[Solved] Vera device not showing variable value on GUI
  • I have built my first sensor (moisture sensor) and gateway.
    With a simple sketch the value displays correctly in the Vera device.
    #define CHILD_ID 0
    // Here we are setting up some water thresholds that we will
    // use later. Note that you will need to change these to match
    // your soil type and environment. It doesn't do much for me because I'm using domoticz
    int thresholdUp = 400;
    int thresholdDown = 075;
    MyMessage msg(CHILD_ID, V_LEVEL);
    unsigned long SLEEP_TIME = 1000;
    // We are setting up the pin A0 on the redboard to be our sensor
    // pin input:
    int sensorPin = A0;
    present(CHILD_ID, S_MOISTURE);
    int sensorValue;
    sensorValue = analogRead(sensorPin);
    //send back the values
    send(msg.set(sensorValue));
    // delay until next measurement (msec)
    sleep(SLEEP_TIME);
    Debug output
    Vera grep log output
    However, when I move onto the sketch I want to use everything works except the moisture value does not display in the Vera device.
     * Code and ideas from
     * mfalkvidd (http://forum.mysensors.org/user/mfalkvidd),
     * carlierd (https://www.openhardware.io/user/97/projects/carlierd)
     * Scalz (https://www.openhardware.io/user/12/projects/scalz)
    /* Moisture sensor Pro Mini                                                           */
    /* Version     : V1.1.2        */
    /* Supported Hardware     : V1.1.x                                                    */
    /* Date        : 15/03/2017                                                           */
    /* Modified by : Jordan Bouey                                                         */
     /* Fuse L:E2 H:DA E:06 x
      *  BOD 1.8V - Int 8Mhz Osc
      *  avec boot  ATmegaBOOT_168_atmega328_pro_8MHz.hex
    #define MY_NODE_ID 1
    #define MY_DEBUG    // Enables debug messages in the serial log
    //#define MY_OTA_FIRMWARE_FEATURE  // Enables OTA firmware updates if DualOptiBoot
    // Enables software signing
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7  //!< Unconnected analog pin for random seed
    // Enable node whitelisting
    //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = 0,.serial = {0xEB,0x86,0x43,0x73,0x14,0xB1,0xAF,0x0E,0x17}}}
    // If enabled, You need to use securityPersonalizer for more security and change the default HMAC_KEY (https://www.mysensors.org/about/signing)
    //Define functions
    #define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
    //Constants for MySensors
    #define SKETCH_NAME           "Moisture Sensor Pro Mini"
    #define SKETCH_VERSION        "1.1.2"
    #define CHILD_ID_VOLTAGE 0 // Id of the sensor child (default 0)
    #define CHILD_ID_MOISTURE 1   // Id of the sensor child (default 1)
    #define BATTERY_SENSE_PIN A0  // select the input pin for the battery sense point (default A0)
    #define LED_PIN_INFO 3 //INFO LED PIN (default 3)
    #define LED_PIN_WARN  4//WARNING LED PIN (default 4)
    #define THRESHOLD             1.1     // Only make a new reading with reverse polarity if the change is larger than 10% (default 1.1)
    #define MOISTURE_THRESHOLD    1.01    // Delta needing for sending moisture to the controler (default 1.01)
    #define STABILIZATION_TIME    2000    // Let the sensor stabilize before reading (default 2000)
    #define BATTERY_FULL          3300    // when full AAA (default 3300)
    #define BATTERY_ZERO          2340    // 2.34V limit for 328p at 8MHz (set extended fuse to 0x06 for BOD 1.8V or you'll never see 2.34V)  (default 2340)
    const int SENSOR_ANALOG_PINS[] = {A1, A2}; //(default {A1, A2})
    #ifndef MY_DEBUG
      #define SLEEP_TIME            3600000 // Sleep time between reads (in milliseconds) (close to 1 hour)(default 3600000)
    #ifdef MY_DEBUG
     #define SLEEP_TIME            1000 // Sleep time between reads (in milliseconds) (close to 1 sec) (default 1000)
    //Variables
    int oldbatteryPcnt = -1;
    byte direction = 0;
    int oldMoistureLevel = -1;
    MyMessage msgMoisture(CHILD_ID_MOISTURE, V_HUM);
    MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
    /* Presentation        */
      //Get time (for presentation)
      #ifdef MY_DEBUG
        unsigned long startTime = millis();
      blinkLedFastly(3);
      //Start MySensors and send the sketch version information to the gateway
      //Register all sensors
      present(CHILD_ID_VOLTAGE, S_MULTIMETER);
      present(CHILD_ID_MOISTURE, S_MOISTURE);
      //Setup done !
      blinkLedFastly(3);
        //Print setup debug
      #ifdef MY_DEBUG
        int duration = millis() - startTime;
        Serial.print("[Presentation duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
    /* Initialization        */
      //Setup LED INFO pin
      pinMode(LED_PIN_INFO, OUTPUT);
      //Setup LED WARNING pin
       pinMode(LED_PIN_WARN, OUTPUT);
      //Set moisutre sensor pins
      for (int i = 0; i < N_ELEMENTS(SENSOR_ANALOG_PINS); i++)
        pinMode(SENSOR_ANALOG_PINS[i], OUTPUT);
        digitalWrite(SENSOR_ANALOG_PINS[i], LOW);
    /* Main loop        */
      //Get time (for a complete loop)
      #ifdef MY_DEBUG
      //Get moisture level
      int moistureLevel = readMoisture();
      //Send rolling average of 2 samples to get rid of the "ripple" produced by different resistance in the internal pull-up resistors
      //See http://forum.mysensors.org/topic/2147/office-plant-monitoring/55 for more information
      //Verify if current measurement is not too far from the previous one
      if (moistureLevel > (oldMoistureLevel * THRESHOLD) || moistureLevel < (oldMoistureLevel / THRESHOLD))
        //The change was large, so it was probably not caused by the difference in internal pull-ups.
