WifiGateway crashes after 1 or 2 days
  • Any ideas how o solve that problem ?
    I built a WifiGateway, after 1 - 2 days, it crashes, i can´t reach it through telnet
    But a ping is still working.
    As it tkaes that long, it´s not that easy to find the problem
    Is there any debug feature ?
    @kr0815 best debug option is to connect something to the serial port (before the crash) and watch the logs.
    I've seen similar behavior on a regular Ethernet getaway, so not sure if it's really WiFi gateway related.
  • Hello Yveaux,
    i tried to debug with serial connected, but
    for hours only that:
    0;255;3;0;9;read: 102-102-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.0
    0;255;3;0;9;read: 102-102-0 s=0,c=1,t=1,pt=7,l=5,sg=0:43.9
    0;255;3;0;9;read: 102-102-0 s=255,c=3,t=0,pt=1,l=1,sg=0:95
    0;255;3;0;9;read: 112-112-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.0
    0;255;3;0;9;read: 112-112-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.9
    then not responsible, no fault message
    after waiting for a while i get
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    LmacRxBlk:1
    After a reboot:
    0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
    ....scandone
    state: 0 -> 2 (b0)
    .state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 3
    pm open phy_2,type:2 0 0
    cnt
    chg_B:-60
    connected with Power-LAN, channel 6
    dhcp client start...
    ...ip:192.168.178.84,mask:255.255.255.0,gw:192.168.178.1
    .IP: 192.168.178.84
    0;255;3;0;9;read: 111-111-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
    0;255;3;0;9;read: 111-111-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
    @kr0815 said:
    LmacRxBlk
    Googled, this came up.
    Here they say it's related to the maximum simultaneous socket connections to the ESP, which is set to 5 in hardware.
    Could it be that you open more than 5 sockets simultaneously?
  • Thanks a lot for your help, it´s really frustrating 🙂
    unfortunately, there are notr more than 5 connections, only my FHEM - installation and me playing around with one, max 2 instances of putty
    but as i´m experimenting with it right now it looks like there is a problem with the radio
    I tried re-pluging power many times, sometimes i get in in a state where it says "radio init ok", but doesn´t receive messages
    I re-checked all the wires (only 10K Pull-Down at GPIO15 , the other lines to Radio are in Mega-Ohm Areas, so no wrong resistors on my ESP-Board)
    I tried to add small / large capacitors to the Vcc Line
    I swapped the NRF2401 - 3 different batches now, which even look different.
    I swapped the wall-wart to a regulated laboratory power supply
    --> all the same result
    I have about 5 of these ESP-Boards running with ESP-Easy since weeks, so i can´t imagine it´s a fake ESP-Unit ?
    Any further ideas what to try ?
    It could still be that 5 or more connections are open simultaneously, when e.g. a connection is dropped and not nicely shut down before a new one is opened.
  • Maybe you are right
    I set up two gateways, only one is connected to FHEM, now i swapped them in FHEM, the connected one crashed
    I´ll ask the FHEM guys for help, but as long as i´m playing with putty, is there any command to check / close connections ?
    Is it ok just to close putty, or should i send something to close the connection ?
    @kr0815 Could also be caused by the ESP side, keep that in mind. Maybe search around for 'closed connections' w.r.t. ESP.
  • Sorry, this i don´t understand ? What do you mean wth by the ESP side ? Changes in the ESP Code needed ?
    The more i think about it, the less i know...
    WHat causes the Wifi Gateway sometines after replugging power to say radio init ok, but not receiving messages ?
    @kr0815 said:
    the ESP side
    I mean that when a connection is disconnected abruptly, the socket connection might also not be closed correctly on the ESP side.
    It can go wrong on either the server or the client side; I don't know.
  • I still have the same problem, it worked now for about 5 days on the workbench, brought it to the final desination, crashes after some hours
    But i always could still ping the ESP
    What i wonder most about is, that sometimes when i replug the power it says radio init ok, but it doesn´t receive messages
    ( i see on other gateway that messages are definetly sent)
    Is there any possibility to restart the gateway remotely ? Or only chance to replug power ?
    Could it be it´s a problem with the initialization of the radio ?
    Is it maybe because in my set-up, the gateway is only receiving, never sending anything ?
    The gateway lays avbout one meter away from a raspberry (no wifi) , but i can´t imagine that causes the problems ?
    Any help / ideas welcome.
  • i investigated further:
    i have 2 gateways, both dev version, one from today, the other one about 2 weeks old
    I tried the relay sketch (newest dev version) - gave it an ID trough my ethernet gateway
    --> directly after connecting the relay sensor both ESP gateway crash - no fault messages in serial monitor
    DId anybody try the wifi gateway together with a repeater ?
