💬 Relay
    The control signal is 5VCD... The "other side" can be anything (up to 230VCD).
  • Can you show converted sketch with 2 buttons and 2 relays ? I dont know how convert this sketch bersion with buttons...
    @pepson Have a look at this thread for some ideas to get you started.
  • I would like to ask about ack. Does the library have a specific timeout? Does the library resends the message when ack is not received? Thank you.
  • Cam I use an arduino pro mini 3.3V 8 Mhz to trigger the relay - or do I need a 5v arduino?
    @Puneit-Thukral - it depends on the relay.
    If you read the datasheet for intended relay you will see what is needed. Most relays i have seen requiers 5v and a good current (which Arduino sometimes fail to deliver).
  • @sundberg84 I used a 3904 transistor between the relay and arduino and it works just fine with 3.3 V Arduino pro mini 8 HMz.
    (2N2222 also works, but I have many pieces of 3904 and just a few 2N2222, hence using 3904)
  • I have my gateway and my relay, I believe is working fine, I just want to know what set of caracters do I need to send in the serial monitor to turn on the relay? I will like to use the info in order to use a controller like Vantage or C4, is that possible? Regards
  • @Javier-Rubio I m not an expert- a complete novice.
    I would suggest one of the following - trigger the relay through a controller or use one the the arduino relay example sketch in which relay is programmed to turn on and off every 1 second. This would help you validate if your wiring is correct or not.
  • I tried the relay sketch on my arduino mini pro (5v), step down converter for the NRF module and a two channel relay. It's conecte to a Raspi GW wirh the 2.0.0 beta and FHEM as controller. The switching works as expexted. but the relay switches continuisly on and off on its own after a certain time. I tried removing the loop-block but with no effort. Is there anything i can do to get a stable state? Thanks
    @Gizmoh sounds like the relays are not receiving enough power to remain on. How are you powering all this?
  • @korttoma
    I'm powering this with 6 x AA Batteries into the RAW Input from the Arduino and the 5v output from Arduino to the Relay.
    @Gizmoh ok so it seems like the voltage regulator on the arduino cannot handle the load the relays produce when activated. You need to power the relay board directly from your batteries either trough another 5V regulator or if your relay board already can handle a higher voltage you can connect it directly.
  • @korttoma Ah, okay, thank you. I'll give it a try.
    Maybe connecting a Decoupling-Capacitor could also fix this problem?
  • hello one doubt
    if a use this sketch: /mysensors/MySensorsArduinoExamples/examples/RelayWithButtonActuator/RelayWithButtonActuator.ino
    when i press the button home assistant knows if switch was turned or off? its change the stat?
    First of all Merry Xmas to all of you!
    I want to use this sketch with three LEDs to present the status of the alarm at home, so with a multicolored LED I have a green status, a red and a blue status, but I just want one color at a time, is there a way to alter the code a little to make sure that is a color is activated, the other one is turned off?
    @riochicken yes, but I wouldn't recommend relays for controlling a led. It can be controlled directly from the Arduino pins.
    Look at the code for these:
    https://www.openhardware.io/view/21/RGBW-LED-Controller#tabs-source
    https://www.openhardware.io/view/74/OH-MySensors-RGBW-Controller#tabs-source
  • @mfalkvidd : I have directly soldered the LED's to the board, would be a waste of relays.. 🙂 Thanks I will look into the examples you just gave...
  • @mfalkvidd I have no clue how to decode the examples you gave, normally in vb or powershell I would check if a pin would be active if another color was requested so I could turn off the other color but I am a bit lost with the code....
  • Hi all
    I use this sketch for controlling 2 x relays. Can anybody change me this sketch to controliling only 1 x relay ?
    Next problem....
    Anybody know how edit sketch for relays to add itrms to send repeate update status to gateway? I want eliminate problem when node start and change status , but gateway is disabled. And after gateway will be enable show in my Domoticz old status/last memory before disable gateway. But after this node has changed status and this status is not show in Domoticz after run. I want to work it as Z-Wave. Z-wave has always actual status. Is any chance to also MySensors Gateway and not has always actual status ?
       DESCRIPTION
       Sketch for 2x relay with buttons monostable. After back power all relays set OFF and send correct status OFF to controller.
