[Solved] MQTT gateway problem
  • Hi all!
    I am not native english speaker, sorry for my text.
    I have:
    • arduino mega
    • ethernet shield
    • mosquitto on linux (192.168.1.75:1883)
    • mysensors 2.0
    • arduino ide 1.6.12
    • MQTT gateway
    Code of MQTT Gateway:
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "ms_mqtt_gw-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "ms_mqtt_gw-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "mqtt_gw_1"
    // Security Signing
    #define MY_SIGNING_SOFT //!< Software signing
    //#define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
    // Enable node whitelisting
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
      #define MY_SOFT_SPI_SCK_PIN 54
      #define MY_SOFT_SPI_MISO_PIN 56
      #define MY_SOFT_SPI_MOSI_PIN 55
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 192,168,1,76
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 75
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    And i have this trouble:
    0;255;3;0;9;Starting gateway (RNNGAS, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.76
    IP: 192.168.1.76
    IP: 192.168.1.76
    IP: 192.168.1.76
    0;255;3;0;9;TSP:SANCHK:OK
    IP: 192.168.1.76
    IP: 192.168.1.76
    IP: 192.168.1.76
    IP: 192.168.1.76
    I try to use mosquitto_sub and pub + mqtt-spy, and mqtt broker is work.
    I replase mega -> uno, one ethernet shield to another, nothing change.
    ping between client and brocker is ok.
    I don't know what else to do, can anybody help me?
  • Can you connect to the MQTT server using MQTT-SPY?
  • @Martin-Tellblom Yes, it work normally, how it seems to me.
    @pinkkoff what version of mosquitto are you running?
  • @Yveaux
    mosquitto is an MQTT v3.1 broker.
    Version: 0.15-2ubuntu1
    Run on Odroid C1+ with ubuntu 14.04
    @pinkkoff iirr the mqtt implementation in mysensors is 3.1.1
    Try upgrading your mosquitto version
  • @Yveaux Thank you!!! It working!
    Problem is in version of mosquitto in ubuntu repository. If someone want to use mqtt, better way is follow step-by-step guide
    @pinkkoff
    FYI, I've had better luck using the mosquitto ppa. Tested on RPI2 and RPI3 running Ubuntu.
  • I'm also trying mqtt. somehow I can't see the messages:
    MySensors $ ./configure --my-gateway=mqtt --my-controller-ip-address=192,168,1,32 --my-port=1883 --my-mqtt-client-id=22 --my-mqtt-publish-topic-prefix=mysensors-from --my-mqtt-subscribe-topic-prefix=mysensors-to --my-rf24-pa-level=RF24_PA_LOW
    MySensors $ sudo make install
    MySensors $ sudo mysGateway -d
    mysGateway: Attempting MQTT connection...
    mysGateway: connected to 192.168.1.32
    mysGateway: TSF:MSG:READ,8-8-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    mysGateway: !TSF:MSG:SEND,0-0-8-8,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
    mysGateway: TSF:MSG:READ,8-8-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta
    mysGateway: TSF:MSG:READ,8-8-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    So GW attempts to send some stuff to mqtt server elsewhere, like that version string. But this on the server prints nothing:
    $ mosquitto_sub -t mysensors-from/*
    I also tried with # instead of *
    I've verified mqtt works, if I pub that from mqtt client, it works.
  • so this works:
    MySensors $ mosquitto_pub -h 192.168.1.32 -t mysensors-from/0/1 -m "MySensors MQTT hello world from raspi to odroid"
    mqtt-host $ mosquitto_sub -t mysensors-from/#
  • My mosquitto is mosquitto 3.1 - 0.15-2ubuntu1 (from ppa) and mysensors is up to date devel branch from github.
  • after upgrading to above mentioned 3.1.1 version from wheezy, the mysensors start to print out it sends stuff. can't see it on subs yet though.
  • nevermind. now after all upgrades AND BATTERY CHANGE to sensebender it's all fine 🙂
  • 18
  • 6
  • 6
