Battery sensor and re-connecting to gateway
  • I found this code in another thread, but it is locked for reply. I have some sensors outside and sometimes they lose the connection and actually they never re-connect.
    So for me to understand properly: It seems to me to make a lot of sense to put this code into all my battery powered sensors, because they sleep all the time and if they lose the connection, then they will never re-connect, but with this code they should. Is that right? They are only awake to take some reading and send it and then sleep,immediately.
    Is that correct?
    if(isTransportOK()){
        sleep(30000);  // transport is OK, node can sleep
      else {
        wait(5000); // transport is not operational, allow the transport layer to fix this
    @karl261 That could do the trick. Because the Node needs time to reestablish the connection with the gateway. Which it can't do when your Arduino is sleeping.
    But before I'd try such tricks, I would be interested in what the cause of connection loss is. Is the distance too long? Is there a power issue? Also what version of MySensors are you using?
  • @TheoL
    In version 1.5.1, when the node send the data without connection it will try to find a parent(repeater) after 6 failures.
    So if your node send data every hour it will need 6 hour before it will try to find a parent.
    If you start the sensor near the GW and then move the node too far away from the GW and out have a repeater next to the new place where you out the node it needs 6 transmissions before it find the repeater.
    But you shall find out what the main problem is for the node.
    Maybe you can connect a serial monitor to it and change the sleep to 1 min and then see what happens.
    @flopp Hello dear friend,
    If I'm not mistaken, there's in improvement on that field in MySensors 2.0. Maybe @Hek or @Tekka or @Yveaux know more about this.
    But as advised before. If you can solve the communication problem, it'll be a more permanent solution.
    @TheoL @flopp @karl261 I'm currently working on a improved sleep function in 2.0.1 that will address some of the issues mentioned above. Depending on the radio status, the node will sleep if link is ok, or try to reconnect and abort if too many failed attempts and retry later.
  • Ok, thanks a lot. It is clear now. I will add some code and try. Later in 2.0.1 I can just remove this code...
    Question: the six failed transmissions: do they need to be consecutive? Or does it just count to six over time?
    @karl261 consecutive
  • Another question:
    Woudn't it be better to do something like this
    while(!isTransportOK()){
    sleep(SLEEP_TIME);  // transport is OK, node can sleep
    or doesn't this bring anything?
  • Wow, This is so cool. This probably solves all my problems from the past year.
    It just happened: I had a node connected to the gateway and brought it far away. It lost the connection to the gateway. I switched on a repeater node halfway. The node reconnected to the gateway via the repeater node.
    I can't believe it!
  • @tekka The only problem with this extra code is, that in case the node loses its connection, it will drain the battery quite quickly...
    @karl261 yes, in the example you mentioned, the node won't sleep at all if connection is lost and cannot be re-established. For battery powered nodes I recommend using MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC to prevent the transport state machine from entering the SNP (search new parent) state.
    MySensors 2.0.1 introduces an enhanced sleeping function with a reconnection timeout: https://github.com/mysensors/MySensors/pull/558
    great work @tekka
  • @tekka Yeah, that's what I actually use. Since I normally don't move my sensors and repeaters, having the parent node static sounds like a good thing to do.
    I look forward to the 2.0.1 release. There seem to be a lot of cool new things inside.
    @tekka, @oitzu, Still, this nrf is driving me nuts. My sensor in the garden has worked just fine for three weeks, and nothing has changed. Now it makes problems. It is still running, because once per day one Temp reading or similar is getting through. Battery is just the same as before.
    Do you have any idea why it could have stopped working? I don't see any reason why the repeater should stop receiving the values. The repeater works fine, it relays all other nodes. And the geometry between repeater and garden sensor has not changed.
    The weather has changed. The T is about 7 degrees less outside...
  • @tekka I'm using the latest snapshot on one of my battery sensors and can see if it can't connect, it doesn't sleep and the debug shows a rapid number of connection attempts. I'd like to know if the sensor will eventually sleep if it cannot successfully connect, and what the default timeout is?
    @Mark-Swift Please post your sketch & full debug log. Thanks
  • @tekka I don't think there's an issue.
