SCT-013-030 current monitor sensor
    this code is for three, first one is wired on A3 / A0, second A4/A1 and third on A5/A2
  • Yes, I've understand this but how is it possible to wire on A3 and A0 with only two wires ? Where is connected the VCC ?
    I've used this : http://openenergymonitor.org/emon/buildingblocks/how-to-build-an-arduino-energy-monitor-measuring-current-only
  • Ahhh ! Ok.
    That why there is A3 and A0 in use !
    I'll digg into the voltage input to know how it's working.
    Thank you.
  • I've change the code to only use A0 for CT sensor.
    It's not plug in the cable, it's for testing.
    Here is the output in arduino serial console :
    sensor started, id 2
    send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
    send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    read: 2-1-0 s=255,c=3,t=6,pt=1,l=1:0
    read: 0-0-2 s=255,c=3,t=6,pt=0,l=1:M
    send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Energy Meter
    send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:2.0
    send: 2-2-0-0 s=0,c=0,t=13,pt=0,l=5,st=ok:1.4.1
    read: 2-1-0 s=0,c=0,t=13,pt=0,l=5:1.4.1
    0.00 0.00 0.00 69.60 nan
    0.00 0.00 0.00 62.07 nan
    0.00 0.00 0.00 55.65 nan
    0.00 0.00 0.00 48.57 nan
    0.00 0.00 0.00 40.78 nan
    0.00 0.00 0.00 35.21 nan
    0.00 0.00 0.00 30.80 nan
    0.00 0.00 0.00 24.84 nan
    0.00 0.00 0.00 19.95 nan
    0.00 0.00 0.00 16.46 nan
    send: 2-2-0-0 s=0,c=1,t=24,pt=7,l=5,st=ok:0.0
    send: 2-2-0-0 s=0,c=1,t=25,pt=7,l=5,st=ok:0.0
    send: 2-2-0-0 s=0,c=1,t=26,pt=7,l=5,st=ok:NAN
    send: 2-2-0-0 s=0,c=1,t=27,pt=7,l=5,st=fail:0.0
    send: 2-2-0-0 s=0,c=1,t=28,pt=7,l=5,st=fail:16.5
    0.00 0.00 0.00 13.53 nan
    0.00 0.00 0.00 11.34 nan
    0.00 0.00 0.00 9.73 nan
    0.00 0.00 0.00 8.11 nan
    0.00 0.00 0.00 6.84 nan
    0.00 0.00 0.00 5.72 nan
    0.00 0.00 0.00 4.71 nan
    0.00 0.00 0.00 3.90 nan
    0.00 0.00 0.00 3.18 nan
    0.00 0.00 0.00 2.61 nan
    send: 2-2-0-0 s=0,c=1,t=28,pt=7,l=5,st=fail:2.6
    0.00 0.00 0.00 2.22 nan
    0.00 0.00 0.00 1.97 nan
    0.00 0.00 0.00 1.76 nan
    0.00 0.00 0.00 1.62 nan
    0.00 0.00 0.00 1.51 nan
    0.00 0.00 0.00 1.40 nan
    0.00 0.00 0.00 1.26 nan
    0.00 0.00 0.00 1.13 nan
    0.00 0.00 0.00 0.99 nan
    0.00 0.00 0.00 0.85 nan
    send: 2-2-0-0 s=0,c=1,t=28,pt=7,l=5,st=fail:0.8
    0.00 0.00 0.00 0.74 nan
    0.00 0.00 0.00 0.65 nan
    0.00 0.00 0.00 0.57 nan
    0.00 0.00 0.00 0.50 nan
    0.00 0.00 0.00 0.40 nan
    0.00 0.00 0.00 0.33 nan
    0.00 0.00 0.00 0.29 nan
    0.00 0.00 0.00 0.25 nan
    0.00 0.00 0.00 0.23 nan
    0.00 0.00 0.00 0.20 nan
    send: 2-2-0-0 s=0,c=1,t=28,pt=7,l=5,st=fail:0.2
    0.00 0.00 0.00 0.19 nan
    0.00 0.00 0.00 0.16 nan
    0.00 0.00 0.00 0.13 nan
    0.00 0.00 0.00 0.14 nan
    0.00 0.00 0.00 0.11 nan
    0.00 0.00 0.00 0.09 nan
    There are some fail, is it normal ?
  • I starting to understand.
