Slim Node Si7021 sensor example
    @GertSanders Thanks, I don't know why I didn't realize that 😉
    I will try that out tomorrow.
  • @LastSamurai I'm having a go as well at updating the .ino file with the different library, but I'm not a coder so I'm "having a hack" - if you have any luck could you post your code?
    @rsachoc Yes, I actually just tried it out and its working.
    Here is my code for now (just for testing):
    I basically just switched libraries
    by m26872, 20151109
    Changed by LastSamurai
    15052016
    #include <SparkFunHTU21D.h>
    #include <RunningAverage.h>
    //#define DEBUG
    #ifdef DEBUG
    #define NODE_ID 100             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
    #define CHILD_ID_TEMP 0
    #define CHILD_ID_HUM 1
    // #define SLEEP_TIME 15000 // 15s for DEBUG
    #define SLEEP_TIME 300000   // 5 min
    #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
    #define BATTERY_REPORT_CYCLE 2016   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
    #define VMIN 1900
    #define VMAX 3300
    #define AVERAGES 2
    int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
    int measureCount = 0;
    float lastTemperature = -100;
    int lastHumidity = -100;
    HTU21D humiditySensor;
      DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
      DEBUG_PRINT("Voltage: ");
      DEBUG_PRINT(readVcc());
      DEBUG_PRINTLN(" mV");
      delay(500);
      DEBUG_PRINTLN(" *C");
      gw.begin(NULL, NODE_ID);
      gw.sendSketchInfo("TempHumTest2", "1.0 17052016");
      gw.present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
      DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
      raHum.clear();
      humiditySensor.begin();
      measureCount ++;
      batteryReportCounter ++;
      bool forceTransmit = false;
      if (measureCount > FORCE_TRANSMIT_CYCLE) {
        forceTransmit = true;
      // Read and print internal temp
      float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
      DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
      // Check battery
      if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
        long batteryVolt = readVcc();
        DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
        uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
        DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
        batteryReportCounter = 0;
      gw.sleep(SLEEP_TIME);
    // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
    long readVcc() {
    // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
    double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
      unsigned int wADC;
      double t;
      // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
      ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
      ADCSRA |= _BV(ADEN);  // enable the ADC
      delay(20);            // wait for voltages to become stable.
      ADCSRA |= _BV(ADSC);  // Start the ADC
      while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
      wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
      t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
      return (t);   // The returned temperature in degrees Celcius.
     * Parameters
      bool tx = force;
      float temperature = humiditySensor.readTemperature();
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
        gw.send(msgTemp.set(temperature,1));
        measureCount = 0;
        DEBUG_PRINTLN("T sent!");
      int humidity = humiditySensor.readHumidity();
      raHum.addValue(humidity);
      if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
        gw.send(msgHum.set(humidity));
        lastHumidity = humidity;
        measureCount = 0;
        DEBUG_PRINTLN("H sent!");
  • @LastSamurai thanks, progress, I'm getting this now, which means it's working! Finally, a working node from a complete rookie like me!
    Serial started
    Voltage: 3389 mV
    Internal temp: 266.00 *C
    send: 100-100-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
    send: 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-100 s=255,c=3,t=15,pt=0,l=2,sg=0:
    sensor started, id=100, parent=0, distance=1
    send: 100-100-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,st=fail:TempHumTest2
    send: 100-100-0-0 s=255,c=3,t=12,pt=0,l=12,sg=0,st=fail:1.0 17052016
    send: 100-100-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
    send: 100-100-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=fail:
    Node and 2 children presented.
    T: 998.00
    TempDiff :1098.00
    send: 100-100-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:998.0
    T sent!
    H: 118
    HumDiff  :218.00
    send: 100-100-0-0 s=1,c=1,t=1,pt=2,l=2,sg=0,st=ok:118
    H sent!
    Battery voltage: 3359 mV
    Battery percent: 104 %
    send: 100-100-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:104
    I think that the readings are not accurate though, not sure why, but I'll have a go at figuring our why anyway!
    @rsachoc
    Congrats !!!
    @GertSanders Thx a lot for your help! I had no clue about the HTU21D lib.
  • so with the correct library there is no need to solder those 3 spots together!?
    @siod
    The "spots" are there to connect the pullup resistors to the SDA and SCL lines. This is always needed, regardless of the library of the board onto which you connect the sensor board does not provide pullup resistors itself. On a minimal board like the one in this thread, this is not the case, so the pull up resistors are needed.