    I'm simply asking what the logic is behind the reconnection logic on sleeping sensors, how long is the timeout for example (I'm conscious of battery drain for nodes having issues connecting).
    @Mark-Swift No, this sounds like an issue - a rapid number of connection attempts is unusual, that's why I'm interested in your sketch/debug log.
    To answer your questions: In the latest dev version the node will try to reconnect with a 10sec timeout (if sleeping time > 10sec, this can be changed via MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS) before sleeping - if time is left.
  • @tekka it's been a while but I never resolved this... If I test by changing the parent node ID to a fake one, it just tried to connect forever, thus draining the battery...
    Sketch:
      REVISION HISTORY
      Created by Mark Swift
      V1.2 - Added sleep time to force daily update
      V1.3 - Deactivate pullup on setup and added old_value logic
      V1.4 - Added daily wakeup to sleep
      V1.5 - Code cleanup
    //*** EXTERNAL LIBRARIES **********************************
    #include <Vcc.h>
    //*** MYSENSORS *******************************************
    // Enable debug prints
    // Lower serial speed if using 1Mhz clock
    // #define MY_BAUD_RATE 9600
    #define MY_NODE_ID 4
    #define MY_PARENT_NODE_ID 1 // AUTO
    // #define MY_RADIO_RFM69
    // Override RF24L01 channel number
    // #define MY_RF24_CHANNEL 125
    // Override RF24L01 module PA level
    // #define MY_RF24_PA_LEVEL RF24_PA_LOW
    // Override RF24L01 datarate
    // #define MY_RF24_DATARATE RF24_250KBPS
    // *** SKETCH CONFIG **************************************
    #define SKETCH_NAME "Door Sensor"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "5"
    // Define the sensor child IDs
    #define CHILD_ID1 1 // Switch
    #define CHILD_ID2 2 // Battery voltage
    #define CHILD_ID3 3 // Battery percent
    // Define the message formats
    MyMessage msg(CHILD_ID1, V_TRIPPED);
    MyMessage msg2(CHILD_ID2, V_CUSTOM);
    MyMessage msg3(CHILD_ID3, V_CUSTOM);
    // *** SENSORS CONFIG *************************************
    // Digital I/O pin for button or reed switch
    #define PRIMARY_BUTTON_PIN 3
    // Debounce using a small sleep
    #define DEBOUNCE_SLEEP 5
    // Sleep timer in milliseconds
    #define SLEEP_IN_MS 86400000
    // Store the old value for comparison
    int old_value = -1;
    // Minimum expected vcc level, in volts (2xAA alkaline)
    const float vcc_min = 2.0 * 0.9;
    // Maximum expected vcc level, in volts (2xAA alkaline)
    const float vcc_max = 2.0 * 1.5;
    // Measured vcc by multimeter divided by reported vcc
    const float vcc_correction = 2.88 / 2.82;
    Vcc vcc(vcc_correction);
    // *** BEGIN **********************************************
      // Setup the contact sensor
      // Activate or deactivate the internal pull-up - high if using internal resistor or low if using external
      digitalWrite(PRIMARY_BUTTON_PIN, LOW);
      // Register all sensors to the gateway
      present(CHILD_ID1, S_DOOR);
      present(CHILD_ID2, S_CUSTOM);
      present(CHILD_ID3, S_CUSTOM);
      // Debouce using sleep
      sleep(DEBOUNCE_SLEEP);
      int value = digitalRead(PRIMARY_BUTTON_PIN);
      // If value has changed send the updated value
      if (value != old_value) {
        send(msg.set(value == HIGH ? 0 : 1));
        old_value = value;
      // Read battery voltage
      float battery_voltage = vcc.Read_Volts();
      // Calculate battery percentage
      float battery_percent = vcc.Read_Perc(vcc_min, vcc_max);
    #ifdef MY_DEBUG
      Serial.print("Battery = ");
      Serial.print(battery_voltage);
      Serial.println(" Volts");
      Serial.print(battery_percent);
      Serial.println("%");
      // Send battery readings
      send(msg2.set(battery_voltage, 2));
      send(msg3.set(battery_percent, 1));
      sendBatteryLevel(battery_percent);
      // Sleep until either interupt change or timer reaches zero
      smartSleep(PRIMARY_BUTTON_PIN - 2, CHANGE, SLEEP_IN_MS);
  • Debug:
    0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
    4 TSM:INIT
    6 TSF:WUR:MS=0
    14 TSM:INIT:TSP OK
    16 TSM:INIT:STATID=4
    18 TSF:SID:OK,ID=4
    20 TSM:FPAR
    22 TSM:FPAR:STATP=1
    24 TSM:ID
    24 TSM:ID:OK
    26 TSM:UPL
    63 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    2072 TSM:UPL
    2109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    4118 TSM:UPL
    4155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    6164 TSM:UPL
    6201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    8210 !TSM:UPL:FAIL
    8212 TSM:FPAR