        //Measure again, this time with reversed polarity.
      #ifdef MY_DEBUG
      Serial.print("Soil Value: ");
      Serial.println(moistureLevel);
      send(msgMoisture.set((moistureLevel), 0));
     if (moistureLevel > (oldMoistureLevel * MOISTURE_THRESHOLD) || moistureLevel < (oldMoistureLevel / MOISTURE_THRESHOLD)) //Send moisture only if moisture changed more than MOISTURE_THRESHOLD
          if (oldMoistureLevel == -1) {
           send(msgMoisture.set((moistureLevel) / 10.23, 0));
          }else{
           send(msgMoisture.set((moistureLevel + oldMoistureLevel) / 2.0 / 10.23, 0));
        //Store current moisture level
        //Report data to the gateway
        long voltage = getVoltageBySoft();
        int batteryPcnt = round((voltage - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO));
       if (batteryPcnt > 100) {batteryPcnt = 100;}
       if (batteryPcnt <= 0) {batteryPcnt = 0;}
       if (oldbatteryPcnt != batteryPcnt) {
          send(msgVolt.set(voltage / 1000.0, 2));
         oldbatteryPcnt = batteryPcnt;
       //Print debug
      #ifdef MY_DEBUG
        Serial.print((moistureLevel + oldMoistureLevel) / 2.0 / 10.23);
        Serial.print("%");
        Serial.print("   ");
        Serial.print(batteryPcnt);
        Serial.print("%");
        Serial.print("   ");
        Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
        Serial.flush();
     //Sleep until next measurement - smart sleep for OTA
      blinkLedFastly(1);
      smartSleep(SLEEP_TIME);
    /* Allows to get moisture.                                                            */
    int readMoisture()
      //Power on the sensor and read once to let the ADC capacitor start charging
      pinMode(SENSOR_ANALOG_PINS[direction], INPUT_PULLUP);
      analogRead(SENSOR_ANALOG_PINS[direction]);
      //Stabilize and read the value
      sleep(STABILIZATION_TIME);
      int moistureLevel = (1023 - analogRead(SENSOR_ANALOG_PINS[direction]));
      //Turn off the sensor to conserve battery and minimize corrosion
      //Make direction alternate between 0 and 1 to reverse polarity which reduces corrosion
     // direction = (direction + 1) % 2;
      return moistureLevel;
    /* Allows to fastly blink the LED.                                                    */
    void blinkLedFastly(byte loop)
      byte delayOn = 150;
      byte delayOff = 150;
      for (int i = 0; i < loop; i++)
        blinkLed(LED_PIN_INFO, delayOn);
        delay(delayOff);
    /* Allows to blink a LED.                                                             */
    void blinkLed(byte pinToBlink, int delayInMs)
      digitalWrite(pinToBlink,HIGH);
      delay(delayInMs);
      digitalWrite(pinToBlink,LOW);
    /* Allows to get the real Vcc (return value in mV).                                   */
    /* http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/   */
    long getVoltageBySoft()
      ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
      delay(50);  // Let mux settle a little to get a more stable A/D conversion
      //Start a conversion
      ADCSRA |= _BV( ADSC );
      //Wait for it to complete
      while (bit_is_set(ADCSRA, ADSC));
      //Compute and return the value
      uint8_t low  = ADCL;                  // must read ADCL first - it then locks ADCH
      uint8_t high = ADCH;                  // unlocks both
      result = 1125300L / result;           // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
      return result;                        // Vcc in millivolts
    /* Mesure battery with divider                                                        */
    long getVoltageByHard()
        analogReference(INTERNAL);
       // get the battery Voltage
       #ifdef MY_DEBUG
       Serial.print("Battery Value: ");
       Serial.println(sensorValue);
          //The analog reference only changes when you make an analogread and it takes a little time to change, hence the tempo and repeat of the analogRead command
          delay(1000);     // this delay is needed
       #ifdef MY_DEBUG
        int batteryMv  = round(batteryV * 1000);
       // int batteryPcnt = sensorValue * 0.0977517106549365;
      int batteryPcnt = round((batteryMv - BATTERY_ZERO) * 100.0 / (BATTERY_FULL - BATTERY_ZERO));
       #ifdef MY_DEBUG
       Serial.print(batteryMv);
       Serial.println(" mV");
       Serial.println(" %");
       analogReference(DEFAULT);
      return batteryMv;                        // Vcc in mV
    Debug output
    The variable value is getting to the Vera device as it shows in the device advanced tab
    Vera 3 UI15
    IDE 1.8.2
    MySensor library 2.2.0 - beta
    I have removed the sensors and gateway multiple times, reloaded Vera multiple times. To no avail.
    Any suggestions welcome.
  • Solved:
    Vera does not have a dedicated moisture device, S_MOISTURE is implemented as a Light Sensor (Ref)
    is therefore incorrect and results in no value being shown in the device.
    For Vera this has to be
    MyMessage msgMoisture(CHILD_ID_MOISTURE, V_LEVEL);
    The level is now showing in the device
  • @Mod
    I think this post would be better in Controllers > Vera
    Could you move please?
    @Woodside done. Welcome to the MySensors commu ity and thanks for sharing the solution.