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RF69_868MHZ
    #define MY_IS_RFM69HW
    #define MY_REPEATER_FEATURE
    // Node id defaults to AUTO (tries to fetch id from controller)
    #define MY_NODE_ID AUTO
    // Define Relays
    #define RELAY_OFF 0  // GPIO value to write to turn off attached relay
    // Define Sensor ID's
    #define SSR_A_ID 1   // Id of the sensor child
    #define SSR_B_ID 2   // Id of the sensor child
    // Define buttons and relays
    const int buttonPinA = 3;
    const int buttonPinB = 4;
    const int relayPinA = 5;
    const int relayPinB = 6;
    // Define Variables
    int oldValueA = 0;
    int oldValueB = 0;
    bool stateA = false;
    bool stateB = false;
    int trigger = 0;
    Bounce debouncerA = Bounce();
    Bounce debouncerB = Bounce();
    MyMessage msgA(SSR_A_ID, V_STATUS);
    MyMessage msgB(SSR_B_ID, V_STATUS);
      pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
      pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
      // After setting up the buttons, setup debouncer
      debouncerA.attach(buttonPinA);
      debouncerA.interval(5);
      debouncerB.attach(buttonPinB);
      debouncerB.interval(5);
      digitalWrite(relayPinA, RELAY_OFF);
      digitalWrite(relayPinB, RELAY_OFF);
      pinMode(relayPinA, OUTPUT);
      pinMode(relayPinB, OUTPUT);
    void presentation()  {
      sendSketchInfo("2xRelay with monostable", "2.1");
      present(SSR_A_ID, S_LIGHT);
      present(SSR_B_ID, S_LIGHT);
    if (trigger == 0){
      send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
      send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
      trigger = 1;
      debouncerA.update();
      // Get the update value
      int valueA = debouncerA.read();
      if (valueA != oldValueA && valueA == 0) {
        send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
      oldValueA = valueA;
      debouncerB.update();
      int valueB = debouncerB.read();
      if (valueB != oldValueB && valueB == 0) {
        send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
      oldValueB = valueB;
        switch (message.sensor) {
          case 1:
            stateA = message.getBool();
            digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
          case 2:
            stateB = message.getBool();
            digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
        Serial.print("from node:");
        Serial.println(message.sender);
    I would like to do an auto off after 2 sec directly in the sketch, however I do not understand how to write the code? I do not want to make a loop, but on pressing the ON button from my box the relay is activated is deactivated after 2 sec.
    Thank you for your help.
  • I'm trying to wrap my head around the button example and don't understand what the loop() really does. To me it only alters the "state" but how does it affect the relay?
    Is the button physically connected to the relay or should the controller send the new state back and let the receive() function handle the actual relay switching?
    Also, after presentation, shouldn't there be a send() to the controller?
    @Efflon you are right about the loop() function it seems like the part where it should change the relay state is missing. Did you try to use this example code?
    The button should be wired between PIN 3 and GND so that when you push the button PIN 3 is Grounded.
    PIN 3 is connected to a "Debouncer" in the "setup()" ( so that when you push the button the code detects only one push and not several ).
    loop() monitors the debouncer and when it detects that you have pushed the button it will send the new state to the controller. I think it should also change the state so if it does not do that you could add the following line
    digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF); //write new state to relay output
    Before this line in the loop() function:
    send(msg.set(state?false:true), true); // Send new state and request ack back
    You could also add the line:
    saveState(CHILD_ID, state); // Store state in eeprom
    To the same part of the code so that the state change is written to eeprom so that the previous state can be returned after a power failure.
  • @korttoma
    Thanks for the explanation! Just as I suspected with missing relay code.
    The loop in the relay with button actuator sketch does three main things
    checks for a new button push
    changes the current state
    Sends the new state to the controller
    If you look at the message code you can see it also asks for an ACK back from the controller. That is the true at the end of the line.
    It is this returned ACK that is used to switch the relay to the new state in the void receive function
    The one drawback in this code if it is used for say a light switch is that if this node looses contact with the controller then the relay cannot be changed by pressing the button.
  • @Boots33 Ok, you explanation is what was my only explanation to the "missing" code. When experimenting with this using the mqtt gateway sketch and home-assistant as controller, the ACK is just an ACK and not a "real" message with payload thus just toggling the state bool and getting things out of sync..