    8212 TSM:FPAR:STATP=1
    8214 TSM:ID
    8216 TSM:ID:OK
    8218 TSM:UPL
    8255 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    10264 TSM:UPL
    10301 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    12310 TSM:UPL
    12347 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    14356 TSM:UPL
    14393 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    16402 !TSM:UPL:FAIL
    16404 TSM:FPAR
    16404 TSM:FPAR:STATP=1
    16408 TSM:ID
    16410 TSM:ID:OK
    16410 TSM:UPL
    16449 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    18458 TSM:UPL
    18495 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    20504 TSM:UPL
    20541 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    22550 TSM:UPL
    22587 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    24596 !TSM:UPL:FAIL
    24598 TSM:FPAR
    24598 TSM:FPAR:STATP=1
    24602 TSM:ID
    24604 TSM:ID:OK
    24604 TSM:UPL
    24643 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    26652 TSM:UPL
    26689 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    28698 TSM:UPL
    28735 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    30744 TSM:UPL
    30781 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    32790 !TSM:UPL:FAIL
    32792 TSM:FPAR
    32792 TSM:FPAR:STATP=1
    32796 TSM:ID
    32798 TSM:ID:OK
    32798 TSM:UPL
    32837 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    34846 TSM:UPL
    34883 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    36892 TSM:UPL
    36929 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    38938 TSM:UPL
    38975 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    40984 !TSM:UPL:FAIL
    40986 TSM:FPAR
    40986 TSM:FPAR:STATP=1
    40990 TSM:ID
    40992 TSM:ID:OK
    40992 TSM:UPL
    41031 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    43040 TSM:UPL
    43077 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    45086 TSM:UPL
    45123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    47132 TSM:UPL
    47169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    49178 !TSM:UPL:FAIL
    49180 TSM:FPAR
    49180 TSM:FPAR:STATP=1
    49184 TSM:ID
    49186 TSM:ID:OK
    49186 TSM:UPL
    49225 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    51234 TSM:UPL
    51271 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    53280 TSM:UPL
    53317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    55326 TSM:UPL
    55363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    57372 !TSM:UPL:FAIL
    57374 TSM:FPAR
    57374 TSM:FPAR:STATP=1
    57378 TSM:ID
    57380 TSM:ID:OK
    57380 TSM:UPL
    57419 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    59428 TSM:UPL
    59465 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    61474 TSM:UPL
    61511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    63520 TSM:UPL
    63557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    65566 !TSM:UPL:FAIL
    65568 TSM:FPAR
    65568 TSM:FPAR:STATP=1
    65572 TSM:ID
    65574 TSM:ID:OK
    65574 TSM:UPL
    65613 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    67624 TSM:UPL
    67661 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    69672 TSM:UPL
    69709 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    71720 TSM:UPL
    71757 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    73768 !TSM:UPL:FAIL
    73771 TSM:FPAR
    73771 TSM:FPAR:STATP=1
    73775 TSM:ID
    73777 TSM:ID:OK
    73777 TSM:UPL
    73816 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    75825 TSM:UPL
    75862 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    77871 TSM:UPL
    77907 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    79917 TSM:UPL
    79953 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    81963 !TSM:UPL:FAIL
    81965 TSM:FPAR
    81965 TSM:FPAR:STATP=1
    81969 TSM:ID
    81971 TSM:ID:OK
    81971 TSM:UPL
    82010 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    84019 TSM:UPL
    84056 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    86065 TSM:UPL
    86102 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    88111 TSM:UPL
    88147 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    90157 !TSM:UPL:FAIL
    90159 TSM:FPAR
    90159 TSM:FPAR:STATP=1
    90163 TSM:ID
    90165 TSM:ID:OK
    90165 TSM:UPL
    90204 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    92213 TSM:UPL
    92250 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    94259 TSM:UPL
    94296 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    96305 TSM:UPL
    96342 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    98351 !TSM:UPL:FAIL
