3-in-1 Humidity Temp and Motion
  • I am wanted to share my 3-in-1 sensor in case its of use to anyone
    Its really just a combination of what's already available
    I used the following hardware:
    Arduino Nano LINK - Gave me both 3.3v and 5v output without having to mess with extra hardware(steppers)
    1 x Motion Sensor LINK
    1 x DHT22 LINK
    Connections is as all other guides except:
    Motion Sensor digital to Pin D3
    and the DHT to Pin D4
    Here is my code
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_MOT 2   // Id of the sensor child
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
      gw.begin();
      gw.sendSketchInfo("Humidity/Motion", "1.0");
      gw.present(CHILD_ID_MOT, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    If anyone wants more info please ask.. I will put up pictures or diagrams if needed
    @Konrad-Walsh
    Battery powered?
  • no. usb charger powered. No idea where to start with battery powering this stuff
  • Very cool. Could you list the hardware you used for this project?
  • @chilump
    Yes of course... I'll update the original post shortly..
    EDIT: UPDATED
  • Interested in how you will package this? will the recorded temp be affected by the duino if it's enclosed?
  • No its not affected as the temp sensor is on the outside of the case along with the motion sensor
  • Do you have a picture of it in the case? Pictures rule 😃
  • I found out quite marked difference between different setups! On the surface of the enclosure there's >3C warmer than few centimeters further from the enclosure, see pictures 🙂
    First picture: temp, light level, door sensor, movement, patio PWM led lightning. DS sensor on the bottom of the enclosure
    Second: temp, light, movement
    @Nuubi Where did you get those cases?
  • Upper picture: a repurposed old movement alarm unit, was on sale for 2€ several years ago on a local store.
    Lower one: from dx.com (http://www.dx.com/p/wall-mount-pir-motion-detector-with-80db-alarm-siren-7-10-meter-110-degrees-15278), just swapped the internals. A bit small for my spider net constructions, though.
    I am trying out your 3-in-1 Humidity Temp and Motion sensor with a DHT11 and get the following in the serial out put
    sensor started, id 5
    send: 5-5-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
    send: 5-5-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    read: 0-0-5 s=255,c=3,t=6,pt=0,l=1:M
    send: 5-5-0-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Humidity/Motion
    send: 5-5-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 5-5-0-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
    send: 5-5-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
    send: 5-5-0-0 s=2,c=0,t=1,pt=0,l=5,st=ok:1.4.1
    send: 5-5-0-0 s=2,c=1,t=16,pt=0,l=1,st=ok:1
    so the motion is working but not the temp or humidity, do I have to do some thing different in the scetch for the DHT11 over the DHT22?
    Thanks for any help.
  • Hey
    From what I just read it shouldnt matter.. you I would double check you wiring of the DHT11. Your output should be on PIN 4.. Also, have you placed the resistor on the DHT1`1
  • hi,
    thanks I did some reading my self and realised I needed the resistor works a treat now. thanks for the reply.
  • @Opus40 Great!
    I am currently finalising a 5 in 1 sensor... just testing and so far its working fantastic
    Hum-temp-motion-light-???
  • @Nuubi LOL.. its a secret!!!
    and I will share my carefully guarded secret... Air quality sensor!! or in other words.. smoke and gas detector...
  • Did you mount your PIR behind the rounded screen area on those cases? It works through that?
    I have yet to get to integrating PIR's in to my sensors, but do plan to, and was curious how to effectively mount them. Need to offer protection from the circuitry, but visibility to the sensor itself.
  • Question about a minor detail:
    Wouldn't a motionsenser trip be missed during:
    delay(dht.getMinimumSamplingPeriod()); ?
    For a DHT22 this is 2 seconds... or does the interrupt still has precedence?
    @C4Vette you could just use a non-blocking method to read the temperature instead of the delay.