  • I did not get the example working properly with my 8 channel SSR. So here is my updated version of the example.
    I have changed the way the pins are assigned by using a array. The current example tries to connect relays 7 and 8 to pins 9 and 10 when you select an 8 channel relays. This won't work because those pins are used by the radio module.
    I think you can connect a relays to any pin which is not used. If so this will make it possible to connect up to 14 relays to the mini pro when also the pins A5-A7 are available.
    const int PINS[] = {3, 4, 5, 6, 7, 8, 14, 15}; // I/O pins 3, 4, 5, 6, 7, 8, A0, A1 for the relays
    #define NUMBER_OF_RELAYS 8 // Total number of attached relays
    void before()
        for (int sensor=1; sensor<=NUMBER_OF_RELAYS; sensor++) {
            pinMode(PINS[sensor-1], OUTPUT);
            digitalWrite(PINS[sensor-1], loadState(sensor)?RELAY_ON:RELAY_OFF);
        sendSketchInfo("Relay", "1.0");
            present(sensor, S_BINARY);
        if (message.type==V_STATUS) {
            // Change relay state
            digitalWrite(PINS[message.sensor-1], message.getBool()?RELAY_ON:RELAY_OFF);
    I'm attempting to get my double relay board containing two switch inputs. I see that the two sketches suggested on the relay page are there but one seems to be updated to the new version which allows you to use multiple relays on the board but the other isn't, as far as i can see. How do I go about making the sketch with buttons accept more relays?
  • Hi @Woeka
    I've been testing your code, but works inverse mode
    if switch in domoticz is on the relay is off and vice versa
    @ijobain Try changing
    To
    and see if that works as you expected
    @Samuel235 Have a look at this thread for some ideas.
  • @Boots33
    Thank you so much
    I am newbie
    @Boots33 - Thanks dude, I have had a quick skim read just but will bookmark it when i get my gateway working. These issues right now are driving me insane, and spending the day to try and find the problem. Thank you for linking me to that post!
  • I just tried this sketch, works on latest version, but i cant seen any relais in Domoticz, only see the node relais, did i miss something
    Hi to all!
    I would edit the secure relay sketch so in loop the node sends to the gateway, let's say every hours, his state (on or off).
    1. I avoid delay otherwise Arduino cannot receive the comands from gateway, so I will use the millis sketch, modified from the official Arduino website.
    My doubt is... How can I get the current state of the relay?
    Relevant part of sketch is in loop and before setup()
    /* TIME variables */
    unsigned long previousMillis = 0;        // will store last time state is sent
    // constants won't change:
    const long interval = 10000;           // interval at which to send state (milliseconds === seconds x 1000). For test we try every 10 seconds
    And the main loop
      // check to see if it's time to send state; that is, if the difference
      // between the current time and last time you sent state is bigger than
      // the interval at which you want to send the state.
      if (currentMillis - previousMillis >= interval) {
        // save the last time you blinked the LED
        // send the state here!
        // test
        Serial.println("This is the moment where I need to send state");
        //send(?????????); // Send current state. Probabily will update also the log?
    The base sketch is >>> https://github.com/mysensors/MySensors/blob/master/examples/SecureActuator/SecureActuator.ino
    And the millis example is >>> https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
    Thank you to all!
    @sineverba
    Edit:
    I did edit the pre-setup configuration
    int val = 0;  // the value of digital pin
    And I did edit the loop:
        // test
        val = digitalRead(LOCK_1);
        Serial.print("Il valore del relay è ");
        Serial.println(val);
        send(msg.set(val),true); // Send new state and request ack back.
    I got the update in Domoticz in Hardware > Configuration > Children of nodes
    And I did test also every 3 seconds, all ok.
    But I don't have the refresh in "main page":
    I did test removing current to Arduino when Relay was ON. With Arduino off, I did change the state in domoticz to OFF.
    Because Arduino save previous state in EEPROM, after full start the relay did go ON, in Domoticz got "1" in children (all right, because digitalRead was 1) but main panel shows OFF.
    I did expect a graphical change...
    Thank you (and hope that all is clear) 🙂
    Hi to all!