  • ok, thanks for making it clear for me Gert!!
    update:
    finally found time to build my sensor and it seems to work fine, will do more testing but for now my results are:
    7.5 uA when sleeping, 15,3 mA when working (every 15 minutes for about 2seconds, but I think my cheap multimeter gives bad readings on those spikes, I guess it´s only around 1 mA)
    seems to be okay, isn´t it?
    edit:
    I have 2 reed switches attached. I recognized that I have +0,10 mA for each reed switch when activated. So when reed switches are both touching their counterpart I have a sleeping consumption of 0,20 mA. Why is that??
    I'm trying to convert existing Si7021 sensor code from 1.5 to 2.0.0 library. I change the code and then I was getting an error which said:
    Si7021_sensor_MySensors_2.0.0:158: error: 'si7021_env' has no member named 'humidityPercent'
    exit status 1
    Then I chech the Si7021 library, and how I saw there wasn't member 'humidityPercent', but there was a member 'humidityBasisPoints'.
    So I change line from:
    ...to:
      int humidity = data.humidityBasisPoints;
    Then code compiles and I upload it to Slim Node Si7021. I leave sensor and today I checked it log on Domoticz. I have this:
    Temperature looks ok, but Humidity value jumping a lot, thats why I don't want to believe it is true.
    Could someone, who has a 2.0.0 library and Si7021 sensor chech is it same situation? Becose I have only one Si7021 sensor.
    Maybe someone could look also on the code and say if I convert it right?
    Converted code:
    by m26872, 20151109
    #define MY_NODE_ID 5             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
    #define MY_BAUD_RATE 115200
    #include <SI7021.h>
    //#define DEBUG
    #ifdef DEBUG
    #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
    #define VMIN 1900
    #define VMAX 3300
    #define AVERAGES 2
    SI7021 humiditySensor;
      sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
      DEBUG_SERIAL(115200);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
      delay(500);
      raHum.clear();
      measureCount ++;
      // Check battery
      sleep(SLEEP_TIME);
    long readVcc() {
      unsigned int wADC;
      double t;
     * Parameters
      bool tx = force;
      float temperature = data.celsiusHundredths / 100.0;
        measureCount = 0;
        measureCount = 0;
    Thank You!
    @jacikaas where did you get the si7021 library? Take a look at the sensebender sketch for a good reference.
  • @AWI
    I download Si7021 library from here: https://github.com/LowPowerLab/SI7021
    I was heard about Sensbender node, but never look deeper what is in it. I will look at it and try to understand whats in there. I just learning about all that stuff, so it will be good practice 😊
    @jacikaas that's the way to go. The sensebender sketch contains some rather nice best practices for low power. You best replace the si library with the one in the MySensors examples on github.
  • @AWI I try to replace library from this one https://github.com/LowPowerLab/SI7021 to this one https://github.com/mysensors/MySensorsArduinoExamples
    to work it I need to return variable name from:
    to:
    I think this library https://github.com/LowPowerLab/SI7021 was updated, so it is not suitable for this one code. Now I test it again and everything looks fine:
    Temperature and humidity node unregister or stop working repeatedly for about 2 hours (2h25min, 2.20, 1.50...). But after that it start to send data again, for some time and then goes around again. 🙂 I will try to understand why it happening too.
  • I am trying to build the code using the HTU21D sensors. This built fine under 1.4 and 1.5 but now under v2 of MySensors I am getting this error:
    C:\Users\wergeld\Documents\Arduino\SlimNodeSi7021\SlimNodeSi7021.ino:4:24: fatal error: MySensor.h: No such file or directory
    compilation terminated.
    exit status 1
    Error compiling for board APM Optiboot internal 1MHz noBOD 9600baud.
    Okay, so I change my reference to:
    And I get this lovely error:
    In file included from C:\Users\wergeld\Documents\Arduino\SlimNodeSi7021\SlimNodeSi7021.ino:4:0:
    C:\Users\wergeld\Documents\Arduino\libraries\MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    exit status 1
    So, other than slamming my head against my desk how can I solve this?
  • Well, I solved it by modifying the code to 2.0 spec. Good lord I need sleep. 😧
    Working on debugging temp outputs now to Ethernet Gateway running on my Uno. Or I will sleep...