    The SCT-013-030 is used only to get Ampere, nothing more ? Is it correct ?
    If I want the Watt I need more sensors connected to the arduino, right ?
    @chatainsim, if you know the Voltage, just multiply the voltage by the amperage and you will have the wattage...
    http://en.wikipedia.org/wiki/Ohm's_law
  • In Emonlib you have example to measure watt etc. without measure voltage.
    https://github.com/openenergymonitor/EmonLib
  • @rvendrame Thanks, I will try this.
    @maglo18 I will try to use some example.
    First I need to check if my sketch and my assemble works at least.
    Thanks for your help. I think I will need more from you guys !
  • Hello guys,
    I've working on my sensor.
    It's seems working, but I have some trouble with Watt or Kwh.
    Here is the sketch:
    // EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3  ***/
    #include "EmonLib.h"             // Include Emon Library
    EnergyMonitor emon1;             // Create an instance
    #define CHILD_ID 0
    unsigned long lastSend;
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    MyMessage IrmsMsg(CHILD_ID,V_WATT);
      gw.begin();
      gw.sendSketchInfo("Energy Meter", "1.0");
      gw.present(CHILD_ID, S_POWER);
      emon1.current(A0, 29.0);       // Current: input pin, calibration.
      unsigned long now = millis();
      double Irms = emon1.calcIrms(1480);
      //emon1.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
      //emon1.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
      if (sendTime) {
        //float Irms = emon1.Irms;             //extract Irms into Variable
        gw.send(IrmsMsg.set(Irms*232.0,1));
        Serial.println(Irms*232.0);
        lastSend = now;
    I've got around 390 for the Irms*232, do you thinks it's a correct value ?
    Can I calculated the current kwh with the ampere ?
    Thank you.
    I've made some change in the code :
    #define CHILD_ID_WATT 0
    #define CHILD_ID_KWH 1
    MyMessage IrmsMsg(CHILD_ID_WATT,V_WATT);
    MyMessage kWhMsg(CHILD_ID_KWH,V_KWH);
      gw.begin();
      gw.sendSketchInfo("Energy Meter", "1.0");  // Send the sketch version information to the gateway and Controller
      gw.present(CHILD_ID_WATT, S_POWER);  // Register this device as power sensor
      gw.present(CHILD_ID_KWH, S_POWER);
      if (sendTime) {
        gw.send(IrmsMsg.set((Irms*232.0)*1000, 1));
    //    Serial.print("Watt: ");
    //    Serial.println(Irms*232.0);
        gw.send(kWhMsg.set((Irms*232.0)/1000, 1));
    //    Serial.print("kWH: ");
    //    Serial.println((Irms*232.0)/1000);
        lastSend = now;
    But in Domoticz, I've two line for this but in kWh and not on in kWh and other in Watt :
    Do you know why ?
    Regards,
    @chatainsim Domoticz does not have a different device for power (Watt) and energy(kWh) but combines them in a single device. What you need to do is send both the power and energy to the same child.
  • Thanks, but I've already test this and only the kWh is updated in domoticz, not watt.
    #define CHILD_ID 0
    MyMessage kWhMsg(CHILD_ID,V_KWH);
      gw.begin();
      gw.present(CHILD_ID, S_POWER);  // Register this device as power sensor
      if (sendTime) {
        lastSend = now;
    Can you help me with this ?
    @chatainsim I am pretty sure it is a combined device which shows Watt only when added ...:
    upload-40825a2f-8628-4412-8fdb-44b222576843
    upload-11b440e7-718e-46ae-87f1-a4eb3c913c7e
    upload-408228f1-e921-418e-bae9-db19b6d47eee
    Although I am not sure if the Domoticz MySensors plug-in handles it right (I'm still using my own script).
  • Ok, thanks.
    How do you get your watt info ? With teleinfo ?
    @chatainsim
    I send the V_Watt messages from the Power meter to Domoticz.
  • @AWI
    I also send both data but it's seems that Domoticz is ingnoring it !
    I don't know why.