    98353 TSM:FPAR
    98353 TSM:FPAR:STATP=1
    98357 TSM:ID
    98359 TSM:ID:OK
    98359 TSM:UPL
    98398 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    100407 TSM:UPL
    100444 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    102453 TSM:UPL
    102490 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    104499 TSM:UPL
    104536 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    106545 !TSM:UPL:FAIL
    106547 TSM:FPAR
    106549 TSM:FPAR:STATP=1
    106551 TSM:ID
    106553 TSM:ID:OK
    106555 TSM:UPL
    106592 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    108601 TSM:UPL
    108638 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    110647 TSM:UPL
    110684 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    112693 TSM:UPL
    112730 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    114739 !TSM:UPL:FAIL
    114741 TSM:FPAR
    114743 TSM:FPAR:STATP=1
    114745 TSM:ID
    114747 TSM:ID:OK
    114749 TSM:UPL
    114786 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    116795 TSM:UPL
    116832 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    118841 TSM:UPL
    118878 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    120887 TSM:UPL
    120924 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    122933 !TSM:UPL:FAIL
    122935 TSM:FPAR
    122937 TSM:FPAR:STATP=1
    122939 TSM:ID
    122941 TSM:ID:OK
    122943 TSM:UPL
    122980 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    124989 TSM:UPL
    125026 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    127035 TSM:UPL
    127072 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    129081 TSM:UPL
    129118 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    131127 !TSM:UPL:FAIL
    131129 TSM:FPAR
    131131 TSM:FPAR:STATP=1
    131133 TSM:ID
    131135 TSM:ID:OK
    131137 TSM:UPL
    131174 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    133183 TSM:UPL
    133220 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    135229 TSM:UPL
    135266 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    137275 TSM:UPL
    137312 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    139321 !TSM:UPL:FAIL
    139323 TSM:FPAR
    139325 TSM:FPAR:STATP=1
    139327 TSM:ID
    139329 TSM:ID:OK
    139331 TSM:UPL
    139368 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    141377 TSM:UPL
    141414 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    143423 TSM:UPL
    143460 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    145469 TSM:UPL
    145506 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    147515 !TSM:UPL:FAIL
    147517 TSM:FPAR
    147519 TSM:FPAR:STATP=1
    147521 TSM:ID
    147523 TSM:ID:OK
    147525 TSM:UPL
    147562 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    149571 TSM:UPL
    149608 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    151617 TSM:UPL
    151654 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    153663 TSM:UPL
    153700 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    155709 !TSM:UPL:FAIL
    155711 TSM:FPAR
    155713 TSM:FPAR:STATP=1
    155715 TSM:ID
    155717 TSM:ID:OK
    155719 TSM:UPL
    155756 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    157765 TSM:UPL
    157802 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    159811 TSM:UPL
    159848 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    161857 TSM:UPL
    161894 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    163903 !TSM:UPL:FAIL
    163905 TSM:FPAR
    163907 TSM:FPAR:STATP=1
    163909 TSM:ID
    163911 TSM:ID:OK
    163913 TSM:UPL
    163950 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    165959 TSM:UPL
    165996 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    168005 TSM:UPL
    168042 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    170051 TSM:UPL
    170088 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    172097 !TSM:UPL:FAIL
    172099 TSM:FPAR
    172101 TSM:FPAR:STATP=1
    172103 TSM:ID
    172105 TSM:ID:OK
    172107 TSM:UPL
    172144 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    174153 TSM:UPL
    174190 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    176199 TSM:UPL
    176236 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    178245 TSM:UPL
    178282 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    180291 !TSM:UPL:FAIL
    180293 TSM:FPAR
    180295 TSM:FPAR:STATP=1
    180297 TSM:ID
    180299 TSM:ID:OK
    180301 TSM:UPL
    180338 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    182347 TSM:UPL
    182384 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    184393 TSM:UPL
