Interrupt and sleep
    I have been tinkering with MySensors and Arduino in the last few weeks, and now I have started to come out with a Domoticz controller, a NRF24L01+ Ethernet gateway and a sensor node that is running on a MEGA2560 just as prototype (later I'll use some Arduino Mini or similar boards) since it has much more pins to play with. So far I have connected ad PIR sensor and a crappy DHT11 just to get some values running. The problem I have now is the last line of the code, as it seems the arduino always sleeps for 10 seconds and does not quickly send the triggered PIR event. Could you pls advise if anything is wrong? I pretty much copied and merged code from examples and it is still not very clean but it should be fairly simple.
    #define MY_NODE_ID 2
    // Enable debug prints
    //#define MY_RS485
    // Pin Confuguration for Arduino Mega
    #define MY_RF24_CE_PIN 40
    #define MY_RF24_CS_PIN 53
    #define DHT_DATA_PIN 4
    #define SENSOR_TEMP_OFFSET 0
    #define SENSOR_HUM_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds)
    #define CHILD_ID_PIR 0   // Id of the sensor child
    #define CHILD_ID_HUM 1
    #define CHILD_ID_TEMP 2
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    MyMessage msgPIR(CHILD_ID_PIR, V_TRIPPED);
    DHT dht;
    	sendSketchInfo("PIR_TemperatureAndHumidity", "1.0");
    	present(CHILD_ID_PIR, S_MOTION);
    	present(CHILD_ID_HUM, S_HUM);
      // Read digital motion value
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
      send(msgPIR.set(tripped?"1":"0"));  // Send tripped value to gw
    	dht.readSensor(true);
    	if (isnan(temperature)) {
    	else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS) {
    		lastTemp = temperature;
    		if (!metric) {
    		// Reset no updates counter
    		nNoUpdatesTemp = 0;
    #ifdef MY_DEBUG
    		Serial.print("T: ");
    	else {
    		nNoUpdatesTemp++;
    	if (isnan(humidity)) {
    	else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS) {
    		lastHum = humidity;
    		nNoUpdatesHum = 0;
        humidity += SENSOR_HUM_OFFSET;
    #ifdef MY_DEBUG
    		Serial.print("H: ");
    		Serial.println(humidity);
    	else {
    		nNoUpdatesHum++;
    	//sleep(UPDATE_INTERVAL);
    Similar but not the same since I don't have crashes, just it is just ignoring interrupt and sleeping 10 seconds every time.
    @gohan seems like we aren't reading the same thing. I don't see anyhing about a crash, only about interrupt not firing.
    Are you referring to the sleep(0xff,0x00, 0xff, 0x00, 0)?
    @gohan no. I am referring to "For some reason I am unable to get the board to respond to pin change interrupts when using MySensors gw.sleep() using the MotionSensor.ino" in the first post in the thread I linked to.
  • From your description it sounds like your problem is pretty much exactly same as mine was when I started that thread. I have not experienced any crashes. The issue is just that the board does not wake up on CHANGE. Have you tried using LOW instead of CHANGE for sleep? There were comments in the aforementioned thread that this might be an issue with a certain version of Arduino and boards file. Have not yet had time to investigate tough.
    @elysion
    I have updated IDE to latest version and I got a change: now it takes a variable time between 30 sec to 2 minutes for the motion sensor to restore to "0" .
    If I set it to LOW it just skips the sleep as I see continuously errors from reading from the DHT11 sensor until I trigger the motion sensor. Changing it to HIGH or CHANGE I get the same result. Now it's late, so maybe tomorrow I'll try downgrading IDE and boards to 1.6.8 as suggested in another thread.
    Downgraded to 1.6.8 IDE and boards but no change, also tried to compile it in Visual Studio but behavior is the same. Maybe the Mega has some issues that other boards don't have?