    @chatainsim Sounds you like you need to consult the Domoticz forum. The Domoticz code shows that is interpreted.
    case V_WATT:
    			_tMySensorSensor *pSensorKwh = FindSensor(pSensor->nodeID, V_KWH);
    			if (pSensorKwh) {
    				SendKwhMeter(pSensorKwh->nodeID, pSensorKwh->childID, pSensorKwh->batValue, pSensor->floatValue / 1000.0f, pSensorKwh->floatValue, "Meter");
    			else {
    				_tUsageMeter umeter;
    				umeter.id1 = 0;
    				umeter.id2 = 0;
    				umeter.id3 = 0;
    				umeter.id4 = pSensor->nodeID;
    				umeter.dunit = pSensor->childID;
    				umeter.fusage = pSensor->floatValue/1000.0f;
    				sDecodeRXMessage(this, (const unsigned char *)&umeter);
    	case V_KWH:
    			_tMySensorSensor *pSensorWatt = FindSensor(pSensor->nodeID, V_WATT);
    			if (pSensorWatt) {
    				SendKwhMeter(pSensor->nodeID, pSensor->childID, pSensor->batValue, pSensorWatt->floatValue / 1000.0f, pSensor->floatValue, "Meter");
    			else {
    				SendKwhMeter(pSensor->nodeID, pSensor->childID, pSensor->batValue, 0, pSensor->floatValue, "Meter");
    		break;```
  • Does anyone have some OpenHab items and rules for @chatainsim sketch posted above? I have a SCT-013-000 can anyone help me use it in my project?
  • Hello, anybody can help me here?
    What I want to do is to get the instant watt or kW read from my SCT013000 and to get also the kWh from a certain date, let's say fro first of this month!
    Any idea will be kindly appreciated!
    I'm using openhanb to display info and I'll need some rules for this!
    Thanks all!
  • Nobody here?
  • I have got this to work on my Cdn system 120/240 vac using A0 and A1 pins. The code needed to be changed to address our voltage and another clamp added., but I do have a few questions;
    1. Is there a way I can record or view amps consumed in the vera dashboard?
    2. I used the sketch above displayed by @chatainsim and in it there are two lines of code with values 29.0 and second 1480 both in green and in brackets. For the life of me I can not find an explanation of these or how the values were arrived at. Can anyone help with explanation?
    3. Is there a method to show current in phase. I tried presenting CHILD_ID, S_MULTIMETER and MyMessage IrmsMsg(CHILD_ID,V_CURRENT); but got nowhere.
    4. There is/was much running up and down stairs from electrical panel to computer and back is OTA IDE what I think it might be-- firmware or sketches can be updated over the air from my computer>vera>gw>node while not needing to access the node? If so there is much learning for me to do.
    5. Using arduino 1.6.5, Lib 1.4.1, vera 3/veralite, ui5, Ethernet g/w , win 8.1, pro mini clone
  • Hello, last week i buy SCT013-30 (ebay.fr) and follow this topic for have powermeter with mysensors. I need only energy (kWh) and power (W) same my OWL sensors (use with domoticz controler)
    I modifie the sketch from mysensors/pulse powermeter (http://www.mysensors.org/build/pulse_power)
    #define CHILD_ID 0
    #define PIN_ANALOG_I A2
    unsigned long lastSend2;
    unsigned long SEND_FREQUENCY = 90000; // Minimum time between send (in milliseconds).
    unsigned long SEND_FREQUENCY2 = SEND_FREQUENCY / 25;
    int index = 0;
    double Irms=0;
    double power;
    boolean pcReceived = false;
    double nrj=0, old_nrj;
    MyMessage pcMsg(CHILD_ID,V_VAR1);
    void incomingMessage(const MyMessage &message)
      if (message.type==V_VAR1)
        nrj = old_nrj = message.getLong();
        Serial.print("Received last nrj count from gw:");
        Serial.println(nrj);
        pcReceived = true;
      gw.begin(incomingMessage);
      gw.request(CHILD_ID, V_VAR1);
      emon1.current(PIN_ANALOG_I, 30.0);       // Current: input pin, calibration.
      unsigned long now2 = millis();
      bool sendTime2 = now2 - lastSend2 > SEND_FREQUENCY2;
      if (sendTime2) //calcul Irms moy
        if (index==0) Irms=emon1.calcIrms(1480);
        else {
        index++;
        Irms = (index*Irms+emon1.calcIrms(1480))/(index+1);
        lastSend2 = now2;
      if (sendTime && pcReceived)
        power = Irms*232.0;
        gw.send(IrmsMsg.set(power,1));
        nrj += (power*SEND_FREQUENCY/1000)/3.6E6;
        gw.send(kWhMsg.set(nrj,3));
        lastSend = now;
        index = 0;
        old_nrj=nrj;
     else if (sendTime && !pcReceived)
      lastSend=now;
    it seems that it works for now (but not optimal).