    To achieve my goal (node that sends relay state after power failure to sync with domoticz), I'm editing the button script.
    I have added this line
    state = digitalRead(RELAY_PIN);
    in setup, so I thought it send only one time at startup the current state after power failure.
    But..... the relay shutdown/shuton (or viceversa) twice, in fast sequence....
    Thank you very much!
    @sineverba
    Bingo!
    If I did understand well, the actuator sketch DOESN'T directly acts the relay, but sends to the gateway and expect from the gw itself the "new state" (in effect, you short GND & PIN 4, arduino sends new state to the gateway and gateway resend the new state).
    So, 'cause I would to update the state on controller, I did this simple edit on setup:
     state = loadState(CHILD_ID);
     Serial.print("Lo stato ultimo era ");
     Serial.println(state);
     if ( state == 1) {
       state = 0;
       state = 1;
    Basically, If relay was OFF on a power failure, and someone on Domoticz try to start the relay, the state in Domoticz will be "on".
    When power returns, the arduino read the state (in my example OFF == 0), convert in 1 and send to the gateway the 1. The gateway // Domoticz will be answer with 0.
    So, relay doesn't nothing and Domoticz state is update.
    But.... why I need to invert the logic? 😄
    @sineverba said in 💬 Relay:
    Have a look at the sketch I used for my Synchronising Light switch you may be able to use some of that code perhaps.
    @Boots33
    Never seen the request function.
    You are hero-member for a reason...
    Thank you very much! 🙂 🙂
    You can find request and other useful info on the API page.
    Hope you are enjoying your MySensors journey 🙂
    since the relay has leds and is therefore power consuming, i was wondering if someone has written a sketch for a low power usage of the relay (as for the sensors) allowing the arduino (and the relay) to sleep all the time and wake up every 5 minutes for instance just to check if the controller has changed the desired state of the switch.
    Of course then the relay could be as late as 5minute, but this is not an issue for my application ...
    thanks for any suggestion
    @fhenryco can't the relay node use power from whatever it is controlling?
    For sleeping nodes, the smartsleep feature can be useful. Search for that keyword in the forum and look at https://www.mysensors.org/download/sensor_api_20#sleeping
  • thanks , indeed it's because the relay is controlling a 12V battery power to solenoid valve , that low power consumption is needed. BTW the 12V is obtained from a 4S lipo (16.5V max voltage) and a 12 regulator and i dont know if its better to feed the arduino from a 5V regulator fed by the same Lipo , or use an additional set of AA batteries ... i remember that it's better to have an as low as possible drop in voltage to save power...
    @fhenryco If you are trying to keep your power use down then you could also consider using either a Latching Relay or even a MOSFET.
  • @mfalkvidd smartsleep was not supported by domoticz at the begining of the year ... but there was a domoticz upgrade in july ... do you know if it's now supported ?
    @Boots33 said in 💬 Relay:
    Agreed, if you want to save power you need to use a latching relay. Also another regulator would be fine to power the arduino.
  • @gohan can you explain the benefit (for a low power app) of a relay switching on electrical pulse rather something else ?
    i mean, even the regular relay has both an open by default circuit output and close by default circuit ouput so it could remain on the desired state even when not powered up ...
    I am referring that when relay is on it is drawing power to stay on, while a latching relay it only draws power during the switch on and only during the switch off.
  • @gohan not sure this is going to be an easy way: need find arduino code for latch relay, dont know if domoticz is supporting this device ?, ...
    Domoticz will just see the same relay node, it is the code that need to be a little different as the relay is switched with a pulse and you need a pin to verify the relay status (if you get the ones that have a monitoring contact)
  • Hi Everyone,
    maybe the below will help people facing random incorrect behaviors.
    In sample from december 2016 /mysensors/MySensors/examples/RelayActuator/RelayActuator.ino, there is something which could be seen as a bug.
    In my case, I have used that sample to control a lot of relais. I noticed some rare but really annoying errors. From time to time a relay got switched incorrectly.
    Annoying and strange as coding was pretty straightforward. All relais are coded to act in pulse mode.
              digitalWrite(message.sensor-1+RELAY_1, RELAY_OFF);
              wait(1000);
              digitalWrite(message.sensor-1+RELAY_1, RELAY_ON);
    And this is the reason of the bug.