    The delay is method is in the library and used so that multiple reads to the sensor don't affect the reading (overheating the sensor).
    since SLEEP_TIME is 30s in the code above... I'd just read the temperature each time the sensor was awakened.
    you could just timestamp the last reading and check that at least the 2 seconds elapsed since the last reading before you take a new one (in the case that motion was detected.
  • @BulldogLowell
    Ok, thanks for explaining. I'm no programmer but trying to understand the code. So because there is also a sleep-periode, the earlier mentioned delay could be omitted? I do not fully understand how the motion interrupt is working but I replaced the 30 second sleep with a few lines using millis, as you implied so that the loop keeps on running to do other things.
    At the moment my sensor is a working combination of a LED-dimmer with a motion-sensor and now trying to add a DHT. This stuff is fun!
    Posted some photo's at http://forum.mysensors.org/topic/781/my-led-dimmer-motion-temp-hum-sensor
  • Nice set up!
    I'm having a problem with this build.
    i'm using the same hardware.
    I get nothing in the serial output screen.
    i am able to compile and load the code.
    when i measure on the 3.3 rail i get 3.8 (only when the radio is hooked up, i get 3.3 when nothing is hooked to the board)
    when i measure on the 5v rail, i get 4.7v when the motion and temp sensor are hooked up.
    I suspect my issues may be voltage related. although i'm not sure why i'm getting nothing on the serial monitor.
    since you said you didn't need any steppers, do you have any suggestions?
    thanks
  • @Konrad-Walsh my nano and pro mini on the way! double each! cant wait!! fed up all confused so have ard r3 n mega n nano n promini all tick tick!
  • Works like a charm...
    Thanks for sharing 🙂
  • dear all.
    What battery u use?
    And what is the battery time?
  • Looks pretty sweet. How is it working comparing to existing products with the same features?
  • Hi Konrad
    Thx for great code. It works like charm but...
    I have a question... It is possible to add to Your code one more (Door/Window) sensor?
    Mayby You can post that code on this forum?
    Best regards
  • Hi to all
    I changed a little Konrad sketch and add to 3in1 Humidity Temp and Motion one more sensor (Door\Window)
    Here is my code:
    #define CHILD_ID_DOOR 3
    #define BUTTON_PIN_DOOR 2
    Bounce debouncer = Bounce();
    int oldValue=-1;
    DHT dht;
    float lastTemp;
    float lastHum;
    MyMessage msgDoor(CHILD_ID_DOOR,V_TRIPPED);
    gw.begin();
    pinMode(BUTTON_PIN_DOOR,INPUT);
    digitalWrite(BUTTON_PIN_DOOR,HIGH);
    debouncer.attach(BUTTON_PIN_DOOR);
    debouncer.interval(5);
    gw.sendSketchInfo("4in1", "1.0");
    gw.present(CHILD_ID_DOOR, S_DOOR);
    if (!metric) {
    lastHum = humidity;
    debouncer.update();
    // Get the update value
    int value = debouncer.read();
    if (value != oldValue) {
    // Send in the new value
    gw.send(msgDoor.set(value==HIGH ? 1 : 0));
    oldValue = value;
    //gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    Now it is 4in1 🙂
  • Has the 3in1 sketch been updated to 2.0 yet? I need some help with it, im not tot keen with coding...
  • @kurniawan77
    This is HUM TEMP and PIR
    This is what I'm using and it runs in mysensors 2.0
    None battery powered. NO sleep mode and dirty code but it runs well enough for me right now.
    If you add or fix anything please post it for everyone.
    #define CHILD_ID_MOT 2 //me
    #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = false;
    unsigned long interval= 3000;//dht.getMinimumSamplingPeriod(); // the time we need to wait
    unsigned long previousMillis=0; // millis() returns an unsigned long.