    0_1456322448197_upload-3801900a-dd69-437d-ac99-6f2baa635713
    Note 1) my cosphy=1 because i use only ampere clamp, i cant measure the phase between curent i and tension v.
    2) my calibration constant (used in emonlib) is 30
    3) Sorry for my english 😞 - Je suis français.
    The cos phi applies only to the three-phase, single phase not
    Je suis français aussi...
  • Hello, if i remember physics course in university Power P=u.i and energy E=integrale(Pdt)=integrale(u.i.dt)=UeffxIeffxcos(phi)
    but for particular citizen same me, energy provider non consider cos(phi)
    So, i correct my last sketch for request last nrj value to the gw.
    #define CHILD_ID 0
    int index = 0;
    double Irms=0;
    double power;
    boolean onyva=true;
    float nrj=0, old_nrj;
        nrj = old_nrj = message.getFloat();
        pcReceived = true;
      if (onyva) gw.process();
      onyva = false;
      //unsigned long now2 = millis();
      bool sendTime2 = now - lastSend2 > SEND_FREQUENCY2;
        else {
        index++;
        lastSend2 = now;
        power = Irms*232.0;
        gw.send(kWhMsg.set(nrj,5));
        gw.send(pcMsg.set(nrj,5));
        lastSend = now;
        index = 0;
        old_nrj=nrj;
        onyva=true;
      lastSend=now;
      index=0;
      onyva=true;
    thx...
  • Hi, I'm beginner of arduino programmer. Can You explain a little this sketch? What for You use "SEND_FREQUENCY2 = SEND_FREQUENCY / 25;" ? Why You using two if statements sendTime2 and sendTime ?
    Maciej
  • Sorry, I'm late debause i come back holiday today
    This sketch send Power and energy (kWh) every Sendfrequency=90s but the sketch not measure power every 90s but everyre 90/25=3,6s and send to the GW the mean power (Pmean)
    this is calculate here :
    else {
    index++;
    lastSend2 = now;
  • Thanks @fredok I will give a try !
    And I'm french too 😉
  • Hi @fredok
    Your sketch working fine.
    Except in domoticz only the kWh is updated. Watt is not.
    Do you have a clue about that ?
    0_1460530318251_upload-2328793c-760b-4d2f-9a6e-5b379895cf58
  • Hello chatainsim, in my domoticz i have only one device counting (kWh+instant Power)
    0_1460535247416_upload-ddcdf9df-e7f6-441a-bdc0-2d426f76aa27
    0_1460535269881_upload-a2371cbe-49f0-497d-af85-7e2433941d15
    The instant power updated every 90s is writing in Watt value(83.3) , the kWh of the day (1.174) and total energy (61.582 kWh).... the device log show the power = f(t).
    Look if Watt value in (kWhMeter) device change, look the log graph ... if is ok, u not need Wattmeter device.
    Thx Fredok
  • @fredok Yes, the kWhMeter is working fine:
    0_1460558668986_upload-6238dfee-4382-4716-913e-6fb03b0f2ddf
  • Ok, so it just stop working after almost 24 hours ...
    I have some issue with mysensors, I don't know why, sometimes sensors stop working but I don't know why ...
    send: 10-10-2-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 10-10-2-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
    send: 10-10-2-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:2
    sensor started, id=10, parent=2, distance=2
    send: 10-10-2-0 s=255,c=3,t=11,pt=0,l=12,sg=0,st=ok:Energy Meter
    send: 10-10-2-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.0
    send: 10-10-2-0 s=0,c=0,t=13,pt=0,l=0,sg=0,st=ok:
    send: 10-10-2-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=fail:
    send: 10-10-2-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=ok:
  • hummm. i use this sketch with arduino mini near the GW (approx 5m max / 1 Wall) and i not see disconnection. So i cant help u.
  • This is a recurring problem I have with MySensors.
    All my sensors stop working, I have to clear the eprom then reupload the sketch.
    Now It's working fine, until it fail again 😉
  • Hello All,
    I have tried this code and it works fine.
    I was questionning myself though. If the index request fails at some point, what would be the behaviour of the code ? From my understanding of it, it will try to get the index again and again until it succeeds. May be a another way would be not to reset the index to 0 and send the additionnal index the next time.