    Explanation.
    During that second of wait, a lot of things may occurs. Due to the 'message' declaration, it is possible that the 'message' is getting changed.
    Typically a ping may come and as result the 'message' is not anymore the same.
    For that reason I would suggest the code to be changed a little bit.
    void receive(const MyMessage &message_orig)
      MyMessage message;
      message = message_orig;
    This way, the function works with a local copy and you are sure nothing can change during the processing.
    Anyway, thanks for the sample it was nevertheless very helpful
    @amemo06
    Because of the const keyword this is a const reference or said another way, a reference to a constant. The const keyword guarantees that the function may not change the object.
    So, I wonder what your real issue is....
  • @BulldogLowell No This is not the coding of the function which changes it. It is most likely the event which triggers it which may changes it.
    I can show the coding with trace and trace result.
    //void receive(const MyMessage &message_orig)
    //  MyMessage message;
    //  message = message_orig;
      Serial.println("receive_in:");
    Serial.print("1st read:Sensor=");Serial.print(message.sensor);Serial.print(", getBool=");Serial.println(message.getBool());
        if (message.getBool() == RELAY_ON){
    Serial.print("2nd read:Sensor=");Serial.print(message.sensor);Serial.print(", getBool=");Serial.println(message.getBool());
          wait(1000);
    Serial.print("3rd read:Sensor=");Serial.print(message.sensor);Serial.print(", getBool=");Serial.println(message.getBool());
    Serial.println("receive_out:");
    Below is a normal trace
    0;255;3;0;9;Eth: 0;0;3;0;18;PING
    0;255;3;0;9;Eth: 0;1;1;0;2;1
    receive_in:
    1st read:Sensor=1, getBool=1
    2nd read:Sensor=1, getBool=1
    3rd read:Sensor=1, getBool=1
    receive_out
    So you see the ping which occured before the message I'm interested in
    Now, because of the wait in the middle of the code, it may occurs the ping arrive in that period. Then the issue occurs.
    See the trace with error.
    receive_in:
    3rd read:Sensor=0, getBool=0
    receive_out
    In the 3rd read, sensor value has changed and getBool returns also a different value.
    Removing the wait or ensuring the function modules performs faster could reduce the risk. Still it will never be reliable.
    Better is to have either a local copy of the message like I wrote in the original post. Or make immediately copies of the information from the message I'm interested in.
    @amemo06 said in 💬 Relay:
    wait(1000);
    where did you find that? I wasn't able to find it
  • @gohan This is not in the original coding. I needed something like a wait in order to make a relay pulse.
    The wait increases the risk or the frequency of the trouble. Removing it does not solves the issue.
    Processing of the function will always take time. And the message can still changes before reaching the end like it is show in the second trace.
    @amemo06
    You should treat the message like an ISR... get in and out so that you don't have another message colliding while you are in the function.
    Get rid of that wait(). I couldn't find the source for that function but you could try to just use delay() to block while you hold the relay.
    otherwise just set a flag to handle the relay event in loop() or use a Timer/callback like the MsTimer2 Library
    example:
    #include <MsTimer2.h>
    const byte onButton = 5;
      Serial.begin(9600);
      pinMode(13, OUTPUT);
      pinMode(onButton, INPUT_PULLUP);
      if(onButtonPressed())
       flashLedThirteen(5000);
    bool onButtonPressed(void)
      static unsigned long lastMillis = 0;
      static byte lastPress = HIGH;
      byte currentPress = digitalRead(onButton);
      if(currentPress != lastPress)
        if(millis() - lastMillis < 200) return false;
        lastPress = currentPress;
        if(currentPress == LOW)
          Serial.println(" button press detected!");
          lastMillis = millis();
          return true;
      return false;
    void flashLedThirteen(int ledTime)
      digitalWrite(13, HIGH);
      Serial.println("LED ON");
      // sets a new timer callback function
      MsTimer2::set(ledTime, [] {  // the square brackets define the start of the anonymous callback function which is executed after 5000 milliseconds in this example
        digitalWrite(13, LOW);
        Serial.println("Timer expired...");
        Serial.println("LED OFF");
        MsTimer2::stop();
      }); // the curly brace defines the end of the anonymous callback function
      MsTimer2::start();
  • @BulldogLowell said in 💬 Relay:
    MsTimer2::
    Thanks for the MSTimer, I was not aware of it.
