[SOLVED]Two nodes with relays interfering
  • As a noob I ran into a problem with two nodes.
    One (node 1) is running code to actuate 6 relays. the other one (node 2) has a relay and a pulse meter.
    Whenever I actuate the relay on node 2 (connected to pin 4), then relay 1 on node 1 (also connected to pin 4) is actuated too. When I actuate relay 1 on node 1 however, node 2 is not affected.
    Some how seems I'm overlooking something basic, but I can't figure it out 😞
    Node 1 is running the following code:
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #define NUMBER_OF_RELAYS 6 // Total number of attached relays
    #define CHILD_ID 1
    MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    //MyTransportRFM69 radio;
    // Message signing driver (none default)
    //MySigningNone signer;
    // Select AtMega328 hardware profile
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
        gw.present(CHILD_ID, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    Node 2 code:
    #define DIGITAL_INPUT_SENSOR 3                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
    //#define PULSE_FACTOR 12500                       // Nummber of blinks per m3 of your meter (One rotation/liter)
    #define PULSE_FACTOR 1000
    #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
    #define MAX_WATT 10000                            // Max flow (l/min) value to report. This filetrs outliers.
    #define INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define CHILD_ID 3                              // Id of the sensor child
    #define RELAY_10  4  // Arduino Digital I/O pin number for first relay
    #define NUMBER_OF_RELAYS 1
    #define RELAY_ON 0
    #define RELAY_OFF 1
    unsigned long SEND_FREQUENCY = 10000;              // Minimum time between send (in miliseconds). We don't want to spam the gateway.
    double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
    volatile double watt = 0;
    boolean pcReceived = false;
    unsigned long oldPulseCount = 0;
    unsigned long newBlink = 0;
    double oldwatt = 0;
    double oldKwh;
    double Kwh;
    unsigned long lastSend;
    unsigned long currentTime;
    unsigned long lastPulse;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage KwhMsg(CHILD_ID,V_KWH);
    MyMessage pcMsg(CHILD_ID,V_VAR1);
      //gw.begin(incomingMessage, AUTO, false, AUTO, RF24_PA_LOW);
      //gw.begin(incomingMessage, AUTO, false, AUTO);
      //  gw.send(pcMsg.set(0));
      //  gw.send(volumeMsg.set(0.000, 3));
      //Water meter setup
      //Serial.print("PPL:");
      //Serial.print(ppl);
      gw.sendSketchInfo("power meter and actuator", "1.0");
      // Register this device as current sensor
      gw.present(CHILD_ID, S_POWER);
      gw.request(CHILD_ID, V_VAR1);
      //pulseCount = oldPulseCount = 0;
      //Serial.print("Last pulse count from gw:");
      //Serial.println(pulseCount);
      attachInterrupt(INTERRUPT, onPulse, RISING);
      lastSend = millis();
      //RELAY SETUP
      for (int sensor=1, pin=RELAY_10; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
        gw.present(sensor, S_LIGHT);
      gw.process();//////t
      currentTime = millis();
      bool sendTime = currentTime - lastSend > SEND_FREQUENCY;
      if (pcReceived && (SLEEP_MODE || sendTime)) {
        // New flow value has been calculated
        if (!SLEEP_MODE && watt != oldwatt) {
          // Check that we dont get unresonable large flow value.
          if (watt<((unsigned long)MAX_WATT)) {
            gw.send(wattMsg.set(watt, 2));        // Send flow value to gw
          //Serial.print("g/min:");
          // Serial.println(flow);
          oldwatt = watt;
        // No Pulse count in 2min
        if(currentTime - lastPulse > 20000){
          watt = 0;
        // Pulse count has changed
        if (pulseCount != oldPulseCount) {
          gw.send(pcMsg.set(pulseCount));                  // Send  volumevalue to gw VAR1
          double volume = ((double)pulseCount/((double)PULSE_FACTOR)*264.172);
          //double volume = ((double)pulseCount/((double)PULSE_FACTOR));
          oldPulseCount = pulseCount;
          if (Kwh != oldKwh) {
            gw.send(KwhMsg.set(Kwh, 3));               // Send volume value to gw
            oldKwh = Kwh;
        lastSend = currentTime;
      else if (sendTime) {
        // No count received. Try requesting it again
        lastSend=currentTime;
      if (SLEEP_MODE) {
        gw.sleep(SEND_FREQUENCY);
    void onPulse()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink-lastBlink;
        lastPulse = millis();
        if (interval < 2080) {       // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)  WAS 2080
          return;
        watt = ((60000000.0 /interval) / ppl)*.264172;
        //flow = ((60000000.0 /interval) / ppl);
        // Serial.print("interval:");
        // Serial.println(interval);
        lastBlink = newBlink;
        // Serial.println(flow, 4);
      pulseCount++;
      if (message.type==V_VAR1) {
        pulseCount = oldPulseCount = message.getLong();
        Serial.print("Received last pulse count from gw:");
        pcReceived = true;
        digitalWrite(message.sensor-1+RELAY_10, message.getBool()?RELAY_ON:RELAY_OFF);
    Can somebody help me to figure this out?