    Here is log
    5079 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
    5107 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
    5112 MCO:SLP:TPD
    5113 MCO:SLP:WUP=1
    5118 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
    5149 TSF:MSG:SEND,2-2-0-0,s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.9
    T: 20.94
    5156 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
    5160 MCO:SLP:TPD
    5163 MCO:SLP:WUP=-1
    5168 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
    5196 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
    5200 MCO:SLP:TPD
    5202 MCO:SLP:WUP=-1
    5208 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
    5238 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:20.0
    H: 20.00
    5244 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
    5250 MCO:SLP:TPD
    5252 MCO:SLP:WUP=-1
    5256 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
    5284 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
    5289 MCO:SLP:TPD
    5291 MCO:SLP:WUP=1
    5298 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
    5326 MCO:SLP:MS=10000,SMS=0,I1=1,M1=1,I2=255,M2=255
    5331 MCO:SLP:TPD
    As you can see when motion is triggered (the "1" on 5th line) it takes a while for it to go back to "0" and each message is 10 seconds from the previous like it is ignoring the interrupt.
    I'm running out of options besides buying a few Pro Mini and start building a definitive sensor
    @gohan - any change if you try to change the trigger delay on the motion sensor?
    No, I tried to move it around but it doesn't change the behavior in this case.
  • ahhhhhhhhhhhh - I created a door/window sensor some weeks ago - but I couldn't make it run to fire an interrupt on pin change (INT0 and INT1 are used to connect external magnetic sensors) - today I decided to work on this issue again and found this topic at the forum - so I downgraded my arduino IDE by downloading v1.6.8 from arduino.cc today - compiled my code again - falshed it - and voilà - it works
    That is really frustrating by wasting that many hours of time only by inconsistancy with compiler/board definitions.
    Is there any need to update to newer arduino-IDE - otherwise I would recommend to general stick to one version ...
    @JoergP
    Would you mind posting board version you are using and also your code? Did some test but I couldn't figure out anything on my mega so probably there is also something about that kind of board, so I didn't spend too much time on it and wait for the other minis I ordered
  • I checked the used versions - as I already wrote the used arduino-IDE is 1.6.8. But due to the case that I used 1.8.0 before and downgraded the board definition by "Board manager" the board definition is 1.6.11 (if you down/upgrade by BoardManager you can find the files in dir "C:\Users...\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11"
    I added my own definitions to board.txt (because I use 2AA Battery node -> https://www.openhardware.io/view/10/My-Slim-2AA-Battery-Node)
    here my quick and dirty source - have to clean up if it works as expected:
    // based on 2AA Battery Node
    // ATMEGA328P (@ internal OSC 1MHz)
    // device ID = 0x07D5 (2005d )
    // 0  - Input 0 -> S_DOOR / V_TRIPPED
    // 1  - Input 1 -> S_DOOR / V_TRIPPED
    // 2  - temperature (HTU)
    // 3  - humidity (HTU)
    // includes
    #include "Adafruit_HTU21DF.h"
    #include <Vcc.h>
    #include <avr/wdt.h>
    // MySensors
    // MySensor
    #define SN "AA - Windows / Temperature"
    #define SV "1.1"
    #define ms_input_0      0
    #define ms_input_1      1
    #define ms_temperature  2
    #define ms_humidity     3
    // used PINs
    #define PIN_INPUT_0     2
    #define PIN_INPUT_1     3
    // Sleep
    #define SLEEP_TIME 300000   // ms => 5 min
    #define VALUE_MIN_COUNT 12  // send min every 12th measurement one value (once per hour)
