Energy meter pulse sensor (ambiguous) won't compile
  • Hi All
    Im trying to get the Energy meter pulse sensor sketch working but when i test the code i get the following message.
    (exit status 1
    call of overloaded 'set(volatile long unsigned int&)' is ambiguous)
    any ideas would be great
    thanks in advance
    I'm running arduino 1.6.12
    and using the development branch
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "home"
    #define MY_ESP8266_PASSWORD "Password"
    // Enable UDP communication
    //#define MY_USE_UDP
    // #define MY_ESP8266_HOSTNAME "sensor-gateway"
    #define MY_IP_ADDRESS 192,168,1,198
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,254
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
      #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    bool pcReceived = false;
    unsigned long oldPulseCount = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
    MyMessage pcMsg(CHILD_ID,V_VAR1);
      request(CHILD_ID, V_VAR1);
      pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
      lastSend=millis();
      present(CHILD_ID, S_POWER);
      unsigned long now = millis();
      if (pcReceived && (SLEEP_MODE || sendTime)) {
        if (!SLEEP_MODE && watt != oldWatt) {
          if (watt<((unsigned long)MAX_WATT)) {
          Serial.print("Watt:");
          Serial.println(watt);
          oldWatt = watt;
        // Pulse cout has changed
        if (pulseCount != oldPulseCount) {
          send(pcMsg.set(pulseCount));  // Send pulse count value to gw
          double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
          oldPulseCount = pulseCount;
          if (kwh != oldKwh) {
            send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
            oldKwh = kwh;
        lastSend = now;
      } else if (sendTime && !pcReceived) {
        // No count received. Try requesting it again
        lastSend=now;
      if (SLEEP_MODE) {
        sleep(SEND_FREQUENCY);
      if (message.type==V_VAR1) {
        pulseCount = oldPulseCount = message.getLong();
        Serial.print("Received last pulse count from gw:");
        Serial.println(pulseCount);
        pcReceived = true;
    void onPulse()
      if (!SLEEP_MODE) {
        unsigned long interval = newBlink-lastBlink;
        if (interval<10000L) { // Sometimes we get interrupt on RISING
          return;
        watt = (3600000000.0 /interval) / ppwh;
        lastBlink = newBlink;
      pulseCount++;
    @Opus40 I can't compile it for ESP because I don't have it installed. But when I change it to an RFF sensor it compiles without errors in Arduino 1.6.8 IDE.
    Could you post the compile errors?
  • hi so this is what i get from the error messages
    C:\Users\opus\Desktop\GatewayESP8266_-power_meter\GatewayESP8266-_power_meter.ino: In function 'void loop()':
    GatewayESP8266_-_power_meter:189: error: call of overloaded 'set(volatile long unsigned int&)' is ambiguous
    C:\Users\opus\Desktop\GatewayESP8266_-power_meter\GatewayESP8266-_power_meter.ino:189:30: note: candidates are:
    In file included from C:\Program Files (x86)\Arduino\libraries\MySensors-development/MySensors.h:322:0,
                 from C:\Users\opus\Desktop\GatewayESP8266_-_power_meter\GatewayESP8266_-_power_meter.ino:134:
    C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:222:12: note: MyMessage& MyMessage::set(const char*) <near match>
    MyMessage& MyMessage::set(const char* value) {
    C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:222:12: note: no known conversion for argument 1 from 'volatile long unsigned int' to 'const char*'
    C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:234:12: note: MyMessage& MyMessage::set(bool)
    MyMessage& MyMessage::set(bool value) {
    C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:241:12: note: MyMessage& MyMessage::set(uint8_t)
    MyMessage& MyMessage::set(uint8_t value) {
    C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:256:12: note: MyMessage& MyMessage::set(uint32_t)
    MyMessage& MyMessage::set(uint32_t value) {
    C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:263:12: note: MyMessage& MyMessage::set(int32_t)
    MyMessage& MyMessage::set(int32_t value) {
    C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:270:12: note: MyMessage& MyMessage::set(uint16_t)
    MyMessage& MyMessage::set(uint16_t value) {
    C:\Program Files (x86)\Arduino\libraries\MySensors-development/core/MyMessage.cpp:277:12: note: MyMessage& MyMessage::set(int16_t)
    MyMessage& MyMessage::set(int16_t value) {
    GatewayESP8266_-_power_meter:197: error: call of overloaded 'set(volatile long unsigned int&)' is ambiguous
    C:\Users\opus\Desktop\GatewayESP8266_-power_meter\GatewayESP8266-_power_meter.ino:197:32: note: candidates are:
    exit status 1
    @Opus40 Might be a bug in the development branch. I use the 2.0 release.
    What happens if you compile it for a normal arduino and not as a gateway? (Just comment all the gateway and esp stuff and uncomment NRF) That's what I did.
  • Thanks Hek that's done it, should have looked for threads on the water sensor as well. and thanks to you alsoTheoL
