Arduino Uno R3 Ethernet Gateway + 4 Relay + Motion + Magnetic Switch
  • Hello ,
    I'm trying to build the gateway with all attached sensors
    But when I inclusion, only appears the 4 relays in Vera , what is wrong with the code?
    not appear --> motion and Magnetic Switch
    Setup:
    Arduino Uno R3
    W5100 Shield
    4 Relay - pin 5,6,7,8
    1 motion - pin 3
    1 magnetic switch - pin 4
    #define MY_GATEWAY_W5100
    #define MY_IP_ADDRESS 192,168,1,169   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // #define MY_INCLUSION_MODE_BUTTON_PIN  4
    #include <Ethernet.h>
    #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define CHILD_ID 3   // Id of the sensor child
    #define ID 4
    #define OPEN 1
    #define CLOSE 0
    #define BUTTON_PIN  4  // Arduino Digital I/O pin for button/reed switc
    boolean lastTripped = 0;
    Bounce debouncer = Bounce();
    int oldValue=-1;
    // Initialize motion message
    MyMessage msgdoor(ID,V_TRIPPED);
    void before() {
        pinMode(pin, OUTPUT);
      pinMode(BUTTON_PIN,INPUT_PULLUP);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      present(ID, S_LIGHT); // S_DOOR
      sendSketchInfo("Relay", "1.0");
        present(sensor, S_LIGHT);
      present(CHILD_ID, S_MOTION);
        // Read digital motion value
        if (lastTripped != tripped ) {
          send(msg.set(tripped?"1":"0")); // Send new state and request ack back
          Serial.println(tripped);
          lastTripped=tripped;
    debouncer.update();
      int value = debouncer.read();
      if (value != oldValue) {
         Serial.print("Door value: ");
         Serial.println(value);
         send(msgdoor.set(value==HIGH ? 1 : 0));
         oldValue = value;
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    Your child ids are overlapping.
  • @hek tks, motion sensor now appear but magnetic switch no 😞 need resistor ?
    Update code
    #define CHILD_ID 69   // Id of the sensor child
    #define ID 70
    #define OPEN 1
    #define CLOSE 0
    int oldValue=-1;
    void before() {
      present(ID, S_DOOR); // S_DOOR
    debouncer.update();
         oldValue = value;
  • Any ideia plz?
    If the presentation fails to be received by the controller, you could introduce a small delay (to let radio "re-change") between the transmits to the controller.
    wait(200); at the top of the loop should be enough.
  • @hek
    Still not working 😕
       wait(200);
    debouncer.update();
         oldValue = value;
    When doing the presentation...
  • @hek
    Working!!!! Tks
    I only have one more problem, with simple button switch ( like that ) simulate door open/close , I receive message "Door value:0 and 1" and status in vera changed, but with reed switch ( like that ) door status no change with magnetic , I bought 5 reed switch and any works 😞
    Reed switch problem right ?
    @mlg Probably the reed switch. It is just a mechanical device. You can try with an ohm meter (or with battery and light/ led)
  • Update
    Finally after changing reed switch all works !
    However , sometimes mysensors gateway stop responding (few weeks works fine), I try to ping Ip of the gateway and no have any reply, solution is power off gateway .
    It is possible to place the gateway (mysensors) to ping a network address and if it does not answer automatically make a restart and wait/limit to a restart every 20 minutes? (to prevent the restart loop)
  • 6
