Serial Gateway with Sensors
  • Hi guys,
    Sorry if there is already a topic with this, however I couldn't find any helpful information.
    There is a long time since last time I have "played" with MySensors.
    Then, I am trying to run a Serial Gateway with a relay attached. However, it seems that it is not calling the presentation() function.
    My code:
    //#define MY_RADIO_NRF24
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define CHILD_ID 1
     sendSketchInfo("Relay", "1.0");
     present(CHILD_ID, S_LIGHT);
    My output:
    0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0)
    Another question that I couldn't find in docs is how can I set hardcode the node ID?
    @alfredocdmiranda the id of a gateway is always 0, it can not be changed.
  • About the Gateway ID it is fine. My main problem is that it seems presentation function is not being run.
    Please use the development branch. There was a bug fixed related to presentations of gateway attached sensors.
  • @hek Thanks! Now it worked 🙂
    Hey, and can you answer me about how to set hardcode ID in some other node(not gateway)?
  • @mfalkvidd
    Oh, okay! Thanks. I haven't seen this code!
    Really thanks for your help, guys 🙂
    @alfredocdmiranda you're wlecome. We're happy to be of assistance.