    What do you think ?
    QQ.
  • Hello, sorry for my late reply.
    About the sketch,
    1. At the beginning, the sketch request the last kWh to the GW (I use Domoticz, so GW ask Domoticz the last kWh value) and send to the node.
    2. If node receiv, the variable pcreceiv=true and it working fine else node wait for the request until he receiv. A serial.print will inform if receiv.
    Fredok
  • Yep, got that lately 🙂
    QQ.
  • @fredok
    hi , do you have please updated sketch for newest version of domoticz ? This old cause problems when I compiling it.
    Thanks 👍
  • @warmaniac
    Sorry i not update this sketch ...
  • @gohan
    tried to modify but I always get error
    /MySensors.h:328:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    #define CHILD_ID 0
    #define PIN_ANALOG_I A1
    //MySensor gw;
    int index = 0;
    double Irms=0;
    double power;
    boolean onyva=true;
    //void incomingMessage(const MyMessage &message)
        pcReceived = true;
    void presentation () {
      if (onyva) process();
      onyva = false;
        else {
        index++;
        lastSend2 = now;
        power = Irms*232.0;
        lastSend = now;
        index = 0;
        old_nrj=nrj;
        onyva=true;
      lastSend=now;
      index=0;
      onyva=true;
    It is possible to compile it with old mysensors library ? It will work with gateway which has a newest version ?
  • Hello, at the end i write a v2.0 of the sketch
    //#include <Arduino.h>
    #include <OneWire.h>
    EnergyMonitor emon2;
    #define CHILD_ID_CLAMP1 0
    #define CHILD_ID_CLAMP2 1
    #define CHILD_ID_TEMP 2
    #define CHILD_ID_LDR 3
    #define PIN_ANALOG_I1 A2 //pince amperemetrique1
    #define PIN_ANALOG_I2 A3
    #define PIN_LDR A0 // LDR
    #define PIN_DALLAS 3
    //Definition de dallas
    #define MAX_ATTACHED_DS18B20 1
    OneWire oneWire(PIN_DALLAS);
    int numSensors = 1;
    bool receivedConfig = false;
    bool metric = true; //truc v2.0
    //int compat = 0;
    unsigned long lastSend_temp = millis();
    unsigned long lastSend_power = millis();
    unsigned long lastSend_c;
    unsigned long SEND_FREQUENCY = 120000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    unsigned long SEND_FREQUENCY_TEMP = 300000; //delais d'emission entre 2 mesures de temps
    unsigned long SEND_FREQUENCY_C = SEND_FREQUENCY / 30;
    int index = 0;
    double Irms1 = 0;
    double Irms2 = 0;
    boolean pcReceived1 = false;
    boolean pcReceived2 = false;
    boolean first_time_temp = HIGH;
    float nrj1 = 0, old_nrj1;
    float nrj2 = 0, old_nrj2;
    int ldr = 0, old_ldr;
    MyMessage IrmsMsg1(CHILD_ID_CLAMP1, V_WATT);
    MyMessage kWhMsg1(CHILD_ID_CLAMP1, V_KWH);
    MyMessage pcMsg1(CHILD_ID_CLAMP1, V_VAR1);
    MyMessage IrmsMsg2(CHILD_ID_CLAMP2, V_WATT);
    MyMessage kWhMsg2(CHILD_ID_CLAMP2, V_KWH);
    MyMessage pcMsg2(CHILD_ID_CLAMP2, V_VAR2);
    MyMessage msgLight(CHILD_ID_LDR, V_LIGHT_LEVEL);
    void before() {
      sensors.begin();
      sendSketchInfo("Multisensors_Entree", "2.0");  // Send the sketch version information to the gateway and Controller
      present(CHILD_ID_CLAMP1, S_POWER);   // Register this device as power sensor
      request(CHILD_ID_CLAMP1, V_VAR1);
      present(CHILD_ID_CLAMP2, S_POWER);   // Register this device as power sensor
      request(CHILD_ID_CLAMP2, V_VAR2);
      numSensors = sensors.getDeviceCount(); //compte le nb de ds18
      present(CHILD_ID_LDR, S_LIGHT_LEVEL);
      if (message.type == V_VAR1)
        nrj1 = old_nrj1 = message.getFloat();
        Serial.println(nrj1);
        pcReceived1 = true;
      if (message.type == V_VAR2)
        nrj2 = old_nrj2 = message.getFloat();
        Serial.println(nrj2);
        pcReceived2 = true;
      emon1.current(PIN_ANALOG_I1, 30.0);       // Current: input pin, calibration.
