfectly on an older dev branch. So I don't think it can be due to coverage or distance.
                    Arghhh: I an only post once within 2 minutes...
                    • T tomkxy
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @tomkxy well, your logs indicate signing works as it's supposed to. But the nonce fails to arrive, and this is also indicated by st=fail, so you have a radio issue. You probably get problems without signing as well if you transmit full length messages.
                      • T tomkxy
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @tomkxy try moving your nodes further apart. It is sometimes hard to predict rf performance based on placement.
                        • T
                          tomkxy
                          @Anticimex I will try it further apart. But I have other nodes having the same problem and they are sitting exactly where they were before the upgrade. The only thing I changed for the sensors is to re-compile with the latest development branch for the sensor nodes.
                          Only the MQTTClientGateway was running a sketch based on a rather "old" version. So that upgrade is significant.
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            Depending on the "leap" you have taken some changes in the rf stack could have affected things. The signing solution have been changed but it has not affected payload sizes so I do not think signing is causing this (other than forcing maximum payload sizes which it has all along).
                            • T
                              tomkxy
                              @Anticimex I just tried to disable signing on the gateway and on the sensor and it works like a charme.
                              So I still hope there is some issue either in my sketch (defines etc.) or a bug. Without signing I do not consider MySensors for me as an option. :-(
                              • T tomkxy
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @tomkxy like I said, from the logs I see nothing wrong with signing. But your nonce is not coming through due to rf issue. I have verified signing on development branch myself (since I developed it) so I am confident it works. But it is well known that rf performance is decreasing with increased message size and I assume you don't use full size transmissions with signing disabled. So I would suggest you check rf decoupling, PA levels and antennae. It is also known that keeping radios too close can cause bursts which appear as failed transmissions but I am no specialist in those areas. Signing assume a ideal transport mechanisms, so you have to ensure there are no st=fail:s for signing related messages. The signing backend cannot handle those for you.
                                • T
                                  tomkxy
                                  @Anticimex thanks for your support. Don't get me wrong I think MySensors and the whole signing concept is great. It is just somehow frustrating to see how a whole installation - even small until now - which worked for more than half a year is just breaking down while not having a glue what I can do about it.
                                  What in particular are you referring to with reference to rf decoupling?
                                  Just wondering how does your config look like?
                                  What radios? What configs?
                                    Are you using an amplified radio on the gateway? If so, what is your PA level set to?
                                    • T tomkxy
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @tomkxy I use rf24 with default settings (except some moved io pins) and a PA-enhanced radio on the GW. But getting the rf24 to behave can be tricky. And the larger the message, the trickier it gets. Unfortunately this means it gets trickiest with signing enabled as it makes most messages very large (thus making them more sensitive to rf disturbance). Unfortunately, it is not much I can do about it from a signing perspective. Reducing the message size for signatures and nonces or adding fault tolerance to the security messages compromises security quality, and I already to that with the truncation of the signatures (due to rf24 limitations) so I don't want to "nerf" if further. So the signing solution is quite rf sensitive. But the way I see it, that just serves as a good measure for the overall quality of the rf network. If it works with shorter messages, sooner or later, maybe you add a node that transmits longer messages and start to get issues. With signing enabled, you are forced to root out any lingering rf issues immediately, and is saved from unpleasant surprises later on. But of course I understand the frustration, having experienced it myself several times. But st=fail is not a signing problem, it is a rf problem. So I am afraid I am not the best resource to provide answers. @tekka has made an excellent pull request where he has optimized the rf24 stack significantly. Perhaps applying it could help solve your rf issue: https://github.com/mysensors/Arduino/pull/392
                                      • T
                                        tomkxy
                                        @Anticimex I fully agree to your judgement that the problem is not due to the signing as such. However, I also do not believe in the RF24 issue. I tried with a CUSTOM child and using the max payload size available which without signing went through.
                                        I think there might be an issue related to the changed code pathes which is caused by "injecting" signing or a define or whatsoever in my sketch is wrong after the upgrade.
                                        I tried @tekka pull request with the result that nothing arrived at the gateway at all.
                                        Do you know why hardware signing is not supported in the MQTTClientGateway?
                                        • T tomkxy
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @tomkxy Both hardware and software signing has no knowledge about MQTT. They only handle signatures of messages passed between gw and nodes. How the gw communicates with controller is irrelevant. Unless MQTT messes up how gw adresses nodes, I cannot see how signing could not work for MQTT. And if it does, it is a bug in MQTT implementation and not signing.