  • Okay, I now have a soldered node and serial gateway setup to my laptop for testing. It presents the sensor node! The name and available sensors is correct. Howevr, it never sends any message payload with temp/hum or battery values. I am using the HTU21D without soldering those 3 pads on it together. I need to get myself a 3.3v FTDI cable so I can serially debug I guess. But, still! Progress.
  • After soldering the 3 pads on the HTU21D I am now reading data and it is being sent to my test serial gateway. Need to measure current usage but at least it is functional.
  • Okay, seeing something odd. The force transmit does not appear to be working.
    Here is my current sketch:
    #include <MyConfig.h>
    by m26872, 20151109
    //#include <MySensors.h>
    //#define DEBUG
    #ifdef DEBUG
    #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
    #define VMIN 1900
    #define VMAX 3300
    #define AVERAGES 2
    //MySensor gw;
      sendSketchInfo("HTU21D", "1.0");
      delay(500);
      //gw.begin(NULL,NODE_ID);
      //sendSketchInfo("HTU21D", "1.0");
      //present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
      //present(CHILD_ID_HUM, S_HUM);
      raHum.clear();
      measureCount ++;
      // Check battery
      sleep(SLEEP_TIME);
    long readVcc() {
      unsigned int wADC;
      double t;
     * Parameters
      bool tx = force;
        measureCount = 0;
        measureCount = 0;
    I am at 1+ hours since last transmission.
    @wergeld It looks like it's set to 3 hrs.
  • @m26872
    Indeed it does. Just was throwing me off with the wording. I read it as "1/2 hour" or "1/3 hour". So far I am prepping up more nodes. Have 4 more 328s to programs and build out. I am thinking at the end I will have:
    1. Gateway (serial or the direct connect nrf+ once it supports v2)
    2. Temp/Hum node using HTU21D for back porch sending every 5 minutes and force send every 30 minutes.
    3. Temp/Hum node using HTU21D inside using same send times.
    4. Parking sensor in garage hardwired to mains.
      5 & 6 I am not sure yet.
    Lots of fun so far.
  • I am seeing 5.0 μA at sleep and 12.4 mA when transmitting. Seems kind of high. I did the poor man's test as well - put an LED across the HTU21D power pins and it lit up. Same when I did it across the nrf's power pins. Shouldn't the MySensors code turn off the power rails during sleep?
    @wergeld
    No, the powerrails are not turned off, just the devices themselves.
    5uA during sleep is about right. The 12.4mA during transmit is also normal, but the transmit time should be very short, so on average the total consumption of power will be low.
  • @GertSanders Excellent! I was hoping I hadn't wired it up wrong. So far the 2 nodes have been flawless for the past 3 days. Next step is to await the direct attached NRF serial gateway to be v2 compatible. Been following along with this thread. Looks like we are getting closer! I have 2 RPis (one a first gen B and the other a Pi2 B ) with this adapter by ceech:
    https://www.openhardware.io/view/100/Raspberry-PI-NRF24l01-hat
  • Hi everyone,
    First thanks for sharing. I love this slim node. But I am facing some issues I did not success to debug. So I use the code shared here for mysensors 2. I try with the mysensors exemple library (did not work at all). I try with the https://github.com/LowPowerLab/SI7021 which worked (at least for getting separately temperature and humidity and using the example file) on an arduino nano. But when I run this sensor with the slim node (red, boot loader 8mhz) and the code (for 2.0.0) I always get -46.85 for temperature and 118 for humidity. Otherwise the radio work normally.
    Winter is coming and I don't know what I could do anymore. Thanks to share you idea on this.
    With the example code I use on the nano. I get with the slim node:
    T: -46.85
    H: 118
    device ID: 50
    With Arduino nano:
    T: 24.34
    H: 43
    device ID: 50
  • Why actually my device id is 50 ? for what 50 stands !?!?!
    @clempat Please post your sketch and maybe some hardware photo or diagram too.
  • @m26872 Sure I can do that. So I simplified the code to only focus on the si7021.
    Here it is: https://github.com/clempat/example-si7021
    And there the photo:
    @clempat Don't think I can help you. Maybe clock related. What voltages do you use on Nano and Slim respectively? Do you have multiple parts to try with and get the same result? Why do you include and start wire.h, isn't already in Si7021.h ? My guess on "device Id 50" is that it's just a chinese clone reply.