      emon2.current(PIN_ANALOG_I2, 30.0);
      Serial.println("SETUP completed");
    void envoi_donnees(double intrms, int id_clamp)
      Serial.print("Envoi des donnees .... clamp="); Serial.println(id_clamp);
      double energie = (intrms * 232.0 * SEND_FREQUENCY / 1000) / 3.6E6;
      switch (id_clamp)
        case 1:
            send(IrmsMsg1.set(intrms * 232.0, 1));
            nrj1 += energie;
            send(kWhMsg1.set(nrj1, 5));
            send(pcMsg1.set(nrj1, 5));
            old_nrj1 = nrj1;
        case 2:
            send(IrmsMsg2.set(intrms * 232.0, 1));
            nrj2 += energie;
            send(kWhMsg2.set(nrj2, 5));
            send(pcMsg2.set(nrj2, 5));
            old_nrj2 = nrj2;
      bool sendTime_c = now - lastSend_c > SEND_FREQUENCY_C;
      // Calcul de Irms1 et Irms2
      if (sendTime_c) //calcul Irms moy clamp1/clamp2
        if (index == 0)
          Irms1 = emon1.calcIrms(1480);
          Irms2 = emon2.calcIrms(1480);
          Irms1 = (index * Irms1 + emon1.calcIrms(1480)) / (index + 1);
          Irms2 = (index * Irms2 + emon2.calcIrms(1480)) / (index + 1);
        lastSend_c = now;
        index++;
      bool sendTime_temp = now - lastSend_temp > SEND_FREQUENCY_TEMP;
      if (sendTime_temp || first_time_temp)
        Serial.println("........ quoiqu'il arrive, on envoi la temp+ldr");
        first_time_temp = LOW;
        //Send Temp
        // Envoi Température d'après https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/DallasTemperatureSensor/DallasTemperatureSensor.ino
        sleep(750);
        for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++)
         // float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
          if (lastTemperature[i] != temperature && temperature != -127.00 && temperature != 85.00)
            send(msgTemp.setSensor(i).set(temperature, 1));
            Serial.println(".....................Envoi Temp");
            lastTemperature[i] = temperature;
      //Send light LDR
      //Envoi Light LDR
      ldr = (1023 - analogRead(PIN_LDR)) / 10.23;
      if (old_ldr != ldr)
        send(msgLight.set(ldr));
        old_ldr = ldr;
       lastSend_temp=now;
     bool sendTime_power = now - lastSend_power > SEND_FREQUENCY;
     if (sendTime_power)
      // Envoi ou request Puissance1
      if (pcReceived1) envoi_donnees(Irms1, 1);
      else     {
        Serial.println("Request VAR1");
      // Envoi ou request Puissance2
      if (pcReceived2) envoi_donnees(Irms2, 2);
      else     {
        Serial.println("Request VAR2");
      //on reinitialise les compteurs
      lastSend_power = now;
      index = 0;
    attention, i use in the same node a ds18b20 for temp and LRD for light measurment
    so u need to delete part of sketch.
    i just compiling/Verifying this with mysensors v2.1 (but not loaded in arduino pro) and no error
    for emonlib => https://github.com/openenergymonitor/EmonLib
  • .... u must to look the monitor for see "Envoi des données .... clamp=0" and after (a few minutes after) "Envoi des données .... clamp=1"
    Look after ur domotic soft for see if your gw become something.
    bye.
  • @fredok
    nice ! thank you very much for fast solution 🙂 I try it at home , it compiles well 👍
    @warmaniac you got errors because you need to move the
    "#include <MySensors.h>" after all the "#DEFINE....." otherwise the library does not know how to be configured
  • @fredok
    I modyfied your sketch (deleting unwanted code like dallas and light sensor) it works but i think I done something wrong, because it spams my gateway , now it looks like this
    #define PIN_ANALOG_I1 A1 //pince amperemetrique1
    //int compat = 0;
    int index = 0;
    double Irms1 = 0;
        pcReceived1 = true;
      switch (id_clamp)
        case 1:
            nrj1 += energie;
            old_nrj1 = nrj1;
        if (index == 0)
        lastSend_c = now;
        index++;
     if (sendTime_power)
      else     {
    and I get this results now
  • hello, i see the sketch send everyloop ???