    And yes, definitively, having a wait() is probably the worst I could have written. Active wait cannot stay.
    My intention, in the stuff I develop, was to remove it asap and probably by handling the wait time in the loop with flags.
    Maybe I was not clear enough about my intention when I opened this thread. I have no issue with what I develop. I already had several ways to solves this. And now, I have a new one with MSTimer. Again thanks.
    I only wanted to raise the fact void receive(const MyMessage &message) may lead to trouble as 'message' content may change during processing of that function.
    And if, like many, you are not skilled enough to code/debug.., you will face erratic issues and real difficulty to understand what is going wrong.
    @amemo06
    As I already explained... message cannot change during the function, because of constness.
    The message handler is being called again from within itself (i.e. from wait()). You would then processing any new messages on that call. It looks as if the function may not be designed to perform recursively as you are trying to do in your code, so that would explain your unexpected/undefined results.
    So yes, block during the relay's holding state or use another non-blocking method (i.e. flag or timer/callback) as you mentioned. Fully process each message before allowing the library to handle subsequent message calls.
  • I was looking for a solution for a low consumption relay and i was adviced in this thread to use a latching relay.
    However since i just need to switch on or off a 12V Vcc (from Li ion battery) to trigger a solenoid valve, i'm wondering whether i need a relay for that :
    looking at the schematic from post #2 in https://forum.arduino.cc/index.php?topic=436555.0 may be i coud just have my solenoid valve directly in place of the relay in the schematic. In other words , i just need a transistor and not a real relay ... just because my application is a low voltage (12V to apply directly to the Vcc in the schematic) rather than 230V one: can someone confirm ? There is a diode in the schematic : what is it needed for ?
    @fhenryco
    Since an inductor (im many cases a relay coil) cannot change it's current instantly, the flyback diode provides a path for the current when the coil is switched off. Otherwise, a voltage spike will occur causing arcing on switch contacts or possibly destroying switching transistors.
    https://electronics.stackexchange.com/questions/100134/why-is-there-a-diode-connected-in-parallel-to-a-relay-coil
  • treat yor solenoid as it was a relay, the difference is that relay switches flow of current, and solenoid valve switches flow of water. so You have to use the same schematic, but put your valve where the relay is. But if You want power it from a battery, choose a latching solenoid valve instead of regular solenoid valve - and that requeires different schematic.
  • @rozpruwacz
    thanks, but do you mean that the schematic simply would not work for the regular valve or that it would work but not be low power cinsumption design anymore ?
    I have a regular solenoid valve but in my application the valve is normally closed and it will be only exceptionnally opened and for a short time when the 12V is applied, so i guess that i can live with it ...
    As for the transistor in the schematic, except it seems to be a NPN , i don't know if i need a particular one for it . probably i can just buy a 2N3904 , or is there a better choice?
  • the schematic you posted is not using latching relay/valve. it doesn't matter if it is relay or valve. both works the same and consume power when in ON state. If you plan to use it in a way that the valve will be ON for very short periods than it is not important if it is latching or not.
    when choosing a transistor for such use, You have to look at its datasheet into "absolute maximum ratings" section and check if it will handle the voltages you will apply to it. 2N3904 looks like it will handle 12V without a problem.
  • @rozpruwacz
    thanks , i will use 2N2222 because the valve needs between 200 and 400 mA.
    I'v read the 2N3904 is OK for < 100 mA
  • It works very well with the transistor and schematic posted above. I think the valve is a latching valve because it only discharges the battery when there is a transition. The only remaining problem is that the 5V arduino alone is too much power consuming. So i'm wondering if the transistor could as well work with a 3.3V arduino, that is when the signal level on the transistor Base is 3.3V rather than 5 V ... then i also could remove the arduino led but i'll need to keep the arduino regulator because my 3.7V cell voltage is too much greater than 3.3V
  • @fhenryco Actually the internal resistor of the solenoid is 27 Ohm while the resistance between C and E of the transistor in the passing state is 35 Ohm ... so it remains less than Vcc/2 for my solenoid which needs 12V ... so i need to tune my boost module at the max ==> more than 30V ... that does not seem ideal, may be i shoud choose another transistor with less internal resistor, but i have little experience with transistors : studied them a long time ago , so if someone can suggest something smart, ready to buy it ...