    184430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    186439 TSM:UPL
    186476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    188485 !TSM:UPL:FAIL
    188487 TSM:FPAR
    188489 TSM:FPAR:STATP=1
    188491 TSM:ID
    188493 TSM:ID:OK
    188495 TSM:UPL
    188532 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    190541 TSM:UPL
    190578 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    192587 TSM:UPL
    192624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    194633 TSM:UPL
    194670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    196679 !TSM:UPL:FAIL
    196681 TSM:FPAR
    196683 TSM:FPAR:STATP=1
    196685 TSM:ID
    196687 TSM:ID:OK
    196689 TSM:UPL
    196726 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    198735 TSM:UPL
    198772 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    200781 TSM:UPL
    200818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    202827 TSM:UPL
    202864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    204873 !TSM:UPL:FAIL
    204875 TSM:FPAR
    204877 TSM:FPAR:STATP=1
    204879 TSM:ID
    204881 TSM:ID:OK
    204883 TSM:UPL
    204920 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    206931 TSM:UPL
    206968 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    208979 TSM:UPL
    209016 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    211027 TSM:UPL
    211064 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    213075 !TSM:UPL:FAIL
    213078 TSM:FPAR
    213080 TSM:FPAR:STATP=1
    213082 TSM:ID
    213084 TSM:ID:OK
    213086 TSM:UPL
    213123 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    215132 TSM:UPL
    215169 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    217178 TSM:UPL
    217214 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    219224 TSM:UPL
    219260 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    221270 !TSM:UPL:FAIL
    221272 TSM:FPAR
    221274 TSM:FPAR:STATP=1
    221276 TSM:ID
    221278 TSM:ID:OK
    221280 TSM:UPL
    221317 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    223326 TSM:UPL
    223363 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    225372 TSM:UPL
    225409 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    225689 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    225695 TSF:MSG:BC
    226275 TSF:MSG:READ,0-3-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    226281 TSF:MSG:BC
    227418 TSM:UPL
    227454 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    229464 !TSM:UPL:FAIL
    229466 TSM:FPAR
    229468 TSM:FPAR:STATP=1
    229470 TSM:ID
    229472 TSM:ID:OK
    229474 TSM:UPL
    229511 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    231520 TSM:UPL
    231557 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    233566 TSM:UPL
    233603 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    235612 TSM:UPL
    235649 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    237658 !TSM:UPL:FAIL
    237660 TSM:FPAR
    237662 TSM:FPAR:STATP=1
    237664 TSM:ID
    237666 TSM:ID:OK
    237668 TSM:UPL
    237705 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    239714 TSM:UPL
    239751 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    241760 TSM:UPL
    241797 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    243806 TSM:UPL
    243843 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    245852 !TSM:UPL:FAIL
    245854 TSM:FPAR
    245856 TSM:FPAR:STATP=1
    245858 TSM:ID
    245860 TSM:ID:OK
    245862 TSM:UPL
    245899 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    247908 TSM:UPL
    247945 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    249954 TSM:UPL
    249991 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    252000 TSM:UPL
    252037 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    254046 !TSM:UPL:FAIL
    254048 TSM:FPAR
    254050 TSM:FPAR:STATP=1
    254052 TSM:ID
    254054 TSM:ID:OK
    254056 TSM:UPL
    254093 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    256102 TSM:UPL
    256139 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    258148 TSM:UPL
    258185 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    260194 TSM:UPL
    260231 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    262240 !TSM:UPL:FAIL
    262242 TSM:FPAR
    262244 TSM:FPAR:STATP=1
    262246 TSM:ID
    262248 TSM:ID:OK
    262250 TSM:UPL
    262287 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    264296 TSM:UPL
    264333 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    266342 TSM:UPL