    try this
    unsigned long lastSend_c = millis();
    int index = 0;
    double Irms1 = 0;
    void before() {
        pcReceived1 = true;
      switch (id_clamp) //can be modified ...
        case 1:
            nrj1 += energie;
            old_nrj1 = nrj1;
        if (index == 0)
        lastSend_c = now;
        index++;
     if (sendTime_power)
      else     {
      index = 0;
    if problem copy the screen of monitor.thx
  • ahoj, if not working i will try with a new arduino for test the code.
    dobrý večer
  • @fredok
    sketch works better now , not spamming
    0_1490898851738_upload-e9fbdb1a-1c4f-4356-826f-4e9112a25036
    0_1490898895065_upload-f9c9fbff-f6e5-48ee-96de-8bf28054b129
    but I dont understand current values
    0_1490898965008_upload-d6846108-30b7-4a7d-ad02-c0b0897b20fd
  • its seem good kWh every 2min
    1864W is the power value
    the sketch send power value P (in W) and energy (in kWh) calculated over 2min.
    // and after
    nrj1 += energie;
    in domoticz i have one "dispositif" included instant power Watt and day cumulate energy kWh
    bye
  • @fredok
    Thank you very much! Only one question left, with multimeter I measured my voltage 241.0 V could I update it in sketch or ?
  • a clamp measure only intensity I (in A) and Power =UrmsxIrms so if in u home Urms=241V u can change with this value but the power measurment not consider cosphy
    by example the power measurment of my fridge =257W but true value is (with cosphy) 257x0,56=....W
    so if u change 232V with 241V why not but at the end its will continu to be a approximate of the true power.
    bye
  • @fredok
    Okay 🙂 understand now, and what about calibration for wiring I followig this site
    https://learn.openenergymonitor.org/electricity-monitoring/ct-sensors/how-to-build-an-arduino-energy-monitor-measuring-current-only?redirected=true
    And they calibrate
     emon1.current(1, 111.1);
    And yours calibration
    Is some difference after this calibrations in measuring ?
    They also have the same sensor with also voltage measurement for a more accurate reading
  • @gohan
    Because with test sketch from that site I get actual consumption 0,5 kWh but from mysensors sketch I get much higher values look
    0_1490962213606_upload-ed834413-8133-438b-8e2a-95c017b3f33c
    1,7 kWh per one hour is too much , I had only TV and fridge in power on mode, I had total consumption per last year about 2140 kWh , which is about 6 kWh per day.
  • hello,
    1. the constant 30 is the divide between ratio/burden resistor including inside the clamp
      for me ration=1800 and R=62ohm (1800/62 approx 30)
      http://www.planete-domotique.com/notices/S/C/SCT013-030V.pdf
    2. i can see 1677 Wh=1,677 kWh ... but 1900W for only TV+fridge its many
      mine clamp2 log in domoticz
    3. Maybe it can help u??? i have a pulse powercounter count every flash (1 Wh of energy) of mine electric box and the power (Watt) send to gw is wrong in domoticz but the energy counting (kWh) is great.
      Where come the wrong of fake power (GW ? sketch ? domoticz , i dont know)
      bye
  • @fredok
    I had SCT-013-000 , not SCT-013-030 maybe this is the problem of measuring .
  • updated my sketch with new values for SCT-013-00 result is now
    int index = 0;
    double Irms1 = 0;
    void before() {
        pcReceived1 = true;
      emon1.current(PIN_ANALOG_I1, 111.1);       // Current: input pin, calibration.
      double energie = (intrms * 240.0 * SEND_FREQUENCY / 1000) / 3.6E6;
        case 1:
            send(IrmsMsg1.set(intrms * 240.0, 1));
            nrj1 += energie;
            old_nrj1 = nrj1;
        if (index == 0)
        lastSend_c = now;
        index++;
     if (sendTime_power)
      else     {
      index = 0;
    0_1490992284051_upload-583cafbf-bd94-4bad-8fd3-8c510f5cfbfc
  • great !!!!!
  • Hi , i update your sketch for Multiple sensor
    #include <EmonLib.h>
    #define SERIAL_BAUD 115200
    #define PIN_ANALOG_I1 A0   // The input you attached SCT1.
