Raspberry Pi and MQTT-OpenHAB
  • I am a newbei and some stupid questions like cookies:p
    Do i have to use Raspberry Pi for OpenHAB or PiDome?
    My hardware : ENC28J60 Ethernet module + UNO + NRF24L01 Radio so I made connections following http://www.mysensors.org/build/ethernet_gateway and using sketch : http://www.mysensors.org/build/mqtt_gateway without changing any code i got this:
    Started!
    0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0:
    0;0;3;0;9;version mismatch
    Is it ok?
    I tried everything to install OpenHAB server with Mac but "start.sh" didnt work, i cant open this file, do you have any idea? (Yes i installed Java)
    When Uno is connected with the same network
    • Win8 cmd is running this:****
    Launching the openHAB runtime...
    osgi> 2014-11-27 19:21:06.004 [INFO ] [.o.core.internal.CoreActivator] - openHAB
    runtime has been started (v1.6.0).
    2014-11-27 19:21:06.619 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service
    has been started
    2014-11-27 19:21:06.734 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Disco
    very initialization completed.
    2014-11-27 19:21:06.739 [INFO ] [.io.transport.mqtt.MqttService] - MQTT Service
    2014-11-27 19:21:06.739 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT
    broker connection 'mysensor'
    2014-11-27 19:21:07.990 [INFO ] [penhab.io.rest.RESTApplication] - Started REST
    API at /rest
    2014-11-27 19:21:16.926 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Class
    ic UI at /openhab.app
    2014-11-27 19:21:27.769 [ERROR] [.io.transport.mqtt.MqttService] - Error startin
    g broker connection
    org.eclipse.paho.client.mqttv3.MqttException: Unable to connect to server
        at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNet
    workModule.java:75) ~[na:na]
        at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(Cli
    entComms.java:538) ~[na:na]
        at java.lang.Thread.run(Unknown Source) ~[na:1.8.0_25]
    Caused by: java.net.ConnectException: Connection timed out: connect
        at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) ~[na:
    1.8.0_25]
        at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source) ~[na:
    1.8.0_25]
        at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) ~[na:1.8.0
    _25]
        at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source) ~[n
    a:1.8.0_25]
        at java.net.AbstractPlainSocketImpl.connect(Unknown Source) ~[na:1.8.0_2
    5]
        at java.net.PlainSocketImpl.connect(Unknown Source) ~[na:1.8.0_25]
        at java.net.SocksSocketImpl.connect(Unknown Source) ~[na:1.8.0_25]
        at java.net.Socket.connect(Unknown Source) ~[na:1.8.0_25]
    workModule.java:66) ~[na:na]
        ... 2 common frames omitted
    If you are planning on using PiDome i would say yes because that is the primary platform focused on, it could theoratically also run on other platforms but we are not done yet supporting a correct way to start.
    If you are planning openhab you can run it on other systems like windows (as you do (win8?)) as well.
    Your first error, i would say double check you are using the latest versions of each (MQTT gateway on the uno and the nodes).
    The second error mentions that it is having a connection timeout which would say it is unable to reach the given ip address, make sure you can connect to the MQTT broker on the uno using for example with mqtt.fx (http://mqttfx.jfx4ee.org/). or other mqtt tools.
    John.
    I can nothing say about OpenHAB or PiDome but:
    Started!
    Does not look good, it seems an error from the gateway.
  • 11