    266379 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    268388 TSM:UPL
    268425 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    270434 !TSM:UPL:FAIL
    270436 TSM:FPAR
    270438 TSM:FPAR:STATP=1
    270440 TSM:ID
    270442 TSM:ID:OK
    270444 TSM:UPL
    270481 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    272490 TSM:UPL
    272527 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    274536 TSM:UPL
    274573 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    276582 TSM:UPL
    276619 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    278628 !TSM:UPL:FAIL
    278630 TSM:FPAR
    278632 TSM:FPAR:STATP=1
    278634 TSM:ID
    278636 TSM:ID:OK
    278638 TSM:UPL
    278675 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    280684 TSM:UPL
    280721 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    282730 TSM:UPL
    282767 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    284776 TSM:UPL
    284813 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    286822 !TSM:UPL:FAIL
    286824 TSM:FPAR
    286826 TSM:FPAR:STATP=1
    286828 TSM:ID
    286830 TSM:ID:OK
    286832 TSM:UPL
    286869 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    288878 TSM:UPL
    288915 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    290924 TSM:UPL
    290961 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    292970 TSM:UPL
    293007 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    295016 !TSM:UPL:FAIL
    295018 TSM:FPAR
    295020 TSM:FPAR:STATP=1
    295022 TSM:ID
    295024 TSM:ID:OK
    295026 TSM:UPL
    295063 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    297072 TSM:UPL
    297109 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    299118 TSM:UPL
    299155 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    301164 TSM:UPL
    301201 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    303210 !TSM:UPL:FAIL
    303212 TSM:FPAR
    303214 TSM:FPAR:STATP=1
    303216 TSM:ID
    303218 TSM:ID:OK
    303220 TSM:UPL
    303257 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    305266 TSM:UPL
    305303 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    307312 TSM:UPL
    307349 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    309358 TSM:UPL
    309395 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    311404 !TSM:UPL:FAIL
    311406 TSM:FPAR
    311408 TSM:FPAR:STATP=1
    311410 TSM:ID
    311412 TSM:ID:OK
    311414 TSM:UPL
    311451 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    313460 TSM:UPL
    313497 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    315506 TSM:UPL
    315543 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    317552 TSM:UPL
    317589 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    319598 !TSM:UPL:FAIL
    319600 TSM:FPAR
    319602 TSM:FPAR:STATP=1
    319604 TSM:ID
    319606 TSM:ID:OK
    319608 TSM:UPL
    319645 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    321654 TSM:UPL
    321691 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    323700 TSM:UPL
    323737 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    325746 TSM:UPL
    325783 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    327792 !TSM:UPL:FAIL
    327794 TSM:FPAR
    327796 TSM:FPAR:STATP=1
    327798 TSM:ID
    327800 TSM:ID:OK
    327802 TSM:UPL
    327839 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    329848 TSM:UPL
    329885 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    331894 TSM:UPL
    331931 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    333940 TSM:UPL
    333977 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    335986 !TSM:UPL:FAIL
    335988 TSM:FPAR
    335990 TSM:FPAR:STATP=1
    335992 TSM:ID
    335994 TSM:ID:OK
    335996 TSM:UPL
    336033 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    338042 TSM:UPL
    338079 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    340088 TSM:UPL
    340125 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    342134 TSM:UPL
    342171 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    344180 !TSM:UPL:FAIL
    344182 TSM:FPAR
    344184 TSM:FPAR:STATP=1
    344186 TSM:ID
    344188 TSM:ID:OK
    344190 TSM:UPL
    344227 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    346238 TSM:UPL
    346275 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    348286 TSM:UPL
    348323 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    350334 TSM:UPL
    350371 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    352382 !TSM:UPL:FAIL
    352385 TSM:FPAR
    352387 TSM:FPAR:STATP=1
    352389 TSM:ID
    352391 TSM:ID:OK