    // Vcc
    #define VCC_MIN 1.9
    #define VCC_MAX 3.3
    #define BATTERY_COUNT 288   // 288 * 5 min = 1 day
    // global vars
    MyMessage msg(0,0);
    Adafruit_HTU21DF htu = Adafruit_HTU21DF();
    boolean htu_available = false;
    float htu_temperature = 1000;
    float htu_humidity = 1000;
    int batteryCnt = 0;
    int temperatureCnt = 0;
    int humidityCnt = 0;;
    Vcc vcc;
    // setup
      // PINs
      pinMode(PIN_INPUT_0, INPUT_PULLUP);
      pinMode(PIN_INPUT_1, INPUT_PULLUP);
      // HTU21
      if (htu.begin())
        htu_available = true;
    // presentation
      sendSketchInfo(SN, SV);
      // Send sensor information
      present(ms_input_0, S_DOOR);
      present(ms_input_1, S_DOOR);
      if(htu_available) {
        present(ms_temperature, S_TEMP);
        present(ms_humidity, S_HUM);
    // loop
      // enable watchdog
      wdt_enable(WDTO_8S);
      // inputs
      sendInput0();
      sendInput1();
      // check battery
      if(batteryCnt == 0)
        sendBatteryReport();
      batteryCnt++;
      if(batteryCnt > BATTERY_COUNT)
        batteryCnt = 0;
      // temperature
      if(htu_available) {
        sendTemperature();
        sendHumidity();
      // sleep
      delay(500);
      wdt_disable();
      sleep(digitalPinToInterrupt(PIN_INPUT_0), CHANGE, digitalPinToInterrupt(PIN_INPUT_1), CHANGE, SLEEP_TIME);
    // helper functions
    float rfloat(float val, unsigned int num) {
      if(num) {
        float f = 10.0 * num;
        return round(val*f)/f;
        return round(val);
    void sendTemperature() {
      wdt_reset();
      float tmp = htu.readTemperature();
      if(tmp < 900){ // check errors
        tmp = rfloat(tmp, 1);
        if((tmp != htu_temperature) || (temperatureCnt >= VALUE_MIN_COUNT)){
          htu_temperature = tmp;
          send(msg.setSensor(ms_temperature).setType(V_TEMP).set(htu_temperature,1));
          temperatureCnt = 0;
          temperatureCnt++;
    void sendHumidity() {
      wdt_reset();
      float tmp = htu.readHumidity();
        tmp = rfloat(tmp, 0);
        if((tmp != htu_humidity) || (humidityCnt >= VALUE_MIN_COUNT)){
          htu_humidity = tmp;
          send(msg.setSensor(ms_humidity).setType(V_HUM).set(htu_humidity,0));
          humidityCnt = 0;
          humidityCnt++;
    void sendBatteryReport() {
      wdt_reset();
      delay(500);
      float p = vcc.Read_Perc(VCC_MIN, VCC_MAX, true);
      int batteryPcnt = static_cast<int>(p);
    void sendInput0() {
      wdt_reset();
      if(digitalRead(PIN_INPUT_0) == HIGH)
        send(msg.setSensor(ms_input_0).setType(V_TRIPPED).set(0));
        send(msg.setSensor(ms_input_0).setType(V_TRIPPED).set(1));
    void sendInput1() {
      wdt_reset();
      if(digitalRead(PIN_INPUT_1) == HIGH)
        send(msg.setSensor(ms_input_1).setType(V_TRIPPED).set(0));
        send(msg.setSensor(ms_input_1).setType(V_TRIPPED).set(1));
    What does this do?
    Tests so far are just as the same as before even with the changes you suggested, so I believe I'll just wait for the other new arduinos and use the mega for other purposes
  • That's bad - if you like you can send me your source and I can try to compile it on my environment.
    I use the watchdog in general - in the past I had the issue that some nodes stopped working without any reason - watchdog helped to solve this
    Look at my first post, that's the code. It's a draft so it's not really cleaned up
  • @JoergP ans others, I have tried versions 1.6.8 and the board definitions 1.6.11 and interrupt seems to work but in the case of using a PIR the sensor somehow seems to be triggered when going out of sleep due to time...
  • @Efflon I'm not sure what exactly you mean - do you refer to my code? In that case this is a quick and dirty try - I'll send at every pin change and at timeout the input values ...