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED); //me
     // metric = getConfig().isMetric;
      sendSketchInfo("3-1 Sensor", "1.0");
      present(CHILD_ID_MOT, V_TRIPPED); //me
    // only run loop if time has passed.
    unsigned long currentMillis = millis(); // grab current time
     // check if "interval" time has passed
     if ((unsigned long)(currentMillis - previousMillis) >= interval) {
          #ifdef MY_DEBUG
           Serial.print("Motion: ");
        if (!metric) {
        #ifdef MY_DEBUG
          lastHum = humidity;
          #ifdef MY_DEBUG
       // save the "current" time
       previousMillis = millis();
      //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
  • My sample is here, unfortunately I didn't see this thread before starting it 🙂
    It works for temp, humidity, door and motion, and interrupts for door and motion, otherwise sleeps the intervals:
    https://github.com/ikke-t/sensebender
    There is also pro-mini to code to monitor only door and motion.
    This is also for 2.0 MySensors.
  • I combined Motion and Air Humidity and Sleep works. This is my first one and I'm pretty sure I have some unnecessary code in it.
     * Motion: Version 1.0 - Henrik Ekblad
     * Humidity: Version 1.0: Henrik EKblad
     * Combination of Motion Sensor example and Air Humidity example
     * https://www.mysensors.org/build/humidity
    // Enable debug prints
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    unsigned long SLEEP_TIME = 60000; // Sleep time between reports (in milliseconds)
    #define MOTION_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define DHT_INPUT_SENSOR 4     // The digital input of attached DHT sensor
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUMID 0        // ID of the Humidity child
    #define CHILD_ID_TEMP 1         // ID of the Tempurature child
    #define CHILD_ID_MOTION1 2   // Id of the Motion sensor child
    // Initialize motion message
    MyMessage msgMotion(CHILD_ID_MOTION1, V_TRIPPED);
    MyMessage msgHum(CHILD_ID_HUMID, V_HUM);
    DHT dht;
      sendSketchInfo("Motion Temp Humidity", "1.0");
      present(CHILD_ID_MOTION1, S_MOTION);
      present(CHILD_ID_TEMP, V_TEMP);
      present(CHILD_ID_HUMID, V_HUM);
    	pinMode(MOTION_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
      dht.setup(DHT_INPUT_SENSOR); // set data pin of DHT sensor
    	bool tripped = digitalRead(MOTION_INPUT_SENSOR) == HIGH;
    	send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
      #ifdef MY_DEBUG
    // DHT ****************************************************************************
      dht.readSensor(true);
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        nNoUpdatesTemp++;
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        nNoUpdatesHum++;
    	// Sleep until interrupt comes in on motion sensor. Send update after (SLEEP_TIME) milliseconds has passed.
    	sleep(digitalPinToInterrupt(MOTION_INPUT_SENSOR), CHANGE, SLEEP_TIME);
  • I did some work today getting this temp / humidity / motion combo sensor running. The main issue I ran into was that though the temp and humidity did not report their values to the GW unless there was a change in values or the max no update trigger was reached, the motion sensor would report it's state value each cycle. @McPostal you also should be seeing this in your code. While this is not an issue if you are powering with a AC adaptor, I am planning on using batteries down the road for these sensors so I do not want it to broadcast unless required.
    I added some code to resolve this. I am still testing this out but in theory this code should allows the Motion sensor to sleep and only report on a state change or when the max no update trigger is reached.
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    //#define MY_RS485
    #define DHT_DATA_PIN 4
    #define MOTION_DATA_PIN 3
    #define CHILD_ID_MOTION 2
    float lastTemp;
    float lastHum;
    bool lastMotion = false;
    uint8_t nNoUpdatesMotion;
    bool metric = true;
    MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
    DHT dht;
      sendSketchInfo("Temp Humidity Motion", "1.1");
      present(CHILD_ID_MOTION, S_MOTION);
      pinMode(MOTION_DATA_PIN, INPUT);
      sleep(5000);
      presentation();
      bool tripped = digitalRead(MOTION_DATA_PIN) == HIGH;
      if (tripped || nNoUpdatesMotion == FORCE_UPDATE_N_READS) {
        lastMotion = tripped;
        nNoUpdatesMotion = 0;
      else if (lastMotion) {
      else {
        nNoUpdatesMotion++;
        if (!metric) {
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        nNoUpdatesTemp++;
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        nNoUpdatesHum++;
      sleep(digitalPinToInterrupt(MOTION_DATA_PIN), CHANGE, UPDATE_INTERVAL);
    Morkin.