    #define PIN_ANALOG_I2 A1   // The input you attached SCT2.
    #define PIN_ANALOG_I3 A2   // The input you attached SCT3.
    #define CHILD_ID_WATT 0    // child-id of sensor
    #define CHILD_ID_KWH  1    // child-id of sensor
    #define CHILD_ID_VAR1 2    // child-id of sensor
    #define MAX_CT 3           // Number of CT sensor
    EnergyMonitor ct1, ct2, ct3;
    MyMessage msgWatt(CHILD_ID_WATT,V_WATT);
    MyMessage msgKwh(CHILD_ID_KWH,V_KWH);
    MyMessage msgVar(CHILD_ID_VAR1,V_VAR1);
    unsigned long SEND_FREQUENCY   = 60000;               // 1 mn Minimum time between send (in milliseconds).
    unsigned long FREQUENCY_SAMPLE = SEND_FREQUENCY / 12 ; // ( 5 s)
    #define MAX_CT 3
    double  Irms[MAX_CT];
    float   nrj[MAX_CT];
    boolean pcReceived[MAX_CT];
    int    index = 0;
    #ifdef MY_DEBUG
      Serial.begin(SERIAL_BAUD);
      Serial.println("Begin SETUP");
      //ct1.current(PIN_ANALOG_I1, 111.1);     // Current: input pin, calibration.
      ct1.current(PIN_ANALOG_I1, 60);          // current constant = (100 ÷ 0.050) ÷ 33 Homs = 60
      ct2.current(PIN_ANALOG_I2, 60);
      ct3.current(PIN_ANALOG_I3, 60);
      Irms[0] = ct1.calcIrms(1480);            // initial boot to charge up capacitor (no reading is taken) - testing
      Irms[1] = ct2.calcIrms(1480);
      Irms[2] = ct3.calcIrms(1480);
      for (int i=0; i<MAX_CT; i++) {
           Irms[i] = nrj[i] = 0;
           pcReceived[i]=false;
    #ifdef MY_DEBUG
      sendSketchInfo("Energy Meter", "2.1");
      present(0, S_POWER);
      request(0, V_VAR1);
      present(1, S_POWER);
      request(1, V_VAR1);
      present(2, S_POWER);
      request(2, V_VAR1);
      int SensorID ;
      SensorID = message.sensor ;
      if (message.type == V_VAR1) {
          nrj[SensorID] =  message.getFloat();
          pcReceived[SensorID] = true;
    #ifdef MY_DEBUG
          Serial.print("Received last nrj[");
          Serial.print(SensorID);
          Serial.print("] count from GW:");
          Serial.println(nrj[SensorID]);
    void send_data(double intrms, int SensorID) {
    #ifdef MY_DEBUG
      Serial.print("Send data for SensorID=");
      Serial.println(SensorID);
      nrj[SensorID] += energie;
      send(msgWatt.setSensor(SensorID).set(intrms * 240.0, 1));
      send(msgKwh.setSensor(SensorID).set(nrj[SensorID], 5));
      send(msgVar.setSensor(SensorID).set(nrj[SensorID], 5));
      double _Irms[MAX_CT];
      bool sendTime_c = now - lastSend_c > FREQUENCY_SAMPLE;
      if (sendTime_c)
        _Irms[0] = ct1.calcIrms(1480) ; if (_Irms[0] < 0.3) _Irms[0] = 0;
        _Irms[1] = ct2.calcIrms(1480) ; if (_Irms[1] < 0.3) _Irms[1] = 0;
        _Irms[2] = ct3.calcIrms(1480) ; if (_Irms[2] < 0.3) _Irms[2] = 0;
        Irms[0] = (index * Irms[0] + _Irms[0]) / (index + 1);
        Irms[1] = (index * Irms[1] + _Irms[1]) / (index + 1);
        Irms[2] = (index * Irms[2] + _Irms[2]) / (index + 1);
        lastSend_c = now;
        index++;
    #ifdef MY_DEBUG
            Serial.print("CT");
            Serial.print(i);  Serial.print(" : ");
            Serial.print(Irms[i]*240.0);  // Apparent power
            Serial.print(" ");
            Serial.println(Irms[i]);      // Irms
      if (sendTime_power)
           if (pcReceived[i])
             send_data(Irms[i], i);
             request(i, V_VAR1);
        index = 0;
  • fine thx....