    My mega goes to sleep for the time specified, but it doesn't wake up when pir is triggered
  • @JoergP Sorry, what I meant was regarding the versions you were using to get your sensor to work. I've been fighting to get interrupts to work for a day and your suggestion helped.
    Now it's just that going out of sleep triggers the PIR, then it goes for sleep and wakes up immediately and then finally goes to sleep ... gahh
    Tripped: 0
    13207 MCO:SLP:MS=30000,SMS=0,I1=1,M1=3,I2=255,M2=255
    13213 MCO:SLP:TPD
    13217 MCO:SLP:WUP=-1
    interrupt: -1
    Tripped: 0
    Tripped: 1
    Tripped: 1
    Tripped: 1
    Tripped: 1
    interrupt: -1
    Tripped: 1
    Tripped: 0
    Tripped: 0
    Tripped: 0
    Tripped: 0
    14024 MCO:SLP:MS=30000,SMS=0,I1=1,M1=3,I2=255,M2=255
    14032 MCO:SLP:TPD
    14034 MCO:SLP:WUP=1
    interrupt: 1
    Tripped: 0
    Tripped: 0
    Tripped: 0
    Tripped: 0
    Tripped: 0
    14440 MCO:SLP:MS=30000,SMS=0,I1=1,M1=3,I2=255,M2=255
    14446 MCO:SLP:TPD```
  • hmmmm .... I'm not so familiar with the arduino build process - I guess that Interrupt Request registers are not reset correctly, but never did that manual with Arduino
    I use following board setting
    AAnode1.name=AA sensor node (1MHz int)
    AAnode1.upload.tool=avrdude
    AAnode1.upload.protocol=arduino
    AAnode1.upload.maximum_size=32256
    AAnode1.upload.speed=9600
    AAnode1.bootloader.tool=avrdude
    AAnode1.bootloader.low_fuses=0x62
    AAnode1.bootloader.high_fuses=0xde
    AAnode1.bootloader.extended_fuses=0x07
    AAnode1.bootloader.path=optiboot_v50
    AAnode1.bootloader.unlock_bits=0x3F
    AAnode1.bootloader.lock_bits=0x2F
    AAnode1.build.mcu=atmega328p
    AAnode1.build.f_cpu=1000000L
    AAnode1.build.core=arduino
    AAnode1.build.variant=standard
    AAnode1.build.board=AVR_AANODE_1MHz
    I guess the xxx.build.xxx settings are of interest - do you use the same or do you have different?
  • @JoergP Don't know. I just select "mini pro" from within Arduino IDE.
    I'll create a new trouble shooting topic with my problem since this is going out of topic.
  • my 2 cents :
    Why are you doing a sleep into setup method?
    why not using wait method instead?
    I understand that you'd like switch in sleep mode after a loop, but this doesnt sounds natural to do this during "initializing" step.
    if you remove sleep from setup, do you still have your issues?
    moreover, i've read somewhere that smartsleep methode gives messages time to be sent before sleeping (i'm not absolutly sure about this, i cannot find anymore the place where i've read that).
    bool smartSleep(uint8_t interrupt, uint8_t mode, unsigned long ms=0)
    @params:
    • interrupt: Pin that should trigger the wakeup
    • mode: RISING, FALLING, CHANGE
    • ms: Number of milliseconds to sleep or 0 to sleep forever
    @return: True if wake up was triggered by pin change and false means timer woke it up.
    at last : you can wait for an aknownledge, it'll be slower but you'll be sure that message is sent before going to the next line of code...
    i did not test it yet, but it would be something like this :
    bool ack = true;
    send(myMsg.set(avalue), ack );
    if(!wait(2000,V_TEMP , mymsg.getType());)
         Serial.println("timeout after 2 secs");
    @giovaFr
    if you are referring to
    that was straight from the example of the DHT11 sensor.
18
