Can't get the void receive() to work, on Repeater and Node's
  • Hi.
    I use the last 2.0.1-beta dev. version (from last night), and I can't get the function void receive(const MyMessage &message) to work.
    It works fine on a Gateway setup.
    Have tryed 2 types of setups.
    1. Node(ID6) to a Repeater(ID7). I see the debug data on the repeater, but can't get any data via the void receive().
    2. Node(ID6) to Node(ID7). Also here, I see the data on Node(ID7), but can't get any data via the void receive() funktion.
    Any ideas?
    Node(ID6) has a Static parent to Node-ID7, and Node(ID7) has a Static parent to Node-ID6
    The void receive(const MyMessage &message) funktion, now works fine, from version 2.0.1-beta, on at GatewaySerial setup.
    @delinend Can you post the sketch.
  • @AWI
    Here the Node6, that sends temperatur, from a IR sensor to Parent-ID7
    #define MY_NODE_ID 6
    //#define MY_DEFAULT_ERR_LED_PIN 4
    #define MY_RF24_CHANNEL 123
    #define MY_PARENT_NODE_ID 7
    //#define MY_REGISTRATION_FEATURE
    #define MY_TRANSPORT_DONT_CARE_MODE
    //#define MY_REPEATER_FEATURE
    #include <Adafruit_MLX90614.h>
    Adafruit_MLX90614 mlx = Adafruit_MLX90614();
    unsigned long SLEEP_TIME = 500; // Sleep time between reads (in milliseconds)
    MyMessage msg(0,V_TEMP);
    float temperature;
     mlx.begin();
      present(0, S_TEMP);
    //  Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempC());
    //  Serial.print("*C\tObject = "); Serial.print(mlx.readObjectTempC()); Serial.println("*C");
     temperature = mlx.readObjectTempC();
     Serial.println(temperature,1);
          send(msg.setSensor(0).set(temperature,1));
      sleep(SLEEP_TIME);
    Ande here Node7, from where I can see the temperatur data, via MY_DEBUG, but not via the void receive() function,
    //#define MY_SPECIAL_DEBUG
    //#define MY_DISABLED_SERIAL
    #define MY_NODE_ID 7
    #define MY_PARENT_NODE_ID 6
    // Enable serial gateway
    //#define MY_GATEWAY_SERIAL
    //#define MY_GATEWAY_W5100
    //  Serial.begin(19200);
    //  Serial.begin(MY_BAUD_RATE);
      Serial.println("Started . Please wait...");
     //sendSketchInfo("Temperature Sensor", "1.1");
    //Serial.println(tempp,1);
    delay(10);
    //wait(10);
      Serial.println("received something: ");
    //Serial.println(message.type);
      Serial.println(message.sender);
    //  Serial.println(message.sensor);
    //  Serial.println(message.getBool());
    shouldn't that be
    send(msg.setDestination(7).setSensor().set(temperature,1));
    in order to have messages delivered at the right destination == 7
  • @AWI
    You hare a Hero 🙂 That works!
    Btw. Is the setting #define MY_TRANSPORT_DONT_CARE_MORE the right setting, when in a 2 Node's only setup ? I can't else get the Node6 beginning transmitting data.
    @delinend The "royal way" is to have one node be a gateway. Else you need the "don't care"