  • Can I suggest a change to this page?
    As it stands the wiring diagram only applies to sketch 1 (without switch). It could get confusing as the 2 sketches use different pins for the relay and there is no need for this.
    I propose that the wiring diagram be changed for the relay to be attached to pin 4.
    The first sketch needs the relay pin to change from pin 3 to pin 4.
    That's it. Then the diagram and sketches will work whichever way the builder wants to do it.
    Good idea @skywatch
    When doing the update, we should also rename RELAY_1 to RELAY_PIN to be consistent with sketch 2.
    https://www.mysensors.org/build/relay has been updated with new wiring instructions (picture + table)
  • That looks good, only the sketchs to go....On that note I wonder if Relay_1 might not be better choice as it gives a clue to people that if they want to add a second relay then that would be Relay_2.... Just a thought and maybe not needed.... 😉
  • @mfalkvidd when updating the example sketch you could maybe consider my version of the relay sketch which offers some nice additions: https://forum.mysensors.org/topic/6638/multiple-relays-motion-sketch-fully-customizable-optional-timer-manual-override
    @HenryWhite my mind is divided when it comes to that type of sketch. Yes, it has a lot of functionality. Yes, it is probably what people need anyway. But the examples are meant to be used by someone who is just getting into diy home automation. Someone new should be able to understand as much of the sketch as possible. There should be as little as possible to trubleshoot. If the sketch is complex, most people's initial reaction will be that there is something wrong with the code, when in reality almost all newbie problems are power or wiring-related. Keeping the sketch simple helps, at lest a bit.
  • @mfalkvidd You are right but may be should there be for each sensor or actuator first the most basic sketch but also at the end of the page a complete version with all functionalities and granted to work by the mysensors team.
    Of course for the complicated sketch version a big warning in red letters that this is not recommended for newbies would help...
  • After testing some functionalities of nodemanager, i was wondering if already somebody was working on making a GUI for nodemanager which would allow to build one's sketch completely from a graphical interface (at least the most common and basic functionalities) : i thing the great work that resulted in Nodemanager has so well structured the various functions needed that it has already paved the way for creating such a graphical interface.
    There was a user some time ago that was trying to make a web GUI
  • I would agree that more advanced sketches 'should' be included on the same page. Keep all the info in one resource place. Provided it is clearly marked as an advanced project it might help people looking for similar functionality or just interested in learning more about programming....
  • wow! fantastic! ... the github link readme warns that it's not yet fully ready but the interface is already impressive!
    I still have the same question i had for nodemanager though : for measuring another battery than the one that feeds Vcc obviously another pin is needed, however why not propose as well the option of measuring such pin voltage but with Vcc as the reference rather than the internal 1.1V which most of the time makes necessary a voltage divider ? Actually i did the modification in nodemanager.cpp to use DEFAULT (~3.3V) rather than INTERNAL (1.1V) reference for a 3.3 pro mini and i can get the expected battery level without any voltage divider.
    Another unrelated question i have is : could there be any way to adapt the idea of the readVcc method (which is to measure the internal 1.1V against the Vcc reference to get Vcc) but using any voltage applied to a pin as the reference to again measure the internal 1.1 against it ? This would allow the masurement of any voltage greater than 1.1 without voltage divider while the usual method would be applied for measuring any voltage lower than 1.1 ... what did i miss that makes this impossible ?
    We need to use the internal reference since it is the only stable voltage source and you need the voltage divider to lower the measured voltage between 0 and 1.1v. There are not many options to choose from
  • i also just realized that there is a special AREF pin intended for what i was thinking about ... but it's not available on the mini pro.
    My measurements using Vcc as Ref have been indeed very fluctuating, however what i get was highly sufficient to monitor the battery feeding a 3.3v step up regulator to the arduino and help anticipate failure
  • I just noticed another thing that should be changed in the 'relay with button' sketch....
