Repeater Node Question
    I would like to add a repeater Node to my Network and I would like to know a few things:
    MY_PARENT_ID for the repeater node is the gateways ID, right? So which MY_PARENT_ID will the repeated Nodes have? The ID of the Repeater Node?
    Does someone have an example sketch of a repeater node for me?
    Thanks in advance!
    @siod yes, your assumptions are correct.
    There is no example sketch for a repeater node because it only needs to contain a single define. You can add this define to any sketch. If the node uses sleep you will need to change sleep to wait, so the node stays awake. See https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes for details.
  • @mfalkvidd great, thanks for your quick and short answer! 👍
  • one more question: that´s what I have so far, is this all? I think I´ve read somewehere that there must be a special command included and I also read this:
    // Repeater Node1, Repeater Nodes starten bei ID 50
    // Define Node ID
    #define MY_NODE_ID 50
    #define MY_PARENT_NODE_ID 0
    #define MY_REPEATER_FEATURE
    //Messages
    void presentation(){
      sendSketchInfo("Repeater Node 1", "1.0");
      wait(500);
    //Setup
    //Starte den Loop
    *Handling incoming radio messages
    Nodes that expects incoming data, such as an actuator or repeating nodes, must implement the receive()-function to handle the incoming messages. Do not sleep a node where you expect incoming data or you will lose messages.
    message - The incoming message data*
    where do I have to add this?
    @siod What you have above is all you need for a repeater node. if you also have sensors/actuators on this node that are expecting to receive data then you will need to add the receive function. have a look at the RelayActuator example to see how it looks.
    the lines below are not mandatory for a repeater either but of course you can use them if needed
  • ok, thanks for clarifying this!