    Do both nodes have different node ids? Maybe both nodes have stored the Same node id in eeprom and thus use it. Could you post serial output of both nodes, when it happens?
  • I just cleared the eeprom on node 2, but nothing changed.
    Output node 2:
    send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
    send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    repeater started, id=1, parent=0, distance=1
    send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=24,sg=0,st=ok:power meter and actuator
    send: 1-1-0-0 s=3,c=0,t=13,pt=0,l=0,sg=0,st=ok:
    send: 1-1-0-0 s=3,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    read: 0-0-1 s=3,c=2,t=24,pt=0,l=0,sg=0:
    Received last pulse count from gw:0
    read: 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:1
    send: 1-1-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
    Incoming change for sensor:1, New status: 1
    read: 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:0
    send: 1-1-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
    Incoming change for sensor:1, New status: 0
    Output node 1:
    send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.1
    send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    repeater started, id=0, parent=0, distance=0
    send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
    send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    read: 0-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0:1
    send: 0-0-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
    read: 0-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0:0
    send: 0-0-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
    read: 0-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0:66.6
    Node 2 was not powered when I monitored this node 1 output.
    The output on node 2 looks strange - ID 0 is (and should only be) the gateway!
    I guess you mean node 1. And indeed, I really messed up the code somehow. Reloaded the original sketch and adapted it again, now everything works like a charm.
    Thanks everyone for thinking along!
  • Im having the same problem. But I'm not finding the solution from this thread really. Did you find it?
    I'm going to manually asign node_ids next.
    I get interference inside one node with two relays (mqtt gw + 2relay) and also across two nodes (dht+relay and 6relay node).
    I checked the mqtt traffic and it sends the same mqtt topic twice (both on and off commands).
    Controller is Domoticz.
    Have you tried with just leds instead of the relays, just to exclude some parts of the circuit.
  • @gohan I have the boards soldered with the relays attached (regreting that now) so that would be difficult.
    ok, so do you get issues either with or without load on relays? Are they optoisolated from the rest of the circuit?
  • I've tested with load only. The circuits are very basic so no opto. The relays are powered from the 5v transformer directly and not vcc off Promini.
    The problem is not global (affecting all relays in node) but only a few lights/relays seem to be "tandem".
    Try without load. I have seen to be a recurring problem that load causes interference on the board. I you see things getting better, you know that opto will be the way 😄
  • I will. But just out of curiosity, are relays always touchy or is it just something about certain loads? The loads are not heavy (10-15w fluorescent lamp per relay or 2-6w led bulb).
    You know when there are coils involved and circuits opening and closing (especially if there are inductive loads) there can be interference generated during switching. There are also solid state relays that should solve this issue, there are some projects already in the openhardware section
  • Back at this after a while... I changed code for all nodes and manually assigned node_ids to make sure nothing interferes.
    Currently the problem: when a remote nodes (number 4) relay is activated, it also causes the relay attached to gw-node to activate. The gw attached relay works well by itself (optocoupled).
    I checked MQTT traffic and there's nothing fishy (activation message "1"). I also checked the debug on the gw and that looks OK to me as well.
    The gw relays are optocoupled, the outside (it's a dht22+single relay node) light relay is not. GW receives power from car battery thru usb, so no interference should be possible.
    Any ideas?