    S_LIGHT should be S_BINARY
    V_LIGHT shoud be V_STATUS
  • I would like to clarify operation of the sketch, where more than 1 sensors input are used along with more than 1 relay actuator. in one node
    1. Does node need unique child ID for each sensor input AND relay output?
    2. If that is the case how child ID is assigned to relay actuators in the above examples?
  • This is a nice sketch and it is very universal for relays. Now m looking for a similar sketch for digital inputs such as buttons i.e.. I would like to join both. The problem: I want to use a mega for reading status of a lot of digital outputs (min.20) of another ISP. It is only High or Low. Only when the level changes, I want the mega send a message to the gateway. I tried this "for" loop, but it didnt help. There are too many informations sent to the gateway. I imagine a solution, where only a change at the pin will create an information, that is sent to the gateway.
    Here my test, which didnt run:
    for (int sensor=16, pin=BIN_1; sensor<=NUMBER_OF_BIN; sensor++, pin++)
    int BUTT;
    int BUTTOLD;
    BUTT =digitalRead(pin);
    if (BUTT != BUTTOLD && BUTT !=0){
    MyMessage msg(sensor, V_TRIPPED);
    send(msg.set(BUTT ? "1" : "0"));
    BUTTOLD = BUTT;
    wait (900);
    Has anybody an idea or a hint for me?
    I believe there is a logic error in the sketch as you would need to declare global variables BUTTOLD_XX unique for each button, otherwise how can you keep track of the variable between each loop and FOR iteraction?
  • Thank You for Your quick answer.
    Do I understand You correctly: I must index the BUTTOLD?
    As BUTTOLD[pin) for example or how? Where?
    You need to create the single variables one by one, unless somebody else has a better way to do it
  • why i can't compile for arduino pro mini on other boards i can upload
    @mitja-blazinsek the error messages are usually essential to figuring out. Did you get any?
  • Arduino: 1.8.1 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega168 (5V, 16 MHz)"
    In file included from c:\users\mitja\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\avr\io.h:99:0,
                 from c:\users\mitja\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\avr\pgmspace.h:90,
                 from C:\Users\mitja\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino/Arduino.h:28,
                 from sketch\button_relay.ino.cpp:1:
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp: In function 'bool hwUniqueID(uint8_t (*)[16])':
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:246:26: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID) = boot_signature_byte_get(0x00);
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:247:30: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID + 1) = boot_signature_byte_get(0x02);
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:248:30: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID + 2) = boot_signature_byte_get(0x04);
    C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:249:30: error: 'SIGRD' was not declared in this scope
    ((uint8_t)uniqueID + 3) = boot_signature_byte_get(0x01); //OSCCAL
    Multiple libraries were found for "Bounce2.h"
    Used: C:\Users\mitja\Documents\Arduino\libraries\Bounce2
    Not used: C:\Users\mitja\Documents\Arduino\libraries\Bounce2-master
    exit status 1
    Error compiling for board Arduino Pro or Pro Mini.
  • OK it's probaly because ia have mini with 168 chip i have to buys 328 😞 again wait 1month to arive from china
  • hello.
    I am building a node with several kind of sensors and two relays.
    My sensors use CHILD ID from 0 to 3. I would like to start child ID of relay from 4.
    How I can't do that with this sketch?
    I guess I have to change this part of sketch :
    "for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
    present(sensor, S_BINARY);"
    correct?
    thanks
  • @lekeb
    You may do something like this:
    In Header:
    uint8_t DS_First_Child_ID = 7; //First Child-ID to be used by Dallas Bus
    an then in presentation():
    for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
        present(i + DS_First_Child_ID, S_TEMP);
    But afaik, it's not recommended to shift the ChildID's for relays but always start with 1. Imo it's better to change the ChildID's of the other attached sensors. You may also take care (in case of shifting ID's) about a consistent mapping from ID to the PINs where the relays are attached.
    Agreed, set you sensors to higher ID numbers like 20 or 30 and you are good to go .
  • ok thanks a lot I will try this night
  • perfect it works great. I started my temperature sensor at CHILD ID 4 and let relays from 1 to 2. I had to add also "DS_First_Child_ID" in the sent message to gateway.
    thanks
  • Hi
    Please put to this topic code your sketch....
  • 110
  • 347