    352393 TSM:UPL
    352430 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    354439 TSM:UPL
    354476 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    356485 TSM:UPL
    356521 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    358531 TSM:UPL
    358567 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    360577 !TSM:UPL:FAIL
    360579 TSM:FPAR
    360581 TSM:FPAR:STATP=1
    360583 TSM:ID
    360585 TSM:ID:OK
    360587 TSM:UPL
    360624 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    362633 TSM:UPL
    362670 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    364679 TSM:UPL
    364716 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    366725 TSM:UPL
    366761 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    368771 !TSM:UPL:FAIL
    368773 TSM:FPAR
    368775 TSM:FPAR:STATP=1
    368777 TSM:ID
    368779 TSM:ID:OK
    368781 TSM:UPL
    368818 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    370827 TSM:UPL
    370864 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    372873 TSM:UPL
    372910 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    374919 TSM:UPL
    374956 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    376965 !TSM:UPL:FAIL
    376967 TSM:FPAR
    376969 TSM:FPAR:STATP=1
    376971 TSM:ID
    376973 TSM:ID:OK
    376975 TSM:UPL
    377012 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    379021 TSM:UPL
    379058 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=9,st=NACK:1
    381067 TSM:UPL
    381104 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=10,st=NACK:1
    383113 TSM:UPL
    383150 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=11,st=NACK:1
    385159 !TSM:UPL:FAIL
    385161 TSM:FPAR
    385163 TSM:FPAR:STATP=1
    385165 TSM:ID
    385167 TSM:ID:OK
    385169 TSM:UPL
    385206 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=12,st=NACK:1
    387215 TSM:UPL
    387252 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=13,st=NACK:1
    389261 TSM:UPL
    389298 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=14,st=NACK:1
    391307 TSM:UPL
    391344 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=15,st=NACK:1
    393353 !TSM:UPL:FAIL
    393355 TSM:FPAR
    393357 TSM:FPAR:STATP=1
    393359 TSM:ID
    393361 TSM:ID:OK
    393363 TSM:UPL
    393400 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    395409 TSM:UPL
    395446 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    397455 TSM:UPL
    397492 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    399501 TSM:UPL
    399538 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    401547 !TSM:UPL:FAIL
    401549 TSM:FPAR
    401551 TSM:FPAR:STATP=1
    401553 TSM:ID
    401555 TSM:ID:OK
    401557 TSM:UPL
    401594 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=4,st=NACK:1
    403603 TSM:UPL
    403640 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=NACK:1
    405649 TSM:UPL
    405686 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=6,st=NACK:1
    407695 TSM:UPL
    407732 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=7,st=NACK:1
    409741 !TSM:UPL:FAIL
    409743 TSM:FPAR
    409745 TSM:FPAR:STATP=1
    409747 TSM:ID
    409749 TSM:ID:OK
    409751 TSM:UPL
    409788 !TSF:MSG:SEND,4-4-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=8,st=NACK:1
    @Mark-Swift I guess because of MY_PARENT_NODE_IS_STATIC which prevents the use of an alternative parent.
  • @tekka I guessed that, I thought however that you'd mentioned it would timeout, and try again later? As it stands it appears it'll keep trying until the battery is dead?
    If nothing else I just want to clear up the behaviour so I fully understand it.
    Mark
    @Mark-Swift it does timeout, but for that you have to set MY_TRANSPORT_WAIT_READY_MS > 0. This ensures, that loop() will be entered after the timeout if the connection could not be established.
  • @tekka thank you, so if I
    #define MY_TRANSPORT_WAIT_READY_MS 60000
    Am I right in thinking that my node will enter the loop after it tries to connect to a parent for 60 seconds and fails? (In my case it'd then sleep until the next interrupt, when I guess it would then try again for 60 seconds...).
    I really appreciate your help getting my head around this 🙂
    @Mark-Swift Almost 🙂
    applies only when the node starts, i.e. before entering loop(). Once you are in loop() and you put the node to sleep
    #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 10000
    defines how long the node will try to establish a connection before going to sleep, default is 10s. Please have a look here for additional information.
  • 24