    Photos look nice btw. 👍
  • @m26872 Thank you. Yes I wanted to try with a pro mini 8Mhz but I need to prepare the pin 4 and 5. I will keep inform when I do it this week end.
    Thanks for the picture but with this nice setup it is difficult to make it bad :)...
    I includes wire.h like in the exemple in https://github.com/LowPowerLab/SI7021 but of course after I tried without. The nano was directly connected to usb and the slim through 3,3V USB to serial.
  • Ok with the arduino micro 8Mhz all works good too.
    Reading...
    T: 20.29
    H: 54
    device ID: 50
  • So sad I still not getting it working with the slim node 😞 !!! Always same result either with internal 1mhz or 8mhz...
    @clempat Make it with external 8MHz then ? Then it should be like a Pro Mini 3.3V.
  • @m26872 I will give a try and let you know... Thanks.
  • Hello
    I also have big problems with getting the node to send temp and hum values
    It starts up and presents itself to the GW but then nothing happens
    I have tested the SI721 module with a simple arduino code and then it reads and prints both values just fine
    My code is below, in practice its a version of Sensebender Micro code. I have changed the force transmit value to 1
    Exactly as @clempat I have tried both 1MHz optiboot and 8MHz internal oscillator without any success
    * Version 1.0 - Thomas Bowman MC8rch
    * Version 1.3 - Thomas Bowman MC8rch
    * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
    * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
    * Version 1.4 - Thomas Bowman MC8rch
    * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
    * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
    * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
    // Define a static node address, remove if you want auto address assignment
    //#deine MY_NODE_ID 3
    #include <SI7021-master\SI7021.h>
    // Uncomment the line below, to transmit battery voltage as a normal sensor value
    #define BATT_SENSOR    199
    #define RELEASE "1.4"
    #define AVERAGES 2
    // Child sensor ID's
    #define CHILD_ID_TEMP  1
    #define CHILD_ID_HUM   2
    #define FORCE_TRANSMIT_INTERVAL 1
    // Sensor messages
    #ifdef BATT_SENSOR
    MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
    // Global settings
    int sendBattery = 0;
    boolean isMetric = true;
    boolean highfreq = true;
    boolean transmission_occured = false;
    long lastBattery = -100;
    * Setup code
    	Serial.begin(9600);
    	Serial.print(RELEASE);
    	Serial.flush();
    	Serial.flush();
    	isMetric = getConfig().isMetric;
    	Serial.print(F("isMetric: ")); Serial.println(isMetric);
    	raHum.clear();
    	sendTempHumidityMeasurements(false);
    	sendBattLevel(false);
    	sendSketchInfo("TempHum", RELEASE);
    #ifdef BATT_SENSOR
    	present(BATT_SENSOR, S_POWER);
    *  Main loop function
    	measureCount++;
    	sendBattery++;
    	if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
    		measureCount = 0;
    	/*  if (sendBattery > 60)
    	sendBattLevel(forceTransmit); // Not needed to send battery info that often
    	sendBattery = 0;
    	sleep(MEASURE_INTERVAL);
    * Parameters
    	bool tx = force;
    	raHum.addValue(data.humidityPercent);
    	Serial.print(F("TempDiff :"));Serial.println(diffTemp);
    	Serial.print(F("HumDiff  :"));Serial.println(diffHum);
    	if (isnan(diffHum)) tx = true;
    	if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
    	if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
    	if (tx) {
    		measureCount = 0;
    		float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
    		Serial.print("T: ");Serial.println(temperature);
    		Serial.print("H: ");Serial.println(humidity);
    		transmission_occured = true;
    		if (sendBattery > 60) {
    			sendBattLevel(true); // Not needed to send battery info that often
    			sendBattery = 0;
    * Parameters
    	if (force) lastBattery = -1;
    	long vcc = readVcc();
    	if (vcc != lastBattery) {
    		lastBattery = vcc;
    #ifdef BATT_SENSOR
    		float send_voltage = float(vcc) / 1000.0f;
    		send(msgBatt.set(send_voltage, 3));
    		// Calculate percentage
    		long percent = vcc / 14.0;
    		sendBatteryLevel(percent);
    long readVcc() {
    It would be interesting if someone with issues also tried older versions of libs for Si7021 and/or MySensors.
