Which Arduino IDE version?
    Just doing some last minute changes for the presentation of the workshop.
    I've read on the forum that not all version of the Arduino IDE work well with MySensors 2.0? What's the best version to use?
    @TheoL I'm using 1.6.8 and I think I've seen that version mentioned in some threads as well.
    I have also has luck with using 1.6.9 but downgrading the Arduino library (through the library manager) one step. Without downgrading something was broken but I don't remember what.
    I would recommend to use the latest version, to make the content reusable in the future without having to update everything that mentions a version. But using the latest version comes with a risk of course.
    @TheoL there is an issue with the avr compiler used in all 1.6.x versions, mysensors 2.0.x and debug enabled. This combination causes resets on w5100 gateways.
    Apart from that I would just use the latest one (1.6.11 at the time of writing I think)
    @Yveaux I'll be using a serial gateway with soft SPI (don't ask why 😉 it's a left over stackable print I soldered for an old WS5100 Arduino Uno ethernet gateway) so 6.11 would be okay for the participants?
    p.s. thack stackable radio print with the LEDs just sticking it adds to the tinker experience 😉
    @TheoL I'm not aware of any issues, but for safety I should be careful when defining MY_DEBUG and test your setup upfront (which you probably will :bowtie:)
    What is the correct way to handle this? (Im upgrading my w5100 with 2.0). Using an older avr compiler or its fixed in dev?
    @sundberg84
    Its a bug in the compiler. Which should be fixed in a newer version of gcc. @tekka did some investigations together with arduino folks on this. So I think he has more info
    @sundberg84 Yes, read here for further information related to the compiler bug: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=77326
    @Yveaux Today we uploaded the serial gateway with soft SPI. The radio initializes and the gateway doesn't reset. Tonight my colleague will try it home, since it would interfere with my own serial gateway network. But I think it will work. Never did soft SPI on a serial gateway, and probably no one has ever tried that before 😉
    @tekka Great job. Hopefully they'll soon release a bug fix for this.
    Confirmed that soft SPI also works an a Serial Gateway. Uploaded 2.0 on that one and tested with 1.5 sketch.
    @TheoL Maybe important for your MySensors tutorial: I suggest using Arduino IDE 1.6.11 with AVR board defs 1.6.11 (1.6.12 and 1.6.13 seem buggy, at least regarding the Ethernet lib)
    @tekka - If i want to build myself a ethernet gw with 2.0 it should work if i download and use IDE < 1.6.12 ?
    @sundberg84 Not IDE, but AVR board defs 1.6.11
  • And how do i downgrade AVR board devs?
  • in your IDE go to tools -> boards: "..." -> board manager and there select Arduino AVR board in the correct version.
  • Thanks, i would not have found that by myself 😄
    It has been a long time since I've updated my IDE (currently running 1.6.6) and I wanted to update before I start converting everything to MySensors 2.0. I noticed that there is a newer version 1.6.12 and the bug reported above appears to have been fixed. Has anyone used the newest IDE and boards files? I will be using an Ethernet gateway but I'm not sure if it is still best to downgrade the boards files. Thanks!
  • Crash still happens using the latest version, downgraded to 1.6.11 😞
    @Mark-Swift I'm using IDE 1.6.12 and board defs 1.6.14 and my Ethernet gateway has been running for almost a week with no apparent issues. How often are you seeing the crash?
  • My W5100 will not start with 1.6.14, it just reboots after getting an IP...
    @Mark-Swift Wow, that's strange. What Ethernet library are you using? I'm on 1.1.2.
  • @petewill same! 😞
    I will try it again when I find a moment, I was using DCHP, are you?
    @Mark-Swift No, I'm using a static IP.
  • An example of what my gateway does with 1.6.14
    )<�a���dv)�0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.43
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
    0;255;3;0;9;TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=3
    0;255;3;0;9;TSF:CKU:OK,FCTRL
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSF:MSG:PINGED,ID=3,HP=1
    0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=0,pt=7,l=5,sg=0:20.9
    IP: 192.168.1.43
    0;255;3;0;9;TSF:MSG:READ,1-1-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
    IP: 192.168.1.43
    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=1,c=1,t=16,pt=2,l=2,sg=0:1
    IP: 192.168.1.43
    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=3,c=1,t=16,pt=2,l=2,sg=0:1
    IP: 192.168.1.43
    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=10,c=1,t=16,pt=1,l=1,sg=0:0
    IP: 192.168.1.43
    IP: 192.168.1.43
    IP: 192.168.1.43
    @Mark-Swift Strange. You're sure all the connections are correct? Are you trying to connect multiple devices to the gateway? Do you have two devices with the same MAC address? I didn't do much beyond the stock code. I am using the LEDs and inclusion mode with an NRF radio using softspi.
  • @petewill I will need to check the connections, but it works once I roll back, so doubt it's connections? Just one controller, I disable the second one while testing. MAC address is unique, and the same in each sketch. It's baffling!
    @petewill not everybody seems to experience the crashes. My gw is also running fine...
    But it's a fact the board defs cause the issue ; it's confirmed by arduino and fixed in the compiler but it will probably take a while to make it into the official release.
    Until then, if you experience reboots then downgrade the board defs.
    @Yveaux Strange. Good to know though. 👍 Thanks.
  • I am a relatively new user to MySensors, and I think a bug such as this needs to be described on the main page on how to build an Ethernet Gateway. This problem caused me a lot of frustation, and I don't know enough about how the hardware works to even realize that my gateway was being reset every 2 seconds. Anyone trying to build a W5100 ethernet gateway with a fresh Arduino install is going to experience this bug, and I think it will reflect poorly on the whole MySensors project if this bug is not highlighted on the build page.
    The biggest benefit of the MySensors project is that getting up and running is relatively easy, but bugs such as this definitely make it harder.
  • I completely agree. I am having a hell of a time getting mine to work at its to the point where I'm searching for an alternative to mysensors. This post should be in the main page regarding setup. I have wasted hours trying to figure this out.
  • 198