  • Nice! I realized the motion was being updated every cycle after I posted my code. I also left out references to metric temperature readings. I fixed the motion part in my code but didn't post it yet because I had already added a second motion sensor. What I did different was not forcing the motion update. I want the time stamp to reflect the last time someone was in the room.
    I took your updated code for 2.0 and tried to add a relay.
    The code looks like this:
    #define CHILD_ID_HUM 10
    #define CHILD_ID_TEMP 11
    #define CHILD_ID_MOT 12 //motion sensor
    #define RELAY_1  7  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define CHILD_ID 5
    DHT dht;
    float lastTemp;
    float lastHum;
    void before()
    		pinMode(pin, OUTPUT);
      sendSketchInfo("4-1 Sensor", "1.0");
    	present(sensor, S_BINARY);
          #ifdef MY_DEBUG
        if (!metric) {
        #ifdef MY_DEBUG
          lastHum = humidity;
          #ifdef MY_DEBUG
    	if (message.type==V_STATUS) {
    		// Change relay state
    		// Store state in eeprom
    However, when i look in domoticz the relay isnt presented as a child.
    Plus, the motion sensor is called "S_LIGHT_LEVEL" and not "S_MOTION" as it does in my other device (that only have temp, hum motion and not a relay in the sketch).
    temp/hum sensor and motion sensor works as intended in domoticz.
    My first though is that the motion and relay somehow is a bit mixed up by the sketch, but im kinda new to this so im not sure.
    Would really appreciate if someone can look at the sketch and see if there is any obvious problem 🙂
  • @stocken
    Under "void presentation()" , present(CHILD_ID_MOT, V_TRIPPED); //me should be
    present(CHILD_ID_MOT, S_MOTION); //me
    that should fix the light level problem.
    I haven't done a relay yet. If no one else responds I look at it later tonight. I also have a relay but haven't had time to try and implement it yet.
  • Hello everybody,
    first off all a big thank you for creating this awsome sketch. It works perfect for me !!
    But, as you might already have guessed I have a little problem.
    I built 2 exact same nodes and flashed the exact same sketch ( only thing I changed is the child ID´s) but one node works just like a charm ( MSPIRAndy) but the other one (MYSENSOR_106) doesnt transmit its readings (?)
    Via the serial monitor the readings do exist and work perfect.
    Thanks a lot, all help is appreciated
    KOmaandy
    Have you tried swapping radio between the 2 sensors? Just to exclude any radio issue
  • Yes i did swap the radios, but what seems to be the problem is the arduino itself.
    When swapping the arduinos ( both arduino pro mini 3,3 volt) both flashed with the same sketch one works and the other just doesnt.
    I just swapped the arduinos on the breadboard and left everything else in place...
    Thats really strange, given the fact that BOTH transmit good readings when connected to the arduino-serial-monitor ...
  • Do you have a schematic that you could post?
    @ryanbrown204 welcome to the MySensors community!
    This is a long thread with a lot of different people posting, so it is a bit hard to guess which schematic you are looking for. Could you clarify?
  • @mfalkvidd the schematic for the original 3-in-1 Humidity Temp and Motion. I would like to try me hand at building the first version and then adding the additions.
    @ryanbrown204 temperature: https://www.mysensors.org/build/temp
    Motion: https://www.mysensors.org/build/motion
    See the first post in this thread for the modifications Konrad did.