  • So, after a few months of 2 nodes up and running using the HTU21D sensor I have come the conclusion that the HTU21D is no good for where I live. Lately it has been getting cooler outside (down to mid 50s F) but humidity is still high. As the evening progresses the humidity gets to 100% and the node no longer sends data. This happens around 6pm every day (about half and hour after sunset). It then comes back online at about 10 am the next day. The node that I have inside does not have this issue (same shipment of arduino, pcb, and HTU21D sensors and the same arduino code). Both running off of fresh AAs. May need to upgrade to the SI7021 for outside node.
    Here is the graph showing last 7 days. As you can see it flatlines (literally!) at 100% humidity!
    All good times with the learning!
    @wergeld Relative humidity at 100% during night sounds very realistic to me. Are you confusing it with the "absolute humidity"? Or is your concern that the "force transmit" isn't working?
  • Mine does the same, but it's also very humid at night - I think this is normal behavoir
  • @m26872 & @bjacobse - Yes, 100% humidity is normal here. Good old Florida! My concern is that the node stops reporting. Possibly due to condensation shorting out something. During the summer here we also hit 100% humidity but it is also a lot hotter (high 90s). Now, I think that the cooler temps are forcing a dew point that is allowing water to condense on the node. Then during the morning it drys out and resumes transmitting. I would like to find a way to stop this.
  • @m26872 I have looked at a lot of those links. I am leaning towards covering my node in non-reactive glue. This will seal all contacts. The only part that would be difficult would be the actual teeny tiny sensor chip on the HTU21D. Hopefully any condensation there can be minimal. The next step would be to make sure the battery case is sealed as well (although I do not think this will be much of an issue).
  • Do you have some battery saving stuff in your code, so you maybe wakeup check temp + humidity, and if they are same value as previous, then go back to sleep - no need to use battery usage to send same values again, this can cause your sensor to not report values
  • @bjacobse Yes, I am checking the values and if the same as last transmission I abort and go back to sleep. If, however, it has been 3 hours since last transmission I force it to send.
  • I've done 6 nodes off this sensor. Do I have to change something else then node id? Also I'm using the 1mhz bootloader with bud rate 9200 should I change that in the sketch?
    Seems like I only get the temprature and humidity once on first start up...
    Edit:
    I think my problem is that I haven't changed the bud rate in mysensors.h file. I've just reinstalled everything now and I don't know how to get si7021 installed the right way. I installed the package inside arduino but it doesn't work.
    I such a noob sorry guys
  • I have problem to get my sensors to work. Thay start up and shows a not so accurate value sometimes and thay report once or twice but then never again. I thought it was because buad rate was wrong in the MyConfig.H file. Now i changed that and i tried a few different codes and librarys. Nothing seems to work.
    So my question is which code and library should i use?
    I got the slim node and sensor as in the first post.
    Im running 1mhz optiboot bootloader from the slim node thread
    And i updated mysensors to 2.1.
    @Eawo Sorry for a late reply. Please post your sketch to begin with.
    Do you have v2.1 for both gateway and sensors?
    "#define MY_BAUD_RATE 9600" should be before the "include MySensors.h" and that should be all regarding baud rate setting. No need to mess with MyConfig.h in v2.x.
    A lot of the SlimNode example codes are still in v1.x unfortunately. So please look at more recent post above in this thread instead for v2.x.
    To verify the Si7021 you should use a clean Arduino+Si7021 setup with the only hw/sw needed for that, i.e. no radio or MySensors-library. Si7021-example sketches generally comes with the lib.
  • Ok i redid everything from skratch and now i got it working atleast with 1 node havnt tried the other yet.
    I used the code miljume did link the only line i changed was
    to
    #include <SI7021.h>
    It is working but it shows up as 2 nodes in domoticz
    1401 0 TempHum Temp + Humidity WTGR800 20.9 C, 35 % 2017-01-19 17:59:05
    1400 0 TempHum Temp + Humidity WTGR800 20.7 C, 34 % 2017-01-19 17:59:05
    anyone know why?
    also this does report every 60sec will this be short battery life?
  • @Eawo Domoticz groups sensors after the order you present them in, see: https://forum.mysensors.org/topic/5132/ds18b20-ans-sht31-d-show-up-as-combined-sensors-on-domoticz/15
    I send every 5 minutes and check the value before so that I only send if the value has changed
    I have been running my sensor for nearly 2 months now and battery level has only decreased 1-2%
    Make sure you use 1 MHz bootloader