    Conflicting relays code:
    // Enable debug prints
    #define MY_REPEATER_FEATURE
    //#define MY_RS485
    #define MY_NODE_ID 4
    #define DHT_DATA_PIN 4
    #define SENSOR_TEMP_OFFSET 0
    //static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    #define CHILD_ID_RELAY 2
    void before()
      sendSketchInfo("TempHumRelUlko", "vMasi");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_RELAY, S_BINARY);
      //for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
        //present(sensor, S_BINARY);
    //  if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod()) {
      //  Serial.println("Warning: UPDATE_INTERVAL is smaller than supported by the sensor!");
      sleep(2000);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      //sleep(UPDATE_INTERVAL);
    wait(120000);
      if (message.type==V_STATUS) {
    And the debug from GW:
    0;255;3;0;9;MCO:BGN:BFR
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.0.201
    0;255;3;0;9;MCO:BGN:STP
    IP: 192.168.0.201
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/0/0/18
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/11
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/12
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/1/0/0/3
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/2/0/0/3
    0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/4/1/1/1/2
    0;255;3;0;9;TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=0,l=1,sg=0:0
    0;255;3;0;9;TSF:MSG:ACK
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/1/1/1/2
    0;255;3;0;9;TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=2,pt=0,l=1,sg=0:1
    @MasMat could you post the sketch for your gateway node as well?
  • Sure. Here it is. Slight mod from MQTT sketch with Relay sketch parts.
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "domoticz/in/MyMQTT"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "domoticz/out/MyMQTT"
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 192,168,0,201
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,254
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 200
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    // #define CHILD_ID_RELAY1 1
    // #define CHILD_ID_RELAY2 2
    #include <Ethernet.h>
    void before()
      sendSketchInfo("MQTT_GWAndRelay", "vMasi");
    @MasMat Looks like the gateway's receive function is called even when the gateway is the destination of the message. That results in the gateway updating its relay even though it shouldn't.
    I think you could do something like this:
        if (message.sensor == 0) { // Only switch the relay if the message is for myself
            Serial.print("Updating relay state");
  • @mfalkvidd All this under "void loop"? Do I remove the "void receive"?
    I added (and commented out previous) under "void receive": the relay became unresponsive.
    debug:
    0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/2/1/0/2
    Incoming change for sensor:2, New status: 1
    Incoming change for sensor:2, New status: 0
    You need the receive, just replace the code
  • @gohan I did. Relay unresponsive but clearly the messages are coming thru. Went back, relay works so not mechanical/electrical.
    Current code:
  • @mfalkvidd I've been reviewing this: I have two relays actually attached, so this code will ignore the other completely, right? I think that's why it's not working. Or the numbering for the sensors is different?
    Am I wrong or does the "message.sensor" actually refer to child_id rather than node_id? Or am I following this wrong?
    @MasMat I have trouble finding documentation explaining the details, but I think you are right. See if message.destination works better.
  • @mfalkvidd That fixed it right up and makes complete sense. I couldn't find docs either on message.sensor or message.destination...
    The problem now appears more complex...
    The GW (node 0) relay STILL follows the other nodes (node 4) commands (completely different circuits, so no electrical connection at all).
    GW debug (first a on & off test for gw-relay, then clicked the node4-relay, on comes OK (gwrelay follows) but off reboots gw)
    0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/1/1/0/2
    Updating relay stateIncoming change for sensor:1, New status: 1
    Updating relay stateIncoming change for sensor:1, New status: 0
    0;255;3;0;9;TSF:MSG:READ,4-4-0,s=1,c=1,t=0,pt=7,l=5,sg=0:16.6
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/1/1/0/0
    0;255;3;0;9;TSF:MSG:READ,4-4-0,s=0,c=1,t=1,pt=7,l=5,sg=0:69.8
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/4/0/1/0/1
    0;255;3;0;9;!TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
    0;255;3;0;9;MCO:BGN:BFR```
  • Nevermind. Whined too soon.
    Completely worked over the node4 code, moved "include"s around and eventually changed the relay presentations and receive clauses. Hope this helps someone with their problems later:
    Thanks a millions!
    void before()
        // Set relay pin in output mode
        pinMode(RELAY_1, OUTPUT);
        digitalWrite(RELAY_1, loadState(CHILD_ID_RELAY)?RELAY_ON:RELAY_OFF);
    later this....
    ....and ending with this...
        if (message.destination == MY_NODE_ID) { // Only switch the relay if the message is for this node
            digitalWrite(RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
            saveState(CHILD_ID_RELAY, message.getBool());
    @MasMat great work! Maybe change this to make the output more complete?
    to
        Serial.print("Incoming change for node: ");
        Serial.print(message.destination);
        Serial.print(", sensor:");
  • @mfalkvidd That would definitely polish it up! 😄
    Cheers!!
